Oracle® E-Business Suite Certified Configuration Installation Guide
Release 11i (11.5.10) for AIX Based Systems, hp-ux PA-RISC (64-bit), Linux x86, and Solaris Operating System (SPARC 32-bit) Part No. B15721-03 |
![]() Previous |
![]() Next |
This chapter describes installation requirements for Oracle E-Business Suite Certified Configuration. It also provides information on how to validate your system for these requirements before you begin installation and deployment.
This chapter consists of the following topics:
Ensure that your system meets the requirements in the following sections:
The minimum hardware requirements for Oracle E-Business Suite Certified Configuration for AIX Based Systems, hp-ux PA-RISC (64-bit), Linux x86, and Solaris Operating System (SPARC 32-bit) are as follows:
2 CPUs
450 MHz speed
900 CPU power factor (port-specific)
To calculate CPU power factor, multiply the number of processors with the speed of the processors. For example, CPU power factor = CPU count * speed
2 Network Interface Cards (NIC), 10/1000 Mbps
2 GB of physical memory
2 GB disk swap space
In addition to these requirements, you need the following disk space for Oracle E-Business Suite Certified Configuration.
Table 2-1 lists the space needed for Oracle E-Business Suite Certified Configuration.
Depending on your platform, go to one of the of the following sections for information on minimum software requirements:
The minimum operating system requirements for the Oracle E-Business Suite Certified Configuration are as follows:
Software patches listed in Table 2-2
System packages listed in Table 2-3
JDK must be installed under the directory /usr/java14.
Notes:
See Also: Refer to the system administration manual for your platform for instructions on setting kernel parameters, installing software patches, and other system administration tasks. |
Table 2-2 lists the operating system software patches required for Oracle E-Business Suite Certified Configuration for AIX Based Systems (64-bit).
Table 2-2 Software Patches for AIX Based Systems (64-bit)
| Patch Identifier | Description |
| IY23677 | Fix for Visual Age C++ |
| IY26778 | Truss Fix |
| IY28766 | bread/bwrite, lread/lwrite, and phread/pwrite
| IY28776 | Fix for OOS Javascript error |
| IY28949 | Fix for aio_nwait
| IY29731 | Fix for cpio
| IY29813 | Fix for cp and mv
| IY29965 | Fix for thread_wait()
| IY30150 | Fix for waitpid
| IY30886 | Fixes for JRE/JDK |
| IY30887 | Fixes for JRE/JDK |
| IY31033 | Fix for SDK |
| IY32907 | Fix for VXFS |
| IY36656 | Ad LV device, which prevents split I/O with striping |
Table 2-3 lists the operating system software packages required for Oracle E-Business Suite Certified Configuration for AIX Based Systems (64-bit).
Table 2-3 System Software Packages for AIX Based Systems (64-bit)
| Product | Version | Description |
bos.adt.lib
5.1.0.0 | File set required to use the mathematical function |
bos.perf.perfstat
5.1.0.0 | Performance tool |
Executable /bin/ksh
5.1.0.10 | Korn shell |
Executable bc
5.1.0.0 | Interpreter for arbitrary-precision arithmetical language |
| Expect | 5.3.3 | Expect module |
| Gnutar | 1.13 | Gnu tar utility |
| Perl | 5.005_003 | Perl |
sudo
1.6.6 | Sudo |
| TCL | 8.2.1 | Tcl |
| Unzip | 5.4.2 | Unzip utility |
| Visual Age C++ Compiler | 5.0.2.1 | Visual Ace C/C++ runtime compiler |
X11.base.rte
5.1.0.0 | X Server |
X11.vfb
5.1.0.0 | X virtual frame buffer |
| Zip | 2.3 | Zip utility |
The minimum operating system requirements for Oracle E-Business Suite Certified Configuration are as follows:
hp-ux PA-RISC (64-bit) 11.11, 11.23
Software patches listed in Table 2-4
Software packages listed in Table 2-5
Note: The minimum operating system version, software patches and software packages are only the minimum requirements. Users might choose to use later versions that supersede the listed version. |
Table 2-4 lists the operating system software patches required for Oracle E-Business Suite Certified Configuration for hp-ux PA-RISC (64-bit) version 11.11.
Table 2-4 Software Patches for hp-ux PA-RISC (64-bit) version 11.11
| Patch Number | Version | Description |
| GOLDAPPS11i | B.11.11.0112.6 | Gold Applications Patches for hp-ux 11i, December 2001 |
| GOLDBASE11i | B.11.11.0112.6 | Gold Base Patches for hp-ux 11i, December 2001 |
| HWEnable11i | B.11.11.0203.5 | Hardware Enablement Patches for hp-ux 11i, March 2002 |
| PHCO_24402 | 1.0 | Libc cumulative header file patch |
| PHCO_25226 | 1.0 | Initialized TLS, Psets, Mutex performance |
| PHCO_26061 | 1.0 | Kernel configuration commands patch |
| PHCO_26331 | 1.0 | Mountall cumulative patch |
| PHCO_26466 | 1.0 | Pthread additive perf enhancement and fixes |
| PHCO_27434 | 1.0 | Libc cumulative patch |
| PHKL_25233 | 1.0 | Select(2) and poll(2) hang |
| PHKL_25389 | 1.0 | Core PM, vPar, Psets Cumulative Patch |
| PHKL_25468 | 1.0 | Eventport (/dev/poll) pseudo driver
| PHKL_25729 | 1.0 | Signals, threads enhancement, Psets Enablement |
| PHKL_25993 | 1.0 | Thread nostop for NFS, rlimit, Ufalloc fix |
| PHKL_25994 | 1.0 | Thread NOSTOP, Psets Enablement, Ufalloc |
| PHKL_25995 | 1.0 | Eventport syscalls; socket close(2); ufalloc |
| PHKL_26468 | 1.0 | Shared mutex synchronization support patch |
| PHKL_27092 | 1.0 | Thread NOSTOP, Abort; Psets |
| PHKL_27278 | 1.0 | Mmap io, VM-JFS ddlock, thread perf, user limit |
| PHKL_27502 | 1.0 | MO 4k sector size; FIFO; Event Port; perf |
| PHNE_25642 | 1.0 | Cumulative ARPA Transport patch |
| PHNE_26388 | 1.0 | ONC/NFS General Release/Performance Patch |
| PHNE_26728 | 1.0 | Cumulative STREAMS Patch |
| PHNE_27063 | 1.0 | Cumulative ARPA Transport patch |
| PHSS_24302 | 1.0 | Linker startup code / SLLIC ELF support |
| PHSS_24638 | 1.0 | HP aC++ -AA runtime libraries (aCC A.03.33) |
| PHSS_25092 | 1.0 | X Font Server SEP2001 Periodic Patch |
| PHSS_25263 | 1.0 | X Server cumulative patch - Xvfb for hp-ux 11.11 |
| PHSS_25881 | 1.0 | X/Motif Runtime JAN2002 Periodic Patch |
| PHSS_25985 | 1.0 | ANSI C compiler General patch |
| PHSS_25986 | 1.0 | +04/PBO compiler |
| PHSS_26263 | 1.0 | Ld(1) and linker tools cumulative patch |
| PHSS_26971 | 1.0 | Japanese TrueType font patch |
| PHSS_26973 | 1.0 | Korean TrueType fonts patch |
| PHSS_26975 | 1.0 | Chinese-S TrueType fonts patch |
| PHSS_26977 | 1.0 | Chinese-T TrueType fonts patch |
| PHSS_27425 | 1.0 | X/Motif Runtime Patch |
Table 2-5 lists the software packages required for Oracle E-Business Suite Certified Configuration for hp-ux PA-RISC (64-bit) version 11.11.
Table 2-5 System Software Packages for hp-ux PA-RISC (64-bit) version 11.11
| B3901BA | B.11.11.04 | HP C/ANSI C Developer's Bundle for hp-ux 11i (S800) |
| B3913DB | C.03.33.01 | HP aC++ Compiler (S800) |
| B5456CA | C.01.18.05 | hp-ux Development Kit for Java |
| B8110AA | 1.2.2.11.01 | Java 2 SDK for hp-ux (700/800), PA1.1 +PA2.0 Add On |
| B9788AA | 1.3.1 | Java 2 SDK 1.3 for hp-ux (700/800), PA1.1 +PA 2.0 Add On |
| BUNDLE11i | B.11.11.0102.2 | Required Patch Bundle for hp-ux 11i, February 2001 |
| Expect | 5.33 | expect
Note: |
| HPUX11i-OE-Ent | B.11.11.0203 | hp-ux Enterprise Operating Environment Component |
| HPUXBase64 | B.11.11 | hp-ux 64-bit Base OS |
| HPUXBaseAux | B.11.11.0203 | hp-ux Base OS Auxiliary |
| RAID-00 | B.11.11.01 | PCI RAID; Supptd HW=A5856A |
| sudo | 1.6.6 | Utility to execute commands as another user. |
| tcl | 8.2.1 | tcl
| tk | 8.2.1 | tk
| unzip | 5.42 | unzip
Note: Should be installed in the |
| X11MotifDevKit | B.11.11.01 | hp-ux Developer's Toolkit - X11, Motif, and Imake |
| zip | 2.3 | zip
The minimum operating system requirements for Oracle E-Business Suite Certified Configuration on Linux are as follows:
Red Hat AS/ES 2.1 (kernel version 2.4.9-e.34smp or later), or Red Hat AS/ES 3.0 (2.4.21-4EL or later), or SUSE Linux Enterprise Server 9 (2.6.5-7.97-bigsmp or later)
Software packages listed in Table 2-6, Table 2-7, and Table 2-8
Operating system patches (3006854 for RH 3.0, and 3633386 for SLES9)
Table 2-6 lists the software packages required for Oracle E-Business Suite Certified Configuration for Red Hat AS/ES 2.1.
If you are installing Red Hat AS/ES 3.0, you must install the patch for bug number 3006854. (INSTALLER INTEROPERABILITY PATCH FOR RHEL3.0). Refer to the README for detailed instructions. Ensure that the PATH environment variable is set correctly before you apply the patch. The LD version should be 2.14.90. Use the following command to determine the LD version.
$ ld -version
The value for the LD_ASSUME_KERNEL environment variable must be set correctly to enable Java to work.
Make the setting permanent by entering it in the applmgr and Oracle's user shell initialization files ($HOME/.bash_profile or $HOME/.profile) or in the system's global shell initialization file (/etc/profile).
From a Bourne, Bash, or Korn shell, enter the following:
LD_ASSUME_KERNEL=2.4.19 export LD_ASSUME_KERNEL
Table 2-7 lists the software packages and patches required for Oracle E-Business Suite Certified Configuration for Red Hat AS/ES 3.0.
If you are installing SUSE Linux Enterprise Server 9, you must install the patch for bug number 3633386. (INSTALLATION STOPS WITH A LINKING ERROR ON SLES9). Refer to the README for detailed instructions. Ensure that the PATH environment variable is set correctly before you apply the patch. The LD version should be 2.4.21. Use the following command to determine the LD version.
$ ld -version
LD_ASSUME_KERNEL=2.4.2.1 export LD_ASSUME_KERNEL
Table 2-8 lists the software packages and patches required for Oracle E-Business Suite Certified Configuration for SUSE Linux Enterprise Server 9.
The operating system requirements for the Oracle E-Business Suite Certified Configuration on Solaris are as follows:
Sun Solaris 8, 9
Software patches listed in the "Software Patch for Oracle E-Business Suite Certified Configuration on Solaris 8" section
Software packages listed in Table 2-9 and Table 2-10
See Also: Refer to the system administration manual for your platform for instructions on setting kernel parameters, installing software patches and other system administration tasks. |
The Solaris 8 Recommended Patch Cluster (05 June 2002 or later) is required for Oracle E-Business Suite Certified Configuration for Solaris Operating Environment (SPARC 32-bit) version 8.
Table 2-9 lists the software packages required for Oracle E-Business Suite Certified Configuration for Solaris Operating Environment (SPARC 32-bit) version 8.
Table 2-9 Software Packages for Solaris Operating System (SPARC 32-bit) Version 8
| Packages | Version | Description |
| SFWexpct | 5.31 | Expect |
| SFWsudo | 1.6.5 | Sudo |
| SFWtcl | 8.3.2 | TCL |
| SFWtk | 8.3.2 | TK |
| SUNWarc | 11.8.0 | Archive Libraries |
| SUNWbtool | 11.8.0 | CCS tools bundled with SunOS |
| SUNWhea | 11.8.0 | SunOS header files |
| SUNWj3dev | 1.4.2 | Java 2 SDK |
| SUNWlibm | 5.8 | Sun WorkShop Bundled libm |
| SUNWlibms | 5.8 | Sun WorkShop Bundled shared libm |
| SUNWmfrun | 2.1.1 | Motif |
| SUNWpl5u | 11.8.0 | Perl |
| SUNWsprot | 5.8 | Solaris Bundled Tools |
| SUNWtoo | 11.8.0 | Programming tools |
| SUNWzip | 11.8.0 | Zip |
| Unzip | 5.42 | Unzip |
Table 2-10 lists the software packages required for Oracle E-Business Suite Certified Configuration for Solaris Operating Environment (SPARC 32-bit) version 9.
Table 2-10 Software Packages for Solaris Operating System (SPARC 32-bit) Version 9
| SUNWarc | 11.9.0 | Archive Libraries |
| SUNWbtool | 11.9.0 | CCS tools bundled with SunOS |
| SUNWhea | 11.9.0 | SunOS header files |
| SUNWlibm | 5.9 | Sun WorkShop Bundled libm |
| SUNWlibms | 5.9 | Sun WorkShop Bundled shared libm |
| SUNWmfrun | 2.1.2 | Motif |
| SUNWpl5u | 11.9.0 | Perl |
| SUNWsprot | 5.9 | Solaris Bundled Tools |
| SUNWtoo | 11.9.0 | Programming tools |
| SUNWzip | 11.9.0 | Zip |
The following sections contain kernel parameter settings necessary to run Oracle E-Business Suite Certified Configuration.
Table 2-11 lists the kernel parameters required for Oracle E-Business Suite Certified Configuration for hp-ux PA-RISC (64-bit).
Table 2-11 Kernel Parameters for hp-ux PA-RISC (64-bit)
| Parameter | Value | Description |
| eqmemsize | 512 | Space reserved for equivalently mapped entry |
| max_async_ports | 150 | Maximum async ports |
| max_thread_proc | 256 | Maximum number of thread processes |
| maxdsiz | 0x4BC00000 | Maximum data segment size |
| maxfiles | 2048 | Maximum number of files |
| maxfiles_lim | 2048 | Hard file limit per process |
| maxssiz | 0x10000000 | Maximum segment size |
| maxssiz_64bit | 0x10000000 | Maximum segment size (64 bit) |
| maxswapchunks | 12539 | Maximum swap chunks |
| maxuprc | 3686 | Maximum processes per user |
| maxusers | 512 | Maximum number of users |
| maxvgs | 80 | Maximum number of volume groups configured by cvm on system |
| msgmax | 32768 | Maximum message size |
| msgmnb | 65535 | Maximum number of bytes on queue |
| msgmni | 4096 | Number of message queue identifiers |
| msgseg | 32767 | Number of message segments in a message queue |
| msgssz | 128 | Message segment size in bytes |
| msgtql | 32767 | Number of system message header |
| nflocks | 4096 | Maximum number of file locks available to system |
| nstrtel | 200 | Maximum number of telnet sessions |
| nswapdev | 25 | Maximum number of swap devices |
| semmni | 4098 | Number of semaphore identifiers |
| semmns | 8192 | Maximum number of semaphores |
| semmnu | 4112 | Number of undo structures in the system |
| semume | 64 | Maximum number of undo entries per process |
| shmmax | 0x40000000 | Maximum size per shared memory segment (bytes) |
| shmmni | 1024 | Number of shared memory identifiers |
| shmseg | 128 | Shared memory segments per process |
| swchunk | 4096 | Size of each chunk created on service devices or file systems |
| unlockable_mem | 2000 | Amount of non-lockable memory |
Table 2-12 lists the kernel parameters required for Oracle E-Business Suite Certified Configuration for Red Hat AS/ES 2.1 and 3.0, and SUSE LINUX Enterprise Server 9.
Table 2-12 Kernel Parameters for Linux x86
| Kernel Parameter | Value | Description |
| SEMMNI | 128 | Number of semaphore identifiers |
| SEMMNS | 32000 | Maximum number of semaphores |
| SEMMSL | 1000 | Maximum number of semaphores per semaphore set |
| SEMOPM | 100 | Maximum number of operations per semop call
| SHMMAX | 1073741824 | Maximum size per shared memory segment (bytes) |
| SHMMNI | 100 | Number of shared memory identifiers |
| nofile | 65535 | The hard limit entry for the number of open files should be defined in the /etc/security/limits.conf file.
Table 2-13 lists the kernel parameters required for Oracle E-Business Suite Certified Configuration for Solaris Operating Environment (SPARC 32-bit).
Table 2-13 Kernel Parameters for Solaris Operating System (SPARC 32-bit)
| Kernel Parameter | Value | Purpose |
| MSGMAX | 16384 | Maximum message size |
| MSGMNB | 16384 | Maximum number of bytes on queue |
| MSGMNI | 2200 | Number of message queue identifiers |
| MSGTQL | 2500 | Number of system message header |
| SEMMNI | 100 | Number of semaphore identifiers |
| SEMMNS | 2500 | Maximum number of semaphores |
| SEMMNU | 2500 | Number of undo structures in the system |
| SEMMSL | 300 | Maximum number of semaphores per semaphore set |
| SEMUME | 2500 | Maximum number of undo entries per process |
| SEMVMX | 32767 | Maximum value of a semaphore |
| SHMMAX | 4294967295 | Maximum size per shared memory segment (bytes) |
| SHMMIN | 1 | Minimum size per shared memory segment |
| SHMSEG | 32 | Shared memory segments per process |
Verify that your system meets the following partitioning requirements before you install Oracle E-Business Suite Certified Configuration.
Table 2-14 lists the mount points for an Oracle Applications 11i environment.
Table 2-14 Oracle Applications 11i Partitioning Requirements
| Type | Mount Points | Size |
| Oracle | /mount_point/oracle
5 GB |
/mount_point/oradata
35 GB (Production)
70 GB (Vision Demo) |
/mount_point/arch
3 GB | |
/mount_point/backupFoot 1
30 GB | |
| Applications | /mount_point/applmgrFoot 2
20 GB |
/mount_point/applcsf
3 GB | |
/mount_point /product
7 GB | |
| CC Stage Area/tools | /admin
10 GB |
/oem
2 GB |
/stage
20 GB |
/interface
1 GB |
applmgr mount point for each language.Oracle E-Business Suite Certified Configuration requires you to create certain users and groups based on instance type (Test, Development, Stage, or Production) and customer short code before starting installation.
Table 2-15 provides examples of users, groups, passwords, and directory structure for the Oracle Applications 11i Test environment, where the customer short code is abcd.
Use the following procedure to validate that your system meets the minimum requirements before proceeding with the installation of Oracle E-Business Suite Certified Configuration.
Log in as the root user.
Create the /admin/ebso directory as the root user, if the directory does not exist.
Install the Oracle E-Business Suite Certified Configuration Utility Pack to the /admin/ebso directory from an NFS mount location or from the DVD-ROM.
To install from an NFS mount location, enter the following command syntax:
# mkdir /stage # mount cclibrary:/vol/LTrepos/CCrepos/<platform>/EBizCC/11510/NFS /stage # cd /stage/StartCD/Disk1/ebso/install # ./setup.sh
In the preceding syntax, replace <platform> with the system on which you are staging the installation.
When prompted for the location of the EBSO_HOME, press Enter to accept the default value, /admin/ebso.
Unmount the /stage directory, using the following commands:
# cd / # umount /stage
To install from DVD-ROM, insert the Start Here CD DVD-ROM into the DVD-ROM drive, and start the installation, using the relevant commands for your platform:
AIX Based Systems
# mount -r -v cdrfs /dev/cd0 /cdrom # cd /cdrom/Disk1/ebso/install # ./setup.sh
# nohup /usr/sbin/pfs_mountd & # nohup /usr/sbin/pfsd & # usr/sbin/pfs_mount -t rrip -z unix /dev/dsk/c5t2d0 /SD_cdrom # cd /SD_CDROM/Disk1/ebso/install # ./setup.sh
Linux x86
# mount -t iso9660 /dev/cdrom /cdrom # cd /cdrom/Disk1/ebso/install # ./setup.sh
# mount -r -F hsfs /dev/dsk/c0t6d0s2 /cdrom # cd /cdrom/Disk1/ebso/install # ./setup.sh
Unmount the DVD-ROM, using the relevant commands for your platform:
AIX Based Systems
# cd / # umount /cdrom
# cd / # /usr/sbin/pfs_umount /cdrom
Linux x86
You can install Oracle E-Business Suite Certified Configuration on existing hardware with an existing operating system, if the hardware and operating system meet the minimum requirements. The media kit includes the ocheck validation script that checks the hardware and operating system before you install Oracle E-Business Suite Certified Configuration.
To verify if your system meets Oracle E-Business Suite Certified Configuration requirements, log in as the root user, and run the ocheck script from the directory /admin/ebso/ocheck. You can run the ocheck script with or without capturing the output in a log file, as follows:
To run the ocheck script without capturing the output in a log file, use the following command:
# ./ocheck -product ebiz -preinstall -prettyprint -relaxed
To run the ocheck script while generating a log file, use the following command, substituting a log file name for output_filename:
# ./ocheck -product ebiz -preinstall -prettyprint -o output_filename -relaxed
Note: Theocheck validation script does not check disk partitions required for Oracle software.
All the failures reported by the ocheck script must be corrected. Otherwise, the installation of Oracle E-Business Suite Certified Configuration might not succeed.
