Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleNotificationSource Enumeration
OracleNotificationSource enumerated values specify the different sources that cause notification.
Table 8-29 lists all the OracleNotificationSource enumeration values with a description of each enumerated value.
Table 8-29 OracleNotificationSource Members
Member Name Description
Data
The data in a table has changed.
Database
A database event such as a database startup or shutdown occurs.
Object
A database object is altered or dropped.
Subscription
The subscription is changed.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
