Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleString Structure
The OracleString structure represents a variable-length stream of characters to be stored in or retrieved from a database.
Class Inheritance
System.Object
  System.ValueType
    Oracle.DataAccess.Types.OracleString
Declaration
// ADO.NET 2.0: C#
public struct OracleString : IComparable, INullable, IXmlSerializable
// ADO.NET 1.x: C#
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleStringSample
  static void Main()
    // Initialize OracleString structs
    OracleString string1 = new OracleString("AAA");
    // Display the string "AAA"
    Console.WriteLine("{0} has length of {1}", string1, string1.Length);
    // Contatenate characters to string1 until the length is 5
    while (string1.Length < 5)
      string1 = OracleString.Concat(string1,"a");
    // Display the string of "AAAaa"
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleString Members
OracleString members are listed in the following tables:
OracleString Constructors
OracleString constructors are listed in Table 12-74
Table 12-74 OracleString Constructors
Constructor Description
Instantiates a new instance of OracleString structure (Overloaded)
OracleString Static Fields
The OracleString static fields are listed in Table 12-75.
Table 12-75 OracleString Static Fields
Field Description
Null
Represents a null value that can be assigned to an instance of the OracleString structure
OracleString Static Methods
The OracleString static methods are listed in Table 12-76.
Table 12-76 OracleString Static Methods
Methods Description
Concat
Concatenates two OracleString instances and returns a new OracleString instance that represents the result
Equals
Determines if two OracleString values are equal (Overloaded)
GreaterThan
Determines whether or not the first of two OracleString values is greater than the second
GreaterThanOrEqual
Determines whether or not the first of two OracleString values is greater than or equal to the second
LessThan
Determines whether or not the first of two OracleString values is less than the second
LessThanOrEqual
Determines whether or not the first of two OracleString values is less than or equal to the second
NotEquals
Determines whether two OracleString values are not equal
OracleString Static Operators
The OracleString static operators are listed in Table 12-77.
Table 12-77 OracleString Static Operators
Operator Description
operator +
Concatenates two OracleString values
operator ==
operator >
Determines if the first of two OracleString values is greater than the second
operator >=
Determines if the first of two OracleString values is greater than or equal to the second
operator !=
Determines if the two OracleString values are not equal
operator <
Determines if the first of two OracleString values is less than the second
operator <=
Determines if two OracleString values are not equal
OracleString Type Conversions
The OracleString type conversions are listed in Table 12-78.
Table 12-78 OracleString Type Conversions
explicit operator string
Converts the supplied OracleString to a string instance
implicit operator OracleString
Converts the supplied string to an OracleString instance
OracleString Properties
The OracleString properties are listed in Table 12-79.
Table 12-79 OracleString Properties
Properties Description
IsCaseIgnored
Indicates whether or not case should be ignored when performing string comparison
IsNull
Indicates whether or not the current instance has a null value
Item
Obtains the particular character in an OracleString using an index.
Length
Returns the length of the OracleString
OracleString Methods
The OracleString methods are listed in Table 12-80.
Table 12-80 OracleString Methods
Methods Description
Clone
Returns a copy of the current OracleString instance
CompareTo
Compares the current OracleString instance to the supplied object, and returns an integer that represents their relative values
Equals
Determines whether or not an object has the same string value as the current OracleString structure (Overloaded)
GetHashCode
Returns a hash code for the OracleString instance
GetNonUnicodeBytes
Returns an array of bytes, containing the contents of the OracleString, in the client character set format
GetType
Inherited from System.Object
GetUnicodeBytes
Returns an array of bytes, containing the contents of the OracleString, in Unicode format
ToString
Converts the current OracleString instance to a string
The OracleString constructors create new instances of the OracleString structure.
Overload List:
OracleString(string)
This constructor creates a new instance of the OracleString structure and sets its value using a string.
Declaration
// C#
public OracleString(string data);
Parameters
OracleString(string, bool)
This constructor creates a new instance of the OracleString structure and sets its value using a string and specifies if case is ignored in comparison.
Declaration
// C#
public OracleString(string data, bool isCaseIgnored);
Parameters
OracleString(byte [ ], bool)
This constructor creates a new instance of the OracleString structure and sets its value using a byte array and specifies if the supplied byte array is Unicode encoded.
Declaration
// C#
public OracleString(byte[] data, bool fUnicode);
Parameters
Exceptions
ArgumentNullException - The data parameter is null.
OracleString(byte [ ], bool, bool)
This constructor creates a new instance of the OracleString structure and sets its value using a byte array and specifies the following: if the supplied byte array is Unicode encoded and if case is ignored in comparison.
Declaration
// C#
public OracleString(byte[] data, bool fUnicode, bool isCaseIgnored);
Parameters
Exceptions
OracleString(byte [ ], int, int, bool)
This constructor creates a new instance of the OracleString structure and sets its value using a byte array, and specifies the following: the starting index in the byte array, the number of bytes to copy from the byte array, and if the supplied byte array is Unicode encoded.
Declaration
// C#
public OracleString(byte[] data, int index, int count, bool fUnicode);
Parameters
Exceptions
ArgumentOutOfRangeException - The count parameter is less than zero.
IndexOutOfRangeException - The index parameter is greater than or equal to the length of data or less than zero.
OracleString(byte [ ], int, int, bool, bool)
This constructor creates a new instance of the OracleString structure and sets its value using a byte array, and specifies the following: the starting index in the byte array, the number of bytes to copy from the byte array, if the supplied byte array is Unicode encoded, and if case is ignored in comparison.
Declaration
// C#
public OracleString(byte[] data, int index, int count, bool fUnicode,
Parameters
Exceptions
The OracleString static fields are listed in Table 12-81.
Table 12-81 OracleString Static Fields
Field Description
Null
Null
This static field represents a null value that can be assigned to an instance of the OracleString structure.
Declaration
// C#
public static readonly OracleString Null;
The OracleString static methods are listed in Table 12-82.
Table 12-82 OracleString Static Methods
Methods Description
Concat
Equals
GreaterThan
GreaterThanOrEqual
LessThan
LessThanOrEqual
NotEquals
Concat
This static method concatenates two OracleString instances and returns a new OracleString instance that represents the result.
Declaration
// C#
public static OracleString Concat(OracleString str1, OracleString str2);
Parameters
Return Value
An OracleString.
Remarks
If either argument has a null value, the returned OracleString structure has a null value.
Equals
Overloads Object
This static method determines whether or not the two OracleStrings being compared are equal.
Declaration
// C#
public static bool Equals(OracleString str1, OracleString str2);
Parameters
Return Value
Returns true if the two OracleStrings being compared are equal; returns false otherwise.
Remarks
The following rules apply to the behavior of this method.
GreaterThan
This static method determines whether or not the first of two OracleString values is greater than the second.
Declaration
// C#
public static bool GreaterThan(OracleString str1, OracleString str2);
Parameters
Return Value
Returns true if the first of two OracleStrings is greater than the second; otherwise, returns false.
Remarks
GreaterThanOrEqual
This static method determines whether or not the first of two OracleString values is greater than or equal to the second.
Declaration
// C#
public static bool GreaterThanOrEqual(OracleString str1,
    OracleString str2);
Parameters
Return Value
Returns true if the first of two OracleStrings is greater than or equal to the second; otherwise, returns false.
Remarks
LessThan
This static method determines whether or not the first of two OracleString values is less than the second.
Declaration
// C#
public static bool LessThan(OracleString str1, OracleString str2);
Parameters
Return Value
Returns true if the first is less than the second; otherwise, returns false.
Remarks
LessThanOrEqual
This static method determines whether or not the first of two OracleString values is less than or equal to the second.
Declaration
// C#
public static bool LessThanOrEqual(OracleString str1, OracleString str2);
Parameters
Return Value
Returns true if the first is less than or equal to the second; otherwise, returns false.
Remarks
NotEquals
This static method determines whether two OracleString values are not equal.
Declaration
// C#
public static bool NotEquals(OracleString str1, OracleString str2);
Parameters
Return Value
Returns true if the two OracleString instances are not equal; otherwise, returns false.
Remarks
The OracleString static operators are listed in Table 12-83.
Table 12-83 OracleString Static Operators
operator +
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator +
This static operator concatenates two OracleString values.
Declaration
// C#
public static OracleString operator + (OracleString value1, OracleString value2);
Parameters
Return Value
An OracleString.
Remarks
operator ==
This static operator determines if two OracleString values are equal.
Declaration
// C#
public static bool operator == (OracleString value1, OracleString value2);
Parameters
Return Value
Returns true if two OracleString values are equal; otherwise, returns false.
Remarks
operator >
This static operator determines if the first of two OracleString values is greater than the second.
Declaration
// C#
public static bool operator > (OracleString value1, OracleString value2);
Parameters
Return Value
Returns true if the first of two OracleString values is greater than the second; otherwise returns false.
Remarks
operator >=
This static operator determines if the first of two OracleString values is greater than or equal to the second.
Declaration
// C#
public static bool operator >= (OracleString value1, OracleString value2);
Parameters
Return Value
Returns true if the first of two OracleString values is greater than or equal to the second; otherwise, returns false.
Remarks
operator !=
This static operator determines if two OracleString values are not equal.
Declaration
// C#
public static bool operator != (OracleString value1, OracleString value2);
Parameters
Return Value
Returns true if two OracleString values are not equal; otherwise, returns false.
Remarks
operator <
This static operator determines if the first of two OracleStrings is less than the second.
Declaration
// C#
public static bool operator < (OracleString value1, OracleString value2);
Parameters
Return Value
Returns true if the first of two OracleStrings is less than the second; otherwise, returns false.
Remarks
operator <=
This static operator determines if the first of two OracleString values is less than or equal to the second.
Declaration
// C#
public static bool operator <= (OracleString value1, OracleString value1);
Parameters
Return Value
Returns true if the first of two OracleString values is less than or equal to the second; otherwise, returns false.
Remarks
The OracleString type conversions are listed in Table 12-84.
Table 12-84 OracleString Type Conversions
This type conversion operator converts the supplied OracleString to a string.
Declaration
//C#
public static explicit operator string (OracleString value1);
Parameters
Return Value
string
Exceptions
OracleNullValueException - The OracleString structure has a null value.
This type conversion operator converts the supplied string to an OracleString.
Declaration
// C#
public static implicit operator OracleString (string value1);
Parameters
Return Value
An OracleString.
The OracleString properties are listed in Table 12-85.
Table 12-85 OracleString Properties
IsCaseIgnored
IsNull
Item
Length
IsCaseIgnored
This property indicates whether or not case should be ignored when performing string comparison.
Declaration
//C#
public bool IsCaseIgnored {get;set;}
Property Value
Returns true if string comparison must ignore case; otherwise false.
Remarks
Default value is true.
Example
// C#
using System;
class IsCaseIgnoredSample
  static void Main()
    OracleString string1 = new OracleString("aAaAa");
    OracleString string2 = new OracleString("AaAaA");
    // Ignore case for comparisons
    string1.IsCaseIgnored = true;
    string2.IsCaseIgnored = true;
    // Same; Prints 0
    Console.WriteLine(string1.CompareTo(string2));
    // Make comparisons case sensitive
    // Note that IsCaseIgnored must be set to false for both
    //   OracleStrings; otherwise an exception is thrown
    string1.IsCaseIgnored = false;
    string2.IsCaseIgnored = false;
    // Different; Prints nonzero value
IsNull
This property indicates whether or not the current instance contains a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
Returns true if the current instance contains has a null value; otherwise, returns false.
Item
This property obtains the particular character in an OracleString using an index.
Declaration
// C#
public char Item {get;}
Property Value
A char value.
Exceptions
OracleNullValueException - The current instance has a null value.
Length
This property returns the length of the OracleString.
Declaration
// C#
public int Length {get;}
Property Value
A int value.
Exceptions
The OracleString methods are listed in Table 12-86.
Table 12-86 OracleString Methods
Methods Description
Clone
CompareTo
Equals
GetHashCode
GetNonUnicodeBytes
GetType
GetUnicodeBytes
ToString
Clone
This method creates a copy of an OracleString instance.
Declaration
// C#
public OracleString Clone();
Return Value
An OracleString structure.
Remarks
The cloned object has the same property values as that of the object being cloned.
Example
// C#
using System;
class CloneSample
  static void Main()
    OracleString str1 = new OracleString("aAaAa");
    OracleString str2 = str1.Clone();
    // The OracleStrings are same; Prints 0
    Console.WriteLine(str1.CompareTo(str2));
CompareTo
This method compares the current OracleString instance to the supplied object, and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
Return Value
The method returns a number that is:
Implements
IComparable
Exceptions
ArgumentException - The obj parameter is not of type OracleString.
Remarks
Equals
This method determines whether or not supplied object is an instance of OracleString and has the same values as the current OracleString instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
Return Value
Returns true if the supplied object is an instance of OracleString and has the same values as the current OracleString instance; otherwise, returns false.
Remarks
GetHashCode
Overrides Object
This method returns a hash code for the OracleString instance.
Declaration
// C#
public override int GetHashCode();
Return Value
A number that represents the hash code.
GetNonUnicodeBytes
This method returns an array of bytes, containing the contents of the OracleString, in the client character set format.
Declaration
// C#
public byte[] GetNonUnicodeBytes();
Return Value
A byte array that contains the contents of the OracleString in the client character set format.
Remarks
If the current instance has a null value, an OracleNullValueException is thrown.
GetUnicodeBytes
This method returns an array of bytes, containing the contents of the OracleString in Unicode format.
Declaration
// C#
public byte[] GetUnicodeBytes();
Return Value
A byte array that contains the contents of the OracleString in Unicode format.
Remarks
ToString
Overrides Object
This method converts the current OracleString instance to a string.
Declaration
// C#
public override string ToString();
Return Value
A string.
Remarks
If the current OracleString instance has a null value, the string contains "null".
