| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
Installing Oracle Data Provider for .NET creates a set of performance counters on the target system. These performance counters are published by ODP.NET for each ODP.NET client application. These performance counters can be viewed using Windows Performance Monitor (Perfmon).
ODP.NET performance counters are published under the following Category Name: Oracle Data Provider for .NET.
