Oracle® Database Installation Guide
10g Release 1 (10.1.0.3) for Linux x86-64 Part No. B14399-01 |
![]() Previous |
![]() Next |
This chapter describes the different types of Oracle Database installations that you can perform, and issues that you should consider before installing the software. It includes information about the following topics:
The Oracle Database installation process consists of four parts:
Planning your installation: This chapter describes the Oracle products that you can install and issues that you must consider before starting the installation.
Completing pre-installation tasks: Chapter 2 describes pre-installation tasks that you must complete before installing the product.
Installing software: Chapter 3 describes how to use the Oracle Universal Installer to install this product.
Completing post-installation tasks: Chapter 4 describes recommended and required post-installation tasks.
You can choose different installation methods to install Oracle Database, as follows:
When you use the interactive method to install Oracle Database, the Installer displays a series of screens that enable you to specify all of the required information to install the Oracle Databasesoftware and optionally create a database.
With Oracle Database 10g release 10.1.0.3 on Linux x86-64, the Installer provides two interactive methods that you can use to install Oracle Database:
Basic Installation method
Select this installation method if you want to quickly install Oracle Database. This installation method requires minimal user input. It installs the software and optionally creates a general-purpose database using the information that you specify on one screen. It is the default installation method.
Advanced Installation method
Select this installation method if you want to complete any of the following tasks:
Perform a custom software installation, or choose a different database configuration
Install Oracle Real Application Clusters
Upgrade an existing database
Select a database character set or different product languages
Create the EXAMPLE tablespace during the installation
Create a database on a different file system from the software
Configure Automatic Storage Management (ASM) or use raw devices for database storage
Specify different passwords for administrative schemas
Configure automated backups or Oracle Enterprise Manager notifications
Note: To choose the Custom installation type or Advanced database configuration options mentioned in this guide, you must choose the Advanced Installation method. |
With release 10.1.0.2 on all platforms or release 10.1.0.3 on platforms other than Linux x86-64, the Basic Installation method is not available. The Advanced Installation method is used by default.
By creating a response file and specifying this file when you start the Installer, you can automate some or all of the Oracle Databaseinstallation. These automated installation methods are useful if you need to perform multiple installations on similarly configured systems or if the system where you want to install the software does not have X Window system software installed.
When you use a response file, you can run the Installer in the following modes, depending on whether you specify all of the required information or not:
Silent Mode: The Installer runs in silent mode if you use a response file that specifies all required information. None of the Installer screens are displayed.
Suppressed Mode: The Installer runs in suppressed mode if you do not specify all required information in the response file. The Installer displays only the screens that prompt for the information that you did not specify.
For more detailed information about these modes and about how to complete an installation using response files, see Appendix B.
Note: Oracle Client is installed separately. You cannot install Oracle Client during an Oracle Database installation. |
You can choose one of the following installation types when installing Oracle Database:
Standard Edition: Installs an integrated set of management tools, full distribution, replication, Web features, and facilities for building business-critical applications.
Enterprise Edition: Installs licensable Oracle Database options and database configuration and management tools in addition to all of the products that are installed during a Standard Edition installation. It also installs products most commonly used for data warehousing and transaction processing.
Custom: Enables you to select the individual components that you want to install from the list of all available components.
During the installation, you can choose whether you want to create an Oracle database as part of the installation. If you choose to create an Oracle database, the Installer uses the Database Configuration Assistant (DBCA) to create it. You can choose to create one of the preconfigured database types, which are designed for a variety of different applications, modify one of the preconfigured database types, or create a customized database to suit your own requirements.
Preconfigured Database Types
Oracle provides the following preconfigured database types that you can create or customize during the installation:
General Purpose
Transaction Processing
Data Warehouse
See the online help provided by either the Installer or the DBCA for a description of these preconfigured database types.
Installation Choices that Affect Database Creation
The Installer runs DBCA in one of two modes, depending on the choices that you make during the installation:
Non-interactive mode
If you choose either the Enterprise Edition or Standard Edition installation type, then choose to create a preconfigured database type, the Installer prompts you for the minimum amount of information required to create a database of the type you choose. It then runs DBCA in non-interactive mode to create the database after it installs the software.
Note: Oracle recommends that you use this method to create a database if you have not previously created one. |
Interactive mode
If you choose the Custom installation type or choose the Advanced database configuration option, the Installer does not prompt you for database information. Instead, it installs the software and then runs DBCA in interactive mode. Using the screens in DBCA, you can either modify one of the preconfigured database types or create a custom database and specify precisely how you want to configure it.
Note: If you choose this method to create a database, click Help on any of the DBCA screens for a description of the information that you must specify on that screen. |
Creating a Database After Installation
If you decide not to create a database during the installation, you can use DBCA to create one after you have installed the software. For more information about using DBCA to create a database after installation, see the Oracle Database 2 Day DBA manual.
This release of Oracle Database provides new options that you can choose during installation to simplify database administration tasks. These options include:
The following sections describe these options.
If you choose to create a database during the installation, you can specify one of three storage options for database files:
File System
If you choose the file system option, the Database Configuration Assistant creates the database files in a directory on a file system mounted on your computer. Oracle recommends that the file system you choose be separate from the file systems used by the operating system or the Oracle software. The file system that you choose can be any of the following:
A file system on a disk that is physically attached to the system
If you are creating a database on basic disks that are not logical volumes or RAID devices, Oracle recommends that you follow the Optimal Flexible Architecture (OFA) recommendations described in Appendix D and distribute the database files over more than one disk.
A file system on a logical volume manager (LVM) volume or a RAID device
If you are using multiple disks in an LVM or RAID configuration, Oracle recommends that you use the stripe and mirror everything (SAME) methodology to increase performance and reliability. Using this methodology, you do not need to specify more than one file system mount point for database storage.
A network file system (NFS) mounted from a certified network attached storage (NAS) device
You can store database files on NAS devices provided that the NAS device is certified by Oracle. See the "Using Network Attached Storage or NFS File Systems" section for more information about certified NAS and NFS devices.
If you choose the Custom installation type or the Advanced database creation option, you can also choose to use the Oracle-managed files feature with the new database. If you use this feature, you need only specify the database object name instead of file names when creating or deleting database files.
See Also: For more information about Oracle-managed files, see the Oracle Database Administrator's Guide. |
Automatic Storage Management (ASM) is a new feature introduced with this release of Oracle Database. It is a high-performance storage management solution for Oracle database files that is consistent across all supported platforms. Designed specifically to simplify the job of the database administrator (DBA), ASM provides you with a flexible storage solution that simplifies the management of a dynamic database environment. The features provided by ASM make most manual I/O performance tuning tasks unnecessary.
To use ASM for database storage, you must create one or more ASM disk groups. A disk group is a set of disk devices that ASM manages as a single unit. ASM spreads data evenly across all of the devices in the disk group to optimize performance and utilization. To protect against disk failure, you can choose one of three redundancy levels when you create a disk group. The redundancy level defines how files are mirrored within a disk group, as follows:
| Redundancy Level | Mirroring |
| Normal | Two-way mirroring |
| High | Three-way mirroring |
| External | No mirroring by ASM |
In addition to the manageability, performance, and reliability benefits provided by ASM, it can also increase database availability. You can add or remove disk devices from disk groups without shutting down the database. ASM automatically rebalances the files across the disk group after disks have been added or removed.
Disk groups are managed by a special Oracle instance, called an ASM instance. This instance must be running before you can start a database instance that uses ASM for storage management. If you choose ASM as the storage mechanism for your database, DBCA creates and starts this instance if necessary.
See Also: For a more detailed description of ASM, see the Oracle Database Concepts manual. For information about administering ASM, see the Oracle Database Administrator's Guide. |
Raw Devices
Raw devices are disk partitions or logical volumes that have not been formatted with a file system. When you use raw devices for database file storage, Oracle writes data directly to the partition or volume, bypassing the operating system file system layer. For this reason, you can sometimes achieve performance gains by using raw devices. However, because raw devices can be difficult to create and administer, and because the performance gains over modern file systems are minimal, Oracle recommends that you choose ASM or file system storage in preference to raw devices.
To simplify database administration, Oracle provides a Web-based management tool called Oracle Enterprise Manager. There are two ways that you can deploy Oracle Enterprise Manager, as follows:
Deploy Oracle Enterprise Manager 10g centrally in your environment
To deploy Oracle Enterprise Manager centrally, you must install at least one Oracle Management Repository and one Oracle Management Service within your environment, then install an Oracle Management Agent on every computer that you want to manage. You can then use a single Web-based interface to manage and monitor software and hardware targets on all of those systems. Targets can include Oracle databases, application servers, Net listeners, and third-party software. This single interface is called Oracle Enterprise Manager Grid Control (or simply Grid Control).
Note: Oracle Enterprise Manager 10g is available separately in the Oracle Database media pack. For more information about Oracle Enterprise Manager 10g, see the Oracle Enterprise Manager 10g Concepts manual and the Oracle Enterprise Manager 10g Installation and Basic Configuration manual. |
Deploy Oracle Enterprise Manager locally on the database system
Oracle Enterprise Manager software is installed by defaultFoot 1 with every Oracle Database installation. This local installation provides a Web-based interface called Oracle Enterprise Manager Database Control. The Database Control is similar in function to the Grid Control, but it can manage only a single database. If you want to administer more than one database on this system, you must either configure a separate Database Control for each one, or install Oracle Enterprise Manager 10g.
Management Options for Preconfigured Databases
When you choose to create a preconfigured database during the installation, you must select the Oracle Enterprise Manager interface that you want to use to manage the database. The following options are available:
Use Grid Control for database management
This option is available only if an Oracle Management Agent is installed on the system. When the Installer detects an Oracle Management Agent on the system, it allows you to choose this option and specify the Oracle Management Service that you want to use to manage the database.
If an Oracle Management Agent is not installed, you must choose to use Database Control to manage the database. However, if you install Oracle Management Agent after you install Oracle Database, you can then use Grid Control to manage this database.
Use Database Control for database management
This option is selected by default if an Oracle Management Agent is not installed on the system. However, even if a Management Agent is installed, you can still choose to configure Database Control to manage the database.
Management Options for Custom Databases
If you choose the Advanced database configuration option or choose to create a database during a Custom installation, the Installer runs Database Configuration Assistant (DBCA) in interactive mode. Using a screen in DBCA, you can specify the Oracle Enterprise Manager interface that you want to use to manage the database. Alternatively, you can also choose not to configure the database with Enterprise Manager.
Note: Oracle recommends that you configure the database to use Enterprise Manager during installation. However, if you choose not to configure the database to use Enterprise Manager during the installation, you can use DBCA after the installation to configure the database to use it. |
Features Provided by Oracle Enterprise Manager Database Control
Oracle Enterprise Manager Database Control provides a Web-based user interface that enables you to monitor, administer, and maintain an Oracle database. You can use it to perform all of your database administration tasks. You can also use it to determine information about the database, such as:
Instance name, database version, Oracle home location, media recovery options, and other instance data
Current instance availability
Database alert information
Session and SQL-related performance information
Space usage metrics
Furthermore, it provides you with automatic notification of security alerts and it provides the ability to download and apply patches for the software.
If you choose to use Oracle Enterprise Manager Database Control during the installation, you can optionally enable automated database backups that use the Oracle-suggested default backup strategy.
Note: You do not have to enable automated backups during the installation. If you prefer, you can use Oracle Enterprise Manager Database Control or Grid Control to configure automated backups after you install the software and create a database. |
Enabling Automated Backups
If you enable automated backups, Oracle Enterprise Manager schedules a daily backup job that uses Oracle Recovery Manager (RMAN) to back up all of the database files to an on-disk storage area called the flash recovery area. The first time the backup job runs, it creates a full backup of the database. Subsequent backup jobs perform incremental back-ups, which enable you to recover the database to its state at any point during the preceding 24 hours.
To enable automated backup jobs during installation, you must specify the following information:
The location of the flash recovery area
You can choose to use either a file system directory or an ASM disk group for the flash recovery area. The default disk quota configured for the flash recovery area is 2 GB. For ASM disk groups, the required disk space depends on the redundancy level of the disk group that you choose. Chapter 2 describes how to choose the location of the flash recovery area and identifies its disk space requirements.
An operating system user name and password for the backup job
Oracle Enterprise Manager uses the operating system credentials that you specify when running the backup job. The user name that you specify must belong to the UNIX group that identifies database administrators (the OSDBA group, typically dba). The Oracle software owner user (typically oracle) that you use to install the software is a suitable choice for this user. Chapter 2 describes the requirements for the OSDBA group and Oracle software owner user and describes how to create them.
Backup Job Default Settings
If you enable automated backups after choosing one of the preconfigured databases during the installation, automated backup is configured with the following default settings:
The backup job is scheduled to run nightly at 2 a.m.
The disk quota for the flash recovery area is 2 GB.
If you enable automated backups by using DBCA, either during or after the installation, you can specify a different start time for the backup job and a different disk quota for the flash recovery area.
More Information About Automated Backups and Recovery
For information about using Oracle Enterprise Manager Database Control to configure or customize automated backups or to recover a backed up database, see the Oracle Database 2 Day DBA manual.
For more detailed information about defining a back-up strategy and backing up and recovering Oracle databases, see the Oracle Database Backup and Recovery Basics manual or the Oracle Database Backup and Recovery Advanced User's Guide.
If you choose to use the Oracle Enterprise Manager Database Control during the installation, you can configure Enterprise Manager to send e-mail when specific events occur. These events can include occurrences such as disk space reaching a critical limit (a threshold), or a database shutting down unexpectedly.
If you choose to enable e-mail notifications, you must specify the following information:
The host name of an simple mail transport protocol (SMTP) server
The e-mail address that should receive the alerts
The e-mail address that you specify could belong to an individual or it could be a shared e-mail account or a distribution list.
You can use Enterprise Manager Database Control to set-up, change, or customize e-mail notifications after you have created the database.
This section contains information that you should consider before deciding how to install this product. It contains the following sections:
The platform-specific hardware and software requirements included in this installation guide were current at the time this guide was published. However, because new platforms and operating system software versions might be certified after this guide is published, review the certification matrix on the OracleMetaLink Web site for the most up-to-date list of certified hardware platforms and operating system versions. The OracleMetaLink Web site is available at the following URL:
If you do not have a current Oracle Support Services contract, you can access the same information from the following Web site:
http://www.oracle.com/technology/support/metalink/content.html
This product supports multiple Oracle homes. This means that you can install this release or previous releases of the software more than once on the same system, in different Oracle home directories.
You must install this product into a new Oracle home directory. You cannot install products from one release of Oracle Databaseinto an Oracle home directory of a different release. For example, you cannot install release 10.1 software into an existing Oracle9i Oracle home directory. If you attempt to install this release into an Oracle home directory that contains software from an earlier Oracle release, the installation fails.
You can install this release more than once on the same system provided that each installation is installed in a separate Oracle home directory.
The first time you install Oracle Database 10g on a system, the installation configures and starts a single-node version of the Oracle Cluster Synchronization Services (CSS) daemon. The CSS daemon is required to enable synchronization between an ASM instance and the database instances that rely on it for database file storage. It is configured and started even if you do not choose ASM as a storage mechanism for database files. Because it must be running before any ASM instance or database instance starts, it is configured to start automatically when the system boots.
For Oracle Real Application Clusters installations, the CSS daemon is installed with Oracle Cluster Ready Services (CRS) in a separate Oracle home directory (also called the CRS home directory). For single-node installations, the CSS daemon is installed in and runs from the same Oracle home as Oracle Database. For this reason, you must use caution when removing Oracle Database 10g software from the system. Before you remove an Oracle home directory that contains Oracle Database 10g, you must either delete the CSS daemon configuration, or if necessary, reconfigure the CSS daemon to run from another Oracle home directory.
Note: If you plan to have more than one Oracle Database 10g installation on a single system and you want to use ASM for database file storage, Oracle recommends that you run the CSS daemon and the ASM instance from the same Oracle home directory and use different Oracle home directories for the database instances. |
Oracle Database must be able to verify that writes to a disk are completed successfully. NFS file systems, including file systems on NAS devices, may not be able to guarantee that writes to a disk are completed successfully, and this may lead to possible datafile corruption. Oracle recommends that you do not store files on NFS mounted file systems unless the storage vendor and storage device are listed in the Oracle Storage Compatibility Program list. This list is available from the following Web site:
http://www.oracle.com/technology/deploy/availability/htdocs/oscp.html
If your storage device is supported, you can use it to store Oracle software files, Oracle database files, or both.
See Also: For guidelines about using NFS and NAS devices for Oracle software or database files, see Appendix C. |
For information about upgrading a previous release of Oracle Database to Oracle Database 10g, see the Oracle Database Upgrade Guide. The following sections include additional platform-specific upgrade information that you should review before upgrading an existing database.
Before you upgrade an existing database that uses the AL24UTFFSS character set, you must first upgrade the database character set to UTF8. Oracle recommends that you use the Character Set Scanner (csscan) utility for data analysis before attempting to upgrade the existing database character set.
The Character Set Scanner utility checks all character data in the database and tests for the effects of, and problems with, changing the character set encoding. Before running the Character Set Scanner utility, set the shared library path environment variable for your platform to include the $ORACLE_HOME/lib directory.
The following table describes the steps that you must follow to upgrade particular Oracle Database releases running on different versions of AIX. In some cases, to complete the upgrade, you must upgrade to an intermediate Oracle Database release before upgrading to Oracle Database 10g.
| Oracle Database Release | AIX Version | Upgrade Instructions |
| 8.0.6 or earlier | 4.3.3 |
| 8.1.7 (64-bit) 9.0.1 | 4.3.3 |
| 9.2 | 4.3.3 |
| 8.1.7 (32-bit) | 4.3.3, 5.1, or 5.2 |
| 9.2 | 5.1 or 5.2 |
Footnote Legend
Footnote 1: During a custom installation, you can choose not to install Oracle Enterprise Manager software, however, Oracle recommends that you do install it.
