Oracle® Database Installation Guide
10g Release 1 (10.1.0.3) for Linux x86-64 Part No. B14399-01 |
![]() Previous |
![]() Next |
This chapter describes how to completely remove all Oracle databases, instances, and software from an Oracle home directory. It includes information about the following topics:
Note: If you want to remove an Oracle Real Application Clusters (RAC) installation, see the Oracle Real Application Clusters Installation and Configuration Guide for more information.If you want to remove an individual product, check the product-specific documentation for requirements and restrictions. |
To completely remove all Oracle databases, instances, and software from an Oracle home directory, you must:
Identify all instances associated with the Oracle home.
Remove database and ASM instances.
Shut down processes.
Reconfigure the Oracle Cluster Synchronization Services Daemon, if necessary.
Remove the Oracle software.
The following sections describe how to perform these tasks.
To identify all instances associated with the Oracle home that you want to remove, enter one of the following commands:
$ more /etc/oratab
The output for this command contains entries similar to the following:
+ASM:/u01/app/oracle/product/10.1.0/db_1:N CUST:/u01/app/oracle/product/10.1.0/db_1:N
These entries show that the +ASM Automatic Storage Manager instance and the CUST Oracle database instance are associated with the /u01/app/oracle/product/10.1.0/db_1 Oracle home directory.
To completely remove Oracle Database software, you must remove any installed databases. To remove an Oracle database:
Note: Removing an Oracle database deletes all of the data in the database. If you want to keep this data, make sure that you back up the database before deleting it. |
Log in as the oracle user:
$ su - oracle
Run the oraenv or coraenv script to set the environment for the database that you want to remove, for example:
Bourne, Bash, or Korn shell:
$ . /usr/local/bin/oraenv
C shell:
% source /usr/local/bin/coraenv
At the prompt, specify the SID for the database that you want to remove.
Start the Database Configuration Assistant (DBCA):
$ dbca
The Welcome window appears.
Click Next.
The Operations window appears.
Select Delete a Database, then click Next.
Select the database that you want to delete, then click Finish.
In the window that appears, confirm that you want to delete the database.
When the DBCA removes the database, you are prompted to choose whether you want to perform another operation. Click Yes to return to the Operations screen or click No to exit from DBCA. If you want to remove another database, click Yes and repeat steps 6 to 8.
To completely remove Oracle database software, you must also remove any ASM instances running in the Oracle home. To remove an ASM instance:
If necessary, log in as the oracle user:
$ su - oracle
Run the oraenv or coraenv script to set the environment for the ASM instance that you want to remove, for example:
C shell:
$ source /usr/local/bin/coraenv
At the prompt, specify the SID for the ASM instance that you want to remove.
Connect to the ASM instance as the SYS user:
$ sqlplus "SYS/SYS_PASSWORD AS SYSDBA"
Enter the following command to determine whether any Oracle database instance is using the ASM instance:
SQL> SELECT INSTANCE_NAME FROM V$ASM_CLIENT;
This command lists all of the database instances that are using this ASM instance.
Note: This command only lists database instances that are running. It is possible that other instances are associated with the ASM instance, but they are not currently running.If you removed a database from this Oracle home but the output from the command shows that this ASM instance is supporting a database instance in another Oracle home, do not remove the ASM instance or the Oracle home. |
If there are no database instances associated with this ASM instance, drop the disk group associated with this instance as follows:
Note: Dropping the ASM disk group makes the disk device available for use with another ASM instance if required. However, all data in the disk group is lost. Make sure that no other database instance requires any data from this disk group before you drop it. |
Identify the disk groups associated with the ASM instance:
SQL> SELECT NAME FROM V$ASM_DISKGROUP;
For each disk group that you want to delete, enter a command similar to the following:
SQL> DROP DISKGROUP name INCLUDING CONTENTS;
Enter the following command to shut down the ASM instance:
SQL> SHUTDOWN
Remove the entry for the ASM instance from the /etc/oratab file.
Oracle Cluster Synchronization Services (CSS) is a daemon process that is configured by the root.sh script when you install Oracle Database 10g for the first time. It is configured to start every time the system boots. This daemon process is required to enable synchronization between Oracle ASM and database instances. It must be running if an Oracle database is using ASM for database file storage.
Note: On cluster systems with Oracle Real Application Clusters (RAC) installations, the CSS daemon is configured during the Oracle Cluster Ready Services (CRS) installation. If the system is running Oracle CRS, see the Oracle Real Application Clusters Installation and Configuration Guide for information about removing RAC or CRS. |
Before you remove an Oracle Database 10g Oracle home, you must determine whether the CSS daemon is running from that Oracle home and whether any other Oracle Database 10g Oracle homes exist on the system:
If the Oracle Database 10g Oracle home that you want to remove is the only Oracle Database 10g installation on the system, you can delete the CSS daemon configuration.
If the CSS daemon is running from the Oracle Database 10g Oracle home that you want to remove and other Oracle Database 10g installations exist on the system, you must reconfigure the CSS daemon to run from another Oracle Database 10g Oracle home.
The following subsections describe how to complete these tasks.
Identifying Oracle Database 10g Oracle Homes
To identify all of the Oracle Database 10g Oracle home directories, enter one of the following commands:
$ more /etc/oratab
From the output, identify any Oracle home directories where Oracle Database 10g is installed. Oracle homes that contain Oracle Database 10g typically have paths similar to the following. However, they might use different paths.
/mount_point/app/oracle/product/10.1.0/db_n
If there is only one Oracle home directory that contains Oracle Database 10g, see the "Deleting the Oracle CSS Daemon Configuration" section for information about deleting the Oracle CSS daemon configuration.
If you identify more than one Oracle Database 10g Oracle home directory, see the following section for information about reconfiguring the Oracle CSS daemon.
Reconfiguring the Oracle CSS Daemon
To reconfigure the Oracle CSS daemon so that it runs from an Oracle home that you are not removing, follow these steps:
In all Oracle home directories on the system, stop all Oracle ASM instances and any Oracle Database instances that use ASM for database file storage.
Switch user to root.
Depending on your operating system, enter one of the following commands to identify the Oracle home directory being used to run the CSS daemon:
# more /etc/oracle/ocr.loc
The output from this command is similar to the following:
ocrconfig_loc=/u01/app/oracle/product/10.1.0/db_1/cdata/localhost/local.ocr local_only=TRUE
The ocrconfig_loc parameter specifies the location of the Oracle Cluster Registry (OCR) used by the CSS daemon. The path up to the cdata directory is the Oracle home directory where the CSS daemon is running (/Volumes/u01/app/oracle/product/10.1.0/db_1 in this example).
Note: If the value for thelocal_only parameter is FALSE, Oracle CRS is installed on this system. See the Oracle Real Application Clusters Installation and Configuration Guide for information about removing RAC or CRS.
If this Oracle home directory is not the Oracle home that you want to remove, you can continue to the "Removing Oracle Software" section.
Change directory to the Oracle home directory for an Oracle Database 10g installation that you are not removing.
Set the ORACLE_HOME environment variable to specify the path to this Oracle home directory:
# ORACLE_HOME=/u01/app/oracle/product/10.1.0/db_2; # export ORACLE_HOME
C shell:
# setenv ORACLE_HOME /u01/app/oracle/product/10.1.0/db_2
Enter the following command to reconfigure the CSS daemon to run from this Oracle home:
# $ORACLE_HOME/bin/localconfig reset $ORACLE_HOME
The script stops the Oracle CSS daemon, reconfigures it in the new Oracle home, and then restarts it. When the system boots, the CSS daemon starts automatically from the new Oracle home.
To remove the original Oracle home directory, see the "Removing Oracle Software" section.
To delete the Oracle CSS daemon configuration, follow these steps:
Note: Delete the CSS daemon configuration only if you are certain that no other Oracle Database 10g installation requires it. |
Remove any databases or ASM instances associated with this Oracle home. See the preceding sections for information about how to complete these tasks.
Change directory to the Oracle home directory that you are removing.
# ORACLE_HOME=/u01/app/oracle/product/10.1.0/db_1; # export ORACLE_HOME
C shell:
# setenv ORACLE_HOME /u01/app/oracle/product/10.1.0/db_1
Enter the following command to delete the CSS daemon configuration from this Oracle home:
# $ORACLE_HOME/bin/localconfig delete
The script stops the Oracle CSS daemon, then deletes its configuration. When the system boots, the CSS daemon no longer starts.
The following steps describe how to use the Installer to remove Oracle software from an Oracle home:
Note: Always use the Oracle Universal Installer to remove Oracle software. Do not delete any Oracle home directories without first using the Installer to remove the software. |
$ su - oracle
Set the ORACLE_HOME environment variable to specify the path of the Oracle home directory that you want to remove:
$ ORACLE_HOME=/u01/app/oracle/product/10.1.0/db_1 $ export ORACLE_HOME
C shell:
$ setenv ORACLE_HOME /u01/app/oracle/product/10.1.0/db_1
Remove any databases or ASM instances associated with this Oracle home and delete or reconfigure the Oracle CSS daemon.
Stop any processes running in this Oracle home:
| Process Name | Command |
| Database Control | $ORACLE_HOME/bin/emctl stop dbconsole
| Oracle Net listener | $ORACLE_HOME/bin/lsnrctl stop
| iSQL*Plus | $ORACLE_HOME/bin/isqlplusctl stop
| Ultra Search | $ORACLE_HOME/bin/searchctl stop
Start the Installer as follows:
$ $ORACLE_HOME/oui/bin/runInstaller
In the Welcome window, click Deinstall Products.
The Inventory window appears, listing all of the Oracle homes on the system.
In the Inventory window, select the Oracle home and the products that you want to remove, then click Remove.
Note: If you choose to remove Oracle JVM, the Oracle Universal Installer removes all installed products that depend on Oracle JVM, including Oracle Database. |
When the Installer displays a confirmation window asking you to confirm that you want to deinstall the products and their dependant components, click Yes.
The Installer displays a progress indicator as it removes the software.
When the products have been deleted, click Cancel to exit from the Installer, then click Yes.
