Skip Headers
Oracle® Application Development Framework Developer's Guide For Forms/4GL Developers
10g Release 3 (10.1.3.0)
B25947-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
34.12 Installing ADF Runtime Library on Third-Party Application Servers
Before you can deploy applications that use ADF on third-party application servers, you need to install the ADF runtime libraries on those application servers. You can perform the installation using a wizard or you can do it manually:
34.12.1 Installing the ADF Runtime Libraries from JDeveloper
You can install the ADF runtime libraries from JDeveloper on selected application servers. The supported application servers are listed in the Tools > ADF Runtime Installer submenu.
Note that for WebSphere, you need to install the libraries manually. See Section 34.12.2, "Configuring WebSphere 6.0.1 to Run ADF Applications".
To install the ADF Runtime Libraries from JDeveloper:
  1. Stop all instances of the target application server.
  2. (WebLogic only) Create a new WebLogic domain, if you do not already have one. You will install the ADF runtime libraries in the domain.
    Steps for creating a domain in WebLogic are provided here for your convenience.
    The domain must be configured to use Sun's JDK.
    Steps for Creating Domains in WebLogic 8.1:
    1. From the Start menu, choose Programs > BEA WebLogic Platform 8.1 > Configuration Wizard. This starts up the Configuration wizard.
    2. On the Create or Extend a Configuration page, select Create a new WebLogic Configuration. Click Next.
    3. On the Select a Configuration Template page, select Basic WebLogic Server Domain. Click Next.
    4. On the Choose Express or Custom Configuration page, select Express. Click Next.
    5. On the Configure Administrative Username and Password page, enter a username and password. Click Next.
    6. On the Configure Server Start Mode and Java SDK page, make sure you select Sun's JDK. Click Next.
    7. On the Create WebLogic Configuration page, you can change the domain name. For example, you might want to change it to jdevdomain.
    Steps for Creating Domains in WebLogic 9.0:
    1. From the Start menu, choose Programs > BEA Products > Tools > Configuration Wizard. This starts up the Configuration wizard.
    2. On the Welcome page, select Create a new WebLogic Domain. Click Next.
    3. On the Select a Domain Source page, select Generate a domain configured automatically to support the following BEA products. Click Next.
    4. On the Configure Administrator Username and Password page, enter a username and password. Click Next.
    5. On the Configure Server Start Mode and JDK page, make sure you select Sun's JDK. Click Next.
    6. On the Customize Environment and Services Settings page, select No. Click Next.
    7. On the Create WebLogic Domain page, set the domain name. For example, you might want to set it to jdevdomain. Click Create.
  3. Start the ADF Runtime Installer wizard by choosing Tools > ADF Runtime Installer > Application_Server_Type. Application_Server_Type is the type of the target application server (for example, Oracle Application Server, WebLogic, JBoss, or standalone OC4J).
  4. Proceed through the pages in the wizard. For detailed instructions for any page in the wizard, click Help. You need to enter the following information in the wizard:
    • On the Home Directory page, select the home or root directory of the target application server.
    • (WebLogic only) On the Domain Directory page, select the home directory of the WebLogic domain where you want to install the ADF libraries. You created this domain in step 2.
    • On the Installation Options page, choose Install the ADF Runtime Libraries.
    • On the Summary page, check the details and click Finish.
  5. (WebLogic only) Edit WebLogic startup files so that WebLogic includes the ADF runtime library when it starts up.
    Steps for WebLogic 8.1:
    1. Make a backup copy of the WEBLOGIC_HOME\user_projects\domains\jdevdomain\startWebLogic.cmd (or startWebLogic.sh) file because you will be editing it in the next step. "jdevdomain" is the name of the domain that you created earlier in step 2.
    2. In the startWebLogic.cmd (or startWebLogic.sh) file, add the "call "setupadf.cmd"" line (for Windows) before the "set CLASSPATH" line:
      call "setupadf.cmd"
      set CLASSPATH=%WEBLOGIC_CLASSPATH%;%POINTBASE_CLASSPATH%;
              %JAVA_HOME%\jre\lib\rt.jar;%WL_HOME%\server\lib\webservices.jar;
              %CLASSPATH%
      The setupadf.cmd script was installed by the ADF Runtime Installer wizard in the WEBLOGIC_HOME\user_projects\domains\jdevdomain directory.
    3. To start WebLogic, change directory to the jdevdomain directory and run startWebLogic.cmd:
      > cd WEBLOGIC_HOME\user_projects\domains\jdevdomain
      > startWebLogic.cmd
    Steps for WebLogic 9.0:
    1. Make a backup copy of the %DOMAIN_HOME%\bin\setDomainEnv.cmd file because you will be editing it in the next step.
      %DOMAIN_HOME% is specified in the startWebLogic.cmd (or startWebLogic.sh) file. For example, if you named your domain jdevdomain, then %DOMAIN_HOME% would be BEA_HOME\user_projects\domains\jdevdomain. You created the domain earlier in step 2.
    2. In the %DOMAIN_HOME%\bin\setDomainEnv.cmd file, add the "call "%DOMAIN_HOME%\setupadf.cmd"" line before the "set CLASSPATH" line:
      set CLASSPATH=%PRE_CLASSPATH%;%WEBLOGIC_CLASSPATH%;%POST_CLASSPATH%;
          %WLP_POST_CLASSPATH%;%WL_HOME%\integration\lib\util.jar;%CLASSPATH%
    3. If the "set CLASSPATH" line does not have %CLASSPATH%, then add it to the line, as shown above.
    4. To start WebLogic, change directory to %DOMAIN_HOME% and run startWebLogic.cmd:
      > cd %DOMAIN_HOME%
      > startWebLogic.cmd
  6. (WebLogic only) Before you run JDeveloper, configure JDeveloper to include the WebLogic client in its class path.
    1. Make a backup copy of the JDEVELOPER_HOME\jdev\bin\jdev.conf file because you will be editing it in the next step.
    2. Add the following line to the jdev.conf file:
      AddJavaLibFile <WEBLOGIC_HOME>\server\lib\weblogic.jar
      Replace <WEBLOGIC_HOME> with the fullpath to the directory where you installed WebLogic.
  7. Restart the target application server. If you are running WebLogic, you may have already started up the server.
Managing Multiple Versions of the ADF Runtime Library
Application servers may contain different versions of the ADF runtime libraries, but at any time only one version (the active version) is accessible to deployed applications. The other versions are archived.
You can use the ADF Runtime Installer wizard to make a different version the active version. On the Installation Options page in the wizard, choose the Restore option.
34.12.2 Configuring WebSphere 6.0.1 to Run ADF Applications
Before you can run ADF applications on WebSphere 6.0.1, you have to perform these steps:
  1. Create the install_adflibs_1013.sh (or .cmd on Windows) script, as follows:
    If you are running on UNIX:
    1. Copy the source shown in Section 34.12.2.1, "Source for install_adflibs_1013.sh Script" and paste it to a file. Save the file as install_adflibs_1013.sh.
    2. Enable execute permission on install_adflibs_1013.sh.
      > chmod a+x install_adflibs_1013.sh
    If you are running on Windows, copy the source shown in Section 34.12.2.2, "Source for install_adflibs_1013.cmd Script" and paste it to a file. Save the file as install_adflibs_1013.cmd.
    You will run the script later, in step 3.
  2. Stop the WebSphere processes.
  3. Run the install_adflibs_1013.sh (.cmd on Windows) script to install the ADF libraries, as follows:
    1. Set the ORACLE_HOME environment variable to point to the JDeveloper installation.
    2. Set the WAS_ADF_LIB environment variable to point to the location where you want to install the ADF library files. Typically this is the WebSphere home directory. The library files are installed in the WAS_ADF_LIB/lib and WAS_ADF_LIB/jlib directories.
    3. Run the script. <script_dir> refers to the directory where you created the script.
      > cd <script_dir>
      > install_adflib_1013.sh           // if on Windows, use the .cmd extension
  4. Start WebSphere processes.
  5. Use the WebSphere administration tools to create a new shared library. Depending on your application, you create one of the shared libraries below.
    • For applications that use Oracle SQL flavor and type map, create the ADF10.1.3-Oracle shared library:
      Set the name of the shared library to ADF10.1.3-Oracle.
      Set the classpath to include all the JAR files in WAS_ADF_LIB\lib and WAS_ADF_LIB\jlib except for WAS_ADF_LIB\jlib\bc4jdomgnrc.jar. This JAR file is used for generic type mappings.
      WAS_ADF_LIB refers to the directory that will be used as a library defined in the WebSphere console. WAS_ADF_LIB contains the ADF library files.
    • For applications that use non-Oracle SQL flavor and type map, create the ADF10.1.3-Generic shared library:
      Set the name of the shared library to ADF10.1.3-Generic.
      Set the classpath to include WAS_ADF_LIB\jlib\bc4jdomgnrc.jar and all the JAR files in WAS_ADF_LIB\lib except for bc4jdomorcl.jar. WAS_ADF_LIB refers to the directory that will be used as a library defined in the WebSphere console. WAS_ADF_LIB contains the ADF library files.
  6. Add the following parameter in the Java command for starting up WebSphere.
    -Djavax.xml.transform.TransformerFactory=org.apache.xalan.processor.TransformerFactoryImpl
  7. Shut down and restart WebSphere so that it uses the new parameter.
34.12.2.1 Source for install_adflibs_1013.sh Script
Example 34-1 shows the source for the install_adflibs_1013.sh script. Instead of copying the ADF runtime library files manually to your WebSphere environment, you can use this script. See Section 34.12.2, "Configuring WebSphere 6.0.1 to Run ADF Applications" for details.
The install_adflibs_1013.sh script is for use on UNIX environments. If you are running on Windows, see Section 34.12.2.2, "Source for install_adflibs_1013.cmd Script".
Example 34-1 install_adflibs_1013.sh
#!/bin/sh
EXIT=0
if [ "$ORACLE_HOME" = "" ]
  then
    echo "Error: The ORACLE_HOME environment variable must be set before executing this script."
    echo "This should point to your JDeveloper installation directory"
    EXIT=1
fi
if [ "$WAS_ADF_LIB" = "" ];
  then
    echo "Error: The WAS_ADF_LIB environment variable must be set before executing this script."
    echo "This should point to the location where you would like the ADF jars to be copied."
    EXIT=1
fi
if [ "$EXIT" -eq 0 ]
then
if [ ! -d $WAS_ADF_LIB ]; then
  mkdir $WAS_ADF_LIB
fi
if [ ! -d $WAS_ADF_LIB/lib ]; then
  mkdir $WAS_ADF_LIB/lib
fi
if [ ! -d $WAS_ADF_LIB/jlib ]; then
  mkdir $WAS_ADF_LIB/jlib
fi
# Core BC4J runtime
cp $ORACLE_HOME/BC4J/lib/adfcm.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/adfm.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/adfmweb.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/adfshare.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jct.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jctejb.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jdomorcl.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jimdomains.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jmt.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/lib/bc4jmtejb.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/jlib/dc-adapters.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/jlib/adf-connections.jar  $WAS_ADF_LIB/lib/
#  Core BC4J jlib runtime
cp $ORACLE_HOME/BC4J/jlib/bc4jdomgnrc.jar $WAS_ADF_LIB/jlib/
cp $ORACLE_HOME/BC4J/jlib/adfui.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/BC4J/jlib/adfmtl.jar $WAS_ADF_LIB/lib/
#  Oracle Home jlib runtime
cp $ORACLE_HOME/jlib/jdev-cm.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/jlib/jsp-el-api.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/jlib/oracle-el.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/jlib/commons-el.jar $WAS_ADF_LIB/lib/
#  Oracle MDS runtime
cp $ORACLE_HOME/jlib/commons-cli-1.0.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/jlib/xmlef.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/mds/lib/mdsrt.jar $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/mds/lib/concurrent.jar $WAS_ADF_LIB/lib/
#  Oracle Diagnostic
cp %ORACLE_HOME%/diagnostics/lib/commons-cli-1.0.jar $WAS_ADF_LIB/lib/
#  SQLJ Runtime
cp $ORACLE_HOME/sqlj/lib/translator.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/sqlj/lib/runtime12.jar  $WAS_ADF_LIB/lib/
#  Intermedia Runtime
cp $ORACLE_HOME/ord/jlib/ordhttp.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/ord/jlib/ordim.jar  $WAS_ADF_LIB/lib/
#  OJMisc
cp $ORACLE_HOME/jlib/ojmisc.jar  $WAS_ADF_LIB/lib/
#  XML Parser
cp $ORACLE_HOME/lib/xmlparserv2.jar  $WAS_ADF_LIB/lib/
#  JDBC
cp $ORACLE_HOME/jdbc/lib/ojdbc14.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/jdbc/lib/ojdbc14dms.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/lib/dms.jar  $WAS_ADF_LIB/lib/
#  XSQL Runtime
cp $ORACLE_HOME/lib/xsqlserializers.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/lib/xsu12.jar  $WAS_ADF_LIB/lib/
cp $ORACLE_HOME/lib/xml.jar  $WAS_ADF_LIB/lib/
fi
34.12.2.2 Source for install_adflibs_1013.cmd Script
Example 34-2 shows the source for the install_adflibs_1013.cmd script. Instead of copying the ADF runtime library files manually to your WebSphere environment, you can use this script. See Section 34.12.2, "Configuring WebSphere 6.0.1 to Run ADF Applications" for details.
The install_adflibs_1013.cmd script is for use on Windows environments. If you are running on UNIX, see Section 34.12.2.1, "Source for install_adflibs_1013.sh Script".
Example 34-2 install_adflibs_1013.cmd
@echo off
if {%ORACLE_HOME%} =={} goto :oracle_home
if {%WAS_ADF_LIB%} =={} goto :was_adf_lib
mkdir %WAS_ADF_LIB%
mkdir %WAS_ADF_LIB%\lib
mkdir %WAS_ADF_LIB%\jlib
@REM Core BC4J runtime
copy %ORACLE_HOME%\BC4J\lib\adfcm.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\adfm.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\adfmweb.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\adfshare.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jct.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jctejb.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jdomorcl.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jimdomains.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jmt.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\bc4jmtejb.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\collections.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\lib\adfbinding.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\jlib\dc-adapters.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\jlib\adf-connections.jar  %WAS_ADF_LIB%\lib\
@REM Core BC4J jlib runtime
copy %ORACLE_HOME%\BC4J\jlib\bc4jdomgnrc.jar %WAS_ADF_LIB%\jlib\
copy %ORACLE_HOME%\BC4J\jlib\adfui.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\BC4J\jlib\adfmtl.jar %WAS_ADF_LIB%\lib\
@REM Oracle Home jlib runtime
copy %ORACLE_HOME%\jlib\jdev-cm.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\jlib\jsp-el-api.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\jlib\oracle-el.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\jlib\commons-el.jar %WAS_ADF_LIB%\lib\
@REM Oracle MDS runtime
copy %ORACLE_HOME%\jlib\commons-cli-1.0.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\jlib\xmlef.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\mds\lib\mdsrt.jar %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\mds\lib\concurrent.jar %WAS_ADF_LIB%\lib\
@REM Oracle Diagnostic
copy %ORACLE_HOME%\diagnostics\lib\ojdl.jar %WAS_ADF_LIB%\lib\
@REM SQLJ Runtime
copy %ORACLE_HOME%\sqlj\lib\translator.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\sqlj\lib\runtime12.jar  %WAS_ADF_LIB%\lib\
@REM Intermedia Runtime
copy %ORACLE_HOME%\ord\jlib\ordhttp.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\ord\jlib\ordim.jar  %WAS_ADF_LIB%\lib\
@REM OJMisc
copy %ORACLE_HOME%\jlib\ojmisc.jar  %WAS_ADF_LIB%\lib\
@REM XML Parser
copy %ORACLE_HOME%\lib\xmlparserv2.jar  %WAS_ADF_LIB%\lib\
@REM JDBC
copy %ORACLE_HOME%\jdbc\lib\ojdbc14.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\jdbc\lib\ojdbc14dms.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\lib\dms.jar  %WAS_ADF_LIB%\lib\
@REM XSQL Runtime
copy %ORACLE_HOME%\lib\xsqlserializers.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\lib\xsu12.jar  %WAS_ADF_LIB%\lib\
copy %ORACLE_HOME%\lib\xml.jar  %WAS_ADF_LIB%\lib\
goto :end
:oracle_home
@echo Set the ORACLE_HOME pointing to the directory of your 10.1.3 JDeveloper installation.
:was_adf_lib
if {%WAS_ADF_LIB%} =={} @echo Set the WAS_ADF_LIB environment variable pointing to the directory where you would like to install ADF libraries.
:end
34.12.3 Installing the ADF Runtime Libraries Manually
Instead of using the ADF Runtime Installer wizard in JDeveloper to install the libraries, you can also install the libraries manually on your target application server.
Table 34-8 lists the files that you must copy to your application server before you deploy any ADF applications. In the table, JDEV_INSTALL refers to the directory where you installed JDeveloper.
  • For JBoss, the destination directory is JBOSS_HOME/server/default/lib.
  • For WebLogic, the destination directory is WEBLOGIC_HOME/ADF/lib. You have to create the ADF directory, and under it, the lib and jlib directories.
  • For Tomcat, the destination directory is TOMCAT_HOME/common/lib.
Table 34-8 ADF Runtime Library Files to Copy
Copy These Files: Notes
From JDEV_INSTALL/BC4J/lib:
  • adfcm.jar
  • adfm.jar
  • adfmweb.jar
  • adfshare.jar
  • bc4jct.jar
  • bc4jctejb.jar
  • bc4jdomorcl.jar or bc4jdomgnrc.jar
    Note: Only one of these files is required, depending on which mapping type you used to build your application. If you are using the Oracle type mappings, copy bc4jdomorcl.jar. If the application was built using "Java" type mappings, copy bc4jdomgnrc.jar instead. bc4jdomgnrc.jar is located in JDEV_INSTALL/BC4J/jlib.
  • bc4jimdomains.jar
  • bc4jmt.jar
  • bc4jmtejb.jar
  • collections.jar
  • adfbinding.jar
These are the ADF runtime library files.
From JDEV_INSTALL/BC4J/jlib:
  • adfmtl.jar
  • bc4jdomgnrc.jar (see the note above)
  • adfui.jar
From JDEV_INSTALL/jlib:
  • jdev-cm.jar
  • commons-el.jar
  • oracle-el.jar
  • jsp-el-api.jar
These are the JDeveloper runtime library files.
  • commons-cli-1.0.jar
  • xmlef.jar
From JDEV_INSTALL/mds/lib:
  • mdsrt.jar
  • concurrent.jar
These are the Oracle MDS files.
From JDEV_INSTALL/diagnostics/lib:
  • ojdl.jar
These are the Oracle diagnostics files.
  • ojmisc.jar
These are the OJMisc runtime files.
From JDEV_INSTALL/lib:
  • xmlparserv2.jar
This file is for XML support.
  • xml.jar
  • xsqlserializers.jar
  • xsu12.jar
These are the XSQL library files.
From JDEV_INSTALL/ord/jlib:
  • ordhttp.jar
  • ordim.jar
These files are for interMedia Text support. interMedia Text is a feature for storing, retrieving, and manipulating audio, document, image, and video data in an Oracle database.
From JDEV_INSTALL/sqlj/lib:
  • runtime12.jar
  • translator.jar
These are the SQLJ runtime library files.
From JDEV_INSTALL/jdbc/lib:
  • ojdbc14.jar
  • ojdbc14dms.jar
  • dms.jar
These are the JDBC runtime library files.
From JDEV_INSTALL/javacache/lib:
  • cache.jar
These are the Java Cache runtime library files.
From JDEV_INSTALL/BC4J/redist:
  • webapp.war or bc4j.ear
This file is for Business Components web application image and cascading style sheet support.
If you are running Tomcat, copy the webapp.war file to the TOMCAT_HOME/webapps directory.
If you are running JBoss, copy the bc4j.ear file to the JBOSS_HOME/server/default/deploy directory.
The destination directory (the directory to which you copy these files) depends on your application server:
34.12.3.1 Installing the ADF Runtime Libraries from a Zip File
You can also install the ADF runtime libraries by downloading adfinstaller.zip from OTN and following the directions below.
To install the ADF Runtime Libraries:
  1. To initiate the download, go to the JDeveloper Download page on OTN, here:
    http://www.oracle.com/technology/software/products/jdev/index.html
    Unzip adfinstaller.zip to the target directory.
  2. Set the DesHome variable in the adfinstaller.properties file to specify the home directory of the destination application server:
    For example:
    Oracle AS: DesHome=c:\\oas1013
    OC4J: DesHome=c:\\oc4j
    JBoss: DesHome=c:\\jboss-4.0.3
    Tomcat: DesHome=c:\\jakarta-tomcat-5.5.9
    WebLogic: DesHome=c:\\bea\weblogic90 (note server home directory is in weblogic subdirectory)
  3. Set the type variable in the adfinstaller.properties file to specify the platform for the application server where the ADF libraries are to be installed. The choices are OC4J/AS/TOMCAT/JBOSS/WEBLOGIC.
    For example:
    type=AS
  4. Set the UserHome variable in the adfinstaller.properties file to specify the WebLogic domain for which ADF is being configured. This setting is only used for WebLogic, and ignored for all other platforms. For example:
    UserHome= c:\\bea\weblogic90\\user_projects\\domains\\adfdomain
  5. Shut down all instances of the application server running on the target platform.
  6. Run the following command if you only wish to see the version of the ADF Installer:
    java -jar runinstaller.jar –version
  7. Run the following command on the command line prompt:
    java -jar runinstaller.jar adfinstaller.properties
34.12.4 Deleting the ADF Runtime Library
If you used the wizard to install the ADF runtime library, you should use the wizard to delete the library. On the Installation Options page in the wizard, choose the Delete option.
If you installed the ADF runtime library manually, you can just manually delete the files from your application server.
