Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleBulkCopyColumnMapping Class
The OracleBulkCopyColumnMapping class defines the mapping between a column in the data source and a column in the destination database table.
Class Inheritance
System.Object
  System.OracleBulkCopyColumnMapping
Declaration
// C#
public sealed class OracleBulkCopyColumnMapping
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
Column mappings define the mapping between data source and the target table.
It is not necessary to specify column mappings for all the columns in the data source. If a ColumnMapping is not specified, then, by default, columns are mapped based on the ordinal position. This succeeds only if the source and destination table schema match. If there is a mismatch, an InvalidOperationException is thrown.
All the mappings in a mapping collection must be by name or ordinal position.
Oracle Data Provider for .NET makes one or more round-trips to the database to determine the column name if the mapping is specified by ordinal position. To avoid this performance overhead, specify the mapping by column name.
Example
// C#
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleBulkCopyColumnMapping Members
OracleBulkCopyColumnMapping members are listed in the following tables.
OracleBulkCopyColumnMapping Constructors
The OracleBulkCopyColumnMapping constructors are listed in Table 17-8.
Table 17-8 OracleBulkCopyColumnMapping Constructors
Constructor Description
Instantiates new instances of the OracleBulkCopyColumnMapping class
OracleBulkCopyColumnMapping Properties
The OracleBulkCopyColumnMapping properties are listed in Table 17-9.
Table 17-9 OracleBulkCopyColumnMapping Properties
Property Description
DestinationColumn
Specifies the column name of the destination table that is being mapped
DestinationOrdinal
Specifies the column ordinal value of the destination table that is being mapped
SourceColumn
Specifies the column name of the data source that is being mapped
SourceOrdinal
Specifies the column ordinal value of the data source that is being mapped
OracleBulkCopyColumnMapping constructors instantiates new instances of the OracleBulkCopyColumnMapping class.
Overload List:
OracleBulkCopyColumnMapping()
This constructor instantiates a new instance of the OracleBulkCopyColumnMapping class.
Declaration
// C#
public OracleBulkCopyColumnMapping();
Remarks
Applications that use this constructor must define the source for the mapping using the SourceColumn or SourceOrdinal property, and must define the destination for the mapping using the DestinationColumn or DestinationOrdinal property.
OracleBulkCopyColumnMapping(int, int)
This constructor instantiates a new instance of the OracleBulkCopyColumnMapping class using the provided source and destination column ordinal positions.
Declaration
// C#
public OracleBulkCopyColumnMapping(int sourceColumnOrdinal,
   int destinationOrdinal);
Parameters
OracleBulkCopyColumnMapping(int, string)
This constructor instantiates a new instance of the OracleBulkCopyColumnMapping class using the provided source column ordinal and destination column name.
Declaration
// C#
   string destinationColumn);
Parameters
OracleBulkCopyColumnMapping(string, int)
This constructor instantiates a new instance of the OracleBulkCopyColumnMapping class using the provided source column name and destination column ordinal.
Declaration
// C#
public OracleBulkCopyColumnMapping(string sourceColumn, int destinationOrdinal);
Parameters
OracleBulkCopyColumnMapping(string, string)
This constructor instantiates a new instance of the OracleBulkCopyColumnMapping class using the provided source and destination column names.
Declaration
// C#
public OracleBulkCopyColumnMapping(string sourceColumn, string destinationColumn);
Parameters
The OracleBulkCopyColumnMapping properties are listed in Table 17-10.
Table 17-10 OracleBulkCopyColumnMapping Properties
DestinationColumn
DestinationOrdinal
SourceColumn
SourceOrdinal
DestinationColumn
This property specifies the column name of the destination table that is being mapped.
Declaration
// C#
public string DestinationColumn {get; set;}
Property Value
A string value that represents the destination column name of the mapping.
Remarks
The DestinationColumn and DestinationOrdinal properties are mutually exclusive. The last value set takes precedence.
DestinationOrdinal
This property specifies the column ordinal value of the destination table that is being mapped.
Declaration
// C#
public int DestinationOrdinal {get; set;}
Property Value
An integer value that represents the destination column ordinal of the mapping.
Exceptions
IndexOutOfRangeException - The destination ordinal is invalid.
Remarks
The DestinationOrdinal and DestinationColumn properties are mutually exclusive. The last value set takes precedence.
SourceColumn
This property specifies the column name of the data source that is being mapped.
Declaration
// C#
public string SourceColumn {get; set;}
Property Value
A string value that represents the source column name of the mapping.
Remarks
The SourceColumn and SourceOrdinal properties are mutually exclusive. The last value set takes precedence.
SourceOrdinal
This property specifies the column ordinal value of the data source that is being mapped.
Declaration
// C#
public int SourceOrdinal {get; set;}
Property Value
An integer value that represents the source column ordinal of the mapping.
Exceptions
IndexOutOfRangeException - The source ordinal is invalid.
Remarks
The SourceOrdinal and SourceColumn properties are mutually exclusive. The last value set takes precedence.
