The APEX_UI_DEFAULT_UPDATE package provides procedures to access user interface defaults from within SQL Developer or SQL*Plus.
You can use this package to set the user interface defaults associated with a table within a schema. The package must be called from within the schema that owns the table you are updating.
User interface defaults enable you to assign default user interface properties to a table, column, or view within a specified schema. When you create a form or report using a wizard, the wizard uses this information to create default values for region and item properties. Utilizing user interface defaults can save valuable development time and has the added benefit of providing consistency across multiple pages in an application.
Topics in this section include:
The UPD_DISPLAY_IN_FORM procedure sets the display in form user interface defaults. This user interface default will be used by wizards when you select to create a form based upon the table. It controls whether the column will be included by default or not.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_DISPLAY_IN_FORM (
p_table_name IN VARCHAR2,
p_column_name IN VARCHAR2,
p_display_in_form IN VARCHAR2);
Parameters
Table 8-1 describes the parameters available in the UPD_DISPLAY_IN_FORM procedure.
Table 8-1 UPD_DISPLAY_IN_FORM Parameters
| Parameter | Description |
Table name |
Column name |
Determines whether or not to display in the form by default, valid values are |
Example
In the following example, when creating a Form against the DEPT table, the display option on the DEPTNO column would default to 'No'.
APEX_UI_DEFAULT_UPDATE.UPD_DISPLAY_IN_FORM(
p_table_name => 'DEPT',
p_column_name => 'DEPTNO',
p_display_in_form => 'N');
The UPD_DISPLAY_IN_REPORT procedure sets the display in report user interface default. This user interface default will be used by wizards when you select to create a report based upon the table and controls whether the column will be included by default or not.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_DISPLAY_IN_REPORT (
p_display_in_report IN VARCHAR2);
Parameters
Table 8-2 describes the parameters available in the UPD_DISPLAY_IN_REPORT procedure.
Table 8-2 UPD_DISPLAY_IN_REPORT Parameters
Table name |
Column name |
Determines whether or not to display in the report by default, valid values are |
Example
In the following example, when creating a Report against the DEPT table, the display option on the DEPTNO column would default to 'No'.
APEX_UI_DEFAULT_UPDATE.UPD_DISPLAY_IN_REPORT(
p_display_in_report => 'N');
The UPD_FORM_REGION_TITLE procedure updates the Form Region Title user interface default. User interface defaults are used in wizards when you create a form based upon the specified table.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_FORM_REGION_TITLE (
p_form_region_title IN VARCHAR2 DEFAULT NULL);
Parameters
Table 8-3 describes the parameters available in the UPD_FORM_REGION_TITLE procedure.
Table 8-3 APEX_UI_DEFAULT_UPDATE Parameters
Table name |
Desired form region title |
Example
This example demonstrates how to set the Forms Region Title user interface default on the DEPT table.
p_form_region_title => 'Deptartment Details');
The UPD_ITEM_DISPLAY_HEIGHT procedure sets the item display height user interface default. This user interface default will be used by wizards when you select to create a form based upon the table and include the specified column. Display height controls if the item will be a text box or a text area.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_DISPLAY_HEIGHT (
p_display_height IN NUMBER);
Parameters
Table 8-4 describes the parameters available in the UPD_ITEM_DISPLAY_HEIGHT procedure.
Table 8-4 UPD_ITEM_DISPLAY_HEIGHT Parameters
Table name |
Column name |
Display height of any items created based upon this column |
Example
The following example sets a default item height of 3 when creating an item on the DNAME column against the DEPT table.
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_DISPLAY_HEIGHT( p_table_name => 'DEPT', p_column_name => 'DNAME', p_display_height => 3);
The UPD_ITEM_DISPLAY_WIDTH procedure sets the item display width user interface default. This user interface default will be used by wizards when you select to create a form based upon the table and include the specified column.n.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_DISPLAY_WIDTH (
p_display_width IN NUMBER);
Parameters
Table 8-5 describes the parameters available in the UPD_ITEM_DISPLAY_WIDTH procedure.
Table 8-5 UPD_ITEM_DISPLAY_WIDTH Parameters
Table name |
Column name |
Display width of any items created based upon this column |
Example
The following example sets a default item width of 5 when creating an item on the DEPTNO column against the DEPT table.
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_DISPLAY_WIDTH( p_table_name => 'DEPT', p_column_name => 'DEPTNO', p_display_width => 5);
The UPD_ITEM_FORMAT_MASK procedure sets the item format mask user interface default. This user interface default will be used by wizards when you select to create a form based upon the table and include the specified column. Item format mask is typically used to format numbers and dates.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_FORMAT_MASK (
p_format_mask IN VARCHAR2 DEFAULT NULL);
Parameters
Table 8-6 describes the parameters available in the UPD_ITEM_FORMAT_MASK procedure.
Table 8-6 UPD_ITEM_FORMAT_MASK Parameters
Table name |
Column name |
Format mask to be associated with the column |
Example
In the following example, when creating a Form against the EMP table, the default item format mask on the HIREDATE column is set to 'DD-MON-YYYY'.
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_FORMAT_MASK(
p_table_name => 'EMP',
p_column_name => 'HIREDATE',
p_format_mask=> 'DD-MON-YYYY');
The UPD_ITEM_HELP procedure updates the help text for the specified table and column. This user interface default will be used when you create a form based upon the table and select to include the specified column.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_HELP (
p_help_text IN VARCHAR2 DEFAULT NULL);
Parameters
Table 8-7 describes the parameters available in the UPD_ITEM_HELP procedure.
Table 8-7 UPD_ITEM_HELP Parameters
Table name |
Column name |
Desired help text |
Example
This example demonstrates how to set the User Interface Item Help Text default for the DEPTNO column in the DEPT table.
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_HELP( p_table_name => 'DEPT', p_column_name => 'DEPTNO', p_help_text => 'The number assigned to the department.');
The UPD_LABEL procedure sets the label used for items. This user interface default will be used when you create a form or report based on the specified table and include a specific column.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_ITEM_LABEL (
p_label IN VARCHAR2 DEFAULT NULL);
Parameters
Table 8-8 describes the parameters available in the UPD_LABEL procedure.
Table 8-8 UPD__LABEL Parameters
Table name |
Column name |
Desired item label |
Example
This example demonstrates how to set the User Interface Item Label default for the DEPTNO column in the DEPT table.
APEX_UI_DEFAULT_UPDATE.UPD_LABEL( p_table_name => 'DEPT', p_column_name => 'DEPTNO', p_label => 'Department Number');
The UPD_REPORT_ALIGNMENT procedure sets the report alignment user interface default. This user interface default will be used by wizards when you select to create a report based upon the table and include the specified column and determines if the report column should be left, center, or right justified.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_REPORT_ALIGNMENT (
p_report_alignment IN VARCHAR2);
Parameters
Table 8-9 describes the parameters available in the UPD_REPORT_ALIGNMENT procedure.
Table 8-9 UPD_REPORT_ALIGNMENT Parameters
Table name. |
Column name. |
Defines the alignment of the column in a report. Valid values are L (left), C (center) and R (right). |
Example
In the following example, when creating a Report against the DEPT table, the default column alignment on the DEPTNO column is set to Right justified.
APEX_UI_DEFAULT_UPDATE.UPD_REPORT_ALIGNMENT(
p_report_alignment => 'R');
The UPD_REPORT_FORMAT_MASK procedure sets the report format mask user interface default. This user interface default will be used by wizards when you select to create a report based upon the table and include the specified column. Report format mask is typically used to format numbers and dates.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_REPORT_FORMAT_MASK (
Parameters
Table 8-10 describes the parameters available in the UPD_REPORT_FORMAT_MASK procedure.
Table 8-10 UPD_REPORT_FORMAT_MASK Parameters
Table name |
Column name |
Format mask to be associated with the column whenever it is included in a report |
Example
In the following example, when creating a Report against the EMP table, the default format mask on the HIREDATE column is set to 'DD-MON-YYYY'.
APEX_UI_DEFAULT_UPDATE.UPD_REPORT_FORMAT_MASK(
The UPD_REPORT_REGION_TITLE procedure sets the Report Region Title. User interface defaults are used in wizards when a report is created on a table.
Syntax
APEX_UI_DEFAULT_UPDATE.UPD_REPORT_REGION_TITLE (
p_report_region_title IN VARCHAR2 DEFAULT NULL);
Parameters
Table 8-11 describes the parameters available in the UPD_REPORT_REGION_TITLE procedure.
Table 8-11 UPD_REPORT_REGION_TITLE Parameters
Table name |
Desired report region title |
Example
This example demonstrates how to set the Reports Region Title user interface default on the DEPT table.
p_report_region_title => 'Deptartments');
