| Oracle® Data Provider for .NET Developer's Guide 10g Release 2 (10.2.0.2) B28089-01 |
![]() Previous |
![]() Next |
An OracleConnection object represents a connection to an Oracle database.
Class Inheritance
System.Object
System.MarshalByRefObject
System.ComponentModel.Component
System.Data.Common.DbConnection (ADO.NET 2.0 only)
Oracle.DataAccess.Client.OracleConnection
Declaration
// ADO.NET 2.0: C# public sealed class OracleConnection : DbConnection, IDbConnection, ICloneable
// ADO.NET 1.x: C#
public sealed class OracleConnection : Component, IdbConnection, ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleConnectionSample
static void Main()
// Connect
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
// Execute a SQL SELECT
OracleCommand cmd = con.CreateCommand();
cmd.CommandText = "select * from emp";
OracleDataReader reader = cmd.ExecuteReader();
// Print all employee numbers
while (reader.Read())
Console.WriteLine(reader.GetInt32(0));
// Clean up
reader.Dispose();
cmd.Dispose();
con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.x or 2.0
OracleConnection members are listed in the following tables:
OracleConnection Constructors
OracleConnection constructors are listed in Table 5-17.
Table 5-17 OracleConnection Constructors
| Constructor | Description |
Instantiates a new instance of the |
OracleConnection Static Properties
The OracleConnection static property is listed in Table 5-19.
Table 5-18 OracleConnection Static Property
| Property | Description |
Indicates whether or not the implicit database connection is available for use |
OracleConnection Static Methods
The OracleConnection static method is listed in Table 5-19.
Table 5-19 OracleConnection Static Method
| Method | Description |
Inherited from |
OracleConnection Properties
OracleConnection properties are listed in Table 5-20
Table 5-20 OracleConnection Properties
| Name | Description |
Specifies the client identifier for the connection |
Specifies connection information used to connect to an Oracle database |
Specifies the maximum amount of time that the |
Inherited from |
Not Supported |
Specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect |
Specifies the version number of the Oracle database to which the |
Inherited from |
Specifies the current state of the connection |
OracleConnection Public Methods
OracleConnection public methods are listed in Table 5-21.
Table 5-21 OracleConnection Public Methods
| Public Method | Description |
Begins a local transaction (Overloaded) Not supported in a .NET stored procedure |
Not Supported |
Creates a copy of an Not supported in a .NET stored procedure |
Closes the database connection |
Creates and returns an |
Inherited from |
Inherited from |
Enables applications to explicitly enlist in a specified distributed transaction Not supported in a .NET stored procedure |
Enables applications to enlist in a specified distributed transaction Supported Only in ADO.NET 2.0-Compliant ODP.NET Not supported in a .NET stored procedure |
Inherited from |
Inherited from |
Inherited from |
Returns schema information for the data source of the Supported Only in ADO.NET 2.0-Compliant ODP.NET |
Returns or refreshes the property values of the |
Inherited from |
Inherited from |
Opens a database connection with the property settings specified by the |
Opens a new connection with the new password Not supported in a .NET stored procedure |
Flushes the Statement Cache by closing all open cursors on the database, when statement caching is enabled |
Alters the session's globalization settings with the property values provided by the |
Inherited from |
OracleConnection Events
OracleConnection events are listed in Table 5-22.
Table 5-22 OracleConnection Events
| Event Name | Description |
Inherited from |
An event that is triggered when an Oracle failover occurs Not supported in a .NET stored procedure |
An event that is triggered for any message or warning sent by the database |
An event that is triggered when the connection state changes |
OracleConnection constructors instantiate new instances of the OracleConnection class.
Overload List:
This constructor instantiates a new instance of the OracleConnection class using default property values.
This constructor instantiates a new instance of the OracleConnection class with the provided connection string.
Declaration
// C# public OracleConnection();
Remarks
The properties for OracleConnection are set to the following default values:
ConnectionString = empty string
ConnectionTimeout = 15 (default value of 0 is used for the implicit database connection)
DataSource = empty string
ServerVersion = empty string
Declaration
// C#
public OracleConnection(String connectionString);
Parameters
connectionString
The connection information used to connect to the Oracle database.
Remarks
The ConnectionString property is set to the supplied connectionString. The ConnectionString property is parsed and an exception is thrown if it contains invalid connection string attributes or attribute values.
The properties of the OracleConnection object default to the following values unless they are set by the connection string:
The OracleConnection static property is listed in Table 5-23.
Table 5-23 OracleConnection Static Property
This property indicates whether or the implicit database connection is available for use.
Declaration
// C#
public static bool IsAvailable {get;}
Property Value
Returns true if the implicit database connection is available for use.
Remarks
The availability of the implicit database connection can be checked at runtime through this static property. When Oracle Data Provider for .NET is used within a .NET stored procedure, this property always returns true. Otherwise, false is returned.
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method.
Note that not all features that are available for an explicit user connection are available for an implicit database connection. See "Implicit Database Connection" for details.
Example
// C# (Library/DLL)
using System;
public class IsAvailableSample
static void MyStoredProcedure()
OracleConnection con = new OracleConnection();
if (OracleConnection.IsAvailable)
// This function is invoked as a stored procedure
// Obtain the implicit database connection by setting
// "context connection=true" in the connection string
con.ConnectionString = "context connection=true";
else
// This function is not invoked as a stored procedure
// Set the connection string for a normal client connection
con.ConnectionString = "user id=scott;password=tiger;data source=oracle";
con.Open();
Console.WriteLine("connected!");
The OracleConnection static method is listed in Table 5-24.
Table 5-24 OracleConnection Static Method
Inherited from |
This method clears the connection pool that is associated with the provided OracleConnection object.
Declaration
// C# public static void ClearPool(OracleConnection connection);
Remarks (Oracle.DataAccess.Client only)
When this method is invoked, all idle connections are closed and freed from the pool. Currently used connections remain usable and will be placed back into the pool when the user invokes Close() on the OracleConnection object.
The connection pool is usable once this method is invoked. Therefore, connection requests succeed even after the invocation of this method. Connections created after this method invocation are not cleared unless another invocation is made.
This method can be invoked with an OracleConnection object before opening the connection as well as after, provided the ConnectionString is properly set.
Exceptions
InvalidOperationException – Either the connection pool cannot be found or the provided connection string is invalid.
Example (Oracle.DataAccess.Client only)
// C#
// Sample demonstrating the use of ClearPool API in OracleConnection class
using System;
class ClearPoolSample
static void Main()
Console.WriteLine("Running ClearPool sample..." );
string strConn = "User Id=scott;Password=tiger;Data Source=oracle;" +
"Min pool size=5;";
OracleConnection conn = new OracleConnection(strConn);
// Open the connection
conn.Open();
// Clears the connection pool associated with connection 'conn'
OracleConnection.ClearPool (conn);
// This connection will be placed back into the pool
conn.Close ();
// Open the connection again to create additional connections in the pool
conn.Open();
// Create a new connection object
OracleConnection connNew = new OracleConnection(strConn);
// Clears the pool associated with Connection 'connNew'
// Since the same connection string is set for both the connections,
// connNew and conn, they will be part of the same connection pool.
// We need not do an Open() on the connection object before calling
// ClearPool
OracleConnection.ClearPool (connNew);
// cleanup
conn.Close();
Console.WriteLine("Done!");
add this back into the tables, include supported only by client
This method clears all connections from all the connection pools.
Declaration
// C# public static void ClearAllPools();
This call is analogous to calling ClearPool for all the connection pools that are created for the application.
Exceptions
InvalidOperationException – No connection pool could be found for the application.
Example
// C#
// Sample demonstrating the use of ClearAllPools API in OracleConnection class
using System;
class ClearAllPoolsSample
static void Main()
Console.WriteLine("Running ClearAllPools sample..." );
"Min pool size=5;";
// Create another connection object with a different connection string
string strConnNew = "User Id=scott;Password=tiger;Data Source=oracle;";
OracleConnection connNew = new OracleConnection(strConnNew);
// Open the connections. Separate pools are created for conn and connNew
conn.Open();
connNew.Open();
// Clears the pools associated with conn and connNew
OracleConnection.ClearAllPools ();
// cleanup
conn.Close();
connNew.Close();
OracleConnection properties are listed in Table 5-25
Table 5-25 OracleConnection Properties
Inherited from |
Not Supported |
Inherited from |
This property specifies the client identifier for the connection.
Declaration
// C#
public string ClientId {set;}
Property Value
The string to be used as the client identifier.
Remarks
The default value is null.
Setting ClientId to null resets the client identifier for the connection. Setting ClientId to an empty string sets the client identifier for the connection to an empty string. ClientId is set to null when the Close method is called on the OracleConnection object.
Using the ClientId property allows the application to set the client identifier in the application context for every database session using ODP.NET. This enables ODP.NET developers to configure the Oracle Virtual Private Database (VPD) more easily.
This property specifies connection information used to connect to an Oracle database.
Declaration
// ADO.NET 2.0: C#
public override string ConnectionString{get; set;}
// ADO.NET: 1.x C#
public string ConnectionString{get; set;}
Property Value
If the connection string is supplied through the constructor, this property is set to that string.
Implements
IDbConnection
Exceptions
ArgumentException - An invalid syntax is specified for the connection string.
InvalidOperationException - ConnectionString is being set while the connection is open.
Remarks
The default value is an empty string.
ConnectionString must be a string of attribute name and value pairings, separated by a semi-colon, for example:
"User Id=scott;password=tiger;data source=oracle"
If the ConnectionString is not in a proper format, an exception is thrown. All spaces are ignored unless they are within double quotes.
When the ConnectionString property is set, the OracleConnection object immediately parses the string for errors. An ArgumentException is thrown if the ConnectionString contains invalid attributes or invalid values. Attribute values for User Id, Password, Proxy User Id, Proxy Password, and Data Source (if provided) are not validated until the Open method is called.
The connection must be closed to set the ConnectionString property. When the ConnectionString property is reset, all previously set values are reinitialized to their default values before the new values are applied.
Oracle database supports case-sensitive user names. To connect as a user whose name is of mixed case, for example, "MySchema", the User Id attribute value must be surrounded by double quotes, as follows:
"User Id=\"MySchema\";Password=MYPASSWORD;Data Source=oracle"
However, if the Oracle user name is all upper case, the User Id connection string attribute can be set to that user name without the use of the double quotes since User Ids that are not doubled-quoted are converted to all upper case when connecting. Single quotes are not supported.
For a complete example, see "Example".
If a connection string attribute is set more than once, the last setting takes effect and no exceptions are thrown.
Boolean connection string attributes can be set to either true, false, yes, or no.
Remarks (.NET Stored Procedure)
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method. Other connection string attributes cannot be used in conjunction with "context connection" when it is set to true.
Supported Connection String Attributes
Table 5-26 lists the supported connection string attributes.
Table 5-26 Supported Connection String Attributes
Example
This code example shows that the case of the User Id attribute value is not preserved unless it is surrounded by double quotes. The example also demonstrates when connection pools are created and when connections are drawn from the connection pool.
/* Database Setup: Log on as SYS or SYSTEM that has CREATE USER privilege.
grant connect, resource to "MYSCHEMA" identified by MYPWD;
grant connect, resource to "MySchema" identified by MYPWD;
// C#
using System;
class ConnectionStringSample
static long GetSID(OracleConnection con)
OracleCommand cmd = new OracleCommand();
cmd.Connection = con;
cmd.CommandText = "select SYS_CONTEXT('USERENV','SID') from dual";
object sid = cmd.ExecuteScalar();
return Convert.ToInt32(sid);
static void Main()
// To demonstrate whether a connection is obtained from the same
// connection pool or not, we check the SID (session id). If the
// session IDs of two connections are the same, that would indicate
// that the connection is the same and hence the connection was
// obtained from the same connection pool.
// If the session IDs are different, it could potentially mean that a
// different connection was obtained from the same connection pool or
// a different connection is obtained from a different connection pool.
// However, since the sample always places the connection
// back into the pool by disposing it before requesting another
// connection, a connection with the same ID will be obtained again
// if a connection is requested from the same connection pool.
string constr1 = "User Id=myschema;Password=mypwd;Data Source=oracle";
string constr2 = "User Id=MySchema;Password=MyPwd;Data Source=oracle";
string constr3 = "User Id=\"MYSCHEMA\";Password=MYPWD;Data Source=oracle";
string constr4 = "User Id=\"MySchema\";Password=MYPWD;Data Source=oracle";
string constr5 = " User Id=myschema;Password=mypwd;Data Source=oracle; ";
string constr6 =
"User Id=myschema;Password=mypwd;Data Source=oracle;pooling=true";
long sid0, sid1;
// Connect as "MYSCHEMA/MYPWD"
// NOTE: the password is case insensitive
// A new connection and a new connection pool X is created
OracleConnection con1 = new OracleConnection(constr1);
con1.Open();
sid0 = GetSID(con1);
// Place connection back into connection pool X
con1.Dispose();
// The connection from pool X is obtained. No new connection created.
OracleConnection con2 = new OracleConnection(constr2);
con2.Open();
sid1 = GetSID(con2);
if (sid1 == sid0)
Console.WriteLine("con1 and con2 are from the same connection pool");
else
Console.WriteLine("con1 and con2 are from different connection pools");
con2.Dispose();
OracleConnection con3 = new OracleConnection(constr3);
con3.Open();
sid1 = GetSID(con3);
if (sid1 == sid0)
Console.WriteLine("con1 and con3 are from the same connection pool");
else
Console.WriteLine("con1 and con3 are from different connection pools");
con3.Dispose();
// Connect as "MySchema/MYPWD"
// A new connection and connection pool Y is created
OracleConnection con4 = new OracleConnection(constr4);
con4.Open();
sid1 = GetSID(con4);
if (sid1 == sid0)
Console.WriteLine("con1 and con4 are from the same connection pool");
else
Console.WriteLine("con1 and con4 are from different connection pools");
// Place connection back into connection pool Y
con4.Dispose();
// Extra spaces or semi-colons in the connection string do not force
// new pools to be created
OracleConnection con5 = new OracleConnection(constr5);
con5.Open();
sid1 = GetSID(con5);
if (sid1 == sid0)
Console.WriteLine("con1 and con5 are from the same connection pool");
else
Console.WriteLine("con1 and con5 are from different connection pools");
con5.Dispose();
// A connection is obtained from Connection Pool X.
// It's important to note that different connection strings do
// not necessarily mean that ODP.NET will create different
// connection pools for them. In other words, ODP.NET does not
// use exact string matching algorithm to determine whether
// a new connection pool needs to be created or not.
// Instead, it creates connection pools based on the uniqueness
// of attribute values settings in the connection string.
OracleConnection con6 = new OracleConnection(constr6);
con6.Open();
sid1 = GetSID(con6);
if (sid1 == sid0)
Console.WriteLine("con1 and con6 are from the same connection pool");
else
Console.WriteLine("con1 and con6 are from different connection pools");
con6.Dispose();
This property specifies the maximum amount of time that the Open method can take to obtain a pooled connection before the request is terminated.
Declaration
// ADO.NET 2.0: C#
public override int ConnectionTimeout {get;}
// ADO.NET 1.x: C#
public int ConnectionTimeout {get;}
Property Value
The maximum time allowed for a pooled connection request, in seconds.
Implements
IDbConnection
Remarks
The default value is 15.
Setting this property to 0 allows the pooled connection request to wait for a free connection without a time limit. The timeout takes effect only for pooled connection requests and not for new connection requests.
There is no connection string specified by the application and a connection on the implicit database is always available, therefore, this property is set to 0.
This property is not supported.
Declaration
// ADO.NET 2.0: C#
public override string Database {get;}
// ADO.NET 1.x: C#
public string Database {get;}
Property Value
A string.
Implements
IDbConnection.Database
Remarks
This property is not supported. It always returns an empty string.
This property specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect
Declaration
// ADO.NET 2.0: C#
public override string DataSource {get;}
// ADO.NET 1.x: C#
public string DataSource {get;}
Property Value
Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect.
The value of this property is always an empty string for the implicit database connection.
This property specifies the version number of the Oracle database to which the OracleConnection has established a connection.
Declaration
// ADO.NET 2.0: C#
public override string ServerVersion {get;}
// ADO.NET 1.x: C#
public string ServerVersion {get;}
Property Value
The version of the Oracle database.
Exceptions
InvalidOperationException - The connection is closed.
Remarks
The default is an empty string.
This property specifies the current state of the connection.
Declaration
// ADO.NET 2.0: C#
public override ConnectionState State {get;}
// ADO.NET 1.x: C#
public ConnectionState State {get;}
Property Value
The ConnectionState of the connection.
Implements
IDbConnection
Remarks
ODP.NET supports ConnectionState.Closed and ConnectionState.Open for this property. The default value is ConnectionState.Closed.
OracleConnection public methods are listed in Table 5-27.
Table 5-27 OracleConnection Public Methods
Not Supported |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
BeginTransaction methods begin local transactions.
Overload List
This method begins a local transaction.
BeginTransaction(IsolationLevel)
This method begins a local transaction with the specified isolation level.
Declaration
// C# public OracleTransaction BeginTransaction();
Return Value
An OracleTransaction object representing the new transaction.
Implements
IDbConnection
Exceptions
InvalidOperationException - A transaction has already been started.
Remarks
The transaction is created with its isolation level set to its default value of IsolationLevel.ReadCommitted. All further operations related to the transaction must be performed on the returned OracleTransaction object.
Using this method causes a Not Supported exception.
Declaration
// C#
public OracleTransaction BeginTransaction(IsolationLevel isolationLevel);
Parameters
isolationLevel
The isolation level for the new transaction.
Return Value
Implements
IDbConnection
Exceptions
ArgumentException - The isolationLevel specified is invalid.
Remarks
The following two isolation levels are supported:
IsolationLevel.Serializable
Requesting other isolation levels causes an exception.
Example
// C#
using System;
using System.Data;
class BeginTransactionSample
static void Main()
con.Open();
// Create an OracleCommand object using the connection object
// Start a transaction
OracleTransaction txn = con.BeginTransaction(IsolationLevel.ReadCommitted);
// Update EMP table
cmd.CommandText = "update emp set sal = sal + 100";
cmd.ExecuteNonQuery();
// Rollback transaction
txn.Rollback();
Console.WriteLine("Transaction rolledback");
// Clean up
txn.Dispose();
cmd.Dispose();
con.Dispose();
This method is not supported.
Declaration
// ADO.NET 2.0: C#
public override void ChangeDatabase(string databaseName);
// ADO.NET 1.x: C# public void ChangeDatabase(string databaseName);
Parameters
databaseName
The name of the database that replaces the current database name.
Implements
IDbConnection.ChangeDatabase
Exceptions
NotSupportedException - Method not supported.
Remarks
This method is not supported and throws a NotSupportedException if invoked.
This method creates a copy of an OracleConnection object.
Declaration
// C# public object Clone();
Return Value
An OracleConnection object.
Implements
ICloneable
Remarks
The cloned object has the same property values as that of the object being cloned.
This method is not supported for an implicit database connection.
Example
// C#
using System;
class CloneSample
static void Main()
con.Open();
// Need a proper casting for the return value when cloned
OracleConnection clonedCon = (OracleConnection)con.Clone();
// Cloned connection is always closed, regardless of its source,
// But the connection string should be identical
clonedCon.Open();
if (clonedCon.ConnectionString.Equals(con.ConnectionString))
Console.WriteLine("The connection strings are the same.");
else
Console.WriteLine("The connection strings are different.");
// Close and Dispose OracleConnection object
clonedCon.Dispose();
This method closes the connection to the database.
Declaration
// ADO.NET 2.0: C# public override void Close();
// ADO.NET 1.x: C#
public void Close();
Implements
IDbConnection
Remarks
Performs the following:
Rolls back any pending transactions.
Places the connection to the connection pool if connection pooling is enabled. Even if connection pooling is enabled, the connection can be closed if it exceeds the connection lifetime specified in the connection string. If connection pooling is disabled, the connection is closed.
Closes the connection to the database.
The connection can be reopened using Open().
This method creates and returns an OracleCommand object associated with the OracleConnection object.
Declaration
// C# public OracleCommand CreateCommand();
Return Value
The OracleCommand object.
Implements
IDbConnection
Example
// C#
using System;
using System.Data;
class CreateCommandSample
static void Main()
// Connect
con.Open();
// Clean up
reader.Dispose();
cmd.Dispose();
con.Dispose();
This method enables applications to explicitly enlist in a specific distributed transaction after a connection has been opened.
Declaration
// C#
public void EnlistDistributedTransaction(ITransaction transaction);
Parameters
transaction
An ITransaction interface.
Exceptions
InvalidOperationException - The connection is part of a local transaction or the connection is closed.
Remarks
EnlistDistributedTransaction enables objects to enlist in a specific transaction that is passed to the method. The ITransaction interface can be obtained by applying an (ITransaction) cast to the ContexUtil.Transaction property within the component that started the distributed transaction.
The connection must be open before calling this method or an InvalidOperationException is thrown.
If a connection is part of a local transaction that was started implicitly or explicitly while attempting to enlist in a distributed transaction, the local transaction is rolled back and an exception is thrown.
By default, distributed transactions roll back, unless the method-level AutoComplete declaration is set.
Invoking the commit on the ITranasction raises an exception.
Invoking the rollback on the ITransaction method and calling ContextUtil.SetComplete on the same distributed transaction raises an exception.
Example
Application:
// C#
/* This is the class that will utilize the Enterprise Services
component. This module needs to be built as an executable.
The Enterprise Services Component DLL must be built first
before building this module.
In addition, the DLL needs to be referenced appropriately
when building this application.
using System;
using System.EnterpriseServices;
using DistribTxnSample;
class DistribTxnSample_App
static void Main()
DistribTxnSample_Comp comp = new DistribTxnSample_Comp();
comp.DoWork();
Component:
// C#
/* This module needs to be
1) built as a component DLL/Library
2) built with a strong name
This library must be built first before the application is built.
using System;
using System.Data;
namespace DistribTxnSample
[Transaction(TransactionOption.RequiresNew)]
public class DistribTxnSample_Comp : ServicedComponent
public void DoWork()
string constr =
"User Id=scott;Password=tiger;Data Source=oracle;enlist=false";
con.Open();
// Enlist in a distrubuted transaction
con.EnlistDistributedTransaction((ITransaction)ContextUtil.Transaction);
// Update EMP table
cmd.CommandText = "UPDATE emp set sal = sal + .01";
// Commit
ContextUtil.SetComplete();
// Dispose OracleConnection object
con.Dispose();
See Also:
This method enlists the connection to the specified transaction.
Declaration
// C#
public override void EnlistTransaction(Transaction transaction)
Parameters
transaction
A System.Transactions.Transaction object.
Exceptions
Remarks
Invocation of this method immediately enlists the connection to a distributed transaction that is specified by the provided transaction parameter.
If OracleConnection is still associated with a distributed transaction that has not completed from a previous EnlistTransaction method invocation, calling this method will cause an exception to be thrown.
In general, for distributed transaction enlistments to succeed, the "enlist" connection string attribute must be set to either "true" or "dynamic" before invoking the Open method. Setting the "enlist" connection string attribute to "true" will implicitly enlist the connection when the Open method is called, if the connection is within a transaction context. Setting it to "dynamic" allows the connection to dynamically enlist in distributed transactions when an EnlistTransaction or EnlistDistributedTransaction method is called. The "enlist" attribute should be set to "false" only if the connection will never enlist in a distributed transaction.
GetSchema methods return schema information for the data source of the OracleConnection.
Overload List
This method returns schema information for the data source of the OracleConnection.
GetSchema (string collectionName)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name.
GetSchema (string collectionName, string[] restrictions)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name and the specified string array for the restriction values.
Declaration
// ADO.NET 2.0: C# public override DataTable GetSchema();
Return Value
A DataTable object.
Exceptions
InvalidOperationException – The connection is closed.
Remarks
This method returns a DataTable object that contains a row for each metadata collection available from the database.
The method is equivalent to specifying the String value "MetaDataCollections" when using the GetSchema(String) method.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
class GetSchemaSample
static void Main(string[] args)
string constr = "User Id=scott; Password=tiger; Data Source=oracle;";
string ProviderName = "Oracle.DataAccess.Client";
DbProviderFactory factory = DbProviderFactories.GetFactory(ProviderName);
using (DbConnection conn = factory.CreateConnection())
try
conn.ConnectionString = constr;
conn.Open();
//Get all the schema collections and write to an XML file.
//The XML file name is Oracle.DataAccess.Client_Schema.xml
DataTable dtSchema = conn.GetSchema();
dtSchema.WriteXml(ProviderName + "_Schema.xml");
catch (Exception ex)
Console.WriteLine(ex.Message);
Console.WriteLine(ex.StackTrace);
Declaration
// ADO.NET 2.0: C#
public override DataTable GetSchema (string collectionName);
Parameters
collectionName
Name of the collection for which metadata is required.
Return Value
A DataTable object.
Exceptions
ArgumentException – The requested collection is not defined.
InvalidOperationException – The requested collection is not supported by current version of Oracle database.
InvalidOperationException – No population string is specified for requested collection.
Example
// C#
using System;
using System.Data;
try
conn.Open();
//Get MetaDataCollections and write to an XML file.
//This is equivalent to GetSchema()
DataTable dtMetadata =
conn.GetSchema(DbMetaDataCollectionNames.MetaDataCollections);
dtMetadata.WriteXml(ProviderName + "_MetaDataCollections.xml");
//Get Restrictions and write to an XML file.
DataTable dtRestrictions =
conn.GetSchema(DbMetaDataCollectionNames.Restrictions);
dtRestrictions.WriteXml(ProviderName + "_Restrictions.xml");
//Get DataSourceInformation and write to an XML file.
DataTable dtDataSrcInfo =
conn.GetSchema(DbMetaDataCollectionNames.DataSourceInformation);
dtDataSrcInfo.WriteXml(ProviderName + "_DataSourceInformation.xml");
//data types and write to an XML file.
DataTable dtDataTypes =
conn.GetSchema(DbMetaDataCollectionNames.DataTypes);
dtDataTypes.WriteXml(ProviderName + "_DataTypes.xml");
//Get ReservedWords and write to an XML file.
DataTable dtReservedWords =
conn.GetSchema(DbMetaDataCollectionNames.ReservedWords);
dtReservedWords.WriteXml(ProviderName + "_ReservedWords.xml");
//Get all the tables and write to an XML file.
DataTable dtTables = conn.GetSchema("Tables");
dtTables.WriteXml(ProviderName + "_Tables.xml");
//Get all the views and write to an XML file.
DataTable dtViews = conn.GetSchema("Views");
dtViews.WriteXml(ProviderName + "_Views.xml");
//Get all the columns and write to an XML file.
DataTable dtColumns = conn.GetSchema("Columns");
dtColumns.WriteXml(ProviderName + "_Columns.xml");
Declaration
// ADO.NET 2.0: C# public override DataTable GetSchema (string collectionName, string[] restrictions);
Parameters
collectionName
The name of the collection of metadata being retrieved.
restrictions
An array of restrictions that apply to the metadata being retrieved.
Return Value
A DataTable object.
Exception
InvalidOperationException – One of the following conditions exist:
The requested collection is not supported by the current version of Oracle database.
More restrictions were provided than the requested collection supports.
Remarks
This method takes the name of a metadata collection and an array of String values that specify the restrictions for filtering the rows in the returned DataTable. This returns a DataTable that contains only rows from the specified metadata collection that match the specified restrictions.
For example, if the Columns collection has three restrictions (owner, tablename, and columnname), to retrieve all the columns for the EMP table regardless of schema, the GetSchema method must pass in at least these values: null, EMP.
If no restriction value is passed in, default values are used for that restriction, which is the same as passing in null. This differs from passing in an empty string for the parameter value. In this case, the empty string ("") is considered the value for the specified parameter.
collectionName is not case-sensitive, but restrictions (string values) are.
Example
// C#
using System;
using System.Data;
try
conn.Open();
//Get Restrictions
DataView dv = dtRestrictions.DefaultView;
dv.RowFilter = "CollectionName = 'Columns'";
dv.Sort = "RestrictionNumber";
for (int i = 0; i < dv.Count; i++)
Console.WriteLine("{0} (default) {1}" ,
dtRestrictions.Rows[i]["RestrictionName"],
dtRestrictions.Rows[i]["RestrictionDefault"]);
//Set restriction string array
string[] restrictions = new string[3];
//Get all columns from all tables owned by "SCOTT"
restrictions[0] = "SCOTT";
DataTable dtAllScottCols = conn.GetSchema("Columns", restrictions);
// clear collection
for (int i = 0; i < 3; i++)
restrictions[i] = null;
//Get all columns from all tables named "EMP" owned by any
//owner/schema
restrictions[1] = "EMP";
DataTable dtAllEmpCols = conn.GetSchema("Columns", restrictions);
// clear collection
//Get columns named "EMPNO" from tables named "EMP",
//owned by any owner/schema
restrictions[2] = "EMPNO";
DataTable dtAllScottEmpCols = conn.GetSchema("Columns", restrictions);
// clear collection
//Get columns named "EMPNO" from all
//tables, owned by any owner/schema
DataTable dtAllEmpNoCols = conn.GetSchema("Columns", restrictions);
Console.WriteLine(ex.Source);
GetSessionInfo returns or refreshes an OracleGlobalization object that represents the globalization settings of the session.
Overload List:
This method returns a new instance of the OracleGlobalization object that represents the globalization settings of the session.
GetSessionInfo(OracleGlobalization)
This method refreshes the provided OracleGlobalization object with the globalization settings of the session.
Declaration
// C# public OracleGlobalization GetSessionInfo();
Return Value
The newly created OracleGlobalization object.
Example
// C#
using System;
class GetSessionInfoSample
static void Main()
con.Open();
// Get session info from connection object
OracleGlobalization info = con.GetSessionInfo();
// Update session info
info.DateFormat = "YYYY-MM-DD";
con.SetSessionInfo(info);
// Execute SQL SELECT
cmd.CommandText = "select TO_CHAR(hiredate) from emp";
Console.WriteLine("Hire Date ({0}): {1}",
info.DateFormat, cmd.ExecuteScalar());
// Clean up
cmd.Dispose();
con.Dispose();
Declaration
// C#
public void GetSessionInfo(OracleGlobalization oraGlob);
Parameters
oraGlob
The OracleGlobalization object to be updated.
This method opens a connection to an Oracle database.
Declaration
// ADO.NET 2.0: C# public overide void Open();
// ADO.NET 1.x: C#
public void Open();
Implements
IDbConnection
Exceptions
ObjectDisposedException - The object is already disposed.
InvalidOperationException - The connection is already opened or the connection string is null or empty.
Remarks
The connection is obtained from the pool if connection pooling is enabled. Otherwise, a new connection is established.
It is possible that the pool does not contain any unused connections when the Open() method is invoked. In this case, a new connection is established.
If no connections are available within the specified connection timeout value, when the Max Pool Size is reached, an OracleException is thrown.
This method opens a new connection with the new password.
Declaration
// C#
public void OpenWithNewPassword(string newPassword);
Parameters
newPassword
A string that contains the new password.
Remarks
This method uses the ConnectionString property settings to establish a new connection. The old password must be provided in the connection string as the Password attribute value.
This method can only be called on an OracleConnection in the closed state.
This method is not supported with an implicit database connection.
This method flushes the statement cache by closing all open cursors on the database, when statement caching is enabled.
Declaration
// C# public void PurgeStatementCache();
Remarks
Flushing the statement cache repetitively results in decreased performance and may negate the performance benefit gained by enabling the statement cache.
Statement caching remains enabled after the call to PurgeStatementCache.
Invocation of this method purges the cached cursors that are associated with the OracleConnection. It does not purge all the cached cursors in the database.
Example
// C#
using System;
using System.Data;
class PurgeStatementCacheSample
static void Main()
string constr = "User Id=scott;Password=tiger;Data Source=oracle;" +
"Statement Cache Size=20";
con.Open();
OracleCommand cmd = new OracleCommand("select * from emp", con);
cmd.CommandType = CommandType.Text;
// Purge Statement Cache
con.PurgeStatementCache();
Console.WriteLine("Statement Cache Flushed");
con.Close();
con.Dispose();
This method alters the session's globalization settings with all the property values specified in the provided OracleGlobalization object.
Declaration
// C#
public void SetSessionInfo(OracleGlobalization oraGlob);
Parameters
oraGlob
An OracleGlobalization object.
Remarks
Calling this method is equivalent to calling an ALTER SESSION SQL on the session.
Example
// C#
using System;
class SetSessionInfoSample
static void Main()
con.Open();
// Clean up
cmd.Dispose();
con.Dispose();
OracleConnection events are listed in Table 5-28.
Table 5-28 OracleConnection Events
Inherited from |
This event is triggered when an Oracle failover occurs.
Declaration
// C# public event OracleFailoverEventHandler Failover;
Event Data
The event handler receives an OracleFailoverEventArgs object which exposes the following properties containing information about the event.
FailoverType
Indicates the type of the failover.
FailoverEvent
Indicates the state of the failover.
Remarks
The Failover event is raised when a connection to an Oracle instance is unexpectedly severed. The client should create an OracleFailoverEventHandler delegate to listen to this event.
This event is triggered for any message or warning sent by the database.
Declaration
// C# public event OracleInfoMessageEventHandler InfoMessage;
Event Data
The event handler receives an OracleInfoMessageEventArgs object which exposes the following properties containing information about the event.
Errors
The collection of errors generated by the data source.
Message
The error text generated by the data source.
Source
The name of the object that generated the error.
Remarks
In order to respond to warnings and messages from the database, the client should create an OracleInfoMessageEventHandler delegate to listen to this event.
This event is triggered when the connection state changes.
Declaration
// ADO.NET 2.0: C# public override event StateChangeEventHandler StateChange;
// ADO.NET 1.x: C#
public event StateChangeEventHandler StateChange;
Event Data
The event handler receives a StateChangeEventArgs object which exposes the following properties containing information about the event.
CurrentState
The new state of the connection.
OriginalState
The original state of the connection.
Remarks
The StateChange event is raised after a connection changes state, whenever an explicit call is made to Open, Close or Dispose.
See Also:
