| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.6.20) E10927-01 |
![]() Previous |
![]() Next |
The OracleRowUpdatedEventArgs class provides event data for the OracleDataAdapter.RowUpdated event.
Class Inheritance
System.Object
System.EventArgs
System.RowUpdatedEventArgs
System.OracleRowUpdatedEventArgs
Declaration
// C# public sealed class OracleRowUpdatedEventArgs : RowUpdatedEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatedEventArgs. See RowUpdated event "Example".
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleRowUpdatedEventArgs members are listed in the following tables.
OracleRowUpdatedEventArgs Constructors
OracleRowUpdatedEventArgs constructors are listed in Table 5-82.
Table 5-82 OracleRowUpdatedEventArgs Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleRowUpdatedEventArgs Static Methods
The OracleRowUpdatedEventArgs static method is listed in Table 5-83.
Table 5-83 OracleRowUpdatedEventArgs Static Method
| Method | Description |
Inherited from |
OracleRowUpdatedEventArgs Properties
The OracleRowUpdatedEventArgs properties are listed in Table 5-84.
Table 5-84 OracleRowUpdatedEventArgs Properties
| Property | Description |
Specifies the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleRowUpdatedEventArgs Public Methods
The OracleRowUpdatedEventArgs properties are listed in Table 5-85.
Table 5-85 OracleRowUpdatedEventArgs Public Methods
| Public Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
The OracleRowUpdatedEventArgs constructor creates a new OracleRowUpdatedEventArgs instance.
Declaration
// C# public OracleRowUpdatedEventArgs(DataRow row,IDbCommand command, StatementType statementType, DataTableMapping tableMapping);
Parameters
row
The DataRow sent for Update.
command
The IDbCommand executed during the Update.
statementType
The StatementType Enumeration value indicating the type of SQL statement executed.
tableMapping
The DataTableMapping used for the Update.
The OracleRowUpdatedEventArgs static method is listed in Table 5-86.
Table 5-86 OracleRowUpdatedEventArgs Static Method
Inherited from |
The OracleRowUpdatedEventArgs properties are listed in Table 5-87.
Table 5-87 OracleRowUpdatedEventArgs Properties
Specifies the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
This property specifies the OracleCommand that is used when OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatedEventArgs properties are listed in Table 5-88.
