Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleNotificationInfo Enumeration
OracleNotificationInfo enumerated values specify the database event that causes the notification.
Table 8-30 lists all the OracleNotificationInfo enumeration values with a description of each enumerated value.
Table 8-30 OracleNotificationInfo Members
Member Name Description
Insert
A row is inserted.
Delete
A row is deleted.
Update
A row is updated.
Startup
A database starts.
Shutdown
A database shuts down.
Shutdown_Any
A database instance in a Real Application Cluster (RAC) environment shuts down.
Alter
An object is altered.
Drop
An object or database is dropped.
End
A registration is removed.
Error
A notification error occurs.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
