Oracle® Database Client Quick Installation Guide
10g Release 1 (10.1.0.3) for Linux x86-64 Part No. B14403-01 |
![]() Previous |
![]() Next |
Copyright © 1996, 2004, Oracle. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its affiliates. Other names may be trademarks of their respective owners.
Part No. B14403-01
October 2004
This guide describes how to quickly install Oracle Client on Linux x86-64 systems. It includes information about the following:
Note: This guide describes how to install Oracle Client on a system that does not have any Oracle software installed on it. If there is an existing Oracle software installation on this system, see the Oracle Database Client Installation Guide for Linux x86-64 for more detailed installation instructions. |
This guide describes how to complete a default installation of Oracle Client in a new Oracle home directory. It describes how to perform one of the following installation types:
Administrator: Enables applications to connect to an Oracle database on the local system or on a remote system. It also provides tools that allow you to administer an Oracle database.
Runtime: Enables applications to connect to an Oracle database on the local system or on a remote system.
Instant Client: Enables you to install only the shared libraries required by Oracle Call Interface applications that use the Instant Client feature. This installation type requires much less disk space than the other Oracle Client installation types.
See Also: For more information about the Instant Client feature, see the Oracle Call Interface Programmer's Guide. |
Where to Get Additional Installation Information
For more detailed information about installing Oracle Client, see the Oracle Database Client Installation Guide for Linux x86-64.
This guide is available on the product disc. To access it, use a Web browser to open the welcome.htm file, either in the top-level directory of the CD-ROM or in the client directory on the DVD-ROM, then select the Documentation tab.
Before you install the Oracle software, you must complete several tasks as the root user. To log in as the root user, complete one of the following procedures:
Note: You must install the software from an X window workstation, an X terminal, or a PC or other system with X server software installed. |
If you are installing the software from an X Window System workstation or X terminal:
Start a local terminal session, for example, an X terminal (xterm).
If you are not installing the software on the local system, enter the following command to enable remote hosts to display X applications on the local X server:
$ xhost +
If you are not installing the software on the local system, use the ssh, rlogin, or telnet command to connect to the system where you want to install the software:
$ telnet remote_host
If you are not logged in as the root user, enter the following command to switch user to root:
$ su - root password: #
If you are installing the software from a PC or other system with X server software installed:
Note: If necessary, see your X server documentation for more information about completing this procedure. Depending on the X server software that you are using, you may need to complete the tasks in a different order. |
Start the X server software.
Configure the security settings of the X server software to permit remote hosts to display X applications on the local system.
Connect to the remote system where you want to install the software and start a terminal session on that system, for example, an X terminal (xterm).
If you are not logged in as the root user on the remote system, enter the following command to switch user to root:
The system must meet the following minimum hardware requirements:
| Requirement | Minimum Value |
| Physical memory (RAM) | 256 MB (262144 KB) |
| Swap space | 512 MB (524288 KB) or twice the size of RAM
On systems with 2 GB or more of RAM, the swap space can be between one and two times the size of RAM |
Disk space in /tmp
400 MB (409600 KB) |
| Disk space for software files | Between 150 MB (153600 KB) and 650 MB (665600 KB) of disk space, depending on the installation type that you choose |
To ensure that the system meets these requirements, follow these steps:
To determine the physical RAM size, enter the following command:
# grep MemTotal /proc/meminfo
If the size of the physical RAM installed in the system is less than 256 MB, you must install more memory before continuing.
To determine the size of the configured swap space, enter the following command:
# grep SwapTotal /proc/meminfo
If necessary, see your operating system documentation for information about how to configure additional swap space.
To determine the amount of free disk space available in the /tmp directory, enter the following command:
# df -h /tmp
If there is less than 400 MB of disk space available in the /tmp directory, complete one of the following steps:
Delete unnecessary files from the /tmp directory to achieve the required disk space.
Set the TEMP and TMPDIR environment variables when setting the oracle user's environment (described later).
Extend the file system that contains the /tmp directory. If necessary, contact your system administrator for information about extending file systems.
To determine the amount of free disk space available on the system, enter the following command:
# df -h
This command displays the disk space usage on all mounted file systems. To complete the installation, identify a file system with sufficient disk space.
The system must meet the following minimum software requirements, depending on your Linux distribution and version.
Red Hat Enterprise Linux 3 (Update 2)
The following packages (or later versions) must be installed:
gcc-3.2.3-34 glibc-2.3.2-95.20 glibc-devel-2.3.2-95.20 glibc-devel-2.3.2-95.20 (32 bit) make-3.79.1 openmotif21-2.2.2-16 setarch-1.3-1 compat-db-4.0.14-5 compat-gcc-7.3-2.96.128 compat-gcc-c++-7.3-2.96.128 compat-libstdc++-7.3-2.96.128 compat-libstdc++-devel-7.3-2.96.128 gnome-libs-1.4.1.2.90-34.1 (32 bit) libaio-0.3.96-3 libaio-devel-0.3.96-3
Kernel version 2.4.21-15.EL or later must be installed
SuSE Linux Enterprise Server 8
Service Pack 3 (SP3) or later (kernel version 2.4.21-185-smp)
The following packages (or later versions) must be also be installed:
gcc-3.3-43 gcc-c++-3.3-43 glibc-2.2.5-213 glibc-32bit-8.1-9 glibc-devel-32bit-8.1-9 make-3.79.1 openmotif-2.2.2-195 libaio-0.3.96-3 libaio-devel-0.3.96-3
SUSE Linux Enterprise Server 9
Kernel version 2.6.5-7.97 or later must be installed
gcc-3.3.3-43 gcc-c++-3.3.3-43 glibc-2.3.3-98 libaio-0.3.98-18 libaio-devel-0.3.98-18 make-3.80 openmotif-libs-2.2.2-519.1
To determine which distribution and version of Linux is installed, enter the following command:
# cat /proc/version
Note: Only the listed distributions and versions are currently certified and supported. |
To determine whether the required packages are installed, enter a command similar to the following:
$ rpm -q package_name
If a required package is not installed, or if the version is lower than the required version, install the package from your operating system distribution media or download the required package version from your Linux vendor's Web site.
On Red Hat Enterprise Linux 3 systems only, enter the following command to determine whether kernel errata 15 (15.EL) or later is installed:
# uname -r 2.4.21-15.EL
This command shows the kernel version (2.4.21) and errata level (15.EL). If the errata level is less than 15, install the latest kernel update. Kernel updates are available from the Red Hat Network.
On SuSE Linux Enterprise Server 8 systems only, enter the following command to determine whether Service Pack 3 is installed:
# uname -r 2.4.21-185-smp
This command shows the kernel version (2.4.21-185) and type (smp). If the kernel version is less than 2.4.21-185, contact SuSE for information about obtaining and installing Service Pack 3.
On SuSE Linux Enterprise Server 9 systems only, enter the following command to determine whether the required kernel is installed:
# uname -r 2.6.5-7.97
This command shows the kernel version (2.6.5-7.97). If the kernel version is less than 2.6.5-7.97, contact SuSE for information about obtaining and installing the kernel updates.
The following local UNIX group and user must exist on the system:
The oinstall group (the Oracle Inventory group)
The oracle user (the Oracle software owner)
The oinstall group and the oracle user may already exist on your system. To determine whether they exist already, and if necessary, to create them, follow these steps:
To determine whether the oinstall group exists, enter the following command:
# grep oinstall /etc/group
If the output from this command shows the specified group name, that group already exists.
If necessary, enter the following command to create the oinstall group:
# /usr/sbin/groupadd oinstall
To determine whether the oracle user exists and belongs to the correct groups, enter the following command:
# id oracle
If the oracle user exists, this command displays information about the groups to which the user belongs. The output should be similar to the following, indicating that oinstall is the primary group:
uid=502(oracle) gid=502(oinstall) groups=502(oinstall),503(dba)
If necessary, complete one of the following actions:
If the oracle user exists, but its primary group is not oinstall, enter a command similar to the following, where the -g option specifies oinstall as the primary group and the -G option specifies any existing groups to which the oracle user belongs:
# /usr/sbin/usermod -g oinstall -G dba oracle
If the oracle user does not exist, enter the following command to create it:
# /usr/sbin/useradd -g oinstall -G dba oracle
This command creates the oracle user and specifies:
dba as an optional secondary group
Enter the following command to set the password of the oracle user:
# passwd oracle
Create an Oracle base directory with a name similar to the following and specify the correct owner, group, and permissions for it:
/u01/app/oracle
The Oracle base directory must have between 150 MB (153600 KB) and 650 MB (665600 KB) of free space depending on the installation type you choose:
| Installation Type | Requirement for Software Files (MB) |
| Instant Client | 150 |
| Administrator | 650 |
| Runtime | 350 |
To determine where to create this directory, follow these steps:
Enter the following command to display information about all mounted file systems:
# df -h
This command displays information about all of the file systems mounted on the system, including:
The physical device name
The total amount, used amount, and available amount of disk space
The mount point directory for that file system
From the display, identify a file system that has sufficient disk space.
Note the name of the mount point directory for the file system that you identified.
In the following examples, /u01 is the mount point directory used for the software. You must specify the appropriate mount point directory for the file system on your system.
To create the required directory and specify the correct owner, group, and permissions for it, follow these steps:
Note: In the following procedure, replace/u01 with the appropriate mount point directory that you identified in Step 3 previously.
Enter the following command to create subdirectories in the mount point directory that you identified for the Oracle base directory:
# mkdir -p /u01/app/oracle
Change the owner and group of the directory that you created to the oracle user and the oinstall group:
# chown -R oracle:oinstall /u01/app/oracle
Change the permissions on the directory that you created to 775:
# chmod -R 775 /u01/app/oracle
The Oracle Database 10g software is available on both CD-ROM and DVD-ROM. These discs are in ISO 9660 format with Rockridge extensions.
On most Linux systems, the product disc mounts automatically when you insert it into the drive. To verify that the disc is mounted correctly, follow these steps:
If necessary, enter a command similar to following to eject the currently mounted disc, then remove it from the drive:
Red Hat:
# eject /mnt/cdrom
SuSE:
# eject /media/cdrom
In this example, /mnt/cdrom or /media/cdrom is the mount point directory for the CD-ROM drive, depending on your distribution.
Insert the disc into the CD-ROM or DVD-ROM drive.
To verify that the disc mounted automatically, enter a command similar to the following:
Red Hat:
# ls /mnt/cdrom
SuSE:
# ls /media/cdrom
If this command fails to display the contents of the disc, enter a command similar to the following, depending on your distribution:
Red Hat:
# mount -t iso9660 /dev/cdrom /mnt/cdrom
SuSE:
# mount -t iso9660 /dev/cdrom /media/cdrom
You run the Installer from the oracle account. However, before you start the Installer you must configure the environment of the oracle user. To configure the environment, you must:
Set the default file mode creation mask (umask) to 022 in the shell startup file.
Set the DISPLAY and ORACLE_BASE environment variables.
To set the oracle user's environment, follow these steps:
Start another terminal session.
Enter the following command to ensure that X Window applications can display on this system:
$ xhost +
Complete one of the following steps:
If the terminal session is not connected to the system where you want to install the software, log in to that system as the oracle user.
If the terminal session is connected to the system where you want to install the software, switch user to oracle:
$ su - oracle
To determine the default shell for the oracle user, enter the following command:
$ echo $SHELL
Open the oracle user's shell startup file in any text editor:
Bash shell (bash) on Red Hat:
$ vi .bash_profile
Bourne shell (sh), Bash shell on SuSE, or Korn shell (ksh):
$ vi .profile
C shell (csh or tcsh):
% vi .login
Enter or edit the following line in the shell startup file, specifying a value of 022 for the default file mode creation mask:
umask 022
Save the file and exit from the editor.
To run the shell startup script, enter the following command:
Bash shell on Red Hat:
$ . ./.bash_profile
Bourne shell, Bash shell on SuSE, or Korn shell:
$ . ./.profile
C shell:
% source ./.login
If you determined that the /tmp directory had insufficient free disk space when checking the hardware requirements, enter the following commands to set the TEMP and TMPDIR environment variables. Specify a directory on a file system with sufficient free disk space.
Bourne, Bash, or Korn shell:
$ TEMP=/directory $ TMPDIR=/directory $ export TEMP TMPDIR
C shell:
% setenv TEMP /directory % setenv TMPDIR /directory
If you are not installing the software on the local system, enter the following command to direct X applications to display on the local system:
$ DISPLAY=local_host:0.0 ; export DISPLAY
C shell:
% setenv DISPLAY local_host:0.0
In this example, local_host is the host name or IP address of the system that you want to use to display the Installer (your workstation or PC).
Enter commands similar to the following to set the ORACLE_BASE environment variable:
$ ORACLE_BASE=/u01/app/oracle $ export ORACLE_BASE
C shell:
% setenv ORACLE_BASE /u01/app/oracle
In these examples, /u01/app/oracle is the Oracle base directory that you created earlier.
Enter the following commands to ensure that the ORACLE_HOME and TNS_ADMIN environment variables are not set:
$ unset ORACLE_HOME $ unset TNS_ADMIN
C shell:
% unsetenv ORACLE_HOME % unsetenv TNS_ADMIN
To verify that the environment has been set correctly, enter the following commands:
$ umask $ env | more
Verify that the umask command displays a value of 022 and the environment variables that you set in this section have the correct values.
After configuring the oracle user's environment, start the Installer and install the Oracle software, as follows:
Note: The following examples show paths to therunInstaller script on a CD-ROM. If you are installing the software from DVD-ROM, use a command similar to the following:
$ /mount_point/client/runInstaller
To start the Installer, enter the following commands:
Red Hat:
# mount -t iso9660 /dev/cdrom /mnt/cdrom # cd /tmp # /mnt/cdrom/runInstaller
SuSE:
# mount -t iso9660 /dev/cdrom /media/cdrom # cd /tmp # /media/cdrom/runInstaller
If the Installer does not appear, see the Oracle Database client Installation Guide for Linux x86-64 for information about how to troubleshoot X display problems.
Use the following guidelines to complete the installation:
The following table describes the recommended action for each Installer screen.
Note: If you have completed the tasks listed previously, you can complete the installation by choosing the default values on most screens. |
If you need more assistance, or if you want to choose an option that is not a default, click Help for additional information.
If you encounter errors while installing or linking the software, see the Oracle Database Client Installation Guide for Linux x86-64 for information about troubleshooting.
| Screen | Recommended Action |
| Welcome | Click Next. |
| Specify Inventory Directory and Credentials | Note: This screen appears only during the first installation of Oracle products on a system.
Specify the following information, then click Next: Enter the full path of the inventory directory Verify that the path is similar to the following, where oracle_base/oraInventory
Specify operating system group name Verify that the group specified is the Oracle Inventory group: oinstall |
| Run orainstRoot.sh | If prompted, run the following script in a separate terminal window as the root user:
oracle_base/oraInventory/orainstRoot.sh
| Specify File Locations | In the Destination section, verify that the Path value for the Oracle home directory is similar to the following, then click Next:
oracle_base/product/10.1.0/client_1
| Select Installation Type | Select InstantClient, Administrator, or Runtime, then click Next. |
| Summary | Review the information displayed, then click Install. |
| Install | The Install screen displays status information while the product is being installed. |
| Configuration Assistants | Note: This screen appears only during an Administrator or Runtime installation.
The Configuration Assistants screen displays status information for the Oracle Net Configuration Assistant that configures Oracle Net. |
| Oracle Net Configuration Assistant: Welcome | Review the information on the screen, then click Next.
The Oracle Net Configuration Assistant configures the easy connect naming method. For more information about this naming method, click Help. |
| Oracle Net Configuration Assistant: Done | Click Finish to continue. |
| Setup Privileges | Note: This screen appears only during an Administrator or Runtime installation.
If prompted, run the following script in a separate terminal window as the oracle_home/root.sh
In this example, Press Return to accept the default values for each prompt displayed by the script. When the script finishes, click OK. |
| End of Installation | To exit from the Installer, click Exit, then click Yes. |
After you have successfully installed Oracle Client, see Chapter 4 in the Oracle Database Client Installation Guide for Linux x86-64 for information about required and optional post-installation steps.
Our goal is to make Oracle products, services, and supporting documentation accessible, with good usability, to the disabled community. To that end, our documentation includes features that make information available to users of assistive technology. This documentation is available in HTML format, and contains markup to facilitate access by the disabled community. Standards will continue to evolve over time, and Oracle is actively engaged with other market-leading technology vendors to address technical obstacles so that our documentation can be accessible to all of our customers. For additional information, visit the Oracle Accessibility Program Web site at
http://www.oracle.com/accessibility/
Accessibility of Code Examples in Documentation
JAWS, a Windows screen reader, may not always correctly read the code examples in this document. The conventions for writing code require that closing braces should appear on an otherwise empty line; however, JAWS may not always read a line of text that consists solely of a bracket or brace.
Accessibility of Links to External Web Sites in Documentation
This documentation may contain links to Web sites of other companies or organizations that Oracle does not own or control. Oracle neither evaluates nor makes any representations regarding the accessibility of these Web sites.
