Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleAQEnqueueOptions Class
The OracleAQEnqueueOptions class represents the options available when enqueuing a message to an OracleAQQueue.
Class Inheritance
System.Object
Declaration
// C#
public sealed class OracleAQEnqueueOptions : ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleAQEnqueueOptions Members
The OracleAQEnqueueOptions members are listed in the following tables.
OracleAQEnqueueOptions Constructor
OracleAQEnqueueOptions constructor is listed in Table 12-9.
Table 12-9 OracleAQEnqueueOptions Constructor
Constructor Description
Instantiates a new instance of the OracleAQEnqueueOptions class.
OracleAQEnqueueOptions Properties
OracleAQEnqueueOptions properties are listed in Table 12-10.
Table 12-10 OracleAQEnqueueOptions Properties
Property Description
DeliveryMode
Specifies the delivery mode of the message being enqueued.
Visibility
Specifies whether or not the new message is enqueued as part of the current transaction.
OracleAQEnqueueOptions Public Methods
The OracleAQEnqueueOptions public method is listed in Table 12-11.
Table 12-11 OracleAQEnqueueOptions Public Methods
Public Method Description
Clone
Creates a copy of an OracleAQEnqueueOptions object.
This constructor creates an instance of the OracleAQEnqueueOptions class with default property values.
Declaration
// C#
public OracleAQEnqueueOptions();
OracleAQEnqueueOptions properties are listed in Table 12-12.
Table 12-12 OracleAQEnqueueOptions Properties
DeliveryMode
Visibility
DeliveryMode
This instance property specifies the delivery mode of the message being enqueued.
Declaration
// C#
public OracleAQMessageDeliveryMode DeliveryMode {get;set;}
Exceptions
ArgumentOutOfRangeException - The specified Visibility value is invalid.
Remarks
The valid values can be any of the following enumerated values:
The default is OracleAQMessageDeliveryMode.Persistent.
OracleAQMessageDeliveryMode.PersistentOrBuffered cannot be set on this property.
OracleAQMessageDeliveryMode.Buffered can be specified only with Oracle Database 10g release 2 (10.2) or higher. Buffered messaging is supported in all queue tables created with a database compatibility level of 8.1 or higher.
Visibility
This instance property specifies whether or not the new message is enqueued as part of the current transaction.
Declaration
// C#
public OracleAQVisibilityMode Visibility {get;set;}
Property Value
An OracleAQVisibilityMode enumerated value.
Exceptions
Remarks
The default value is OracleAQVisibilityMode.OnCommit. Use transactions when using the default value in order to commit or rollback the enqueue. If transactions are not used when using the default visibility mode of OracleAQVisibilityMode.OnCommit, then messages are not enqueued to the queue.
Using the alternative visibility mode value, OracleAQVisibilityMode.Immediate eliminates the need to use a transaction. The queue is not affected in case the enqueue operation fails. The message does not get enqueued to the queue for such cases.
OracleAQEnqueueOptions public method is listed in Table 12-13.
Table 12-13 OracleAQEnqueueOptions Public Methods
Clone
Clone
This method creates a copy of an OracleAQEnqueueOptions object.
Declaration
// C#
public object Clone();
Return Value
An OracleAQEnqueueOptions object.
Implements
ICloneable.
Remarks
The cloned object has the same property values as that of the object being cloned.
