Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3)
Part No. B14164-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
OracleRowUpdatingEventArgs Class
The OracleRowUpdatingEventArgs class provides event data for the OracleDataAdapter.RowUpdating event.
Class Inheritance
Object
  EventArgs
Declaration
// C#
public sealed class OracleRowUpdatingEventArgs : RowUpdatingEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatingEventArgs. See "Example".
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
OracleRowUpdatingEventArgs Members
OracleRowUpdatingEventArgs members are listed in the following tables:
OracleRowUpdatingEventArgs Constructors
OracleRowUpdatingEventArgs constructors are listed in Table 4-93.
Table 4-93 OracleRowUpdatingEventArgs Constructors
Constructor Description
OracleRowUpdatingEventArgs Constructor Instantiates a new instance of OracleRowUpdatingEventArgs class (Overloaded)
OracleRowUpdatingEventArgs Static Methods
The OracleRowUpdatingEventArgs static methods are listed in Table 4-94.
Table 4-94 OracleRowUpdatingEventArgs Static Methods
Methods Description
Equals Inherited from Object (Overloaded)
OracleRowUpdatingEventArgs Properties
The OracleRowUpdatingEventArgs properties are listed in Table 4-95.
Table 4-95 OracleRowUpdatingEventArgs Properties
Name Description
Command
Specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called
Errors Inherited from RowUpdatingEventArgs
Row Inherited from RowUpdatingEventArgs
StatementType Inherited from RowUpdatingEventArgs
Status Inherited from RowUpdatingEventArgs
TableMapping Inherited from RowUpdatingEventArgs
OracleRowUpdatingEventArgs Public Methods
The OracleRowUpdatingEventArgs public methods are listed in Table 4-96.
Table 4-96 OracleRowUpdatingEventArgs Public Methods
Name Description
GetHashCode Inherited from Object
GetType Inherited from Object
ToString Inherited from Object
The OracleRowUpdatingEventArgs constructor creates a new instance of the OracleRowUpdatingEventArgs class using the supplied data row, IDbCommand, type of SQL statement, and table mapping.
Declaration
// C#
public OracleRowUpdatingEventArgs(DataRow row, IDbCommand command,
    StatementType statementType, DataTableMapping tableMapping);
Parameters
The OracleRowUpdatingEventArgs static methods are listed in Table 4-97.
Table 4-97 OracleRowUpdatingEventArgs Static Methods
Methods Description
The OracleRowUpdatingEventArgs properties are listed in Table 4-98.
Table 4-98 OracleRowUpdatingEventArgs Properties
Name Description
Command
Command
This property specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get; set;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatingEventArgs public methods are listed in Table 4-99.
Table 4-99 OracleRowUpdatingEventArgs Public Methods
Name Description
