Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleIntervalDS Structure
The OracleIntervalDS structure represents the Oracle INTERVAL DAY TO SECOND data type to be stored in or retrieved from a database. Each OracleIntervalDS stores a period of time in term of days, hours, minutes, seconds, and fractional seconds.
Class Inheritance
System.Object
  System.ValueType
    Oracle.DataAccess.Types.OracleIntervalDS
Declaration
// ADO.NET 2.0: C#
public struct OracleIntervalDS : IComparable, INullable, IXmlSerializable
// ADO.NET 1.x: C#public struct OracleIntervalDS : IComparable, INullable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleIntervalDSSample
  static void Main()
    OracleIntervalDS iDSMax = OracleIntervalDS.MaxValue;
    double totalDays = iDSMax.TotalDays;
    totalDays -= 1;
    OracleIntervalDS iDSMax_1 = new OracleIntervalDS(totalDays);
    // Calculate the difference
    OracleIntervalDS iDSDiff = iDSMax - iDSMax_1;
    // Prints "iDSDiff.ToString() = +000000000 23:59:59.999999999"
    Console.WriteLine("iDSDiff.ToString() = " + iDSDiff.ToString());
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleIntervalDS Members
OracleIntervalDS members are listed in the following tables:
OracleIntervalDS Constructors
OracleIntervalDS constructors are listed in Table 12-48
Table 12-48 OracleIntervalDS Constructors
Constructor Description
Instantiates a new instance of OracleIntervalDS structure (Overloaded)
OracleIntervalDS Static Fields
The OracleIntervalDS static fields are listed in Table 12-49.
Table 12-49 OracleIntervalDS Static Fields
Field Description
MaxValue
Represents the maximum valid time interval for an OracleIntervalDS structure
MinValue
Represents the minimum valid time interval for an OracleIntervalDS structure
Null
Represents a null value that can be assigned to an OracleIntervalDS instance
Zero
Represents a zero value for an OracleIntervalDS structure
OracleIntervalDS Static Methods
The OracleIntervalDS static methods are listed in Table 12-50.
Table 12-50 OracleIntervalDS Static Methods
Methods Description
Equals
Determines whether or not two OracleIntervalDS values are equal (Overloaded)
GreaterThan
Determines whether or not one OracleIntervalDS value is greater than another
GreaterThanOrEqual
Determines whether or not one OracleIntervalDS value is greater than or equal to another
LessThan
Determines whether or not one OracleIntervalDS value is less than another
LessThanOrEqual
Determines whether or not one OracleIntervalDS value is less than or equal to another
NotEquals
Determines whether or not two OracleIntervalDS values are not equal
Parse
Returns an OracleIntervalDS structure and sets its value for time interval using a string
SetPrecision
Returns a new instance of an OracleIntervalDS with the specified day precision and fractional second precision
OracleIntervalDS Static Operators
The OracleIntervalDS static operators are listed in Table 12-51.
Table 12-51 OracleIntervalDS Static Operators
Operator Description
operator +
Adds two OracleIntervalDS values
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator -
Subtracts one OracleIntervalDS value from another
operator -
Negates an OracleIntervalDS structure
operator *
Multiplies an OracleIntervalDS value by a number
operator /
Divides an OracleIntervalDS value by a number
OracleIntervalDS Type Conversions
The OracleIntervalDS type conversions are listed in Table 12-52.
Table 12-52 OracleIntervalDS Type Conversions
explicit operator TimeSpan
Converts an OracleIntervalDS structure to a TimeSpan structure
explicit operator OracleIntervalDS
Converts a string to an OracleIntervalDS structure
implicit operator OracleIntervalDS
Converts a TimeSpan structure to an OracleIntervalDS structure
OracleIntervalDS Properties
The OracleIntervalDS properties are listed in Table 12-53.
Table 12-53 OracleIntervalDS Properties
Properties Description
BinData
Returns an array of bytes that represents the Oracle INTERVAL DAY TO SECOND in Oracle internal format
Days
Gets the days component of an OracleIntervalDS
Hours
Gets the hours component of an OracleIntervalDS
IsNull
Indicates whether or not the current instance has a null value
Milliseconds
Gets the milliseconds component of an OracleIntervalDS
Minutes
Gets the minutes component of an OracleIntervalDS
Nanoseconds
Gets the nanoseconds component of an OracleIntervalDS
Seconds
Gets the seconds component of an OracleIntervalDS
TotalDays
Returns the total number, in days, that represent the time period in the OracleIntervalDS structure
Value
Specifies the time interval that is stored in the OracleIntervalDS structure
OracleIntervalDS Methods
The OracleIntervalDS methods are listed in Table 12-54.
Table 12-54 OracleIntervalDS Methods
Methods Description
CompareTo
Compares the current OracleIntervalDS instance to an object, and returns an integer that represents their relative values
Equals
Determines whether or not the specified object has the same time interval as the current instance (Overloaded)
GetHashCode
Returns a hash code for the OracleIntervalDS instance
GetType
Inherited from System.Object
ToString
Converts the current OracleIntervalDS structure to a string
OracleIntervalDS constructors create a new instance of the OracleIntervalDS structure.
Overload List:
OracleIntervalDS(TimeSpan)
This constructor creates a new instance of the OracleIntervalDS structure and sets its value using a TimeSpan structure.
Declaration
// C#
public OracleIntervalDS(TimeSpan ts);
Parameters
OracleIntervalDS(string)
This constructor creates a new instance of the OracleIntervalDS structure and sets its value using a string that indicates a period of time.
Declaration
// C#
public OracleIntervalDS(string intervalStr);
Parameters
Exceptions
ArgumentException - The intervalStr parameter is not in the valid format or has an invalid value.
ArgumentNullException - The intervalStr parameter is null.
Remarks
The value specified in the supplied intervalStr must be in Day HH:MI:SSxFF format.
Example
"1 2:3:4.99" means 1 day, 2 hours, 3 minutes, 4 seconds, and 990 milliseconds or 1 day, 2 hours, 3 minutes, 4 seconds, and 990000000 nanoseconds.
OracleIntervalDS(double)
This constructor creates a new instance of the OracleIntervalDS structure and sets its value using the total number of days.
Declaration
// C#
public OracleIntervalDS(double totalDays);
Parameters
Exceptions
ArgumentOutOfRangeException - The argument value for one or more of the parameters is out of the specified range.
ArgumentException - The argument values of the parameters cannot be used to construct a valid OracleIntervalDS.
OracleIntervalDS(int, int, int, int, double)
This constructor creates a new instance of the OracleIntervalDS structure and sets its value using the supplied days, hours, minutes, seconds, and milliseconds.
Declaration
// C#
public OracleIntervalDS (int days, int hours, int minutes, int seconds,
   double milliSeconds);
Parameters
Exceptions
Remarks
The sign of all the arguments must be the same.
OracleIntervalDS(int, int, int, int, int)
This constructor creates a new instance of the OracleIntervalDS structure and sets its value using the supplied days, hours, minutes, seconds, and nanoseconds.
Declaration
// C#
   int nanoseconds);
Parameters
Exceptions
Remarks
OracleIntervalDS(byte[ ])
This constructor creates a new instance of the OracleIntervalDS structure and sets its value to the provided byte array, which is in an internal Oracle INTERVAL DAY TO SECOND format.
Declaration
// C#
public OracleIntervalDS (byte[ ] bytes);
Parameters
Exceptions
ArgumentException - bytes is not in internal Oracle INTERVAL DAY TO SECOND format, or bytes is not a valid Oracle INTERVAL DAY TO SECOND.
ArgumentNullException - bytes is null.
The OracleIntervalDS static fields are listed in Table 12-55.
Table 12-55 OracleIntervalDS Static Fields
Field Description
MaxValue
MinValue
Null
Zero
MaxValue
This static field represents the maximum value for an OracleIntervalDS structure.
Declaration
// C#
public static readonly OracleIntervalDS MaxValue;
Remarks
Maximum values:
MinValue
This static field represents the minimum value for an OracleIntervalDS structure.
Declaration
// C#
public static readonly OracleIntervalDS MinValue;
Remarks
Minimum values:
Null
This static field represents a null value that can be assigned to an OracleIntervalDS instance.
Declaration
// C#
public static readonly OracleIntervalDS Null;
Zero
This static field represents a zero value for an OracleIntervalDS structure.
Declaration
// C#
public static readonly OracleIntervalDS Zero;
The OracleIntervalDS static methods are listed in Table 12-56.
Table 12-56 OracleIntervalDS Static Methods
Methods Description
Equals
GreaterThan
GreaterThanOrEqual
LessThan
LessThanOrEqual
NotEquals
Parse
SetPrecision
Equals
This static method determines whether or not two OracleIntervalDS values are equal.
Declaration
// C#
public static bool Equals(OracleIntervalDS val1, OracleIntervalDS val2);
Parameters
Return Value
If the two OracleIntervalDS structures represent the same time interval, returns true; otherwise, returns false.
Remarks
The following rules apply to the behavior of this method.
GreaterThan
This static method determines whether or not the first of two OracleIntervalDS values is greater than the second.
Declaration
// C#
public static bool GreaterThan(OracleIntervalDS val1, OracleIntervalDS
   val2);
Parameters
Return Value
Returns true if the first of two OracleIntervalDS values is greater than the second; otherwise, returns false.
Remarks
GreaterThanOrEqual
This static method determines whether or not the first of two OracleIntervalDS values is greater than or equal to the second.
Declaration
// C#
public static bool GreaterThanOrEqual(OracleIntervalDS val1,
Parameters
Return Value
Returns true if the first of two OracleIntervalDS values is greater than or equal to the second; otherwise, returns false.
Remarks
LessThan
This static method determines whether or not the first of two OracleIntervalDS values is less than the second.
Declaration
// C#
public static bool LessThan(OracleIntervalDS val1, OracleIntervalDS val2);
Parameters
Return Value
Returns true if the first of two OracleIntervalDS values is less than the second; otherwise, returns false.
Remarks
LessThanOrEqual
This static method determines whether or not the first of two OracleIntervalDS values is less than or equal to the second.
Declaration
// C#
public static bool LessThanOrEqual(OracleIntervalDS val1, OracleIntervalDS val2);
Parameters
Return Value
Returns true if the first of two OracleIntervalDS values is less than or equal to the second; otherwise, returns false.
Remarks
NotEquals
This static method determines whether or not two OracleIntervalDS values are not equal.
Declaration
// C#
public static bool NotEquals(OracleIntervalDS val1, OracleIntervalDS val2);
Parameters
Return Value
Returns true if two OracleIntervalDS values are not equal; otherwise, returns false.
Remarks
Parse
This static method returns an OracleIntervalDS instance and sets its value for time interval using a string.
Declaration
// C#
public static OracleIntervalDS Parse(string intervalStr);
Parameters
Return Value
Returns an OracleIntervalDS instance representing the time interval from the supplied string.
Exceptions
ArgumentException - The intervalStr parameter is not in the valid format or intervalStr has an invalid value.
Remarks
The value specified in intervalStr must be in Day HH:MI:SSxFF format.
Example
SetPrecision
This static method returns a new instance of an OracleIntervalDS with the specified day precision and fractional second precision.
Declaration
// C#
public static OracleIntervalDS SetPrecision(OracleIntervalDS value1,
    int dayPrecision, int fracSecPrecision);
Parameters
Return Value
An OracleIntervalDS instance.
Exceptions
ArgumentOutOfRangeException - An argument value is out of the specified range.
Remarks
Depending on the value specified in the supplied dayPrecision, 0 or more leading zeros are displayed in the string returned by ToString().
The value specified in the supplied fracSecPrecision is used to perform a rounding off operation on the supplied OracleIntervalDS value. Depending on this value, 0 or more trailing zeros are displayed in the string returned by ToString().
Example
The OracleIntervalDS with a value of "1 2:3:4.99" results in the string "001 2:3:4.99000" when SetPrecision() is called, with the day precision set to 3 and fractional second precision set to 5.
The OracleIntervalDS static operators are listed in Table 12-57.
Table 12-57 OracleIntervalDS Static Operators
operator +
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator -
operator -
operator *
operator /
operator +
This static operator adds two OracleIntervalDS values.
Declaration
// C#
public static OracleIntervalDS operator + (OracleIntervalDS val1,
Parameters
Return Value
An OracleIntervalDS.
Remarks
If either argument has a null value, the returned OracleIntervalDS structure has a null value.
operator ==
This static operator determines if two OracleIntervalDS values are equal.
Declaration
// C#
public static bool operator == (OracleIntervalDS val1,
Parameters
Return Value
Returns true if the two OracleIntervalDS values are the same; otherwise returns false.
Remarks
operator >
This static operator determines if the first of two OracleIntervalDS values is greater than the second.
Declaration
// C#
public static bool operator > (OracleIntervalDS val1,
Parameters
Return Value
Returns true if one OracleIntervalDS value is greater than another; otherwise, returns false.
Remarks
operator >=
This static operator determines if the first of two OracleIntervalDS values is greater than or equal to the second.
Declaration
// C#
public static bool operator >= (OracleIntervalDS val1,
Parameters
Return Value
Remarks
operator !=
This static operator determines if the two OracleIntervalDS values are not equal.
Declaration
// C#
public static bool operator != (OracleIntervalDS val1,
Parameters
Return Value
Returns true if the two OracleIntervalDS values are not equal; otherwise, returns false.
Remarks
operator <
This static operator determines if the first of two OracleIntervalDS values is less than the second.
Declaration
// C#
public static bool operator < (OracleIntervalDS val1,
Parameters
Return Value
Remarks
operator <=
This static operator determines if the first of two OracleIntervalDS values is less than or equal to the second.
Declaration
// C#
public static bool operator <= (OracleIntervalDS val1,
Parameters
Return Value
Remarks
operator -
This static operator subtracts one OracleIntervalDS structure from another.
Declaration
// C#
public static OracleIntervalDS operator - (OracleIntervalDS val1,
Parameters
Return Value
An OracleIntervalDS structure.
Remarks
operator -
This static operator negates the supplied OracleIntervalDS structure.
Declaration
// C#
public static OracleIntervalDS operator - (OracleIntervalDS val);
Parameters
Return Value
Remarks
If the supplied OracleIntervalDS structure has a null value, the returned OracleIntervalDS structure has a null value.
operator *
This static operator multiplies an OracleIntervalDS value by a number.
Declaration
// C#
public static OracleIntervalDS operator * (OracleIntervalDS val1,
   int multiplier);
Parameters
Return Value
A new OracleIntervalDS instance.
Remarks
If the OracleIntervalDS structure has a null value, the returned OracleIntervalDS structure has a null value.
operator /
This static operator divides an OracleIntervalDS value by a number.
Declaration
// C#
public static OracleIntervalDS operator / (OracleIntervalDS val1,
   int divisor);
Parameters
Return Value
Remarks
The OracleIntervalDS type conversions are listed in Table 12-58.
Table 12-58 OracleIntervalDS Type Conversions
This type conversion operator converts an OracleIntervalDS structure to a TimeSpan structure.
Declaration
// C#
public static explicit operator TimeSpan(OracleIntervalDS val);
Parameters
Return Value
A TimeSpan structure.
Exceptions
OracleNullValueException - The OracleIntervalDS structure has a null value.
Remarks
This type conversion operator converts a string to an OracleIntervalDS structure.
Declaration
// C#
public static explicit operator OracleIntervalDS (string intervalStr);
Parameters
Return Value
Exceptions
ArgumentException - The supplied intervalStr parameter is not in the correct format or has an invalid value.
Remarks
The returned OracleIntervalDS structure contains the same time interval represented by the supplied intervalStr. The value specified in the supplied intervalStr must be in Day HH:MI:SSxFF format.
Example
"1 2:3:4.99" means 1 day, 2 hours, 3 minutes 4 seconds and 990 milliseconds or 1 day, 2 hours, 3 minutes 4 seconds and 990000000 nanoseconds.
This type conversion operator converts a TimeSpan structure to an OracleIntervalDS structure.
Declaration
// C#
public static implicit operator OracleIntervalDS(TimeSpan val);
Parameters
Return Value
Remarks
The returned OracleIntervalDS structure contains the same days, hours, seconds, and milliseconds as the supplied TimeSpan val.
The OracleIntervalDS properties are listed in Table 12-59.
Table 12-59 OracleIntervalDS Properties
BinData
Days
Hours
IsNull
Milliseconds
Minutes
Nanoseconds
Seconds
TotalDays
Value
BinData
This property returns an array of bytes that represents the Oracle INTERVAL DAY TO SECOND in Oracle internal format.
Declaration
// C#
public byte[] BinData {get;}
Property Value
A byte array that represents an Oracle INTERVAL DAY TO SECOND in Oracle internal format.
Exceptions
OracleNullValueException - The current instance has a null value.
Remarks
Days
This property gets the days component of an OracleIntervalDS.
Declaration
// C#
public int Days {get;}
Property Value
An int representing the days component.
Exceptions
Hours
This property gets the hours component of an OracleIntervalDS.
Declaration
// C#
public int Hours {get;}
Property Value
An int representing the hours component.
Exceptions
IsNull
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
Returns true if the current instance has a null value; otherwise, returns false.
Milliseconds
This property gets the milliseconds component of an OracleIntervalDS.
Declaration
// C#
public double Milliseconds {get;}
Property Value
A double that represents milliseconds component.
Exceptions
Minutes
This property gets the minutes component of an OracleIntervalDS.
Declaration
// C#
public int Minutes {get;}
Property Value
A int that represents minutes component.
Exceptions
Nanoseconds
This property gets the nanoseconds component of an OracleIntervalDS.
Declaration
// C#
public int Nanoseconds {get;}
Property Value
An int that represents nanoseconds component.
Exceptions
Seconds
This property gets the seconds component of an OracleIntervalDS.
Declaration
// C#
public int Seconds {get;}
Property Value
An int that represents seconds component.
Exceptions
TotalDays
This property returns the total number, in days, that represent the time period in the OracleIntervalDS structure.
Declaration
// C#
public double TotalDays {get;}
Property Value
A double that represents the total number of days.
Exceptions
Value
This property specifies the time interval that is stored in the OracleIntervalDS structure.
Declaration
// C#
public TimeSpan Value {get;}
Property Value
A time interval.
Exceptions
The OracleIntervalDS methods are listed in Table 12-60.
Table 12-60 OracleIntervalDS Methods
Methods Description
CompareTo
Equals
GetHashCode
GetType
ToString
CompareTo
This method compares the current OracleIntervalDS instance to an object, and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
Return Value
The method returns:
Implements
IComparable
Exceptions
ArgumentException - The obj parameter is not of type OracleIntervalDS.
Remarks
Equals
This method determines whether or not the specified object has the same time interval as the current instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
Return Value
Returns true if obj is of type OracleIntervalDS and has the same time interval as the current instance; otherwise, returns false.
Remarks
GetHashCode
Overrides Object
This method returns a hash code for the OracleIntervalDS instance.
Declaration
// C#
public override int GetHashCode();
ToString
Overrides Object
This method converts the current OracleIntervalDS structure to a string.
Declaration
// C#
public override string ToString();
Return Value
Returns a string.
Remarks
If the current instance has a null value, the returned string contains "null".
