| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.6.20) E10927-01 |
![]() Previous |
![]() Next |
The OracleDecimal structure represents an Oracle NUMBER in the database or any Oracle numeric value.
Class Inheritance
System.Object
System.ValueType
Oracle.DataAccess.Types.OracleDecimal
Declaration
// ADO.NET 2.0: C# public struct OracleDecimal : IComparable, INullable, IXmlSerializable
// ADO.NET 1.x: C#public struct OracleDecimal : IComparable, INullable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
OracleDecimal can store up to 38 precision, while the .NET Decimal data type can only hold up to 28 precision. When accessing the OracleDecimal.Value property from an OracleDecimal that has a value greater than 28 precision, an exception is thrown. To retrieve the actual value of OracleDecimal, use the OracleDecimal.ToString() method. Another approach is to obtain the OracleDecimal value as a byte array in an internal Oracle NUMBER format through the BinData property.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleDecimalSample
static void Main(string[] args)
// Illustrates the range of OracleDecimal vs. .NET decimal
OracleDecimal decimal1 = OracleDecimal.MinValue;
OracleDecimal decimal2 = OracleDecimal.MaxValue;
OracleDecimal decimal3 = new OracleDecimal(decimal.MinValue);
OracleDecimal decimal4 = new OracleDecimal(decimal.MaxValue);
// Print the ranges
Console.WriteLine("OracleDecimal can range from\n{0}\nto\n{1}\n",
decimal1, decimal2);
Console.WriteLine(".NET decimal can range from\n{0}\nto\n{1}",
decimal3, decimal4);
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleDecimal members are listed in the following tables:
OracleDecimal Constructors
OracleDecimal constructors are listed in Table 12-27
Table 12-27 OracleDecimal Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleDecimal Static Fields
The OracleDecimal static fields are listed in Table 12-28.
Table 12-28 OracleDecimal Static Fields
| Field | Description |
A constant representing the maximum precision, which is 38 |
A constant representing the maximum scale, which is 127 |
A constant representing the maximum value for this structure, which is 9.9…9 x 10125 |
A constant representing the minimum scale, which is -84 |
A constant representing the minimum value for this structure, which is -1.0 x 10130 |
A constant representing the negative one value |
Represents a null value that can be assigned to an |
A constant representing the positive one value |
A constant representing the numeric Pi value |
A constant representing the zero value |
OracleDecimal Static (Comparison) Methods
The OracleDecimal static (comparison) methods are listed in Table 12-29.
Table 12-29 OracleDecimal Static (Comparison) Methods
| Methods | Description |
Determines if two |
Determines if the first of two |
Determines if two |
OracleDecimal Static (Manipulation) Methods
The OracleDecimal static (manipulation) methods are listed in Table 12-30.
Table 12-30 OracleDecimal Static (Manipulation) Methods
Returns the absolute value of an |
Adds two |
Returns a new |
Returns a new |
Returns a new |
Divides one |
Returns a new |
Returns the maximum value of the two supplied |
Returns the minimum value of the two supplied |
Returns a new |
Returns a new |
Returns a new |
Converts a |
Returns a new |
Returns a new |
Returns a new |
Determines the sign of an |
Returns a new |
Returns a new |
Truncates the |
OracleDecimal Static (Logarithmic) Methods
The OracleDecimal static (logarithmic) methods are listed in Table 12-31.
Table 12-31 OracleDecimal Static (Logarithmic) Methods
Returns a new |
Returns the supplied |
Returns a new |
OracleDecimal Static (Trigonometric) Methods
The OracleDecimal static (trigonometric) methods are listed in Table 12-32.
Table 12-32 OracleDecimal Static (Trigonometric) Methods
Returns an angle in radian whose cosine is the supplied |
Returns an angle in radian whose sine is the supplied |
Returns an angle in radian whose tangent is the supplied |
Returns an angle in radian whose tangent is the quotient of the two supplied |
Returns the cosine of the supplied angle in radian |
Returns the sine of the supplied angle in radian |
Returns the tangent of the supplied angle in radian |
Returns the hyperbolic cosine of the supplied angle in radian |
Returns the hyperbolic sine of the supplied angle in radian |
Returns the hyperbolic tangent of the supplied angle in radian |
OracleDecimal Static (Comparison) Operators
The OracleDecimal static (comparison) operators are listed in Table 12-33.
Table 12-33 OracleDecimal Static (Comparison) Operators
| Operator | Description |
Adds two |
Divides one |
Determines if the two |
Multiplies two |
Subtracts one |
Negates an |
Returns a new |
OracleDecimal Static Operators (Conversion from .NET Type to OracleDecimal)
The OracleDecimal static operators (Conversion from .NET Type to OracleDecimal) are listed in Table 12-34.
Table 12-34 OracleDecimal Static Operators (Conversion from .NET Type to OracleDecimal)
Converts an instance value to an |
OracleDecimal Static Operators (Conversion from OracleDecimal to .NET)
The OracleDecimal static operators (Conversion from OracleDecimal to .NET) are listed in Table 12-35.
Table 12-35 OracleDecimal Static Operators (Conversion from OracleDecimal to .NET)
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
OracleDecimal Properties
The OracleDecimal properties are listed in Table 12-36.
Table 12-36 OracleDecimal Properties
| Properties | Description |
Returns a byte array that represents the Oracle |
Specifies the format for |
Indicates whether or not the current instance is an integer |
Indicates whether or not the current instance has a null value |
Indicates whether or not the current instance is greater than |
Indicates whether or not the current instance has a |
Returns a |
OracleDecimal Instance Methods
The OracleDecimal instance methods are listed in Table 12-37.
Table 12-37 OracleDecimal Instance Methods
| Method | Description |
Compares the current instance to the supplied object and returns an integer that represents their relative values |
Determines whether or not an object is an instance of |
Returns a hash code for the current instance |
GetType |
Inherited from |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Overloads Returns the |
The OracleDecimal constructors instantiate a new instance of the OracleDecimal structure.
Overload List:
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied byte array, which is in an Oracle NUMBER format.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied Decimal value.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied double value.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied Int32 value.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied Single value.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied Int64 value.
This constructor creates a new instance of the OracleDecimal structure and sets its value to the supplied string value.
This constructor creates a new instance of the OracleDecimal structure with the supplied string value and number format.
Declaration
// C# public OracleDecimal(byte [] bytes);
Parameters
bytes
A byte array that represents an Oracle NUMBER in an internal Oracle format.
Exceptions
ArgumentException - The bytes parameter is not in a internal Oracle NUMBER format or bytes has an invalid value.
ArgumentNullException - The bytes parameter is null.
Declaration
// C#
public OracleDecimal(decimal decX);
Parameters
decX
The provided Decimal value.
Declaration
// C#
public OracleDecimal(double doubleX)
Parameters
doubleX
The provided double value.
Exceptions
OverFlowException - The value of the supplied double is greater than the maximum value or less than the minimum value of OracleDecimal.
Remarks
OracleDecimal contains the following values depending on the provided double value:
double.PositiveInfinity: positive infinity value
double.NegativeInfinity: negative infinity value.
double.NaN: null value
Declaration
// C#
public OracleDecimal(int intX);
Parameters
intX
The provided Int32 value.
Declaration
// C#
public OracleDecimal(float floatX);
Parameters
floatX
The provided float value.
Remarks
OracleDecimal contains the following values depending on the provided float value:
float.PositiveInfinity: positive infinity value
float.NegativeInfinity: negative infinity value
float.NaN: null value
Declaration
// C#
public OracleDecimal(long longX);
Parameters
longX
The provided Int64 value.
Declaration
// C#
public OracleDecimal(string numStr);
Parameters
numStr
The provided string value.
Exceptions
ArgumentException - The numStr parameter is an invalid string representation of an OracleDecimal.
ArgumentNullException - The numStr parameter is null.
OverFlowException - The value of numStr is greater than the maximum value or less than the minimum value of OracleDecimal.
Declaration
// C# public OracleDecimal(string numStr, string format);
Parameters
numStr
format
The provided number format.
Exceptions
ArgumentException - The numStr parameter is an invalid string representation of an OracleDecimal or the numStr is not in the numeric format specified by format.
OverFlowException - The value of numStr parameter is greater than the maximum value or less than the minimum value of OracleDecimal.
Remarks
If the numeric format includes decimal and group separators, then the provided string must use those characters defined by the OracleGlobalization.NumericCharacters of the thread.
If the numeric format includes the currency symbol, ISO currency symbol, or the dual currency symbol, then the provided string must use those symbols defined by the OracleGlobalization.Currency, OracleGlobalization.ISOCurrency, and OracleGlobalization.DualCurrency properties respectively.
Example
// C#
using System;
using Oracle.DataAccess.Client;
// Set the nls parameters related to currency
OracleGlobalization info = OracleGlobalization.GetClientInfo();
info.Currency = "$";
info.NumericCharacters = ".,";
OracleGlobalization.SetThreadInfo(info);
// Construct an OracleDecimal using a valid numeric format
OracleDecimal dec = new OracleDecimal("$2,222.22","L9G999D99");
// Print "$2,222.22"
Console.WriteLine(dec.ToString());
The OracleDecimal static fields are listed in Table 12-38.
Table 12-38 OracleDecimal Static Fields
This static field represents the maximum precision, which is 38.
Declaration
// C# public static readonly byte MaxPrecision;
This static field a constant representing the maximum scale, which is 127.
Declaration
// C# public static readonly byte MaxScale;
This static field indicates a constant representing the maximum value for this structure, which is 9.9…9 x 10125 (38 nines followed by 88 zeroes).
Declaration
// C# public static readonly OracleDecimal MaxValue;
This static field indicates a constant representing the maximum scale, which is -84.
Declaration
// C# public static readonly int MinScale;
This static field indicates a constant representing the minimum value for this structure, which is -1.0 x 10130.
Declaration
// C# public static readonly OracleDecimal MinValue;
This static field indicates a constant representing the negative one value.
Declaration
// C# public static readonly OracleDecimal NegativeOne;
This static field represents a null value that can be assigned to an OracleDecimal instance.
Declaration
// C# public static readonly OracleDecimal Null;
This static field indicates a constant representing the positive one value.
Declaration
// C# public static readonly OracleDecimal One;
This static field indicates a constant representing the numeric Pi value.
Declaration
// C# public static readonly OracleDecimal Pi;
This static field indicates a constant representing the zero value.
Declaration
// C# public static readonly OracleDecimal Zero;
The OracleDecimal static (comparison) methods are listed in Table 12-39.
Table 12-39 OracleDecimal Static (Comparison) Methods
Determines if two |
Determines if two |
This method determines if two OracleDecimal values are equal.
Declaration
// C# public static bool Equals(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
The first OracleDecimal.
value2
The second OracleDecimal.
Return Value
Returns true if two OracleDecimal values are equal; otherwise, returns false.
Remarks
The following rules apply to the behavior of this method.
Any OracleDecimal that has a value compares greater than an OracleDecimal that has a null value.
Two OracleDecimals that contain a null value are equal.
This method determines if the first of two OracleDecimal values is greater than the second.
Declaration
// C# public static bool GreaterThan(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleDecimal values is greater than the second; otherwise, returns false.
Remarks
This method determines if the first of two OracleDecimal values is greater than or equal to the second.
Declaration
// C# public static bool GreaterThanOrEqual(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleDecimal values is greater than or equal to the second; otherwise, returns false.
Remarks
This method determines if the first of two OracleDecimal values is less than the second.
Declaration
// C# public static bool LessThan(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleDecimal values is less than the second; otherwise, returns false.
Remarks
This method determines if the first of two OracleDecimal values is less than or equal to the second.
Declaration
// C# public static bool LessThanOrEqual(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleDecimal values is less than or equal to the second; otherwise, returns false.
Remarks
This method determines if two OracleDecimal values are not equal.
Declaration
// C# public static bool NotEquals(OracleDecimal value1, OracleDecimal value2);
Parameters
value1
value2
Return Value
Returns true if two OracleDecimal values are not equal; otherwise, returns false.
Remarks
The OracleDecimal static (manipulation) methods are listed in Table 12-40.
Table 12-40 OracleDecimal Static (Manipulation) Methods
Adds two |
Returns a new |
Returns a new |
Returns a new |
Divides one |
Returns a new |
Returns a new |
Returns a new |
Returns a new |
Converts a |
Returns a new |
Returns a new |
Returns a new |
Returns a new |
Returns a new |
Truncates the |
This method returns the absolute value of an OracleDecimal.
Declaration
// C#
public static OracleDecimal Abs(OracleDecimal val);
Parameters
val
An OracleDecimal.
Return Value
The absolute value of an OracleDecimal.
Remarks
If either argument has a null value, the returned OracleDecimal has a null value.
This method adds two OracleDecimal structures.
Declaration
// C# public static OracleDecimal Add(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Returns an OracleDecimal structure.
Remarks
This method returns a new OracleDecimal with the specified number of digits and indicates whether or not to round or truncate the number if the scale is less than the original.
Declaration
// C# public static OracleDecimal AdjustScale(OracleDecimal val, int digits, bool fRound);
Parameters
val
An OracleDecimal.
digits
The number of digits.
fRound
Indicates whether or not to round or truncate the number. Setting it to true rounds the number and setting it to false truncates the number.
Return Value
An OracleDecimal.
Remarks
If the supplied OracleDecimal has a null value, the returned OracleDecimal has a null value.
Example
// C#
using System;
class AdjustScaleSample
OracleDecimal dec1 = new OracleDecimal(5.555);
// Adjust Scale to 2 with rounding off
OracleDecimal dec2 = OracleDecimal.AdjustScale(dec1, 2, true);
// Prints 5.56
Console.WriteLine(dec2.ToString());
// Adjust Scale to 2 with truncation
OracleDecimal dec3 = OracleDecimal.AdjustScale(dec1, 2, false);
// Prints 5.55
Console.WriteLine(dec3.ToString());
This method returns a new OracleDecimal structure with its value set to the ceiling of the supplied OracleDecimal.
Declaration
// C#
public static OracleDecimal Ceiling(OracleDecimal val);
Parameters
val
An OracleDecimal.
Return Value
A new OracleDecimal structure.
Remarks
This method returns a new OracleDecimal structure with a new precision and scale.
Declaration
// C# public static OracleDecimal ConvertToPrecScale(OracleDecimal val int precision, int scale);
Parameters
val
An OracleDecimal structure.
precision
The precision. Range of precision is 1 to 38.
scale
The number of digits to the right of the decimal point. Range of scale is -84 to 127.
Return Value
Remarks
Example
// C#
using System;
class ConvertToPrecScaleSample
OracleDecimal dec1 = new OracleDecimal(555.6666);
// Set the precision of od to 5 and scale to 2
OracleDecimal dec2 = OracleDecimal.ConvertToPrecScale(dec1,5,2);
// Prints 555.67
// Set the precision of od to 3 and scale to 0
OracleDecimal dec3 = OracleDecimal.ConvertToPrecScale(dec1,3,0);
// Prints 556
This method divides one OracleDecimal value by another.
Declaration
// C# public static OracleDecimal Divide(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
An OracleDecimal.
val2
An OracleDecimal.
Return Value
Remarks
This method returns a new OracleDecimal structure with its value set to the floor of the supplied OracleDecimal structure.
Declaration
// C#
public static OracleDecimal Floor(OracleDecimal val);
Parameters
val
Return Value
Remarks
This method returns the maximum value of the two supplied OracleDecimal structures.
Declaration
// C# public static OracleDecimal Max(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
An OracleDecimal structure that has the greater value.
This method returns the minimum value of the two supplied OracleDecimal structures.
Declaration
// C# public static OracleDecimal Min(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
An OracleDecimal structure that has the smaller value.
This method returns a new OracleDecimal structure with its value set to the modulus of two OracleDecimal structures.
Declaration
// C# public static OracleDecimal Mod(OracleDecimal val1, OracleDecimal divider);
Parameters
val1
divider
Return Value
An OracleDecimal.
Remarks
This method returns a new OracleDecimal structure with its value set to the result of multiplying two OracleDecimal structures.
Declaration
// C# public static OracleDecimal Multiply(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method returns a new OracleDecimal structure with its value set to the negation of the supplied OracleDecimal structures.
Declaration
// C#
public static OracleDecimal Negate(OracleDecimal val);
Parameters
val
Return Value
Remarks
This method converts a string to an OracleDecimal.
Declaration
// C#
public static OracleDecimal Parse (string str);
Parameters
str
The string being converted.
Return Value
Exceptions
This method returns a new OracleDecimal structure with its value set to that of the supplied OracleDecimal structure and rounded off to the specified place.
Declaration
// C# public static OracleDecimal Round(OracleDecimal val, int decplace);
Parameters
val
decplace
The specified decimal place. If the value is positive, the function rounds the OracleDecimal structure to the right of the decimal point. If the value is negative, the function rounds to the left of the decimal point.
Return Value
Remarks
If the supplied OracleDecimal structure has a null value, the returned OracleDecimal has a null value.
This method returns a new OracleDecimal structure with a new specified precision.
Declaration
// C# public static OracleDecimal SetPrecision(OracleDecimal val, int precision);
Parameters
val
precision
The specified precision. Range of precision is 1 to 38.
Return Value
Remarks
The returned OracleDecimal is rounded off if the specified precision is smaller than the precision of val.
If val has a null value, the returned OracleDecimal has a null value.
Example
// C#
using System;
class SetPrecisionSample
// Set the precision of dec1 to 3
OracleDecimal dec2 = OracleDecimal.SetPrecision(dec1, 3);
// Prints 556
// Set the precision of dec1 to 4
OracleDecimal dec3 = OracleDecimal.SetPrecision(dec1, 4);
// Prints 555.7
This method returns a new OracleDecimal structure with its value set to that of the supplied OracleDecimal structure, and its decimal place shifted to the specified number of places to the right.
Declaration
// C# public static OracleDecimal Shift(OracleDecimal val, int decplaces);
Parameters
val
decplaces
The specified number of places to be shifted.
Return Value
Remarks
If decplaces is negative, the shift is to the left.
This method determines the sign of an OracleDecimal structure.
Declaration
// C#
public static int Sign(OracleDecimal val);
Parameters
val
Return Value
-1: if the supplied OracleDecimal < 0
0: if the supplied OracleDecimal == 0
1: if the supplied OracleDecimal > 0
Exceptions
OracleNullValueException - The argument has a null value.
This method returns a new OracleDecimal structure with its value set to the square root of the supplied OracleDecimal structure.
Declaration
// C#
public static OracleDecimal Sqrt(OracleDecimal val);
Parameters
val
Return Value
Exceptions
ArgumentOutOfRangeException - The provided OracleDecimal structure is less than zero.
Remarks
This method returns a new OracleDecimal structure with its value set to result of subtracting one OracleDecimal structure from another.
Declaration
// C# public static OracleDecimal Subtract(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method truncates the OracleDecimal at a specified position.
Declaration
// C# public static OracleDecimal Truncate(OracleDecimal val, int pos);
Parameters
val
pos
The specified position. If the value is positive, the function truncates the OracleDecimal structure to the right of the decimal point. If the value is negative, it truncates the OracleDecimal structure to the left of the decimal point.
Return Value
Remarks
The OracleDecimal static (logarithmic) methods are listed in Table 12-41.
Table 12-41 OracleDecimal Static (Logarithmic) Methods
Returns a new |
Returns a new |
This method returns a new OracleDecimal structure with its value set to e raised to the supplied OracleDecimal.
Declaration
// C#
public static OracleDecimal Exp(OracleDecimal val);
Parameters
val
Return Value
Remarks
Log returns the supplied OracleDecimal structure with its value set to the logarithm of the supplied OracleDecimal structure.
Overload List:
This method returns a new OracleDecimal structure with its value set to the natural logarithm (base e) of the supplied OracleDecimal structure.
This method returns the supplied OracleDecimal structure with its value set to the logarithm of the supplied OracleDecimal structure in the supplied base.
Log(OracleDecimal, OracleDecimal)
Declaration
// C#
public static OracleDecimal Log(OracleDecimal val);
Parameters
val
An OracleDecimal structure whose logarithm is to be calculated.
Return Value
Returns a new OracleDecimal structure with its value set to the natural logarithm (base e) of val.
Exceptions
ArgumentOutOfRangeException - The supplied OracleDecimal value is less than zero.
Remarks
If the supplied OracleDecimal structure has zero value, the result is undefined, and the returned OracleDecimal structure has a null value.
Declaration
// C# public static OracleDecimal Log(OracleDecimal val, int logBase);
Parameters
val
logBase
An int that specifies the base of the logarithm.
Return Value
A new OracleDecimal structure with its value set to the logarithm of val in the supplied base.
Exceptions
ArgumentOutOfRangeException - Either argument is less than zero.
Remarks
If both arguments have zero value, the result is undefined, and the returned OracleDecimal structure has a null value.
Declaration
// C# public static OracleDecimal Log(OracleDecimal val, OracleDecimal logBase);
Parameters
val
logBase
An OracleDecimal structure that specifies the base of the logarithm.
Return Value
Returns the logarithm of val in the supplied base.
Exceptions
ArgumentOutOfRangeException - Either the val or logBase parameter is less than zero.
Remarks
Pow returns a new OracleDecimal structure with its value set to the supplied OracleDecimal structure raised to the supplied power.
Overload List:
This method returns a new OracleDecimal structure with its value set to the supplied OracleDecimal value raised to the supplied Int32 power.
Pow(OracleDecimal, OracleDecimal)
This method returns a new OracleDecimal structure with its value set to the supplied OracleDecimal structure raised to the supplied OracleDecimal power.
Declaration
// C# public static OracleDecimal Pow(OracleDecimal val, int power);
Parameters
val
power
An int value that specifies the power.
Return Value
Remarks
Declaration
// C# public static OracleDecimal Pow(OracleDecimal val, OracleDecimal power);
Parameters
val
power
An OracleDecimal structure that specifies the power.
Return Value
Remarks
The OracleDecimal static (trigonometric) methods are listed in Table 12-42.
Table 12-42 OracleDecimal Static (Trigonometric) Methods
This method returns an angle in radian whose cosine is the supplied OracleDecimal structure.
Declaration
// C#
public static OracleDecimal Acos(OracleDecimal val);
Parameters
val
An OracleDecimal structure. Range is (-1 to 1).
Return Value
An OracleDecimal structure that represents an angle in radian.
Remarks
This method returns an angle in radian whose sine is the supplied OracleDecimal structure.
Declaration
// C#
public static OracleDecimal Asin(OracleDecimal val);
Parameters
val
Return Value
Remarks
This method returns an angle in radian whose tangent is the supplied OracleDecimal structure
Declaration
// C#
public static OracleDecimal Atan(OracleDecimal val);
Parameters
val
An OracleDecimal.
Return Value
Remarks
If the argument has a null value, the returned OracleDecimal has a null value.
This method returns an angle in radian whose tangent is the quotient of the two supplied OracleDecimal structures.
Declaration
// C# public static OracleDecimal Atan2(OracleDecimal val1, OracleDecimal val2);
Parameters
val1
An OracleDecimal structure that represents the y-coordinate.
val2
An OracleDecimal structure that represents the x-coordinate.
Return Value
Remarks
This method returns the cosine of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Cos(OracleDecimal val);
Parameters
val
Return Value
An OracleDecimal instance.
Exceptions
ArgumentOutOfRangeException - The val parameter is positive or negative infinity.
Remarks
This method returns the sine of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Sin(OracleDecimal val);
Parameters
val
Return Value
Exceptions
Remarks
This method returns the tangent of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Tan(OracleDecimal val);
Parameters
val
Return Value
Exceptions
Remarks
This method returns the hyperbolic cosine of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Cosh(OracleDecimal val);
Parameters
val
Return Value
Remarks
This method returns the hyperbolic sine of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Sinh(OracleDecimal val);
Parameters
val
Return Value
Remarks
This method returns the hyperbolic tangent of the supplied angle in radian.
Declaration
// C#
public static OracleDecimal Tanh(OracleDecimal val);
Parameters
val
Return Value
Remarks
The OracleDecimal static (comparison) operators are listed in Table 12-43.
Table 12-43 OracleDecimal Static (Comparison) Operators
Adds two |
Divides one |
Multiplies two |
Subtracts one |
Negates an |
Returns a new |
This method adds two OracleDecimal values.
Declaration
// C# public static OracleDecimal operator + (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
If either operand has a null value, the returned OracleDecimal has a null value.
Declaration
/ C# public static OracleDecimal operator / (OracleDecimal val1, OracleDecimal val2)
Parameters
val1
val2
Return Value
Remarks
Declaration
// C# public static bool operator == (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Returns true if their values are equal; otherwise, returns false.
Remarks
Declaration
// C# public static bool operator > (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Returns true if the two OracleDecimal values are not equal; otherwise, returns false.
Remarks
Declaration
// C# public static bool operator >= (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method determines if the first of two OracleDecimal values are not equal.
Declaration
// C# public static bool operator != (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
Declaration
// C# public static bool operator < (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
Declaration
// C# public static bool operator <= (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method multiplies two OracleDecimal structures.
Declaration
// C# public static OracleDecimal operator * (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method subtracts one OracleDecimal structure from another.
Declaration
// C# public static OracleDecimal operator - (OracleDecimal val1, OracleDecimal val2);
Parameters
val1
val2
Return Value
Remarks
This method negates the supplied OracleDecimal structure.
Declaration
// C#
public static OracleDecimal operator - (OracleDecimal val);
Parameters
val
An OracleDecimal.
Return Value
Remarks
Declaration
// C# public static OracleDecimal operator % (OracleDecimal val, OracleDecimal divider);
Parameters
val
An OracleDecimal.
divider
An OracleDecimal.
Return Value
Remarks
The OracleDecimal static operators (Conversion from .NET Type to OracleDecimal) are listed in Table 12-44.
Table 12-44 OracleDecimal Static Operators (Conversion from .NET Type to OracleDecimal)
implicit operator OracleDecimal returns the OracleDecimal representation of a value.
Overload List:
implicit operator OracleDecimal(decimal)
This method returns the OracleDecimal representation of a decimal value.
implicit operator OracleDecimal(int)
This method returns the OracleDecimal representation of an int value.
implicit operator OracleDecimal(long)
This method returns the OracleDecimal representation of a long value.
Declaration
// C#
public static implicit operator OracleDecimal(decimal val);
Parameters
val
A decimal value.
Return Value
An OracleDecimal.
Declaration
// C#
public static implicit operator OracleDecimal(int val);
Parameters
val
An int value.
Return Value
An OracleDecimal.
Declaration
// C#
public static implicit operator OracleDecimal(long val);
Parameters
val
A long value.
Return Value
An OracleDecimal.
Overload List:
explicit operator OracleDecimal(double)
This method returns the OracleDecimal representation of a double.
explicit operator OracleDecimal(string)
This method returns the OracleDecimal representation of a string.
Declaration
// C#
public static explicit operator OracleDecimal(double val);
Parameters
val
A double.
Return Value
An OracleDecimal.
Exceptions
OverFlowException - The value of the supplied double is greater than the maximum value of OracleDecimal or less than the minimum value of OracleDecimal.
Remarks
Declaration
// C#
public static explicit operator OracleDecimal(string numStr);
Parameters
numStr
A string that represents a numeric value.
Return Value
An OracleDecimal.
Exceptions
The OracleDecimal static operators (Conversion from OracleDecimal to .NET) are listed in Table 12-45.
Table 12-45 OracleDecimal Static Operators (Conversion from OracleDecimal to .NET)
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
This method returns the byte representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator byte(OracleDecimal val);
Parameters
val
Return Value
A byte.
Exceptions
OracleNullValueException - OracleDecimal has a null value.
OverFlowException- The byte cannot represent the supplied OracleDecimal structure.
This method returns the decimal representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator decimal(OracleDecimal val);
Parameters
val
Return Value
A decimal.
Exceptions
OracleNullValueException - The OracleDecimal has a null value.
OverFlowException - The decimal cannot represent the supplied OracleDecimal structure.
This method returns the double representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator double(OracleDecimal val);
Parameters
val
Return Value
A double.
Exceptions
OverFlowException - The double cannot represent the supplied OracleDecimal structure.
This method returns the short representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator short(OracleDecimal val);
Parameters
val
Return Value
A short.
Exceptions
OverFlowException - The short cannot represent the supplied OracleDecimal structure.
This method returns the int representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator int(OracleDecimal val);
Parameters
val
Return Value
An int.
Exceptions
OverFlowException - The int cannot represent the supplied OracleDecimal structure.
This method returns the long representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator long(OracleDecimal val);
Parameters
val
Return Value
A long.
Exceptions
OverFlowException - The long cannot represent the supplied OracleDecimal structure.
This method returns the float representation of the OracleDecimal value.
Declaration
// C#
public static explicit operator float(OracleDecimal val);
Parameters
val
Return Value
A float.
Exceptions
OverFlowException - The float cannot represent the supplied OracleDecimal structure.
The OracleDecimal properties are listed in Table 12-46.
Table 12-46 OracleDecimal Properties
Returns a |
This property returns a byte array that represents the Oracle NUMBER in an internal Oracle format.
Declaration
// C#
public byte[] BinData {get;}
Property Value
A byte array that represents the Oracle NUMBER in an internal Oracle format.
Exceptions
OracleNullValueException - The current instance has a null value.
This property specifies the format for ToString().
Declaration
// C#
public string Format {get; set;}
Property Value
The string which specifies the format.
Remarks
Format is used when ToString() is called on an instance of an OracleDecimal. It is useful if the ToString() method needs a specific currency symbol, group, or decimal separator as part of a string.
By default, this property is null which indicates that no special formatting is used.
The decimal and group separator characters are specified by the thread's OracleGlobalization.NumericCharacters.
The currency symbols are specified by the following thread properties:
This property indicates whether or not the current instance is an integer value.
Declaration
// C#
public bool IsInt {get;}
Property Value
A bool value that returns true if the current instance is an integer value; otherwise, returns false.
Exceptions
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
A bool value that returns true if the current instance has a null value; otherwise, returns false.
This property indicates whether or not the value of the current instance is greater than 0.
Declaration
// C#
public bool IsPositive {get;}
Property Value
A bool value that returns true if the current instance is greater than 0; otherwise, returns false.
Exceptions
This property indicates whether or not the current instance has a zero value.
Declaration
// C#
public bool IsZero{get;}
Property Value
A bool value that returns true if the current instance has a zero value; otherwise, returns false.
Exceptions
This method returns a decimal value.
Declaration
// C#
public decimal Value {get;}
Property Value
A decimal value.
Exceptions
Remarks
Precision can be lost when the decimal value is obtained from an OracleDecimal. See Remarks under "OracleDecimal Structure" for further information.
The OracleDecimal instance methods are listed in Table 12-47.
Table 12-47 OracleDecimal Instance Methods
GetType |
Inherited from |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
Returns the |
This method compares the current instance to the supplied object and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
obj
The supplied instance.
Return Value
The method returns a number:
Less than zero: if the value of the current instance is less than obj.
Zero: if the value of the current instance is equal to obj.
Greater than zero: if the value of the current instance is greater than obj.
Implements
IComparable
Exceptions
ArgumentException - The parameter is not of type OracleDecimal.
Remarks
The comparison must be between OracleDecimals. For example, comparing an OracleDecimal instance with an OracleBinary instance is not allowed. When an OracleDecimal is compared with a different type, an ArgumentException is thrown.
Overrides Object
This method determines whether or not an object is an instance of OracleDecimal, and whether or not the value of the object is equal to the current instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
obj
Return Value
Returns true if obj is an instance of OracleDecimal, and the value of obj is equal to the current instance; otherwise, returns false.
Remarks
Overrides Object
This method returns a hash code for the current instance.
Declaration
// C# public override int GetHashCode();
Return Value
Returns a hash code.
This method returns the byte representation of the current instance.
Declaration
// C# public byte ToByte();
Return Value
A byte.
Exceptions
OverFlowException - The byte cannot represent the current instance.
This method returns the double representation of the current instance.
Declaration
// C# public double ToDouble();
Return Value
A double.
Exceptions
OverFlowException - The double cannot represent the current instance.
This method returns the Int16 representation of the current instance.
Declaration
// C# public short ToInt16();
Return Value
A short.
Exceptions
OverFlowException - The short cannot represent the current instance.
This method returns the Int32 representation of the current instance.
Declaration
// C# public int ToInt32();
Return Value
An int.
Exceptions
OverFlowException - The int cannot represent the current instance.
This method returns the Int64 representation of the current instance.
Declaration
// C# public long ToInt64();
Return Value
A long.
Exceptions
OverFlowException - The long cannot represent the current instance.
This method returns the Single representation of the current instance.
Declaration
// C# public float ToSingle();
Return Value
A float.
Exceptions
OverFlowException - The float cannot represent the current instance.
Overrides Object
This method returns the string representation of the current instance.
Declaration
// C# public override string ToString();
Return Value
Returns the number in a string.
Remarks
If the current instance has a null value, the returned string is "null".
The returned value is a string representation of an OracleDecimal in the numeric format specified by the Format property.
If the numeric format is not specified, an Oracle default value is used.
