Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleTimeStamp Structure
The OracleTimeStamp structure represents the Oracle TIMESTAMP data type to be stored in or retrieved from a database. Each OracleTimeStamp stores the following information: year, month, day, hour, minute, second, and nanosecond.
Class Inheritance
System.Object
  System.ValueType
    Oracle.DataAccess.Types.OracleTimeStamp
Declaration
 // ADO.NET 2.0: C#public struct OracleTimeStamp : IComparable, INullable, IXmlSerializable
// ADO.NET 1.x: C#
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleTimeStampSample
  static void Main()
    OracleTimeStamp tsCurrent1 = OracleTimeStamp.GetSysDate();
    OracleTimeStamp tsCurrent2 = DateTime.Now;
    // Calculate the difference between tsCurrent1 and tsCurrent2
    OracleIntervalDS idsDiff = tsCurrent2.GetDaysBetween(tsCurrent1);
    // Calculate the difference using AddNanoseconds()
    int nanoDiff = 0;
    while (tsCurrent2 > tsCurrent1)
      nanoDiff += 10;
      tsCurrent1 = tsCurrent1.AddNanoseconds(10);
    Console.WriteLine("idsDiff.Nanoseconds = " + idsDiff.Nanoseconds);
    Console.WriteLine("nanoDiff = " + nanoDiff);
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
OracleTimeStamp Members
OracleTimeStamp members are listed in the following tables:
OracleTimeStamp Constructors
OracleTimeStamp constructors are listed in Table 12-87
Table 12-87 OracleTimeStamp Constructors
Constructor Description
Instantiates a new instance of OracleTimeStamp structure (Overloaded)
OracleTimeStamp Static Fields
The OracleTimeStamp static fields are listed in Table 12-88.
Table 12-88 OracleTimeStamp Static Fields
Field Description
MaxValue
Represents the maximum valid date for an OracleTimeStamp structure, which is December 31, 9999 23:59:59.999999999
MinValue
Represents the minimum valid date for an OracleTimeStamp structure, which is January 1, -4712 0:0:0
Null
Represents a null value that can be assigned to an instance of the OracleTimeStamp structure
OracleTimeStamp Static Methods
The OracleTimeStamp static methods are listed in Table 12-89.
Table 12-89 OracleTimeStamp Static Methods
Methods Description
Equals
Determines if two OracleTimeStamp values are equal (Overloaded)
GreaterThan
Determines if the first of two OracleTimeStamp values is greater than the second
GreaterThanOrEqual
Determines if the first of two OracleTimeStamp values is greater than or equal to the second
LessThan
Determines if the first of two OracleTimeStamp values is less than the second
LessThanOrEqual
Determines if the first of two OracleTimeStamp values is less than or equal to the second
NotEquals
Determines if two OracleTimeStamp values are not equal
GetSysDate
Gets an OracleTimeStamp structure that represents the current date and time
Parse
Gets an OracleTimeStamp structure and sets its value using the supplied string
SetPrecision
Returns a new instance of an OracleTimeStamp with the specified fractional second precision
OracleTimeStamp Static Operators
The OracleTimeStamp static operators are listed in Table 12-90.
Table 12-90 OracleTimeStamp Static Operators
Operator Description
operator +
Adds the supplied instance value to the supplied OracleTimeStamp and returns a new OracleTimeStamp structure (Overloaded)
operator ==
operator >
operator >=
operator !=
Determines if the two OracleTimeStamp values are not equal
operator <
operator <=
operator -
Subtracts the supplied instance value from the supplied OracleTimeStamp and returns a new OracleTimeStamp structure (Overloaded)
OracleTimeStamp Static Type Conversions
The OracleTimeStamp static type conversions are listed in Table 12-91.
Table 12-91 OracleTimeStamp Static Type Conversions
explicit operator OracleTimeStamp
Converts an instance value to an OracleTimeStamp structure (Overloaded)
implicit operator OracleTimeStamp
explicit operator DateTime
Converts an OracleTimeStamp value to a DateTime structure
OracleTimeStamp Properties
The OracleTimeStamp properties are listed in Table 12-92.
Table 12-92 OracleTimeStamp Properties
Properties Description
BinData
Returns an array of bytes that represents an Oracle TIMESTAMP in Oracle internal format
Day
Specifies the day component of an OracleTimeStamp
IsNull
Indicates whether or not the OracleTimeStamp instance has a null value
Hour
Specifies the hour component of an OracleTimeStamp
Millisecond
Specifies the millisecond component of an OracleTimeStamp
Minute
Specifies the minute component of an OracleTimeStamp
Month
Specifies the month component of an OracleTimeStamp
Nanosecond
Specifies the nanosecond component of an OracleTimeStamp
Second
Specifies the second component of an OracleTimeStamp
Value
Specifies the date and time that is stored in the OracleTimeStamp structure
Year
Specifies the year component of an OracleTimeStamp
OracleTimeStamp Methods
The OracleTimeStamp methods are listed in Table 12-93.
Table 12-93 OracleTimeStamp Methods
Methods Description
AddDays
Adds the supplied number of days to the current instance
AddHours
Adds the supplied number of hours to the current instance
AddMilliseconds
Adds the supplied number of milliseconds to the current instance
AddMinutes
Adds the supplied number of minutes to the current instance
AddMonths
Adds the supplied number of months to the current instance
AddNanoseconds
Adds the supplied number of nanoseconds to the current instance
AddSeconds
Adds the supplied number of seconds to the current instance
AddYears
Adds the supplied number of years to the current instance
CompareTo
Compares the current OracleTimeStamp instance to an object, and returns an integer that represents their relative values
Equals
Determines whether or not an object has the same date and time as the current OracleTimeStamp instance (Overloaded)
GetHashCode
Returns a hash code for the OracleTimeStamp instance
GetDaysBetween
Subtracts an OracleTimeStamp value from the current instance and returns an OracleIntervalDS that represents the time difference between the supplied OracleTimeStamp and the current instance
GetYearsBetween
Subtracts value1 from the current instance and returns an OracleIntervalYM that represents the difference between value1 and the current instance using OracleIntervalYM
GetType
Inherited from System.Object
ToOracleDate
Converts the current OracleTimeStamp structure to an OracleDate structure
ToOracleTimeStampLTZ
Converts the current OracleTimeStamp structure to an OracleTimeStampLTZ structure
ToOracleTimeStampTZ
Converts the current OracleTimeStamp structure to an OracleTimeStampTZ structure
ToString
Converts the current OracleTimeStamp structure to a string
The OracleTimeStamp constructors create new instances of the OracleTimeStamp structure.
Overload List:
OracleTimeStamp(DateTime)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value for date and time using the supplied DateTime value.
Declaration
// C#
public OracleTimeStamp (DateTime dt);
Parameters
Exceptions
ArgumentException - The dt parameter cannot be used to construct a valid OracleTimeStamp.
OracleTimeStamp(string)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value using the supplied string.
Declaration
// C#
public OracleTimeStamp (string tsStr);
Parameters
Exceptions
ArgumentException - The tsStr value is an invalid string representation of an Oracle TIMESTAMP or the supplied tsStr is not in the timestamp format specified by the OracleGlobalization.TimeStampFormat property of the thread, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
ArgumentNullException - The tsStr value is null.
Remarks
The names and abbreviations used for months and days are in the language specified by the DateLanguage and Calendar properties of the thread's OracleGlobalization object. If any of the thread's globalization properties are set to null or an empty string, the client computer's settings are used.
Example
// C#
using System;
using Oracle.DataAccess.Client;
  static void Main()
    // Set the nls_timestamp_format for the OracleTimeStamp(string)
    // constructor
    OracleGlobalization info = OracleGlobalization.GetClientInfo();
    info.TimeStampFormat = "DD-MON-YYYY HH:MI:SS.FF AM";
    OracleGlobalization.SetThreadInfo(info);
    // construct OracleTimeStamp from a string using the format specified.
    OracleTimeStamp ts = new OracleTimeStamp("11-NOV-1999 11:02:33.444 AM");
    // Set the nls_timestamp_format for the ToString() method
    info.TimeStampFormat = "YYYY-MON-DD HH:MI:SS.FF AM";
    // Prints "1999-NOV-11 11:02:33.444000000 AM"
    Console.WriteLine(ts.ToString());
OracleTimeStamp(int, int, int)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value for date using year, month, and day.
Declaration
// C#
public OracleTimeStamp(int year, int month, int day);
Parameters
Exceptions
ArgumentOutOfRangeException - The argument value for one or more of the parameters is out of the specified range.
ArgumentException - The argument values of the parameters cannot be used to construct a valid OracleTimeStamp (that is, the day is out of range for the month).
OracleTimeStamp(int, int, int, int, int, int)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value for date and time using year, month, day, hour, minute, and second.
Declaration
// C#
public OracleTimeStamp (int year, int month, int day, int hour,
  int minute, int second);
Parameters
Exceptions
OracleTimeStamp(int, int, int, int, int, int, double)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value for date and time using year, month, day, hour, minute, second, and millisecond.
Declaration
// C#
public OracleTimeStamp(int year, int month, int day, int hour,
   int minute,  int second, double millisecond);
Parameters
Exceptions
OracleTimeStamp(int, int, int, int, int, int, int)
This constructor creates a new instance of the OracleTimeStamp structure and sets its value for date and time using year, month, day, hour, minute, second, and nanosecond.
Declaration
// C#
   int minute, int second, int nanosecond);
Parameters
Exceptions
OracleTimeStamp(byte [ ])
This constructor creates a new instance of the OracleTimeStamp structure and sets its value to the provided byte array, which is in the internal Oracle TIMESTAMP format.
Declaration
// C#
public OracleTimeStamp (byte[] bytes);
Parameters
Exceptions
ArgumentException - bytes is not in an internal Oracle TIMESTAMP format or bytes is not a valid Oracle TIMESTAMP.
ArgumentNullException - bytes is null.
The OracleTimeStamp static fields are listed in Table 12-94.
Table 12-94 OracleTimeStamp Static Fields
Field Description
MaxValue
MinValue
Null
MaxValue
This static field represents the maximum valid date and time for an OracleTimeStamp structure, which is December 31, 9999 23:59:59.999999999.
Declaration
// C#
public static readonly OraTimestamp MaxValue;
MinValue
This static field represents the minimum valid date and time for an OracleTimeStamp structure, which is January 1, -4712 0:0:0.
Declaration
// C#
public static readonly OracleTimeStamp MinValue;
Null
This static field represents a null value that can be assigned to an instance of the OracleTimeStamp structure.
Declaration
// C#
public static readonly OracleTimeStamp Null;
The OracleTimeStamp static methods are listed in Table 12-95.
Table 12-95 OracleTimeStamp Static Methods
Methods Description
Equals
GreaterThan
GreaterThanOrEqual
LessThan
LessThanOrEqual
NotEquals
GetSysDate
Parse
SetPrecision
Equals
This static method determines if two OracleTimeStamp values are equal.
Declaration
// C#
public static bool Equals(OracleTimeStamp value1, OracleTimeStamp value2);
Parameters
Return Value
Returns true if two OracleTimeStamp values are equal; otherwise, returns false.
Remarks
The following rules apply to the behavior of this method.
GreaterThan
This static method determines if the first of two OracleTimeStamp values is greater than the second.
Declaration
// C#
public static bool GreaterThan(OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStamp values is greater than the second; otherwise, returns false.
Remarks
GreaterThanOrEqual
This static method determines if the first of two OracleTimeStamp values is greater than or equal to the second.
Declaration
// C#
public static bool GreaterThanOrEqual(OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStamp values is greater than or equal to the second; otherwise, returns false.
Remarks
LessThan
This static method determines if the first of two OracleTimeStamp values is less than the second.
Declaration
// C#
public static bool LessThan(OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStamp values is less than the second. Returns false otherwise.
Remarks
LessThanOrEqual
This static method determines if the first of two OracleTimeStamp values is less than or equal to the second.
Declaration
// C#
public static bool LessThanOrEqual(OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStamp values is less than or equal to the second. Returns false otherwise.
Remarks
NotEquals
This static method determines if two OracleTimeStamp values are not equal.
Declaration
// C#
public static bool NotEquals(OracleTimeStamp value1,
Parameters
Return Value
Returns true if two OracleTimeStamp values are not equal. Returns false otherwise.
Remarks
GetSysDate
This static method gets an OracleTimeStamp structure that represents the current date and time.
Declaration
// C#
public static OracleTimeStamp GetSysDate();
Return Value
An OracleTimeStamp structure that represents the current date and time.
Parse
This static method gets an OracleTimeStamp structure and sets its value using the supplied string.
Declaration
// C#
public static OracleTimeStamp Parse(string datetime);
Parameters
Return Value
An OracleTimeStamp structure.
Exceptions
ArgumentException - The tsStr is an invalid string representation of an Oracle TIMESTAMP or the supplied tsStr is not in the timestamp format specified by the OracleGlobalization.TimeStampFormat property of the thread, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
Remarks
Example
// C#
using System;
class ParseSample
  static void Main()
    // Set the nls_timestamp_format for the Parse() method
      OracleTimeStamp.Parse("11-NOV-1999 11:02:33.444 AM");
SetPrecision
This static method returns a new instance of an OracleTimeStamp with the specified fractional second precision.
Declaration
// C#
public static OracleTimeStamp SetPrecision(OracleTimeStamp value1,
    int fracSecPrecision);
Parameters
Return Value
An OracleTimeStamp structure with the specified fractional second precision.
Exceptions
ArgumentOutOfRangeException - fracSecPrecision is out of the specified range.
Remarks
The value specified in the supplied fracSecPrecision is used to perform a rounding off operation on the supplied OracleTimeStamp value. Depending on this value, 0 or more trailing zeros are displayed in the string returned by ToString().
Example
The OracleTimeStamp with a value of "December 31, 9999 23:59:59.99" results in the string "December 31, 9999 23:59:59.99000" when SetPrecision() is called with the fractional second precision set to 5.
The OracleTimeStamp static operators are listed in Table 12-96.
Table 12-96 OracleTimeStamp Static Operators
operator +
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator -
operator +
operator+ adds the supplied object to the OracleTimeStamp and returns a new OracleTimeStamp structure.
Overload List:
operator + (OracleTimeStamp, OracleIntervalDS)
This static operator adds the supplied OracleIntervalDS to the OracleTimeStamp and returns a new OracleTimeStamp structure.
Declaration
// C#
public static operator + (OracleTimeStamp value1, OracleIntervalDS value2);
Parameters
Return Value
An OracleTimeStamp.
Remarks
If either parameter has a null value, the returned OracleTimeStamp has a null value.
operator + (OracleTimeStamp, OracleIntervalYM)
This static operator adds the supplied OracleIntervalYM to the supplied OracleTimeStamp and returns a new OracleTimeStamp structure.
Declaration
// C#
public static operator + (OracleTimeStamp value1, OracleIntervalYM value2);
Parameters
Return Value
An OracleTimeStamp.
Remarks
operator + (OracleTimeStamp, TimeSpan)
This static operator adds the supplied TimeSpan to the supplied OracleTimeStamp and returns a new OracleTimeStamp structure.
Declaration
// C#
public static operator + (OracleTimeStamp value1, TimeSpan value2);
Parameters
Return Value
An OracleTimeStamp.
Remarks
If the OracleTimeStamp instance has a null value, the returned OracleTimeStamp has a null value.
operator ==
This static operator determines if two OracleTimeStamp values are equal.
Declaration
// C#
public static bool operator == (OracleTimeStamp value1,
Parameters
Return Value
Returns true if they are the same; otherwise, returns false.
Remarks
operator >
This static operator determines if the first of two OracleTimeStamp values is greater than the second.
Declaration
// C#
public static bool operator > (OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first OracleTimeStamp value is greater than the second; otherwise, returns false.
Remarks
operator >=
This static operator determines if the first of two OracleTimeStamp values is greater than or equal to the second.
Declaration
// C#
public static bool operator >= (OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first OracleTimeStamp is greater than or equal to the second; otherwise returns false.
Remarks
operator !=
This static operator determines if two OracleTimeStamp values are not equal.
Declaration
// C#
public static bool operator != (OracleTimeStamp value1,
Parameters
Return Value
Returns true if two OracleTimeStamp values are not equal; otherwise, returns false.
Remarks
operator <
This static operator determines if the first of two OracleTimeStamp values is less than the second.
Declaration
// C#
public static bool operator < (OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first OracleTimeStamp is less than the second; otherwise, returns false.
Remarks
operator <=
This static operator determines if the first of two OracleTimeStamp values is less than or equal to the second.
Declaration
// C#
public static bool operator <= (OracleTimeStamp value1,
Parameters
Return Value
Returns true if the first OracleTimeStamp is less than or equal to the second; otherwise, returns false.
Remarks
operator -
operator- subtracts the supplied value, from the supplied OracleTimeStamp value, and returns a new OracleTimeStamp structure.
Overload List:
operator - (OracleTimeStamp, OracleIntervalDS)
This static operator subtracts the supplied OracleIntervalDS value, from the supplied OracleTimeStamp value, and return a new OracleTimeStamp structure.
Declaration
// C#
public static operator - (OracleTimeStamp value1, OracleIntervalDS value2);
Parameters
Return Value
Remarks
operator - (OracleTimeStamp, OracleIntervalYM)
This static operator subtracts the supplied OracleIntervalYM value, from the supplied OracleTimeStamp value, and returns a new OracleTimeStamp structure.
Declaration
// C#
public static operator - (OracleTimeStamp value1, OracleIntervalYM value2);
Parameters
Return Value
Remarks
operator - (OracleTimeStamp, TimeSpan)
This static operator subtracts the supplied TimeSpan value, from the supplied OracleTimeStamp value, and returns a new OracleTimeStamp structure.
Declaration
// C#
public static operator - (OracleTimeStamp value1, TimeSpan value2);
Parameters
Return Value
Remarks
If the OracleTimeStamp instance has a null value, the returned OracleTimeStamp structure has a null value.
The OracleTimeStamp static type conversions are listed in Table 12-97.
Table 12-97 OracleTimeStamp Static Type Conversions
explicit operator OracleTimeStamp converts the supplied value to an OracleTimeStamp structure
Overload List:
explicit operator OracleTimeStamp(OracleTimeStampLTZ)
This static type conversion operator converts an OracleTimeStampLTZ value to an OracleTimeStamp structure.
Declaration
// C#
public static explicit operator OracleTimeStamp(OracleTimeStampLTZ value1);
Parameters
Return Value
The returned OracleTimeStamp contains the date and time of the OracleTimeStampLTZ structure.
Remarks
If the OracleTimeStampLTZ structure has a null value, the returned OracleTimeStamp structure also has a null value.
explicit operator OracleTimeStamp(OracleTimeStampTZ)
This static type conversion operator converts an OracleTimeStampTZ value to an OracleTimeStamp structure.
Declaration
// C#
public static explicit operator OracleTimeStamp(OracleTimeStampTZ value1);
Parameters
Return Value
The returned OracleTimeStamp contains the date and time information from value1, but the time zone information from value1 is truncated.
Remarks
If the OracleTimeStampTZ structure has a null value, the returned OracleTimeStamp structure also has a null value.
explicit operator OracleTimeStamp(string)
This static type conversion operator converts the supplied string to an OracleTimeStamp structure.
Declaration
// C#
public static explicit operator OracleTimeStamp(string tsStr);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
ArgumentException - The tsStr is an invalid string representation of an Oracle TIMESTAMP or the tsStr is not in the timestamp format specified by the thread's OracleGlobalization.TimeStampFormat property, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
Remarks
Example
// C#
using System;
  static void Main()
    // Set the nls_timestamp_format for the explicit
    // operator OracleTimeStamp(string)
    // Set the nls_timestamp_format for the ToString method
This static type conversion operator converts a value to an OracleTimeStamp structure.
Overload List:
implicit operator OracleTimeStamp(OracleDate)
This static type conversion operator converts an OracleDate value to an OracleTimeStamp structure.
Declaration
// C#
public static implicit operator OracleTimeStamp (OracleDate value1);
Parameters
Return Value
An OracleTimeStamp structure that contains the date and time of the OracleDate structure, value1.
Remarks
If the OracleDate structure has a null value, the returned OracleTimeStamp structure also has a null value.
implicit operator OracleTimeStamp(DateTime)
This static type conversion operator converts a DateTime value to an OracleTimeStamp structure.
Declaration
// C#
public static implicit operator OracleTimeStamp(DateTime value);
Parameters
Return Value
This static type conversion operator converts an OracleTimeStamp value to a DateTime structure.
Declaration
// C#
public static explicit operator DateTime(OracleTimeStamp value1);
Parameters
Return Value
A DateTime containing the date and time in the current instance.
Exceptions
OracleNullValueException - The OracleTimeStamp structure has a null value.
Remarks
The precision of the OracleTimeStamp can be lost during the conversion.
The OracleTimeStamp properties are listed in Table 12-98.
Table 12-98 OracleTimeStamp Properties
BinData
Day
IsNull
Hour
Millisecond
Minute
Month
Nanosecond
Second
Value
Year
BinData
This property returns an array of bytes that represents an Oracle TIMESTAMP in Oracle internal format.
Declaration
// C#
public byte[] BinData {get;}
Property Value
A byte array that represents an Oracle TIMESTAMP in an internal format.
Exceptions
OracleNullValueException - The current instance has a null value.
Day
This property specifies the day component of an OracleTimeStamp.
Declaration
// C#
public int Day{get;}
Property Value
A number that represents the day. Range of Day is (1 to 31).
Exceptions
IsNull
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull{get;}
Property Value
Returns true if the current instance has a null value; otherwise, returns false.
Hour
This property specifies the hour component of an OracleTimeStamp.
Declaration
// C#
public int Hour{get;}
Property Value
A number that represents the hour. Range of hour is (0 to 23).
Exceptions
Millisecond
This property gets the millisecond component of an OracleTimeStamp.
Declaration
// C#
public double Millisecond{get;}
Property Value
A number that represents a millisecond. Range of Millisecond is (0 to 999.999999).
Exceptions
Minute
This property gets the minute component of an OracleTimeStamp.
Declaration
// C#
public int Minute{get;}
Property Value
A number that represent a minute. Range of Minute is (0 to 59).
Exceptions
Month
This property gets the month component of an OracleTimeStamp.
Declaration
// C#
public int Month{get;}
Property Value
A number that represents a month. Range of Month is (1 to 12).
Exceptions
Nanosecond
This property gets the nanosecond component of an OracleTimeStamp.
Declaration
// C#
public int Nanosecond{get;}
Property Value
A number that represents a nanosecond. Range of Nanosecond is (0 to 999999999).
Exceptions
Second
This property gets the second component of an OracleTimeStamp.
Declaration
// C#
public int Second{get;}
Property Value
A number that represents a second. Range of Second is (0 to 59).
Exceptions
Value
This property specifies the date and time that is stored in the OracleTimeStamp structure.
Declaration
// C#
public DateTime Value{get;}
Property Value
A DateTime.
Exceptions
Year
This property gets the year component of an OracleTimeStamp.
Declaration
// C#
public int Year{get;}
Property Value
A number that represents a year. The range of Year is (-4712 to 9999).
Exceptions
The OracleTimeStamp methods are listed in Table 12-99.
Table 12-99 OracleTimeStamp Methods
Methods Description
AddDays
AddHours
AddMilliseconds
AddMinutes
AddMonths
AddNanoseconds
AddSeconds
AddYears
CompareTo
Equals
GetHashCode
GetDaysBetween
GetYearsBetween
GetType
ToOracleDate
ToOracleTimeStampTZ
ToString
AddDays
This method adds the supplied number of days to the current instance.
Declaration
// C#
public OracleTimeStamp AddDays(double days);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
ArgumentOutofRangeException - The argument value is out of the specified range.
AddHours
This method adds the supplied number of hours to the current instance.
Declaration
// C#
public OracleTimeStamp AddHours(double hours);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddMilliseconds
This method adds the supplied number of milliseconds to the current instance.
Declaration
// C#
public OracleTimeStamp AddMilliseconds(double milliseconds);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddMinutes
This method adds the supplied number of minutes to the current instance.
Declaration
// C#
public OracleTimeStamp AddMinutes(double minutes);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddMonths
This method adds the supplied number of months to the current instance.
Declaration
// C#
public OracleTimeStamp AddMonths(long months);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddNanoseconds
This method adds the supplied number of nanoseconds to the current instance.
Declaration
// C#
public OracleTimeStamp AddNanoseconds(long nanoseconds);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddSeconds
This method adds the supplied number of seconds to the current instance.
Declaration
// C#
public OracleTimeStamp AddSeconds(double seconds);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
AddYears
This method adds the supplied number of years to the current instance.
Declaration
// C#
public OracleTimeStamp AddYears(int years);
Parameters
Return Value
An OracleTimeStamp.
Exceptions
CompareTo
This method compares the current OracleTimeStamp instance to an object, and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
Return Value
The method returns a number that is:
Less than zero: if the current OracleTimeStamp instance value is less than that of obj.
Zero: if the current OracleTimeStamp instance and obj values are equal.
Greater than zero: if the current OracleTimeStamp instance value is greater than that of obj.
Implements
IComparable
Exceptions
ArgumentException - The obj parameter is not of type OracleTimeStamp.
Remarks
Equals
Overrides Object
This method determines whether or not an object has the same date and time as the current OracleTimeStamp instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
Return Value
Returns true if the obj is of type OracleTimeStamp and represents the same date and time; otherwise, returns false.
Remarks
GetHashCode
Overrides Object
This method returns a hash code for the OracleTimeStamp instance.
Declaration
// C#
public override int GetHashCode();
Return Value
A number that represents the hash code.
GetDaysBetween
This method subtracts an OracleTimeStamp value from the current instance and returns an OracleIntervalDS that represents the time difference between the supplied OracleTimeStamp structure and the current instance.
Declaration
// C#
public OracleIntervalDS GetDaysBetween(OracleTimeStamp value1);
Parameters
Return Value
An OracleIntervalDS that represents the interval between two OracleTimeStamp values.
Remarks
If either the current instance or the parameter has a null value, the returned OracleIntervalDS has a null value.
GetYearsBetween
This method subtracts an OracleTimeStamp value from the current instance and returns an OracleIntervalYM that represents the time difference between the OracleTimeStamp value and the current instance.
Declaration
// C#
public OracleIntervalYM GetYearsBetween(OracleTimeStamp value1);
Parameters
Return Value
An OracleIntervalYM that represents the interval between two OracleTimeStamp values.
Remarks
If either the current instance or the parameter has a null value, the returned OracleIntervalYM has a null value.
ToOracleDate
This method converts the current OracleTimeStamp structure to an OracleDate structure.
Declaration
// C#
public OracleDate ToOracleDate();
Return Value
The returned OracleDate contains the date and time in the current instance.
Remarks
The precision of the OracleTimeStamp value can be lost during the conversion.
If the value of the OracleTimeStamp has a null value, the value of the returned OracleDate structure has a null value.
This method converts the current OracleTimeStamp structure to an OracleTimeStampLTZ structure.
Declaration
// C#
public OracleTimeStampLTZ ToOracleTimeStampLTZ();
Return Value
The returned OracleTimeStampLTZ contains date and time in the current instance.
Remarks
If the value of the current instance has a null value, the value of the returned OracleTimeStampLTZ structure has a null value.
ToOracleTimeStampTZ
This method converts the current OracleTimeStamp structure to an OracleTimeStampTZ structure.
Declaration
// C#
public OracleTimeStampTZ ToOracleTimeStampTZ();
Return Value
The returned OracleTimeStampTZ contains the date and time from the OracleTimeStamp and the time zone from the OracleGlobalization.TimeZone of the thread.
Remarks
If the value of the current instance has a null value, the value of the returned OracleTimeStampTZ structure has a null value.
ToString
Overrides Object
This method converts the current OracleTimeStamp structure to a string.
Declaration
// C#
public override string ToString();
Return Value
A string that represents the same date and time as the current OracleTimeStamp structure.
Remarks
The returned value is a string representation of an OracleTimeStamp in the format specified by the OracleGlobalization.TimeStampFormat property of the thread.
The names and abbreviations used for months and days are in the language specified by the OracleGlobalization's DateLanguage and Calendar properties of the thread. If any of the thread's globalization properties are set to null or an empty string, the client computer's settings are used.
Example
// C#
using System;
class ToStringSample
  static void Main()
    // constructor
