Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleDataReader Class
An OracleDataReader object represents a forward-only, read-only, in-memory result set.
Unlike the DataSet, the OracleDataReader object stays connected and fetches one row at a time.
The following section contain related information:
Class Inheritance
System.Object
  System.MarshalByRefObject
    System.Data.Common.DataReader
      System.Data.Common.DbDataReader (ADO.NET 2.0 only)
        Oracle.DataAccess.Client.OracleDataReader
Declaration
// ADO.NET 2.0: C#
public sealed class OracleDataReader : DbDataReader, IEnumerable,
   IDataReader, IDisposable, IDataRecord
// ADO.NET 1.x: C#
public sealed class OracleDataReader : MarshalByRefObject, IEnumerable,
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
An OracleDataReader instance is constructed by a call to the ExecuteReader method of the OracleCommand object. The only properties that can be accessed after the DataReader is closed or has been disposed, are IsClosed and RecordsAffected.
To minimize the number of open database cursors, OracleDataReader objects should be explicitly disposed.
Example
The following OracleDataReader example retrieves the data from the EMP table:
/* Database Setup, if you have not done so yet.
connect scott/tiger@oracle
CREATE TABLE empInfo (
empno NUMBER(4) PRIMARY KEY,
empName VARCHAR2(20) NOT NULL,
hiredate DATE,
salary NUMBER(7,2),
jobDescription Clob,
byteCodes BLOB
Insert into empInfo(EMPNO,EMPNAME,JOBDESCRIPTION,byteCodes) values
(1,'KING','SOFTWARE ENGR', '5657');
(2,'SCOTT','MANAGER', '5960');
commit;
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleDataReaderSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    string cmdstr = "SELECT * FROM EMPINFO";
    OracleConnection connection = new OracleConnection(constr);
    OracleCommand cmd = new OracleCommand(cmdstr, con);
    OracleDataReader reader = cmd.ExecuteReader();
    // Declare the variables to retrieve the data in EmpInfo
    short empNo;
    string empName;
    DateTime hireDate;
    double salary;
    string jobDesc;
    byte[] byteCodes = new byte[10];
    // Read the next row until end of row
    while (reader.Read())
      empNo = reader.GetInt16(0);
      Console.WriteLine("Employee number: " + empNo);
      empName = reader.GetString(1);
      Console.WriteLine("Employee name: " + empName);
      // The following columns can have NULL value, so it
      //   is important to call IsDBNull before getting the column data
      if (!reader.IsDBNull(2))
        hireDate = reader.GetDateTime(2);
        Console.WriteLine("Hire date: " + hireDate);
      if (!reader.IsDBNull(3))
        salary = reader.GetDouble(3);
        Console.WriteLine("Salary: " + salary);
      if (!reader.IsDBNull(4))
        jobDesc = reader.GetString(4);
        Console.WriteLine("Job Description: " + jobDesc);
      if (!reader.IsDBNull(5))
        long len = reader.GetBytes(5, 0, byteCodes, 0, 10);
        Console.Write("Byte codes: ");
        for (int i = 0; i < len; i++)
          Console.Write(byteCodes[i].ToString("x"));
        Console.WriteLine();
    // Clean up
    reader.Dispose();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleDataReader Members
OracleDataReader members are listed in the following tables.
OracleDataReader Static Methods
The OracleDataReader static method is listed in Table 5-38.
Table 5-38 OracleDataReader Static Method
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleDataReader Properties
OracleDataReader properties are listed in Table 5-39.
Table 5-39 OracleDataReader Properties
Property Description
Depth
Gets a value indicating the depth of nesting for the current row
FetchSize
Specifies the size of OracleDataReader's internal cache
FieldCount
Gets the number of columns in the result set
HasRows
Indicates whether the OracleDataReader has one or more rows
HiddenFieldCount
Gets the number of fields in the OracleDataReader that are hidden
Supported Only in ADO.NET 2.0-Compliant ODP.NET
IsClosed
Indicates whether or not the data reader is closed
Item
Gets the value of the column (Overloaded)
InitialLOBFetchSize
Specifies the amount that the OracleDataReader initially fetches for LOB columns
InitialLONGFetchSize
Specifies the amount that the OracleDataReader initially fetches for LONG and LONG RAW columns
RecordsAffected
Gets the number of rows changed, inserted, or deleted by execution of the SQL statement
RowSize
Gets the amount of memory the internal cache of the OracleDataReader needs to store one row of data.
VisibleFieldCount
Gets the number of fields in the OracleDataReader that are not hidden
OracleDataReader Public Methods
OracleDataReader public methods are listed in Table 5-40.
Table 5-40 OracleDataReader Public Methods
Public Method Description
Close
Closes the OracleDataReader
CreateObjRef
Inherited from System.MarshalByRefObject
Dispose
Releases any resources or memory allocated by the object
Equals
GetBoolean
Not Supported
GetByte
Returns the byte value of the specified column
GetBytes
Populates the provided byte array with up to the maximum number of bytes, from the specified offset (in bytes) of the column
GetChar
Not Supported
GetChars
Populates the provided character array with up to the maximum number of characters, from the specified offset (in characters) of the column
GetData
Not Supported
GetDataTypeName
Returns the ODP.NET type name of the specified column
GetDateTime
Returns the DateTime value of the specified column
GetDecimal
Returns the decimal value of the specified NUMBER column
GetDouble
Returns the double value of the specified NUMBER column or BINARY_DOUBLE column
GetEnumerator
Returns an IEnumerator that can be used to iterate through the collection
GetFieldType
Returns the Type of the specified column
GetFloat
Returns the float value of the specified NUMBER column or BINARY_FLOAT column
GetGuid
Not Supported
GetHashCode
GetInt16
Returns the Int16 value of the specified NUMBER column
GetInt32
Returns the Int32 value of the specified NUMBER column
GetInt64
Returns the Int64 value of the specified NUMBER column
GetLifetimeService
Inherited by System.MarshalByRefObject
GetName
Returns the name of the specified column
GetOracleBFile
Returns an OracleBFile object of the specified BFILE column
GetOracleBinary
Returns an OracleBinary structure of the specified column
GetOracleBlob
Returns an OracleBlob object of the specified BLOB column
GetOracleBlobForUpdate
Returns an updatable OracleBlob object of the specified BLOB column
GetOracleClob
Returns an OracleClob object of the specified CLOB column
GetOracleClobForUpdate
Returns an updatable OracleClob object of the specified CLOB column
GetOracleDate
Returns an OracleDate structure of the specified DATE column
GetOracleDecimal
Returns an OracleDecimal structure of the specified NUMBER column
GetOracleIntervalDS
Returns an OracleIntervalDS structure of the specified INTERVAL DAY TO SECOND column
GetOracleIntervalYM
Returns an OracleIntervalYM structure of the specified INTERVAL YEAR TO MONTH column
GetOracleRef
Returns an OracleRef object of the specified REF column
GetOracleString
Returns an OracleString structure of the specified column
GetOracleTimeStamp
Returns an OracleTimeStamp structure of the Oracle TimeStamp column
GetOracleTimeStampLTZ
Returns an OracleTimeStampLTZ structure of the specified Oracle TimeStamp WITH LOCAL TIME ZONE column
GetOracleTimeStampTZ
Returns an OracleTimeStampTZ structure of the specified Oracle TimeStamp WITH TIME ZONE column
GetOracleXmlType
Returns an OracleXmlType object of the specified XMLType column
GetOracleValue
Returns the specified column value as a ODP.NET type
GetOracleValues
Gets all the column values as ODP.NET types
GetOrdinal
Returns the 0-based ordinal (or index) of the specified column name
GetProviderSpecificFieldType
Returns the provider-specific type of the specified column
GetProviderSpecificValue
Returns an object that represents the underlying provider-specific value of the specified ordinal
GetProviderSpecificValues
Returns an array of objects that represent the underlying provider-specific values
GetSchemaTable
Returns a DataTable that describes the column metadata of the OracleDataReader
GetString
Returns the string value of the specified column
GetTimeSpan
Returns the TimeSpan value of the specified INTERVAL DAY TO SECOND column
GetType
Inherited from System.Object class
GetValue
Returns the column value as a .NET type
GetValues
Gets all the column values as .NET types
GetXmlReader
Returns the value of an XMLType column as an instance of an .NET XmlTextReader
IsDBNull
Indicates whether or not the column value is null
NextResult
Advances the data reader to the next result set when reading the results
Read
Reads the next row in the result set
ToString
The OracleDataReader static method is listed in Table 5-41.
Table 5-41 OracleDataReader Static Method
Method Description
Equals
OracleDataReader properties are listed in Table 5-42.
Table 5-42 OracleDataReader Properties
Depth
FetchSize
FieldCount
HasRows
HiddenFieldCount
IsClosed
Item
InitialLOBFetchSize
RecordsAffected
RowSize
VisibleFieldCount
Depth
This property gets a value indicating the depth of nesting for the current row.
Declaration
// ADO.NET 2.0: C#
public override int Depth {get;}
// ADO.NET 1.x: C#
public int Depth {get;}
Property Value
The depth of nesting for the current row.
Implements
IDataReader
Exceptions
InvalidOperationException - The reader is closed.
Remarks
Default = 0
This property always returns zero because Oracle does not support nesting.
FetchSize
This property specifies the size of OracleDataReader's internal cache.
Declaration
// C#
public long FetchSize {get; set;}
Property Value
A long that specifies the amount of memory (in bytes) that the OracleDataReader uses for its internal cache.
Exceptions
ArgumentException - The FetchSize value specified is invalid.
Remarks
Default = The OracleCommand's FetchSize property value.
The FetchSize property is inherited by the OracleDataReader that is created by a command execution returning a result set. The FetchSize property on the OracleDataReader object determines the amount of data fetched into its internal cache for each database round-trip.
The RowSize and FetchSize properties handle UDT and XMLType data differently than other scalar data types. Because only a reference to the UDT and XMLType data is stored in the ODP.NET's internal cache, the RowSize property accounts for only the memory needed for the reference (which is very small) and not the actual size of the UDT and XMLType data. Thus, applications can inadvertently fetch massive amount s of UDT or XMLType instances from the database in a single database round-trip because the actual size of UDT and XMLType data do not count against the FetchSize, and it would require numerous UDT and XMLType references to fill up the default cache size of 64K. Therefore, when fetching UDT or XMLType data, the FetchSize property must be appropriately configured to control the number of UDT and XMLType instances that are to be fetched, rather than the amount of the actual UDT and XMLType data to be fetched
NOTE: For LOB and LONG data types, only the sizes specified in the InitialLOBFetchSize and InitialLONGFetchSize properties are accounted for by the RowSize property in addition to the metadata and reference information that is maintained by the cache for each LOB in the select list.
FieldCount
This property returns the number of columns in the result set.
Declaration
// ADO.NET 2.0: C#
public override int FieldCount {get;}
// ADO.NET 1.x: C#
public int FieldCount {get;}
Property Value
The number of columns in the result set if one exists, otherwise 0.
Implements
IDataRecord
Exceptions
Remarks
Default = 0
This property has a value of 0 for queries that do not return result sets.
HasRows
This property indicates whether the OracleDataReader has one or more rows.
Declaration
// ADO.NET 2.0: C#
public override bool HasRows {get;}
// ADO.NET 1.x: C#
public bool HasRows {get;}
Return Value
bool
Remarks
HasRows indicates whether or not the OracleDataReader has any rows.
The value of HasRows does not change based on the row position. For example, even if the application has read all the rows from the result set and the next Read method invocation will return false, the HasRows property still returns true since the result set was not empty to begin with.
Rows are fetched to determine the emptiness of the OracleDataReader when HasRows property is accessed for the first time after the creation of the OracleDataReader object.
Example
// C#
using System;
class HasRowsSample
  static void Main()
    con.Open();
      "select * from emp where empno = 9999", con);
    if (!reader.HasRows)
      Console.WriteLine("The result set is empty.");
    else
      Console.WriteLine("The result set is not empty.");
    con.Dispose();
See Also:
HiddenFieldCount
This property gets the number of fields in the OracleDataReader that are hidden.
Declaration
// C#
public int HiddenFieldcount { get; }
Property Value
The number of fields in the OracleDataReader that are hidden.
Exceptions
Remarks
OracleDataReader.FieldCount and OracleDataReader.VisibleFieldCount return the visible field count.
IsClosed
This property indicates whether or not the data reader is closed.
Declaration
// ADO.NET 2.0: C#
public override bool IsClosed {get;}
// ADO.NET 1.x: C#
public bool IsClosed {get;}
Property Value
If the OracleDataReader is in a closed state, returns true; otherwise, returns false.
Implements
IDataReader
Remarks
Default = true
IsClosed and RecordsAffected are the only two properties that are accessible after the OracleDataReader is closed.
Item
This property gets the value of the column in .NET data type.
Overload List:
Item [index]
This property gets the .NET Value of the column specified by the column index.
Declaration
// ADO.NET 2.0: C#
public override object this[int index] {get;}
// ADO.NET 1.x: C#
public object this[int index] {get;}
Parameters
Property Value
The .NET value of the specified column.
Implements
IDataRecord
Remarks
Default = Not Applicable
In C#, this property is the indexer for this class.
Item [string]
This property gets the .NET Value of the column specified by the column name.
Declaration
// ADO.NET 2.0: C#
public override object this[string columnName] {get;}
// ADO.NET 1.x: C#
public object this[string columnName] {get;}
Parameters
Property Value
The .NET Value of the specified column.
Implements
IDataRecord
Remarks
A case-sensitive search is made to locate the specified column by its name. If this fails, then a case-insensitive search is made.
InitialLOBFetchSize
This property specifies the amount that the OracleDataReader initially fetches for LOB columns.
Declaration
// C#
public int InitialLOBFetchSize {get;}
Property Value
The size of the chunk to retrieve.
Exceptions
Remarks
For Oracle Database 10g release 2 (10.2) and later, the maximum value supported for InitialLOBFetchSize is 2 GB.
For releases prior to Oracle Database 10g release 2 (10.2), the maximum value supported for InitialLOBFetchSize is 32K.
Default is the OracleCommand.InitialLOBFetchSize, from which this value is inherited.
This property specifies the amount that the OracleDataReader initially fetches for LONG and LONG RAW columns.
Declaration
// C#
public long InitialLONGFetchSize {get;}
Property Value
The size of the chunk to retrieve. The default is 0.
Exceptions
Remarks
The maximum value supported for InitialLONGFetchSize is 32767. If this property is set to a higher value, the provider resets it to 32767.
Default is OracleCommand.InitialLONGFetchSize, from which this value is inherited.
This property is read-only for the OracleDataReader.
RecordsAffected
This property gets the number of rows changed, inserted, or deleted by execution of the SQL statement.
Declaration
// C#
public int RecordsAffected {get;}
Property Value
The number of rows affected by execution of the SQL statement.
Implements
IDataReader
Remarks
Default = 0
The value of -1 is returned for SELECT statements.
RowSize
This property gets the amount of memory the internal cache of the OracleDataReader needs to store one row of data.
Declaration
// C#
public long RowSize {get;}
Property Value
A long that indicates the amount of memory (in bytes) that an OracleDataReader needs to store one row of data for the executed query.
Remarks
The RowSize property is set to a nonzero value when the OracleDataReader object is created. This property can be used at design time or dynamically during run time, to set the FetchSize property, based on the number of rows. For example, to enable the OracleDataReader object to fetch N rows for each database round-trip, the OracleDataReader FetchSize property can be set dynamically to RowSize * N. Note that for the FetchSize property to take effect appropriately, it must be set before the first invocation of OracleDataReader.Read() for the particular result set.
VisibleFieldCount
This property gets the number of fields in the OracleDataReader that are not hidden.
Declaration
// C#
public override int VisibleFieldcount { get; }
Property Value
The number of fields that are not hidden.
Exceptions
Remarks
If an application sets the AddRowid property on an OracleCommand object to true, then the application can access the RowId but it is not a visible field. If RowId is added in the select statement list, then it is a visible field. OracleDataReader.VisibleFieldCount and OracleDataReader.FieldCount always have the same value.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
class VisibleFieldCountSample
  static void Main(string[] args)
    string constr = "User Id=scott; Password=tiger; Data Source=oracle;";
    DbProviderFactory factory =
            DbProviderFactories.GetFactory("Oracle.DataAccess.Client");
    using (DbConnection conn = factory.CreateConnection())
      conn.ConnectionString = constr;
      try
        conn.Open();
        OracleCommand cmd = (OracleCommand)factory.CreateCommand();
        cmd.Connection = (OracleConnection)conn;
        //to gain access to ROWIDs of the table
        cmd.AddRowid = true;
        cmd.CommandText = "select empno, ename from emp;";
        int visFC = reader.VisibleFieldCount; //Results in 2
        int hidFC = reader.HiddenFieldCount;  // Results in 1
        Console.Write("Visible field count: " + visFC);
        Console.Write("Hidden field count: " + hidFC);
        reader.Dispose();
        cmd.Dispose();
      catch (Exception ex)
        Console.WriteLine(ex.Message);
        Console.WriteLine(ex.StackTrace);
OracleDataReader public methods are listed in Table 5-43.
Table 5-43 OracleDataReader Public Methods
Close
CreateObjRef
Dispose
Equals
GetBoolean
Not Supported
GetByte
GetBytes
GetChar
Not Supported
GetChars
GetData
Not Supported
GetDataTypeName
GetDateTime
GetDecimal
GetDouble
GetEnumerator
GetFieldType
GetFloat
GetGuid
Not Supported
GetHashCode
GetInt16
GetInt32
GetInt64
GetLifetimeService
GetName
GetOracleBFile
GetOracleBinary
GetOracleBlob
GetOracleClob
GetOracleDate
GetOracleDecimal
GetOracleIntervalDS
GetOracleIntervalYM
GetOracleRef
GetOracleString
GetOracleTimeStamp
GetOracleXmlType
GetOracleValue
GetOracleValues
GetOrdinal
GetSchemaTable
GetString
GetTimeSpan
GetType
GetValue
GetValues
GetXmlReader
IsDBNull
NextResult
Read
ToString
Close
This method closes the OracleDataReader.
Declaration
// ADO.NET 2.0: C#
public override void Close();
// ADO.NET 1.x: C#
public void Close();
Implements
IDataReader
Remarks
The Close method frees all resources associated with the OracleDataReader.
Example
The code example for the OracleDataReader class includes the Close method. See OracleDataReader Overview "Example".
Dispose
This method releases any resources or memory allocated by the object.
Declaration
// C#
public void Dispose();
Implements
IDisposable
Remarks
The Dispose method also closes the OracleDataReader.
GetBoolean
This method is not supported.
Declaration
// ADO.NET 2.0: C#
public override bool GetBoolean(int index);
// ADO.NET 1.x: C#
public bool GetBoolean(int index);
Parameters
Implements
IDataRecord
Exceptions
NotSupportedException - This property is not supported.
GetByte
This method returns the byte value of the specified column.
Declaration
// ADO.NET 2.0: C#
public override byte GetByte(int index);
// ADO.NET 1.x: C#
public byte GetByte(int index);
Parameters
Return Value
The value of the column as a byte.
Implements
IDataRecord
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called, or all rows have been read.
IndexOutOfRangeException - The column index is invalid.
InvalidCastException - The accessor method is invalid for this column type or the column value is NULL.
Remarks
IsDBNull should be called to check for NULL values before calling this method.
GetBytes
This method populates the provided byte array with up to the maximum number of bytes, from the specified offset (in bytes) of the column.
Declaration
// ADO.NET 2.0: C#
public override long GetBytes(int index, long fieldOffset, byte[] buffer,
   int bufferOffset, int length);
// ADO.NET 1.x: C#
public long GetBytes(int index, long fieldOffset, byte[] buffer,
Parameters
Return Value
The number of bytes read.
Implements
IDataRecord
Exceptions
Remarks
This method returns the number of bytes read into the buffer. This may be less than the actual length of the field if the method has been called previously for the same column.
If a null reference is passed for buffer, the length of the field in bytes is returned.
GetChar
Declaration
// ADO.NET 2.0: C#
public override long GetChar(int index);
// ADO.NET 1.x: C#
public long GetChar(int index);
Parameters
Implements
IDataRecord
Exceptions
GetChars
This method populates the provided character array with up to the maximum number of characters, from the specified offset (in characters) of the column.
Declaration
// ADO.NET 2.0: C#
public override long GetChars(int index, long fieldOffset, char[] buffer,
// ADO.NET 1.x: C#
public long GetChars(int index, long fieldOffset, char[] buffer,
Parameters
Return Value
The number of characters read.
Implements
IDataRecord
Exceptions
Remarks
This method returns the number of characters read into the buffer. This may be less than the actual length of the field, if the method has been called previously for the same column.
If a null reference is passed for buffer, the length of the field in characters is returned.
GetDataTypeName
This method returns the ODP.NET type name of the specified column.
Declaration
// ADO.NET 2.0: C#
public override string GetDataTypeName(int index);
// ADO.NET 1.x: C#
public string GetDataTypeName(int index);
Parameters
Return Value
The name of the ODP.NET type of the column.
Implements
IDataRecord
Exceptions
GetDateTime
This method returns the DateTime value of the specified column.
Declaration
// ADO.NET 2.0: C#
public override DateTime GetDateTime(int index);
// ADO.NET 1.x: C#
public DateTime GetDateTime(int index);
Parameters
Return Value
The DateTime value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetDecimal
This method returns the decimal value of the specified NUMBER column.
Declaration
// ADO.NET 2.0: C#
public override decimal GetDecimal(int index);
// ADO.NET 1.x: C#
public decimal GetDecimal(int index);
Parameters
Return Value
The decimal value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetDouble
This method returns the double value of the specified NUMBER column or BINARY_DOUBLE column.
Declaration
// ADO.NET 2.0: C#
public override double GetDouble(int index);
// ADO.NET 1.x: C#
public double GetDouble(int index);
Parameters
Return Value
The double value of the column.
Implements
IDataRecord
Exceptions
Remarks
Starting with Oracle Database 10g, GetDouble now supports retrieval of data from BINARY_DOUBLE columns.
GetEnumerator
This method returns an IEnumerator that can be used to iterate through the collection (record set).
Declaration
// ADO.NET 2.0: C#
public override IEnumerator GetEnumerator();
// ADO.NET 1.x: C#
IEnumerator IEnumerable.GetEnumerator();
Return Value
An IEnumerator that can be used to iterate through the collection (record set).
Exceptions
GetFieldType
This method returns the type of the specified column.
Declaration
// ADO.NET 2.0: C#
public override Type GetFieldType(int index);
// ADO.NET 1.x: C#
public Type GetFieldType(int index);
Parameters
Return Value
The type of the default .NET type of the column.
Implements
IDataRecord
Exceptions
InvalidOperationException - The reader is closed, or the specified column is a UDT but no registered custom type mapping exists for the UDT.
Remarks
GetFieldType returns a type that corresponds to the value that the application obtains after invoking the GetValue accessor or Item property on the OracleDataReader. For example, if the column is a string, this method returns a .NET Type object for a .NET string.
If the attribute is a UDT, this method may return either of the following:
GetFloat
This method returns the float value of the specified NUMBER column or BINARY_FLOAT column.
Declaration
// ADO.NET 2.0: C#
public override float GetFloat(int index);
// ADO.NET 1.x: C#
public float GetFloat(int index);
Parameters
Return Value
The float value of the column.
Implements
IDataRecord
Exceptions
Remarks
Starting with Oracle Database 10g, GetFloat now supports retrieval of data from BINARY_FLOAT columns.
GetGuid
Declaration
// ADO.NET 2.0: C#
public override Guid GetGuid(int index);
// ADO.NET 1.x: C#
public Guid GetGuid(int index);
Parameters
Implements
IDataRecord
Exceptions
GetInt16
This method returns the Int16 value of the specified NUMBER column.
short is equivalent to Int16.
Declaration
// ADO.NET 2.0: C#
public override short GetInt16(int index);
// ADO.NET 1.x: C#
public short GetInt16(int index);
Parameters
Return Value
The Int16 value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetInt32
This method returns the Int32 value of the specified NUMBER column.
int is equivalent to Int32.
Declaration
// ADO.NET 2.0: C#
public override int GetInt32(int index);
// ADO.NET 1.x: C#
public int GetInt32(int index);
Parameters
Return Value
The Int32 value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetInt64
This method returns the Int64 value of the specified NUMBER column.
long is equivalent to Int64.
Declaration
// ADO.NET 2.0: C#
public override long GetInt64(int index);
// ADO.NET 1.x: C#
public long GetInt64(int index);
Parameters
Return Value
The Int64 value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetName
This method returns the name of the specified column.
Declaration
// ADO.NET 2.0: C#
public override string GetName(int index);
// ADO.NET 1.x: C#
public string GetName(int index);
Parameters
Return Value
The name of the column.
Implements
IDataRecord
Exceptions
GetOracleBFile
This method returns an OracleBFile object of the specified BFILE column.
Declaration
// C#
public OracleBFile GetOracleBFile(int index);
Parameters
Return Value
The OracleBFile value of the column.
Exceptions
Remarks
GetOracleBinary
This method returns an OracleBinary structure of the specified column.
Declaration
// C#
public OracleBinary GetOracleBinary(int index);
Parameters
Return Value
The OracleBinary value of the column.
Exceptions
Remarks
GetOracleBinary is used on the following Oracle types:
GetOracleBlob
This method returns an OracleBlob object of the specified BLOB column.
Declaration
// C#
public OracleBlob GetOracleBlob(int index);
Parameters
Return Value
The OracleBlob value of the column.
Exceptions
Remarks
GetOracleBlobForUpdate returns an updatable OracleBlob object of the specified BLOB column.
Overload List:
GetOracleBlobForUpdate(int)
This method returns an updatable OracleBlob object of the specified BLOB column.
Declaration
// C#
public OracleBlob GetOracleBlobForUpdate(int index);
Parameters
Return Value
An updatable OracleBlob object.
Exceptions
Remarks
When the OracleCommand's ExecuteReader() method is invoked, all the data fetched by the OracleDataReader is from a particular snapshot. Therefore, calling an accessor method on the same column always returns the same value. However, the GetOracleBlobForUpdate() method incurs a database round-trip to obtain a reference to the current BLOB data while also locking the row using the FOR UPDATE clause. This means that the OracleBlob obtained from GetOracleBlob() can have a different value than the OracleBlob obtained from GetOracleBlobForUpdate() since it is not obtained from the original snapshot.
The returned OracleBlob object can be used to safely update the BLOB because the BLOB column has been locked after a call to this method.
Invoking this method internally executes a SELECT..FOR UPDATE statement without a WAIT clause. Therefore, the statement can wait indefinitely until a lock is acquired for that row.
Example
The following example gets the OracleBlob object for update from the reader, updates the OracleBlob object, and then commits the transaction.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
using Oracle.DataAccess.Types;
class GetOracleBlobForUpdateSample
  static void Main()
    con.Open();
    // Get the ByteCodes for empno = 1
    string cmdstr = "SELECT BYTECODES, EMPNO FROM EMPINFO where EMPNO = 1";
    // Since we are going to update the OracleBlob object, we will
    //have to create a transaction
    OracleTransaction txn = con.BeginTransaction();
    // Get the reader
    OracleBlob byteCodesBlob;
    // Read the first row
    reader.Read();
    if (!reader.IsDBNull(0))
      byteCodesBlob = reader.GetOracleBlobForUpdate(0);
      // Close the reader
      reader.Close();
      // Update the ByteCodes object
      byte[] addedBytes = new byte[2] {0, 0};
      byteCodesBlob.Append(addedBytes, 0, addedBytes.Length);
      // Now commit the transaction
      txn.Commit();
      Console.WriteLine("Blob Column successfully updated");
    else
      reader.Dispose();
    // Close the connection
    con.Dispose();
GetOracleBlobForUpdate(int, int)
This method returns an updatable OracleBlob object of the specified BLOB column using a WAIT clause.
Declaration
// C#
public OracleBlob GetOracleBlobForUpdate(int index, int wait);
Parameters
Return Value
Exceptions
Remarks
Invoking this method internally executes a SELECT..FOR UPDATE statement which locks the row.
Different WAIT clauses are appended to the statement, depending on the wait value. If the wait value is:
Example
The GetOracleBlobForUpdate methods are comparable. See "Example" for a code example demonstrating usage.
GetOracleClob
This method returns an OracleClob object of the specified CLOB column.
Declaration
// C#
public OracleClob GetOracleClob(int index);
Parameters
Return Value
The OracleClob value of the column.
Exceptions
Remarks
GetOracleClobForUpdate returns an updatable OracleClob object of the specified CLOB column.
Overload List:
GetOracleClobForUpdate(int)
This method returns an updatable OracleClob object of the specified CLOB column.
Declaration
// C#
public OracleClob GetOracleClobForUpdate(int index);
Parameters
Return Value
An updatable OracleClob.
Exceptions
Remarks
When the OracleCommand's ExecuteReader() method is invoked, all the data fetched by the OracleDataReader is from a particular snapshot. Therefore, calling an accessor method on the same column always returns the same value. However, the GetOracleClobForUpdate() method incurs a database round-trip to obtain a reference to the current CLOB data while also locking the row using the FOR UPDATE clause. This means that the OracleClob obtained from GetOracleClob() can have a different value than the OracleClob obtained from GetOracleClobForUpdate() since it is not obtained from the original snapshot.
The returned OracleClob object can be used to safely update the CLOB because the CLOB column is locked after a call to this method.
Example
The following example gets the OracleClob object for update from the reader, updates the OracleClob object, and then commits the transaction.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
class GetOracleClobForUpdateSample
  static void Main()
    con.Open();
    // Get the job description for empno = 1
    string cmdStr = "SELECT JOBDESCRIPTION, EMPNO FROM EMPINFO where EMPNO = 1";
    OracleCommand cmd = new OracleCommand(cmdStr, con);
    // Since we are going to update the OracleClob object, we will
    //  have to create a transaction
    // Get the reader
    OracleClob jobDescClob;
    reader.Read();
      jobDescClob = reader.GetOracleClobForUpdate(0);
      // Close the reader
      reader.Close();
      // Update the job description Clob object
      char[] jobDesc = "-SALES".ToCharArray();
      jobDescClob.Append(jobDesc, 0, jobDesc.Length);
      txn.Commit();
      Console.WriteLine("Clob Column successfully updated");
    else
      reader.Close();
    con.Close();
GetOracleClobForUpdate(int, int)
This method returns an updatable OracleClob object of the specified CLOB column using a WAIT clause.
Declaration
// C#
public OracleClob GetOracleClobForUpdate(int index, int wait);
Parameters
Return Value
Exceptions
Remarks
Example
The GetOracleClobForUpdate methods are comparable. See "Example" for a code example demonstrating usage.
GetOracleDate
This method returns an OracleDate structure of the specified DATE column.
Declaration
// C#
public OracleDate GetOracleDate(int index);
Parameters
Return Value
The OracleDate value of the column.
Exceptions
Remarks
GetOracleDecimal
This method returns an OracleDecimal structure of the specified NUMBER column.
Declaration
// C#
public OracleDecimal GetOracleDecimal(int index);
Parameters
Return Value
The OracleDecimal value of the column.
Exceptions
Remarks
GetOracleIntervalDS
This method returns an OracleIntervalDS structure of the specified INTERVAL DAY TO SECOND column.
Declaration
// C#
public OracleIntervalDS GetOracleIntervalDS(int index);
Parameters
Return Value
The OracleIntervalDS value of the column.
Exceptions
Remarks
GetOracleIntervalYM
This method returns an OracleIntervalYM structure of the specified INTERVAL YEAR TO MONTH column.
Declaration
// C#
public OracleIntervalYM GetOracleIntervalYM(int index);
Parameters
Return Value
The OracleIntervalYM value of the column.
Exceptions
Remarks
GetOracleRef
This method returns an OracleRef object of the specified REF column.
Declaration
// C#
public OracleRef GetOracleRef(int index);
Parameters
Return Value
The OracleRef object of the specified column.
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, the Read method has not been called, or all rows have been read.
InvalidCastException - The accessor method is invalid for this column type.
GetOracleString
This method returns an OracleString structure of the specified column.
Declaration
// C#
public OracleString GetOracleString(int index);
Parameters
Return Value
The OracleString value of the column.
Exceptions
Remarks
If the column is an Oracle REF column, the string returned is a hexadecimal value that represents the REF in the database.
GetOracleTimeStamp
This method returns an OracleTimeStamp structure of the Oracle TimeStamp column.
Declaration
// C#
public OracleTimeStamp GetOracleTimeStamp(int index);
Parameters
Return Value
The OracleTimeStamp value of the column.
Exceptions
Remarks
GetOracleTimeStamp is used with the Oracle Type TimeStamp.
This method returns an OracleTimeStampLTZ structure of the specified Oracle TimeStamp WITH LOCAL TIME ZONE column.
Declaration
// C#
public OracleTimeStampLTZ GetOracleTimeStampLTZ(int index);
Parameters
Return Value
The OracleTimeStampLTZ value of the column.
Exceptions
Remarks
GetOracleTimeStampLTZ is used with the Oracle Type TimeStamp with Local Time Zone columns.
This method returns an OracleTimeStampTZ structure of the specified Oracle TimeStamp WITH TIME ZONE column.
Declaration
// C#
public OracleTimeStampTZ GetOracleTimeStampTZ(int index);
Parameters
Return Value
The OracleTimeStampTZ value of the column.
Exceptions
Remarks
Used with the Oracle Type TimeStamp with Local Time Zone columns
GetOracleXmlType
This method returns an OracleXmlType object of the specified XMLType column.
Declaration
// C#
public OracleXmlType GetOracleXmlType(int index);
Parameters
Return Value
The OracleXmlType value of the column.
Exceptions
Remarks
Requirements
This property can only be used with Oracle9i Release 2 (9.2) or later.
GetOracleValue
This method returns the specified column value as an ODP.NET type.
Declaration
// C#
public object GetOracleValue(int index);
Parameters
Return Value
The value of the column as an ODP.NET type.
Exceptions
Remarks
If the column is an Oracle object or Oracle collection column and a custom type mapping exists, then a custom type is returned.
If the column is an Oracle REF column, then an OracleRef is returned.
GetOracleValues
This method gets all the column values as ODP.NET types.
Declaration
// C#
public int GetOracleValues(object[] values);
Parameters
Return Value
The number of ODP.NET types in the values array.
Exceptions
Remarks
This method provides a way to retrieve all column values rather than retrieving each column value individually.
The number of column values retrieved is the minimum of the length of the values array and the number of columns in the result set.
GetOrdinal
This method returns the 0-based ordinal (or index) of the specified column name.
Declaration
// ADO.NET 2.0: C#
public override int GetOrdinal(string name);
// ADO.NET 1.x: C#
public int GetOrdinal(string name);
Parameters
Return Value
The index of the column.
Implements
IDataRecord
Exceptions
Remarks
This method returns the provider-specific type of the specified column.
Declaration
// ADO.NET 2.0: C#public override Type GetProviderSpecificFieldType(int index);
Parameters
Return Value
The provider-specific type of the specified column. This is a member of the Oracle.DataAccess.Types namespace.
Exceptions
Remarks
GetProviderSpecficFieldType returns a type that corresponds to the value the application obtains after invoking the GetProviderSpecificValue accessor on the OracleDataReader. For example, if the column is a string, this method returns a .NET Type object for an OracleString.
If the attribute is a UDT, this method may return any of the following:
This method returns an object that represents the underlying provider-specific value of the specified ordinal.
Declaration
// ADO.NET 2.0: C#
public override object GetProviderSpecificValue (int index);
Parameters
index
A zero-based column index.
Return Value
An Object that is a representation of the underlying provider-specific field type.
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called or all rows have been read.
Remarks
If the column is an Oracle object or collection column, and a custom type mapping exists, a custom type is returned.
If the column is an Oracle REF column, an OracleRef is returned.
This method returns an array of objects that represent the underlying provider-specific values.
Declaration
// ADO.NET 2.0: C#
public override int GetProviderSpecificValues(object [ ] values);
Parameters
Return Value
The number of Object instances in the array.
Exceptions
GetSchemaTable
This method returns a DataTable that describes the column metadata of the OracleDataReader.
Declaration
// ADO.NET 2.0: C#
public override DataTable GetSchemaTable();
// ADO.NET 1.x: C#
public DataTable GetSchemaTable();
Return Value
A DataTable that contains the metadata of the result set.
Implements
IDataReader
Exceptions
InvalidOperationException - The connection is closed or the reader is closed.
Remarks
The OracleDataReader.GetSchemaTable method returns the SchemaTable.
OracleDataReader SchemaTable
The OracleDataReader SchemaTable is a DataTable that describes the column metadata of the OracleDataReader.
The columns of the SchemaTable are in the order shown.
Table 5-44 OracleDataReader SchemaTable
Name Name Type Description
ColumnName
System.String
ColumnOrdinal
System.Int32
The 0-based ordinal of the column.
ColumnSize
System.Int64
The maximum possible length of a value in the column. ColumnSize value is determined as follows:
  • CHAR and VARCHAR2 types:
    in bytes - if IsByteSemantic boolean value is true
    in characters - if IsByteSemantic boolean value is false
  • All other types:
    in bytes
See "IsByteSemantic" for more information.
NumericPrecision
System.Int16
The maximum precision of the column, if the column is a numeric data type.
This column has valid values for Oracle NUMBER, Oracle INTERVAL YEAR TO MONTH, and Oracle INTERVAL DAY TO SECOND columns. For all other columns, the value is null.
NumericScale
System.Int16
The scale of the column.
This column has valid values for Oracle NUMBER, Oracle INTERVAL DAY TO SECOND, and the Oracle TIMESTAMP columns. For all other columns, the value is null.
IsUnique
System.Boolean
Indicates whether or not the column is unique.
true if no two rows in the base table can have the same value in this column, where the base table is the table returned in BaseTableName.
IsUnique is guaranteed to be true if one of the following applies:
  • the column constitutes a key by itself
  • there is a unique constraint or a unique index that applies only to this column and a NOT NULL constraint has been defined on the column
  • the column is an explicitly selected ROWID
IsUnique is false if the column can contain duplicate values in the base table.
The default is false.
The value of this property is the same for each occurrence of the base table column in the select list.
IsKey
System.Boolean
Indicates whether or not the column is a key column.
true if the column is one of a set of columns in the rowset that, taken together, uniquely identify the row. The set of columns with IsKey set to true must uniquely identify a row in the rowset. There is no requirement that this set of columns is a minimal set of columns.
This set of columns can be generated from one of the following in descending order of priority:
  • A base table primary key.
  • Any of the unique constraints or unique indexes with the following condition: A NOT NULL constraint must be defined on the column or on all of the columns, in the case of a composite unique constraint or composite unique index.
  • Any of the composite unique constraints or composite unique indexes with the following condition: A NULL constraint must be defined on at least one, but not all, of the columns.
An explicitly selected ROWID. false if the column is not required to uniquely identify the row. The value of this property is the same for each occurrence of the base table column in the select list.
IsRowID
System.Boolean
true if the column is a ROWID, otherwise false.
BaseColumnName
System.String
The name of the column in the database if an alias is used for the column.
BaseSchemaName
System.String
The name of the schema in the database that contains the column.
BaseTableName
System.String
The name of the table or view in the database that contains the column.
DataType
System.RuntimeType
Maps to the common language runtime type.
ProviderType
Oracle.DataAccess. Client.OracleDbType
The database column type (OracleDbType) of the column.
AllowDBNull
System.Boolean
true if null values are allowed, otherwise false.
IsAliased
System.Boolean
true if the column is an alias; otherwise false.
IsByteSemantic
System.Boolean
IsByteSemantic is:
  • true if the ColumnSize value uses bytes semantics
  • false if ColumnSize uses character semantics
This value is always true when connected to a database version earlier than Oracle9i.
IsExpression
System.Boolean
true if the column is an expression; otherwise false.
IsHidden
System.Boolean
true if the column is hidden; otherwise false.
IsReadOnly
System.Boolean
true if the column is read-only; otherwise false.
IsLong
System.Boolean
true if the column is a LONG, LONG RAW, BLOB, CLOB, or BFILE; otherwise false.
UdtTypeName
System.String
The type name of the UDT.
Example
This example creates and uses the SchemaTable from the reader.
hiredate DATE,
salary NUMBER(7,2),
byteCodes BLOB
commit;
// C#
using System;
using System.Data;
class GetSchemaTableSample
  static void Main()
    con.Open();
    string cmdstr = "SELECT EMPNO,EMPNAME FROM EMPINFO where EMPNO = 1";
    //get the reader
    //get the schema table
    DataTable schemaTable = reader.GetSchemaTable();
    //retrieve the first column info.
    DataRow row = schemaTable.Rows[0];
    //print out the column info
    Console.WriteLine("Column name: " + row["COLUMNNAME"]);
    Console.WriteLine("Precision: " + row["NUMERICPRECISION"]);
    Console.WriteLine("Scale: " + row["NUMERICSCALE"]);
    reader.Close();
    con.Close();
GetString
This method returns the string value of the specified column.
Declaration
// ADO.NET 2.0: C#
public override string GetString(int index);
// ADO.NET 1.x: C#
public string GetString(int index);
Parameters
Return Value
The string value of the column.
Implements
IDataRecord
Exceptions
Remarks
Call the IsDBNull method to check for null values before calling this method.
If the column is an Oracle REF column, the string returned is a hexadecimal string that represents the REF in the database.
GetTimeSpan
This method returns the TimeSpan value of the specified INTERVAL DAY TO SECOND column.
Declaration
// C#
public TimeSpan GetTimeSpan(int index);
Parameters
Return Value
The TimeSpan value of the column.
Implements
IDataRecord
Exceptions
Remarks
GetValue
This method returns the column value as a .NET type.
Declaration
// ADO.NET 2.0: C#
public override object GetValue(int index);
// ADO.NET 1.x: C#
public object GetValue(int index);
Parameters
Return Value
The value of the column as a .NET type.
Implements
IDataRecord
Exceptions
InvalidOperationException - The connection is closed, the reader is closed, Read() has not been called, all rows have been read, or no valid custom type mapping has been specified for the Oracle Object or Oracle Collection column.
Remarks
If the column is an Oracle Object or an Oracle Collection column, the .NET custom type corresponding to the custom type mapping is returned.
If the column is an Oracle REF column, a hexidecimal value is returned as a .NET string that represents the REF in the database.
If the UDT is NULL, DBNull.Value is returned
GetValues
This method gets all the column values as .NET types.
Declaration
// ADO.NET 2.0: C#
public override int GetValues(object[ ] values);
// ADO.NET 1.x: C#
public int GetValues(object[ ] values);
Parameters
Return Value
The number of objects in the values array.
Implements
IDataRecord
Exceptions
Remarks
GetXmlReader
This method returns the contents of an XMLType column as an instance of an .NET XmlTextReader object.
Declaration
// C#
public XmlReader GetXmlReader(int index);
Parameters
Return Value
A .NET XmlTextReader.
Exceptions
Remarks
IsDBNull
This method indicates whether or not the column value is NULL.
Declaration
// ADO.NET 2.0: C#
public override bool IsDBNull(int index);
// ADO.NET 1.x: C#
public bool IsDBNull(int index);
Parameters
Return Value
Returns true if the column is a NULL value; otherwise, returns false.
Implements
IDataRecord
Exceptions
InvalidOperationException - The reader is closed, Read() has not been called, or all rows have been read.
Remarks
This method should be called to check for NULL values before calling the other accessor methods.
Example
The code example for the OracleDataReader class includes the IsDBNull method. See "Example".
NextResult
This method advances the data reader to the next result set.
Declaration
// ADO.NET 2.0: C#
public override bool NextResult();
// ADO.NET 1.x: C#
public bool NextResult();
Return Value
Returns true if another result set exists; otherwise, returns false.
Implements
IDataReader
Exceptions
Remarks
NextResult is used when reading results from stored procedure execution that return more than one result set.
Read
This method reads the next row in the result set.
Declaration
// ADO.NET 2.0: C#
public override  bool Read();
// ADO.NET 1.x: C#
public bool Read();
Return Value
Returns true if another row exists; otherwise, returns false.
Implements
IDataReader
Exceptions
Remarks
The initial position of the data reader is before the first row. Therefore, the Read method must be called to fetch the first row. The row that was just read is considered the current row. If the OracleDataReader has no more rows to read, it returns false.
Example
The code example for the OracleDataReader class includes the Read method. See "Example".
