| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
The OracleBulkCopyOptions enumeration specifies the values that can be combined with an instance of the OracleBulkCopy class and used as options to determine its behavior and the behavior of the WriteToServer methods for that instance.
Table 17-15 lists all the OracleBulkCopyOptions enumeration values with a description of each enumerated value.
Table 17-15 OracleBulkCopyOptions Enumeration Members
| Member Name | Description |
Indicates that the default value for all options are to be used |
Indicates that each batch of the bulk copy operation occurs within a transaction. If the connection used to perform the bulk copy operation is already part of a transaction, an If this member is not specified, |
Note: All bulk copy operations are agnostic of any local or distributed transaction created by the application. |
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
