| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
The OracleBinary structure represents a variable-length stream of binary data to be stored in or retrieved from a database.
Class Inheritance
System.Object
System.ValueType
Oracle.DataAccess.Types.OracleBinary
Declaration
// ADO.NET 2.0: C# public struct OracleBinary : IComparable, INullable, IXmlSerializable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
class OracleBinarySample
static void Main(string[] args)
// Initialize the OracleBinary structures
OracleBinary binary1= new OracleBinary(new byte[] {1,2,3,4,5});
OracleBinary binary2 = new OracleBinary(new byte[] {1,2,3});
OracleBinary binary3 = new OracleBinary(new byte[] {4,5});
OracleBinary binary4 = binary2 + binary3;
// Compare binary1 and binary4; they're equal
if (binary1 == binary4)
Console.WriteLine("The two OracleBinary structs are equal");
else
Console.WriteLine("The two OracleBinary structs are different");
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleBinary members are listed in the following tables:
OracleBinary Constructors
OracleBinary constructors are listed in Table 14-1
Table 14-1 OracleBinary Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleBinary Static Fields
The OracleBinary static fields are listed in Table 14-2.
Table 14-2 OracleBinary Static Fields
| Field | Description |
Represents a null value that can be assigned to an instance of the |
OracleBinary Static Methods
The OracleBinary static methods are listed in Table 14-3.
Table 14-3 OracleBinary Static Methods
| Methods | Description |
Returns the concatenation of two |
Determines if two |
Determines if the first of two |
Determines if two |
OracleBinary Static Operators
The OracleBinary static operators are listed in Table 14-4.
Table 14-4 OracleBinary Static Operators
| Operator | Description |
Concatenates two |
Determines if two |
Determines if two |
OracleBinary Static Type Conversion Operators
The OracleBinary static type conversion operators are listed in Table 14-5.
Table 14-5 OracleBinary Static Type Conversion Operators
Converts an instance value to a byte array |
Converts an instance value to an |
OracleBinary Properties
The OracleBinary properties are listed in Table 14-6.
Table 14-6 OracleBinary Properties
| Properties | Description |
Indicates whether or not the current instance has a null value |
Obtains the particular |
Returns the length of the binary data |
Returns the binary data that is stored in an |
OracleBinary Instance Methods
The OracleBinary instance methods are listed in Table 14-7.
Table 14-7 OracleBinary Instance Methods
Compares the current instance to an object and returns an integer that represents their relative values |
Determines if two objects contain the same binary data (Overloaded) |
Returns a hash code for the current instance |
GetType |
Inherited from |
Converts the current |
The OracleBinary constructor instantiates a new instance of the OracleBinary structure and sets its value to the provided array of bytes.
Declaration
// C#
public OracleBinary(byte[ ] bytes);
Parameters
bytes
A byte array.
The OracleBinary static fields are listed in Table 14-8.
Table 14-8 OracleBinary Static Fields
This static field represents a null value that can be assigned to an instance of the OracleBinary structure.
Declaration
// C# public static readonly OracleBinary Null;
The OracleBinary static methods are listed in Table 14-9.
Table 14-9 OracleBinary Static Methods
Determines if two |
Determines if two |
This method returns the concatenation of two OracleBinary structures.
Declaration
// C# public static OracleBinary Concat(OracleBinary value1, OracleBinary value2);
Parameters
value1
The first OracleBinary.
value2
The second OracleBinary.
Return Value
An OracleBinary.
Remarks
If either argument has a null value, the returned OracleBinary structure has a null value.
This method determines if two OracleBinary values are equal.
Declaration
// C# public static bool Equals(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if two OracleBinary values are equal; otherwise returns false.
Remarks
The following rules apply to the behavior of this method.
Any OracleBinary that has a value is greater than an OracleBinary that has a null value.
Two OracleBinarys that contain a null value are equal.
This method determines whether or not the first of two OracleBinary values is greater than the second.
Declaration
// C# public static bool GreaterThan(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is greater than the second; otherwise returns false.
Remarks
Example
// C#
using System;
class GreaterThanSample
OracleBinary binary1 = OracleBinary.Null;
OracleBinary binary2 = new OracleBinary(new byte[] {1});
// Compare two OracleBinary structs; binary1 < binary2
if (OracleBinary.GreaterThan(binary1, binary2))
Console.WriteLine("binary1 > binary2");
else
Console.WriteLine("binary1 < binary2");
This method determines whether or not the first of two OracleBinary values is greater than or equal to the second.
Declaration
// C# public static bool GreaterThanOrEqual(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is greater than or equal to the second; otherwise returns false.
Remarks
This method determines whether or not the first of two OracleBinary values is less than the second.
Declaration
// C# public static bool LessThan(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is less than the second; otherwise returns false.
Remarks
This method determines whether or not the first of two OracleBinary values is less than or equal to the second.
Declaration
// C# public static bool LessThanOrEqual(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is less than or equal to the second; otherwise returns false.
Remarks
This method determines whether or not two OracleBinary values are not equal.
Declaration
// C# public static bool NotEquals(OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if two OracleBinary values are not equal; otherwise returns false.
Remarks
The OracleBinary static operators are listed in Table 14-10.
Table 14-10 OracleBinary Static Operators
Concatenates two |
Determines if two |
Determines if two |
This method concatenates two OracleBinary values.
Declaration
// C# public static OracleBinary operator + (OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
OracleBinary
Remarks
If either argument has a null value, the returned OacleBinary structure has a null value.
Declaration
// C# public static bool operator == (OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if they are the same; otherwise returns false.
Remarks
This method determines if the first of two OracleBinary values is greater than the second.
Declaration
// C# public static bool operator > (OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is greater than the second; otherwise, returns false.
Remarks
Example
// C#
using System;
class OperatorSample
if (binary1 > binary2)
else
This method determines if the first of two OracleBinary values is greater than or equal to the second.
Declaration
// C# public static bool operator >= (OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is greater than or equal to the second; otherwise, returns false.
Remarks
This method determines if two OracleBinary values are not equal.
Declaration
// C# public static bool operator != (OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the two OracleBinary values are not equal; otherwise, returns false.
This method determines if the first of two OracleBinary values is less than the second.
Declaration
// C# public static bool operator < ( OracleBinary value1, OracleBinary value2);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is less than the second; otherwise, returns false.
Remarks
This method determines if the first of two OracleBinary values is less than or equal to the second.
Declaration
// C# public static bool operator <= (OracleBinary value1, OracleBinary value1);
Parameters
value1
value2
Return Value
Returns true if the first of two OracleBinary values is less than or equal to the second; otherwise, returns false.
Remarks
The OracleBinary static type conversion operators are listed in Table 14-11.
Table 14-11 OracleBinary Static Type Conversion Operators
This method converts an OracleBinary value to a byte array.
Declaration
// C#
public static explicit operator byte[ ] (OracleBinary val);
Parameters
val
An OracleBinary.
Return Value
A byte array.
Exceptions
OracleNullValueException - The OracleBinary structure has a null value.
This method converts a byte array to an OracleBinary structure.
Declaration
// C#
public static implicit operator OracleBinary(byte[ ] bytes);
Parameters
bytes
A byte array.
Return Value
OracleBinary
The OracleBinary properties are listed in Table 14-12.
Table 14-12 OracleBinary Properties
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull {get;}
Property Value
Returns true if the current instance has a null value; otherwise returns false.
This property obtains the particular byte in an OracleBinary structure using an index.
Declaration
// C#
public byte this[int index] {get;}
Property Value
A byte in the specified index.
Exceptions
OracleNullValueException - The current instance has a null value.
Example
// C#
using System;
class ItemSample
OracleBinary binary = new OracleBinary(new byte[] {1,2,3,4});
// Prints the value 4
Console.WriteLine(binary[binary.Length - 1]);
This property returns the length of the binary data.
Declaration
// C#
public int length {get;}
Property Value
Length of the binary data.
Exceptions
Example
// C#
using System;
class LengthSample
Console.WriteLine(binary.Length);
This property returns the binary data that is stored in the OracleBinary structure.
Declaration
// C#
public byte[] Value {get;}
Property Value
Binary data.
Exceptions
The OracleBinary instance methods are listed in Table 14-13.
Table 14-13 OracleBinary Instance Methods
GetType |
Inherited from |
This method compares the current instance to an object and returns an integer that represents their relative values
Declaration
// C#
public int CompareTo(object obj);
Parameters
obj
The object being compared.
Return Value
The method returns a number that is:
Less than zero: if the current OracleBinary instance value is less than obj.
Zero: if the current OracleBinary instance and obj values have the same binary data.
Greater than zero: if the current OracleBinary instance value is greater than obj.
Implements
IComparable
Exceptions
ArgumentException - The parameter is not of type OracleBinary.
Remarks
The comparison must be between OracleBinarys. For example, comparing an OracleBinary instance with an OracleTimeStamp instance is not allowed. When an OracleBinary is compared with a different type, an ArgumentException is thrown.
Example
// C#
using System;
class CompareToSample
OracleBinary binary1 = new OracleBinary(new byte[] {1,2,3});
OracleBinary binary2 = new OracleBinary(new byte[] {1,2,3,4});
// Compare
if (binary1.CompareTo(binary2) == 0)
Console.WriteLine("binary1 is the same as binary2");
else
Console.WriteLine("binary1 is different from binary2");
This method determines whether or not an object is an instance of OracleBinary, and has the same binary data as the current instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
obj
Return Value
Returns true if obj is an instance of OracleBinary, and has the same binary data as the current instance; otherwise, returns false.
Remarks
Overrides Object
This method returns a hash code for the OracleBinary instance.
Declaration
// C# public override int GetHashCode();
Return Value
An int that represents the hash.
Overrides Object
This method converts an OracleBinary instance to a string instance.
Declaration
// C# public override string ToString();
Return Value
string
Remarks
If the current OracleBinary instance has a null value, the returned string "null".
