Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 2 (10.2.0.2)
B28089-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleXmlQueryProperties Class
An OracleXmlQueryProperties object represents the XML properties used by the OracleCommand class when the XmlCommandType property is Query.
Class Inheritance
System.Object
  System.OracleXmlQueryProperties
Declaration
public sealed class OracleXmlQueryProperties : ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
OracleXmlQueryProperties can be accessed, and modified using the XmlQueryProperties property of the OracleCommand class. Each OracleCommand object has its own instance of the OracleXmlQueryProperties class in the XmlQueryProperties property.
Use the default constructor to get a new instance of the OracleXmlQueryProperties. Use the OracleXmlQueryProperties.Clone() method to get a copy of an OracleXmlQueryProperties instance.
Example
This example retrieves relational data as XML.
// C#
using System;
using System.IO;
using System.Data;
using System.Xml;
using System.Text;
using Oracle.DataAccess.Client;
class OracleXmlQueryPropertiesSample
  static void Main()
    int rows = 0;
    StreamReader sr = null;
    // Define the XSL document for doing the transform.
    string xslstr = "<?xml version='1.0'?>\n" +
      "<xsl:stylesheet version=\"1.0\"" +
      " xmlns:xsl=\"http://www.w3.org/1999/XSL/Transform\">\n" +
      "  <xsl:output encoding=\"utf-8\"/>\n" +
      "  <xsl:template match=\"/\">\n" +
      "    <EMPLOYEES>\n" +
      "      <xsl:apply-templates select=\"ROWSET\"/>\n" +
      "    </EMPLOYEES>\n" +
      "  </xsl:template>\n" +
      "  <xsl:template match=\"ROWSET\">\n" +
      "      <xsl:apply-templates select=\"ROW\"/>\n" +
      "  <xsl:template match=\"ROW\">\n" +
      "    <EMPLOYEE>\n" +
      "    <EMPLOYEE_ID>\n" +
      "      <xsl:apply-templates select=\"EMPNO\"/>\n" +
      "    </EMPLOYEE_ID>\n" +
      "    <EMPLOYEE_NAME>\n" +
      "      <xsl:apply-templates select=\"ENAME\"/>\n" +
      "    </EMPLOYEE_NAME>\n" +
      "    <HIRE_DATE>\n" +
      "      <xsl:apply-templates select=\"HIREDATE\"/>\n" +
      "    </HIRE_DATE>\n" +
      "    <JOB_TITLE>\n" +
      "      <xsl:apply-templates select=\"JOB\"/>\n" +
      "    </JOB_TITLE>\n" +
      "    </EMPLOYEE>\n" +
      "</xsl:stylesheet>\n";
    // Create the connection.
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Set the date, and timestamp formats for Oracle 9i Release 2, or later.
    // This is just needed for queries.
    if (!con.ServerVersion.StartsWith("9.0") &&
      !con.ServerVersion.StartsWith("8.1"))
      OracleGlobalization sessionParams = con.GetSessionInfo();
      sessionParams.DateFormat = "YYYY-MM-DD\"T\"HH24:MI:SS";
      sessionParams.TimeStampFormat = "YYYY-MM-DD\"T\"HH24:MI:SS.FF3";
      sessionParams.TimeStampTZFormat = "YYYY-MM-DD\"T\"HH24:MI:SS.FF3";
      con.SetSessionInfo(sessionParams);
    // Create the command.
    OracleCommand cmd = new OracleCommand("", con);
    // Set the XML command type to query.
    cmd.XmlCommandType =  OracleXmlCommandType.Query;
    // Set the SQL query.
    cmd.CommandText = "select * from emp e where e.empno = :empno";
    // Set command properties that affect XML query behaviour.
    cmd.BindByName = true;
    // Bind values to the parameters in the SQL query.
    Int32 empNum = 7369;
    cmd.Parameters.Add("empno", OracleDbType.Int32, empNum,
      ParameterDirection.Input);
    // Set the XML query properties.
    cmd.XmlQueryProperties.MaxRows =  1;
    cmd.XmlQueryProperties.RootTag =  "ROWSET";
    cmd.XmlQueryProperties.RowTag =  "ROW";
    cmd.XmlQueryProperties.Xslt =  xslstr;
    // Test query execution without returning a result.
    Console.WriteLine("SQL query: select * from emp e where e.empno = 7369");
    Console.WriteLine("Maximum rows: all rows (-1)");
    Console.WriteLine("Return Value from OracleCommand.ExecuteNonQuery():");
    rows = cmd.ExecuteNonQuery();
    Console.WriteLine(rows);
    Console.WriteLine("\n");
    // Get the XML document as an XmlReader.
    Console.WriteLine("XML Document from OracleCommand.ExecuteXmlReader():");
    XmlReader xmlReader =  cmd.ExecuteXmlReader();
    XmlDocument xmlDocument = new XmlDocument();
    xmlDocument.PreserveWhitespace = true;
    xmlDocument.Load(xmlReader);
    Console.WriteLine(xmlDocument.OuterXml);
    // Change the SQL query, and set the maximum number of rows to 2.
    cmd.CommandText = "select * from emp e";
    cmd.Parameters.Clear();
    cmd.XmlQueryProperties.MaxRows =  2;
    // Get the XML document as a Stream.
    Console.WriteLine("SQL query: select * from emp e");
    Console.WriteLine("Maximum rows: 2");
    Console.WriteLine("XML Document from OracleCommand.ExecuteStream():");
    Stream stream = cmd.ExecuteStream();
    sr = new StreamReader(stream, Encoding.Unicode);
    Console.WriteLine(sr.ReadToEnd());
    // Get all the rows.
    cmd.XmlQueryProperties.MaxRows =  -1;
    // Append the XML document to an existing Stream.
    Console.WriteLine("XML Document from OracleCommand.ExecuteToStream():");
    MemoryStream mstream = new MemoryStream(32);
    cmd.ExecuteToStream(mstream);
    mstream.Seek(0, SeekOrigin.Begin);
    sr = new StreamReader(mstream, Encoding.Unicode);
    // Clean up.
    cmd.Dispose();
    con.Close();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.x or 2.0
OracleXmlQueryProperties Members
OracleXmlQueryProperties members are listed in the following tables:
OracleXmlQueryProperties Constructors
The OracleXmlQueryProperties constructors are listed in Table 6-2.
Table 6-2 OracleXmlQueryProperties Constructors
Constructor Description
Instantiates a new instance of the OracleXmlQueryProperties class
OracleXmlQueryProperties Properties
The OracleXmlQueryProperties properties are listed in Table 6-3.
Table 6-3 OracleXmlQueryProperties Properties
Name Description
MaxRows
Specifies the maximum number of rows from the result set of the query that can be represented in the result XML document
RootTag
Specifies the root element of the result XML document
RowTag
Specifies the value of the XML element which identifies a row of data from the result set in an XML document
Xslt
Specifies the XSL document used for XML transformation using XSLT
XsltParams
Specifies parameters for the XSL document
OracleXmlQueryProperties Public Methods
The OracleXmlQueryProperties public methods are listed in Table 6-4.
Table 6-4 OracleXmlQueryProperties Public Methods
Name Description
Clone
Creates a copy of an OracleXmlQueryProperties object
The OracleXmlQueryProperties constructor instantiates a new instance of the OracleXmlQueryProperties class.
Declaration
// C#
public OracleXmlQueryProperties();
The OracleXmlQueryProperties properties are listed in Table 6-5.
Table 6-5 OracleXmlQueryProperties Properties
Name Description
MaxRows
RootTag
RowTag
Xslt
XsltParams
MaxRows
This property specifies the maximum number of rows from the result set of the query that can be represented in the result XML document.
Declaration
// C#
public int MaxRows {get; set;}
Property Value
The maximum number of rows.
Exceptions
ArgumentException - The new value for MaxRows is not valid.
Remarks
Default value is -1.
Possible values are:
RootTag
This property specifies the root element of the result XML document.
Declaration
// C#
public string RootTag {get; set;}
Property Value
The root element of the result XML document.
Remarks
The default root tag is ROWSET.
To indicate that no root tag is be used in the result XML document, set this property to null or "" or String.Empty.
If both RootTag and RowTag are set to null, an XML document is returned only if the result set returns one row and one column.
RowTag
This property specifies the value of the XML element which identifies a row of data from the result set in an XML document.
Declaration
// C#
public string RowTag {get; set;}
Property Value
The value of the XML element.
Remarks
The default is ROW.
To indicate that no row tag is be used in the result XML document, set this property to null or "" or String.Empty.
Xslt
This property specifies the XSL document used for XML transformation using XSLT.
Declaration
// C#
public string Xslt {get; set;}
Property Value
The XSL document used for XML transformation.
Remarks
Default value is null.
The XSL document is used for XML transformation of the XML document generated from the result set of the query.
XsltParams
This property specifies parameters for the XSL document.
Declaration
// C#
public string XsltParams {get; set;}
Property Value
The parameters for the XSL document.
Remarks
The parameters are specified as a string of "name=value" pairs of the form "param1=value1; param2=value2;..." delimited by semicolons.
The OracleXmlQueryProperties public methods are listed in Table 6-6.
Table 6-6 OracleXmlQueryProperties Public Methods
Name Description
Clone
Clone
This method creates a copy of an OracleXmlQueryProperties object.
Declaration
// C#
public object Clone();
Return Value
Implements
ICloneable
