| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.6.20) E10927-01 |
![]() Previous |
![]() Next |
The OracleRowUpdatingEventArgs class provides event data for the OracleDataAdapter.RowUpdating event.
Class Inheritance
System.Object
System.EventArgs
System.RowUpdatingEventArgs
System.OracleRowUpdatingEventArgs
Declaration
// C# public sealed class OracleRowUpdatingEventArgs : RowUpdatingEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatingEventArgs. See RowUpdated event "Example".
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleRowUpdatingEventArgs members are listed in the following tables.
OracleRowUpdatingEventArgs Constructors
OracleRowUpdatingEventArgs constructors are listed in Table 5-89.
Table 5-89 OracleRowUpdatingEventArgs Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleRowUpdatingEventArgs Static Methods
The OracleRowUpdatingEventArgs static methods are listed in Table 5-90.
Table 5-90 OracleRowUpdatingEventArgs Static Methods
| Method | Description |
Inherited from |
OracleRowUpdatingEventArgs Properties
The OracleRowUpdatingEventArgs properties are listed in Table 5-91.
Table 5-91 OracleRowUpdatingEventArgs Properties
| Property | Description |
Specifies the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleRowUpdatingEventArgs Public Methods
The OracleRowUpdatingEventArgs public methods are listed in Table 5-92.
Table 5-92 OracleRowUpdatingEventArgs Public Methods
| Public Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
The OracleRowUpdatingEventArgs constructor creates a new instance of the OracleRowUpdatingEventArgs class using the supplied data row, IDbCommand, type of SQL statement, and table mapping.
Declaration
// C# public OracleRowUpdatingEventArgs(DataRow row, IDbCommand command, StatementType statementType, DataTableMapping tableMapping);
Parameters
row
The DataRow sent for Update.
command
The IDbCommand executed during the Update.
statementType
The StatementType enumeration value indicating the type of SQL statement executed.
tableMapping
The DataTableMapping used for the Update.
The OracleRowUpdatingEventArgs static method is listed in Table 5-93.
Table 5-93 OracleRowUpdatingEventArgs Static Method
Inherited from |
The OracleRowUpdatingEventArgs properties are listed in Table 5-94.
Table 5-94 OracleRowUpdatingEventArgs Properties
Specifies the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
This property specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get; set;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatingEventArgs public methods are listed in Table 5-95.
