Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleAQDequeueMode Enumeration
Table 12-30 lists all the OracleAQDequeueMode enumeration values with a description of each enumerated value.
Table 12-30 OracleAQDequeueMode Members
Member Name Description
Browse
Reads the message without acquiring any lock on the message. This is equivalent to a SELECT statement.
Locked
Reads and obtains a write lock on the message. The lock lasts for the duration of the transaction. This is equivalent to a SELECT FOR UPDATE statement.
Remove
Reads the message and updates or deletes it. This is the default.
The message can be retained in the queue table based on the retention properties
RemoveNoData
Confirms receipt of the message but does not deliver the actual message content.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
