Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3) Part No. B14164-01 |
An OracleXmlQueryProperties object represents the XML properties used by the OracleCommand class when the XmlCommandType property is Query.
Class Inheritance
Object
Declaration
public sealed class OracleXmlQueryProperties : ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
OracleXmlQueryProperties can be accessed, and modified using the XmlQueryProperties property of the OracleCommand class. Each OracleCommand object has its own instance of the OracleXmlQueryProperties class in the XmlQueryProperties property.
Use the default constructor to get a new instance of the OracleXmlQueryProperties. Use the OracleXmlQueryProperties.Clone() method to get a copy of an OracleXmlQueryProperties instance.
Example
This example retrieves relational data as XML.
// C#
using System;
using Oracle.DataAccess.Client;
class OracleXmlSavePropertiesSample
static void Main()
string[] KeyColumnsList = null;
string[] UpdateColumnsList = null;
int rows = 0;
// Create the connection.
string constr = "User Id=hr;Password=hr;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
// Create the command.
OracleCommand cmd = new OracleCommand("", con);
// Set the XML command type to insert.
cmd.XmlCommandType = OracleXmlCommandType.Insert;
// Set the XML document.
cmd.CommandText = "<?xml version=\"1.0\"?>\n" +
"<ROWSET>\n" +
" <MYROW num = \"1\">\n" +
" <EMPLOYEE_ID>1234</EMPLOYEE_ID>\n" +
" <LAST_NAME>Smith</LAST_NAME>\n" +
" <EMAIL>Smith@Oracle.com</EMAIL>\n" +
" <HIRE_DATE>1982-01-23T00:00:00.000</HIRE_DATE>\n" +
" <JOB_ID>IT_PROG</JOB_ID>\n" +
" </MYROW>\n" +
" <MYROW num = \"2\">\n" +
" <EMPLOYEE_ID>1235</EMPLOYEE_ID>\n" +
" <LAST_NAME>Barney</LAST_NAME>\n" +
" <EMAIL>Barney@Oracle.com</EMAIL>\n" +
" </MYROW>\n" +
"</ROWSET>\n";
// Set the XML save properties.
KeyColumnsList = new string[1];
KeyColumnsList[0] = "EMPLOYEE_ID";
UpdateColumnsList = new string[5];
UpdateColumnsList[0] = "EMPLOYEE_ID";
UpdateColumnsList[1] = "LAST_NAME";
UpdateColumnsList[2] = "EMAIL";
UpdateColumnsList[3] = "HIRE_DATE";
UpdateColumnsList[4] = "JOB_ID";
cmd.XmlSaveProperties.KeyColumnsList = KeyColumnsList;
cmd.XmlSaveProperties.RowTag = "MYROW";
cmd.XmlSaveProperties.Table = "employees";
cmd.XmlSaveProperties.UpdateColumnsList = UpdateColumnsList;
cmd.XmlSaveProperties.Xslt = null;
cmd.XmlSaveProperties.XsltParams = null;
// Do the inserts.
rows = cmd.ExecuteNonQuery();
Console.WriteLine("rows: " + rows);
// Set the XML command type to update.
cmd.XmlCommandType = OracleXmlCommandType.Update;
"<ROWSET>\n" +
" <LAST_NAME>Adams</LAST_NAME>\n" +
" </MYROW>\n" +
"</ROWSET>\n";
UpdateColumnsList = new string[1];
UpdateColumnsList[0] = "LAST_NAME";
// Set the XML command type to delete.
cmd.XmlCommandType = OracleXmlCommandType.Delete;
"<ROWSET>\n" +
" </MYROW>\n" +
" </MYROW>\n" +
"</ROWSET>\n";
cmd.XmlSaveProperties.UpdateColumnsList = null;
// Do the deletes.
// Clean up.
cmd.Dispose();
con.Close();
con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
OracleXmlQueryProperties members are listed in the following tables:
OracleXmlQueryProperties Constructors
The OracleXmlQueryProperties constructors are listed in Table 5-2.
Table 5-2 OracleXmlQueryProperties Constructors
| Constructor | Description |
| OracleXmlQueryProperties Constructor | Instantiates a new instance of the OracleXmlQueryProperties class
OracleXmlQueryProperties Properties
The OracleXmlQueryProperties properties are listed in Table 5-3.
Table 5-3 OracleXmlQueryProperties Properties
| Name | Description |
| MaxRows | Specifies the maximum number of rows from the result set of the query that can be represented in the result XML document |
| RootTag | Specifies the root element of the result XML document |
| RowTag | Specifies the value of the XML element which identifies a row of data from the result set in an XML document |
| Xslt | Specifies the XSL document used for XML transformation using XSLT |
| XsltParams | Specifies parameters for the XSL document |
OracleXmlQueryProperties Public Methods
The OracleXmlQueryProperties public methods are listed in Table 5-4.
Table 5-4 OracleXmlQueryProperties Public Methods
| Clone | Creates a copy of an OracleXmlQueryProperties object
The OracleXmlQueryProperties constructor instantiates a new instance of the OracleXmlQueryProperties class.
Declaration
// C# public OracleXmlQueryProperties();
The OracleXmlQueryProperties properties are listed in Table 5-5.
Table 5-5 OracleXmlQueryProperties Properties
This property specifies the maximum number of rows from the result set of the query that can be represented in the result XML document.
Declaration
// C#
public int MaxRows {get; set;}
Property Value
The maximum number of rows.
Exceptions
ArgumentException - The new value for MaxRows is not valid.
Remarks
Default value is -1.
Possible values are:
-1 (all rows).
A number greater than or equal to 0.
This property specifies the root element of the result XML document.
Declaration
// C#
public string RootTag {get; set;}
Property Value
The root element of the result XML document.
Remarks
The default root tag is ROWSET.
To indicate that no root tag is be used in the result XML document, set this property to null or "" or String.Empty.
If both RootTag and RowTag are set to null, an XML document is returned only if the result set returns one row and one column.
This property specifies the value of the XML element which identifies a row of data from the result set in an XML document.
Declaration
// C#
public string RowTag {get; set;}
Property Value
The value of the XML element.
Remarks
The default is ROW.
To indicate that no row tag is be used in the result XML document, set this property to null or "" or String.Empty.
This property specifies the XSL document used for XML transformation using XSLT.
Declaration
// C#
public string Xslt {get; set;}
Property Value
The XSL document used for XML transformation.
Remarks
Default value is null.
The XSL document is used for XML transformation of the XML document generated from the result set of the query.
This property specifies parameters for the XSL document.
Declaration
// C#
public string XsltParams {get; set;}
Property Value
The parameters for the XSL document.
Remarks
The parameters are specified as a string of "name=value" pairs of the form "param1=value1; param2=value2; …" delimited by semicolons.
The OracleXmlQueryProperties public methods are listed in Table 5-6.
Table 5-6 OracleXmlQueryProperties Public Methods
This method creates a copy of an OracleXmlQueryProperties object.
Declaration
// C# public object Clone();
Return Value
Implements
ICloneable
