Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.6.20)
E10927-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleTransaction Class
An OracleTransaction object represents a local transaction.
Class Inheritance
System.Object
  System.MarshalByRefObject
    System.Data.Common.DbTransaction (ADO.NET 2.0 only)
      Oracle.DataAccess.Client.OracleTransaction
Declaration
// ADO.NET 2.0: C#
public sealed class OracleTransaction : DbTransaction
// C#
public sealed class OracleTransaction : MarshalByRefObject,
   IDbTransaction, IDisposable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
The application calls BeginTransaction on the OracleConnection object to create an OracleTransaction object. The OracleTransaction object can be created in Read Committed mode only. Any other mode results in an exception.
The execution of a DDL statement in the context of a transaction is not recommended since it results in an implicit commit that is not reflected in the state of the OracleTransaction object.
All operations related to savepoints pertain to the current local transaction. Operations like commit and rollback performed on the transaction have no effect on data in any existing DataSet.
Example
// Database Setup, if you have not done so yet.
connect scott/tiger@oracle
DROP TABLE MyTable;
CREATE TABLE MyTable (MyColumn NUMBER);
--CREATE TABLE MyTable (MyColumn NUMBER PRIMARY KEY);
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleTransactionSample
  static void Main()
    // Drop & Create MyTable as indicated Database Setup, at beginning
    // This sample starts a transaction and inserts two records with the same
    // value for MyColumn into MyTable.
    // If MyColumn is not a primary key, the transaction will commit.
    // If MyColumn is a primary key, the second insert will violate the
    // unique constraint and the transaction will rollback.
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    OracleCommand cmd = con.CreateCommand();
    // Check the number of rows in MyTable before transaction
    cmd.CommandText = "SELECT COUNT(*) FROM MyTable";
    int myTableCount = int.Parse(cmd.ExecuteScalar().ToString());
    // Print the number of rows in MyTable
    Console.WriteLine("myTableCount = " + myTableCount);
    // Start a transaction
    OracleTransaction txn = con.BeginTransaction(
      IsolationLevel.ReadCommitted);
    try
      // Insert the same row twice into MyTable
      cmd.CommandText = "INSERT INTO MyTable VALUES (1)";
      cmd.ExecuteNonQuery();
      cmd.ExecuteNonQuery(); // This may throw an exception
      txn.Commit();
    catch (Exception e)
      // Print the exception message
      Console.WriteLine("e.Message    =  " + e.Message);
      // Rollback the transaction
      txn.Rollback();
    // Check the number of rows in MyTable after transaction
    // Prints the number of rows
    // If MyColumn is not a PRIMARY KEY, the value should increase by two.
    // If MyColumn is a PRIMARY KEY, the value should remain same.
    txn.Dispose();
    cmd.Dispose();
    con.Close();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 1.0 or later
Comment: Not supported in a .NET stored procedure
OracleTransaction Members
OracleTransaction members are listed in the following tables.
OracleTransaction Static Methods
The OracleTransaction static method is listed in Table 5-96.
Table 5-96 OracleTransaction Static Method
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleTransaction Properties
OracleTransaction properties are listed in Table 5-97.
Table 5-97 OracleTransaction Properties
Property Description
IsolationLevel
Specifies the isolation level for the transaction
Connection
Specifies the connection that is associated with the transaction
OracleTransaction Public Methods
OracleTransaction public methods are listed in Table 5-98.
Table 5-98 OracleTransaction Public Methods
Public Method Description
Commit
Commits the database transaction
CreateObjRef
Inherited from System.MarshalByRefObject
Dispose
Frees the resources used by the OracleTransaction object
Equals
GetHashCode
GetLifetimeService
GetType
InitializeLifetimeService
Rollback
Rolls back a database transaction (Overloaded)
Save
Creates a savepoint within the current transaction
ToString
The OracleTransaction static method is listed in Table 5-99.
Table 5-99 OracleTransaction Static Method
Method Description
Equals
OracleTransaction properties are listed in Table 5-100.
Table 5-100 OracleTransaction Properties
IsolationLevel
Connection
IsolationLevel
This property specifies the isolation level for the transaction.
Declaration
// ADO.NET 2.0: C#
public override IsolationLevel IsolationLevel {get;}
// ADO.NET 1.x: C#
public IsolationLevel IsolationLevel {get;}
Property Value
IsolationLevel
Implements
IDbTransaction
Exceptions
InvalidOperationException - The transaction has already completed.
Remarks
Default = IsolationLevel.ReadCommitted
Connection
This property specifies the connection that is associated with the transaction.
Declaration
// C#
public OracleConnection Connection {get;}
Property Value
Connection
Implements
IDbTransaction
Remarks
This property indicates the OracleConnection object that is associated with the transaction.
OracleTransaction public methods are listed in Table 5-101.
Table 5-101 OracleTransaction Public Methods
Commit
CreateObjRef
Dispose
Equals
GetHashCode
GetLifetimeService
GetType
Rollback
Save
ToString
Commit
This method commits the database transaction.
Declaration
// ADO.NET 2.0: C#
public override void Commit();
// ADO.NET 1.x: C#
public void Commit();
Implements
IDbTransaction
Exceptions
InvalidOperationException - The transaction has already been completed successfully, has been rolled back, or the associated connection is closed.
Remarks
Upon a successful commit, the transaction enters a completed state.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class CommitSample
  static void Main()
    // Drop & Create MyTable as indicated in Database Setup, at beginning
    con.Open();
    try
      txn.Commit();
    catch (Exception e)
      txn.Rollback();
    txn.Dispose();
    cmd.Dispose();
    con.Close();
    con.Dispose();
Dispose
This method frees the resources used by the OracleTransaction object.
Declaration
// C#
public void Dispose();
Implements
IDisposable
Remarks
This method releases both the managed and unmanaged resources held by the OracleTransaction object. If the transaction is not in a completed state, an attempt to rollback the transaction is made.
Rollback
Rollback rolls back a database transaction.
Overload List:
Rollback()
This method rolls back a database transaction.
Declaration
// ADO.NET 2.0: C#
public override void Rollback();
// ADO.NET 1.x: C#
public void Rollback();
Implements
IDbTransaction
Exceptions
Remarks
After a Rollback(), the OracleTransaction object can no longer be used because the Rollback ends the transaction.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class RollbackSample
  static void Main()
    // Drop & Create MyTable as indicated previously in Database Setup
    // This sample starts a transaction and inserts one record into MyTable.
    // It then rollsback the transaction, the number of rows remains the same
    con.Open();
    // Insert a row into MyTable
    txn.Rollback();
    // Prints the number of rows, should remain the same
    txn.Dispose();
    cmd.Dispose();
    con.Close();
    con.Dispose();
Rollback(string)
This method rolls back a database transaction to a savepoint within the current transaction.
Declaration
// ADO.NET 2.0: C#
public override void Rollback(string savepointName);
// ADO.NET 1.x: C#
public void Rollback(string savepointName);
Parameters
Exceptions
Remarks
After a rollback to a savepoint, the current transaction remains active and can be used for further operations.
The savepointName specified does not have to match the case of the savepointName created using the Save method, since savepoints are created in the database in a case-insensitive manner.
Save
This method creates a savepoint within the current transaction.
Declaration
// C#
public void Save(string savepointName);
Parameters
Exceptions
InvalidOperationException - The transaction has already been completed.
Remarks
After creating a savepoint, the transaction does not enter a completed state and can be used for further operations.
The savepointName specified is created in the database in a case-insensitive manner. Calling the Rollback method rolls back to savepointName. This allows portions of a transaction to be rolled back, instead of the entire transaction.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class SaveSample
  static void Main()
    // This sample starts a transaction and creates a savepoint after
    // inserting one record into MyTable.
    // After inserting the second record it rollsback to the savepoint
    // and commits the transaction. Only the first record will be inserted
    con.Open();
    // Create a savepoint
    txn.Save("MySavePoint");
    // Insert another row into MyTable
    cmd.CommandText = "insert into mytable values (2)";
    // Rollback to the savepoint
    txn.Rollback("MySavePoint");
    // Commit the transaction
    txn.Commit();
    // Prints the number of rows, should have increased by 1
    txn.Dispose();
    cmd.Dispose();
    con.Close();
    con.Dispose();
