| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.6.20) E10927-01 |
![]() Previous |
![]() Next |
The OracleObjectMappingAttribute class marks custom class fields or properties with information that ODP.NET uses when a custom type represents an Oracle Object type.
Class Inheritance
System.Object
System.Attribute
System.OracleObjectMappingAttribute
Declaration
// C# [AttributeUsageAttribute(AttributeTargets.Field|AttributeTargets.Property, AllowMultiple=false, Inherited=true)] public sealed class OracleObjectMappingAttribute : Attribute
Remarks
The OracleObjectMappingAttribute is specified on members of a custom type that represent an Oracle object type. This attribute must specify the name or zero-based index of the attribute in the Oracle object that the custom class field or property maps to. This also allows the custom type to declare field or property names which differ from the Oracle Object type.
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleObjectMappingAttribute members are listed in the following tables.
OracleObjectMappingAttribute Constructors
OracleObjectMappingAttribute constructors are listed in Table 14-8.
Table 14-8 OracleObjectMappingAttribute Constructors
| Constructor | Description |
OracleObjectMappingAttribute Constructors |
Instantiates a new instance of |
OracleObjectMappingAttribute Static Methods
OracleObjectMappingAttribute static methods are listed in Table 14-9.
Table 14-9 OracleObjectMappingAttribute Static Methods
| Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleObjectMappingAttribute Properties
OracleObjectMappingAttribute properties are listed in Table 14-10.
Table 14-10 OracleObjectMappingAttribute Properties
| Property | Description |
Specifies the index of the Oracle Object attribute that must be retrieved |
Specifies the name of Oracle Object attribute that must be retrieved |
Inherited from |
OracleObjectMappingAttribute Methods
OracleObjectMappingAttribute methods are listed in Table 14-11.
Table 14-11 OracleObjectMappingAttribute Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleObjectMappingAttribute constructors create new instances of the OracleObjectMappingAttribute class.
Overload List:
OracleObjectMappingAttribute(string)
This constructor creates and initializes an OracleObjectMappingAttribute object with the specified Oracle Object attribute name.
OracleObjectMappingAttribute(int)
This constructor creates and initializes an OracleObjectMappingAttribute with the specified Oracle Object attribute index.
Declaration
// C#
public OracleObjectMappingAttribute(string attrName);
Parameters
attrName
The name of the Oracle Object attribute to map to.
Remarks
The attrName parameter is case-sensitive.
This constructor creates and initializes an OracleObjectMappingAttribute object with the specified Oracle Object attribute index.
Declaration
// C#
public OracleObjectMappingAttribute(int attrIndex);
Parameters
attrIndex
The zero-based index of the Oracle Object attribute to map to.
OracleObjectMappingAttribute static methods are listed in Table 14-12.
Table 14-12 OracleObjectMappingAttribute Static Method
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleObjectMappingAttribute properties are listed in Table 14-13.
Table 14-13 OracleObjectMappingAttribute Properties
Specifies the name of the Oracle Object attribute that must be retrieved |
Inherited from |
This property specifies the index of the Oracle Object attribute that must be retrieved.
Declaration
// C#
public int AttributeIndex {get;}
Property Value
The zero-based index of an Oracle Object type attribute.
Remarks
The AttributeIndex property specifies the index of the Oracle Object type attribute that the custom class field or property maps to. This allows the custom class to declare fields or property names that differ from the Oracle object.
This property specifies the name of the Oracle Object attribute that must be retrieved.
Declaration
// C#
public string AttributeName {get;}
Property Value
The name of an attribute of an Oracle Object type.
Remarks
The AttributeName property specifies name of the attribute in the Oracle Object type that the custom class field or property maps to. This allows the custom class to declare field or property names that differ from the Oracle object.
The specified attribute name is case-sensitive.
OracleObjectMappingAttribute methods are listed in Table 14-14.
Table 14-14 OracleObjectMappingAttribute Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
