Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleParameterStatus Enumeration
The OracleParameterStatus enumeration type indicates whether a NULL value is fetched from a column, or truncation has occurred during the fetch, or a NULL value is to be inserted into a database column.
Table 5-104 lists all the OracleParameterStatus enumeration values with a description of each enumerated value.
Table 5-104 OracleParameterStatus Members
Member Name Description
Success
Indicates that (for input parameters) the input value has been assigned to the column. For output parameter, it indicates that the provider assigned an intact value to the parameter.
NullFetched
Indicates that a NULL value has been fetched from a column or an OUT parameter.
NullInsert
Indicates that a NULL value is to be inserted into a column.
Truncation
Indicates that truncation has occurred when fetching the data from the column.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
