| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.6.20) E10927-01 |
![]() Previous |
![]() Next |
The OracleFailoverEventArgs class provides event data for the OracleConnection.Failover event. When database failover occurs, the OracleConnection.Failover event is triggered along with the OracleFailoverEventArgs object that stores the event data.
Class Inheritance
System.Object
System.EventArgs
Oracle.DataAccess.Client.OracleFailoverEventArgs
Declaration
// C# public sealed class OracleFailoverEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example (Oracle.DataAccess.Client only)
// Transparent Application Failover (TAF) Setup
// Refer Oracle® Database Net Services Administrator's Guide
// C#
using System;
using System.Threading;
using Oracle.DataAccess.Client;
using Oracle.DataAccess.Types;
class FailoverSample
static void Main(string[] args)
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
// Register the event handler OnFailover
con.Failover += new OracleFailoverEventHandler(OnFailover);
Console.WriteLine("Wait for a failover for 5 seconds");
Thread.Sleep(5000);
con.Close();
con.Dispose();
// TAF callback function
static FailoverReturnCode OnFailover(object sender,
OracleFailoverEventArgs eventArgs)
switch (eventArgs.FailoverEvent)
case FailoverEvent.Begin:
Console.WriteLine("FailoverEvent.Begin - Failover is starting");
Console.WriteLine("FailoverType = " + eventArgs.FailoverType);
break;
case FailoverEvent.End:
Console.WriteLine("FailoverEvent.End - Failover was successful");
break;
case FailoverEvent.Reauth:
Console.WriteLine("FailoverEvent.Reauth - User reauthenticated");
break;
case FailoverEvent.Error:
Console.WriteLine("FailoverEvent.Error - Failover was unsuccessful");
// Sleep for 3 sec and Retry
Thread.Sleep(3000);
return FailoverReturnCode.Retry;
case FailoverEvent.Abort:
Console.WriteLine("FailoverEvent.Abort - Failover was unsuccessful");
break;
default:
Console.WriteLine("Invalid FailoverEvent : " + eventArgs.FailoverEvent);
break;
return FailoverReturnCode.Success;
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
Comment: Not supported in a .NET stored procedure
OracleFailoverEventArgs members are listed in the following tables.
OracleFailoverEventArgs Static Methods
The OracleFailoverEventArgs static methods are listed in Table 10-1.
Table 10-1 OracleFailoverEventArgs Static Methods
| Methods | Description |
Inherited from |
OracleFailoverEventArgs Properties
The OracleFailoverEventArgs properties are listed in Table 10-2.
Table 10-2 OracleFailoverEventArgs Properties
| Name | Description |
Specifies the type of failover the client has requested |
Indicates the state of the failover |
OracleFailoverEventArgs Public Methods
The OracleFailoverEventArgs public methods are listed in Table 10-3.
Table 10-3 OracleFailoverEventArgs Public Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Table 10-4 OracleFailoverEventArgs Static Methods
Inherited from |
The OracleFailoverEventArgs properties are listed in Table 10-5.
Table 10-5 OracleFailoverEventArgs Properties
This property indicates the state of the failover.
Declaration
// C#
public FailoverType FailoverType {get;}
Property Value
A FailoverType enumeration value.
Declaration
// C#
public FailoverEvent FailoverEvent {get;}
Property Value
A FailoverEvent enumerated value.
The OracleFailoverEventArgs public methods are listed in Table 10-6.
