| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
The OracleBulkCopyColumnMappingCollection class represents a collection of OracleBulkCopyColumnMapping objects that are used to map columns in the data source to columns in a destination table.
Class Inheritance
System.Object
System.CollectionBase
System.OracleBulkCopyColumnMappingCollection
Declaration
// C# public sealed class OracleBulkCopyColumnMappingCollection : CollectionBase
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
Column mappings define the mapping between data source and the target table.
It is not necessary to specify column mappings for all the columns in the data source. If a ColumnMapping is not specified, then, by default, columns are mapped based on the ordinal position. This succeeds only if the source and destination table schema match. If there is a mismatch, an InvalidOperationException is thrown.
All the mappings in a mapping collection must be by name or ordinal position.
Note: Oracle Data Provider for .NET makes one or more round-trips to the database to determine the column name if the mapping is specified by ordinal position. To avoid this performance overhead, specify the mapping by column name. |
Example
// C#
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleBulkCopyColumnMappingCollection members are listed in the following tables.
OracleBulkCopyColumnMappingCollection Properties
The OracleBulkCopyColumnMappingCollection properties are listed in Table 17-11.
Table 17-11 OracleBulkCopyColumnMappingCollection Properties
| Property | Description |
Gets or sets the |
OracleBulkCopyColumnMappingCollection Public Methods
The OracleBulkCopyColumnMappingCollection public methods are listed in Table 17-12.
Table 17-12 OracleBulkCopyColumnMappingCollection Public Methods
| Public Method | Description |
Adds objects to the collection |
Clears the contents of the collection |
Returns a value indicating whether or not a specified |
Copies the elements of the |
Returns the index of the specified |
Inserts a new |
Removes the specified |
Removes the mapping from the collection at the specified index. |
The OracleBulkCopyColumnMappingCollection properties are listed in Table 17-13.
Table 17-13 OracleBulkCopyColumnMappingCollection Properties
Gets or sets the |
This property gets or sets the OracleBulkCopyColumnMapping object at the specified index.
Declaration
// C#
public OracleBulkCopyColumnMapping this[int index] {get;set;}
Parameters
index
The zero-based index of the OracleBulkCopyColumnMapping being set or retrieved.
Property Value
An OracleBulkCopyColumnMapping object at the specified index.
Exceptions
IndexOutOfRangeException - The specified index does not exist.
The OracleBulkCopyColumnMappingCollection public methods are listed in Table 17-14.
Table 17-14 OracleBulkCopyColumnMappingCollection Public Methods
Inserts a new |
Add methods add objects to the collection.
Overload List:
Add(OracleBulkCopyColumnMapping)
This method adds the supplied OracleBulkCopyColumnMapping object to the collection.
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source and destination column ordinal positions.
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source column ordinal and destination column name.
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source column name and destination column ordinal.
This method creates and adds an OracleBulkCopyColumnMapping object to the collection using the supplied source and destination column names.
Declaration
// C#
public OracleBulkCopyColumnMapping Add(OracleBulkCopyColumnMapping bulkCopyColumnMapping);
Parameters
The OracleBulkCopyColumnMapping object that describes the mapping to be added to the collection.
Exceptions
InvalidOperationException - The bulk copy operation is in progress.
Declaration
// C# public OracleBulkCopyColumnMapping Add(int sourceColumnIndex, int destinationColumnIndex);
Parameters
sourceColumnIndex
The ordinal position of the source column within the data source.
The ordinal position of the destination column within the destination table.
Exceptions
Return Value
The newly created OracleBulkCopyColumnMapping object that was added to the collection.
Remarks
Declaration
// C# public OracleBulkCopyColumnMapping Add(int sourceColumnIndex, string destinationColumn);
Parameters
sourceColumnIndex
destinationColumn
The name of the destination column within the destination table.
Exceptions
Return Value
Remarks
Note: Oracle Data Provider for .NET makes one or more round trips to the database to determine the column names if the mapping is specified by ordinal resulting in a performance overhead. Therefore, it is recommended to specify the mapping by column names. |
Declaration
// C# public OracleBulkCopyColumnMapping Add(string sourceColumn, int destinationColumnIndex);
Parameters
sourceColumn
The name of the source column within the data source.
Return Value
Exceptions
Remarks
Declaration
// C# public OracleBulkCopyColumnMapping Add(string sourceColumn, string destinationColumn);
Parameters
sourceColumn
destinationColumn
Exceptions
Return Value
Remarks
This method clears the contents of the collection.
Declaration
// C# public void Clear();
Exceptions
Remarks
The Clear method is most commonly used when an application uses a single OracleBulkCopy instance to process more than one bulk copy operation. If column mappings are created for one bulk copy operation, the OracleBulkCopyColumnMappingCollection must be cleared after the WriteToServer method invocation and before the next bulk copy is processed.
It is usually more efficient to perform several bulk copies using the same OracleBulkCopy instance than to use a separate OracleBulkCopy for each operation.
This method returns a value indicating whether or not a specified OracleBulkCopyColumnMapping object exists in the collection.
Declaration
// C#
public bool Contains(OracleBulkCopyColumnMapping value);
Parameters
value
A valid OracleBulkCopyColumnMapping object.
Return Value
Returns true if the specified mapping exists in the collection; otherwise, returns false.
This method copies the elements of the OracleBulkCopyColumnMappingCollection to an array of OracleBulkCopyColumnMapping items, starting at a specified index.
Declaration
// C# public void CopyTo(OracleBulkCopyColumnMapping[] array, int index);
Parameters
array
The one-dimensional OracleBulkCopyColumnMapping array that is the destination for the elements copied from the OracleBulkCopyColumnMappingCollection object. The array must have zero-based indexing.
index
The zero-based array index at which copying begins.
This method returns the index of the specified OracleBulkCopyColumnMapping object.
Declaration
// C#
public int IndexOf(OracleBulkCopyColumnMapping value);
Parameters
value
The OracleBulkCopyColumnMapping object that is being returned.
Return Value
The zero-based index of the column mapping or -1 if the column mapping is not found in the collection.
This method inserts a new OracleBulkCopyColumnMapping object in the collection, at the index specified.
Declaration
// C# public void Insert(int index, OracleBulkCopyColumnMapping value);
Parameters
index
The integer value of the location within the OracleBulkCopyColumnMappingCollection at which the new OracleBulkCopyColumnMapping is inserted.
value
The OracleBulkCopyColumnMapping object to be inserted in the collection.
Exceptions
This method removes the specified OracleBulkCopyColumnMapping element from the OracleBulkCopyColumnMappingCollection.
Declaration
// C#
public void Remove(OracleBulkCopyColumnMapping value);
Parameters
value
The OracleBulkCopyColumnMapping object to be removed from the collection.
Exceptions
Remarks
The Remove method is most commonly used when a single OracleBulkCopy instance processes more than one bulk copy operation. If column mappings are created for one bulk copy operation, mappings that no longer apply must be removed after the WriteToServer method invocation and before mappings are defined for the next bulk copy. The Clear method can clear the entire collection, and the Remove and the RemoveAt methods can remove mappings individually.
This method removes the mapping from the collection at the specified index.
Declaration
// C#
public void RemoveAt(int index);
Parameters
index
The zero-based index of the OracleBulkCopyColumnMapping object to be removed from the collection.
Exceptions
Remarks
The RemoveAt method is most commonly used when a single OracleBulkCopy instance is used to process more than one bulk copy operation. If column mappings are created for one bulk copy operation, mappings that no longer apply must be removed after the WriteToServer method invocation and before the mappings for the next bulk copy are defined. The Clear method can clear the entire collection, and the Remove and the RemoveAt methods can remove mappings individually.
