Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleBulkCopyColumnMappingCollection Class
The OracleBulkCopyColumnMappingCollection class represents a collection of OracleBulkCopyColumnMapping objects that are used to map columns in the data source to columns in a destination table.
Class Inheritance
System.Object
  System.CollectionBase
    System.OracleBulkCopyColumnMappingCollection
Declaration
// C#
public sealed class OracleBulkCopyColumnMappingCollection : CollectionBase
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
Column mappings define the mapping between data source and the target table.
It is not necessary to specify column mappings for all the columns in the data source. If a ColumnMapping is not specified, then, by default, columns are mapped based on the ordinal position. This succeeds only if the source and destination table schema match. If there is a mismatch, an InvalidOperationException is thrown.
All the mappings in a mapping collection must be by name or ordinal position.
Oracle Data Provider for .NET makes one or more round-trips to the database to determine the column name if the mapping is specified by ordinal position. To avoid this performance overhead, specify the mapping by column name.
Example
// C#
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleBulkCopyColumnMappingCollection Members
OracleBulkCopyColumnMappingCollection members are listed in the following tables.
OracleBulkCopyColumnMappingCollection Properties
The OracleBulkCopyColumnMappingCollection properties are listed in Table 15-11.
Table 15-11 OracleBulkCopyColumnMappingCollection Properties
Property Description
Item[index]
Gets or sets the OracleBulkCopyColumnMappingCollection object at the specified index
OracleBulkCopyColumnMappingCollection Public Methods
The OracleBulkCopyColumnMappingCollection public methods are listed in Table 15-12.
Table 15-12 OracleBulkCopyColumnMappingCollection Public Methods
Public Method Description
Add
Adds objects to the collection
Clear
Clears the contents of the collection
Contains
Returns a value indicating whether or not a specified OracleBulkCopyColumnMapping object exists in the collection
CopyTo
Copies the elements of the OracleBulkCopyColumnMappingCollection to an array of OracleBulkCopyColumnMapping items, starting at a specified index
IndexOf
Returns the index of the specified OracleBulkCopyColumnMapping object
Insert
Inserts a new OracleBulkCopyColumnMapping object in the collection, at the index specified.
Remove
Removes the specified OracleBulkCopyColumnMapping element from the OracleBulkCopyColumnMappingCollection.
RemoveAt
Removes the mapping from the collection at the specified index.
The OracleBulkCopyColumnMappingCollection properties are listed in Table 15-13.
Table 15-13 OracleBulkCopyColumnMappingCollection Properties
Item[index]
Item[index]
This property gets or sets the OracleBulkCopyColumnMapping object at the specified index.
Declaration
// C#
public OracleBulkCopyColumnMapping this[int index] {get;set;}
Parameters
Property Value
An OracleBulkCopyColumnMapping object at the specified index.
Exceptions
IndexOutOfRangeException - The specified index does not exist.
The OracleBulkCopyColumnMappingCollection public methods are listed in Table 15-14.
Table 15-14 OracleBulkCopyColumnMappingCollection Public Methods
Add
Clear
Contains
CopyTo
IndexOf
Insert
Remove
RemoveAt
Add
Add methods add objects to the collection.
Overload List:
Add(OracleBulkCopyColumnMapping)
This method adds the supplied OracleBulkCopyColumnMapping object to the collection.
Declaration
// C#
public OracleBulkCopyColumnMapping Add(OracleBulkCopyColumnMapping  bulkCopyColumnMapping);
Parameters
Exceptions
InvalidOperationException - The bulk copy operation is in progress.
Add(int, int)
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source and destination column ordinal positions.
Declaration
// C#
public OracleBulkCopyColumnMapping Add(int sourceColumnIndex,
    int destinationColumnIndex);
Parameters
Exceptions
Return Value
The newly created OracleBulkCopyColumnMapping object that was added to the collection.
Remarks
Add(int, string)
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source column ordinal and destination column name.
Declaration
// C#
    string destinationColumn);
Parameters
Exceptions
Return Value
Remarks
Oracle Data Provider for .NET makes one or more round trips to the database to determine the column names if the mapping is specified by ordinal resulting in a performance overhead. Therefore, it is recommended to specify the mapping by column names.
Add(string, int)
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source column name and destination column ordinal.
Declaration
// C#
public OracleBulkCopyColumnMapping Add(string sourceColumn,
Parameters
Return Value
Exceptions
Remarks
Add(string, string)
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source and destination column names.
Declaration
// C#
Parameters
Exceptions
Return Value
Remarks
Clear
This method clears the contents of the collection.
Declaration
// C#
public void Clear();
Exceptions
Remarks
The Clear method is most commonly used when an application uses a single OracleBulkCopy instance to process more than one bulk copy operation. If column mappings are created for one bulk copy operation, the OracleBulkCopyColumnMappingCollection must be cleared after the WriteToServer method invocation and before the next bulk copy is processed.
It is usually more efficient to perform several bulk copies using the same OracleBulkCopy instance than to use a separate OracleBulkCopy for each operation.
Contains
This method returns a value indicating whether or not a specified OracleBulkCopyColumnMapping object exists in the collection.
Declaration
// C#
public bool Contains(OracleBulkCopyColumnMapping value);
Parameters
Return Value
Returns true if the specified mapping exists in the collection; otherwise, returns false.
CopyTo
This method copies the elements of the OracleBulkCopyColumnMappingCollection to an array of OracleBulkCopyColumnMapping items, starting at a specified index.
Declaration
// C#
public void CopyTo(OracleBulkCopyColumnMapping[] array, int index);
Parameters
IndexOf
This method returns the index of the specified OracleBulkCopyColumnMapping object.
Declaration
// C#
public int IndexOf(OracleBulkCopyColumnMapping value);
Parameters
Return Value
The zero-based index of the column mapping or -1 if the column mapping is not found in the collection.
Insert
This method inserts a new OracleBulkCopyColumnMapping object in the collection, at the index specified.
Declaration
// C#
public void Insert(int index, OracleBulkCopyColumnMapping value);
Parameters
Exceptions
Remove
This method removes the specified OracleBulkCopyColumnMapping element from the OracleBulkCopyColumnMappingCollection.
Declaration
// C#
public void Remove(OracleBulkCopyColumnMapping value);
Parameters
Exceptions
Remarks
The Remove method is most commonly used when a single OracleBulkCopy instance processes more than one bulk copy operation. If column mappings are created for one bulk copy operation, mappings that no longer apply must be removed after the WriteToServer method invocation and before mappings are defined for the next bulk copy. The Clear method can clear the entire collection, and the Remove and the RemoveAt methods can remove mappings individually.
RemoveAt
This method removes the mapping from the collection at the specified index.
Declaration
// C#
public void RemoveAt(int index);
Parameters
Exceptions
Remarks
The RemoveAt method is most commonly used when a single OracleBulkCopy instance is used to process more than one bulk copy operation. If column mappings are created for one bulk copy operation, mappings that no longer apply must be removed after the WriteToServer method invocation and before the mappings for the next bulk copy are defined. The Clear method can clear the entire collection, and the Remove and the RemoveAt methods can remove mappings individually.
