Skip Headers
Oracle® Database Installation Guide
10g Release 2 (10.2) for Linux Itanium
B15674-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
D Managing Oracle Database Port Numbers
During installation, Oracle Universal Installer assigns port numbers to components from a set of default port numbers. This appendix lists the default port numbers and describes how to change the assigned port after installation. It includes information about the following topics:
D.1 About Managing Ports
During installation, Oracle Universal Installer assigns port numbers to components from a set of default port numbers. Many Oracle Database components and services use ports. As an administrator, it is important to know the port numbers used by these services, and to make sure that the same port number is not used by two services on your host.
Most port numbers are assigned during installation. Every component and service has an allotted port range, which is the set of port numbers Oracle Database attempts to use when assigning a port. Oracle Database starts with the lowest number in the range and performs the following checks:
If the answer to any of the preceding questions is yes, Oracle Database moves to the next highest port in the allotted port range and continues checking until it finds a free port.
D.2 Viewing Port Numbers and Access URLs
In most cases, the Oracle Database component's port number is listed in the tool used to configure the port. In addition, ports for some Oracle Database applications are listed in the portlist.ini file. This file is located in the $ORACLE_HOME/install directory.
If you change a port number, it is not updated in the portlist.ini file, so you can only rely on this file immediately after installation. To find or change a port number, use the methods described in this appendix.
D.3 Port Numbers and Protocols of Oracle Components
The following table lists the port numbers and protocols used by components that are configured during the installation. By default, the first port in the range is assigned to the component, if it is available.
Table D-1 Ports Used in Oracle Components
Component and Description Default Port Number Port Range Protocol
Oracle SQL*Net Listener
Allows Oracle client connections to the database over Oracle's SQL*Net protocol. You can configure it during installation. To reconfigure this port, use Net Configuration Assistant.
1521
1521
TCP
Data Guard
Shares the SQL*Net port and is configured during installation. To reconfigure this port, use Net Configuration Assistant to reconfigure the Oracle SQL*Net listener.
1521 (same value as the listener)
1521
TCP
Connection Manager
Listening port for Oracle client connections to Oracle Connection Manager. It is not configured during installation, but can be configured using Net Configuration Assistant.
1630
1630
TCP
Oracle Management Agent
HTTP port for Enterprise Management Agent. It is configured during installation.
"Changing the Oracle Enterprise Management Agent Port" explains how to modify its port number
3938
1830–1849
HTTP
Oracle Enterprise Manager Database Console
HTTP port for Enterprise Manager Database Control. It is configured during installation. "Changing the Oracle Enterprise Manager Database Console Ports" explains how to modify its port number.
1158
5500–5519
TCP/HTTP
RMI port for Enterprise Manager Database Control. It is configured during installation."Changing the Oracle Enterprise Manager Database Console Ports" explains how to modify its port number.
5520
5520–5539
TCP
JMS port for Enterprise Manager Database Control. It is configured during installation. "Changing the Oracle Enterprise Manager Database Console Ports" explains how to modify its port number.
5540
5540–5559
TCP
iSQL*Plus
HTTP port for iSQL*Plus. The port number is automatically assigned during installation. "Changing the iSQL*Plus Ports" explains how to change its port number.
5560
5560–5579
TCP/HTTP
iSQL*Plus
RMI port for iSQL*Plus. The port number is automatically assigned during installation."Changing the iSQL*Plus Ports" explains how to change its port number.
5580
5580–5599
TCP
iSQL*Plus
JMS port for iSQL*Plus. The port number is automatically assigned during installation. "Changing the iSQL*Plus Ports" explains how to change its port number.
5600
5600–5619
TCP
Oracle Ultra Search
HTTP port for Oracle Ultra Search. Its port number is assigned automatically when you install Oracle Ultra Search, by using the Custom installation type. "Changing the Oracle Ultra Search Ports" explains how to change its port number.
5620
5620–5639
TCP/HTTP
Oracle Ultra Search
RMI port for Oracle Ultra Search. Its port number is assigned automatically when you install Oracle Ultra Search, by using the Custom installation type. "Changing the Oracle Ultra Search Ports" explains how to change its port number.
5640
5640–5659
TCP
Oracle Ultra Search
JMS port for Oracle Ultra Search. Its port number is assigned automatically when you install Oracle Ultra Search, by using the Custom installation type. "Changing the Oracle Ultra Search Ports" explains how to change its port number.
5660
5660–5679
TCP
Oracle XML DB
The Oracle XML DB HTTP port is used if Web-based applications need to access an Oracle database from an HTTP listener. It is configured during installation, but you cannot view it afterward. "Changing the Oracle XML DB Ports" explains how to change its port number.
Dynamic
Dynamic
HTTP
Oracle XML DB
The Oracle XML DB FTP is used when applications need to access an Oracle database from an FTP listener. It is configured during installation, but you cannot view it afterward. "Changing the Oracle XML DB Ports" explains how to change its port number.
Dynamic
Dynamic
FTP
Oracle Real Application Clusters (Local Host: Windows only)
- On Rac is configured by default - Is configurable
61000
61000–61300
TCP
Oracle Real Application Clusters (Cluster Interconnect: Windows only)
- On RAC is configured by default - Is configurable
11000
11000–26000
TCP
Oracle Real Application Clusters (UNIX)
The port number is assigned automatically during installation. You cannot view or modify it afterward.
Dynamic
Dynamic
UDP
Oracle Clusterware
CRS daemon (Oracle Cluster Ready Services Daemon) internode connection. The port number is assigned automatically during installation. You cannot view or modify it afterward.
49896
49896
TCP
Cluster Synchronization Service (CSS)
CSS daemon internode connection for the GM layer. The port number is assigned automatically during installation. You cannot view or modify it afterward.
49895
49895
TCP
Oracle Cluster Registry
Dynamic
Dynamic
TCP
Oracle Event Manager
49897
49897–49898
TCP
Cluster Manager
Dynamic
Dynamic
TCP
D.4 Changing the Oracle Enterprise Management Agent Port
To find the current setting for the Oracle Management agent port, search for EMD_URL in the $ORACLE_HOME/host_sid/sysman/config/emd.properties file.
To change the Oracle Management Agent HTTP port, use the emca -reconfig ports command:
emca -reconfig ports -AGENT_PORT 1831
D.5 Changing the Oracle Enterprise Manager Database Console Ports
To find the current HTTP, RMI, and JMS port settings, search in the following files:
To change the Oracle Enterprise Manager Database Control ports, use the emca -reconfig ports command:
$ORACLE_HOME\bin> emca -reconfig ports option setting
where option can be:
You can enter multiple -reconfig port settings in one line, for example:
emca -reconfig ports -DBCONTROL_HTTP_PORT 1820 -AGENT_PORT 1821 -RMI_PORT 5520
D.6 Changing the iSQL*Plus Ports
The following sections describe how to change the iSQL*Plus ports.
Changing the HTTP Port
To change the HTTP port, edit the following files:
Changing the RMI Port
To change the RMI port, modify the port attribute of the rmi-server element in the $ORACLE_HOME/oc4j/j2ee/isqlplus/config/rmi.xml file:
<rmi-server port="5580"...>
Changing the JMS Port
To change the JMS port, modify the port attribute of the jms-server element in the $ORACLE_HOME/oc4j/j2ee/isqlplus/config/jms.xml file:
<jms-server port="5600"...>
D.7 Changing the Oracle Ultra Search Ports
The following sections describe how to change the Oracle Ultra Search ports.
To change the HTTP port, modify the port attribute of the web-site element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/http-web-site.xml file:
<web-site port="5620"...>
To change the RMI port, modify the port attribute of the rmi-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/rmi.xml file:
<rmi-server port="5640"...>
To change the JMS port, modify the port attribute of the jms-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/jms.xml file:
<jms-server port="5660"...>
D.8 Changing the Oracle XML DB Ports
To change the Oracle XML DB FTP and HTTP ports, you need to run the catxdbdbca.sql script, which in a default installation is located in $ORACLE_HOME/rdbms/admin.
To change the Oracle XML DB ports:
  1. Check that the Oracle listener is running. To do so, in the Services control panel, make sure that the Oracle TNS Listener service (for example, OracleOraDb10g_home1TNSListener) is set to Started.
    If you cannot start the listener, refer to Oracle Net Services Administrator's Guide.
  2. Log into SQL*Plus or iSQL*Plus as SYS or XDB using the SYSDBA role.
    For example, to log in to SQL*Plus as SYS using the password welcome:
    # sqlplus "sys/welcome as SYSDBA"
  3. Run the catxdbdbca.sql script.
    For example, to use 2200 for the FTP port and 8200 for the HTTP port, and assuming your Oracle home is in the following location, enter the following command:
    SQL> $ORACLE_HOME\rdbms\admin\catxdbdbca.sql 2200 8200
  4. Exit SQL*Plus or iSQL*Plus.
