Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleClientFactory Class
An OracleClientFactory object allows applications to instantiate ODP.NET classes in a generic way.
Supported Only in ADO.NET 2.0-Compliant ODP.NET
Class Inheritance
System.Object
  System.Data.Common.DbProviderFactory
    Oracle.DataAccess.Client.OracleClientFactory
Declaration
// C#
public sealed class OracleClientFactory : DbProviderFactory
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
using Oracle.DataAccess.Client;
class FactorySample
  static void Main()
    string constr = "user id=scott;password=tiger;data source=oracle";
    DbProviderFactory factory =
            DbProviderFactories.GetFactory("Oracle.DataAccess.Client");
    DbConnection conn = factory.CreateConnection();
    try
      conn.ConnectionString = constr;
      conn.Open();
      DbCommand cmd = factory.CreateCommand();
      cmd.Connection = conn;
      cmd.CommandText = "select * from emp";
      DbDataReader reader = cmd.ExecuteReader();
      while (reader.Read())
        Console.WriteLine(reader["EMPNO"] + " : " + reader["ENAME"]);
    catch (Exception ex)
      Console.WriteLine(ex.Message);
      Console.WriteLine(ex.StackTrace);
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleClientFactory Members
OracleClientFactory members are listed in the following tables.
OracleClientFactory Public Properties
The OracleClientFactory public properties are listed in Table 7-1.
Table 7-1 OracleClientFactory Public Properties
Property Description
CanCreateDataSourceEnumerator
Indicates whether or not the CreateDataSourceEnumerator method is supported
OracleClientFactory Public Methods
OracleClientFactory Public Methods are listed in Table 7-2.
Table 7-2 OracleClientFactory Public Method
Method Description
CreateCommand
Returns a DbCommand object that represents an OracleCommand object
CreateCommandBuilder
Returns a DbCommandBuilder object that represents an OracleCommandBuilder object
CreateConnection
Returns a DbConnection object that represents an OracleConnection object
CreateConnectionStringBuilder
Returns a DbConnectionStringBuilder object that represents an OracleConnectionStringBuilder object
CreateDataAdapter
Returns a DbDataAdapter object that represents an OracleDataAdapter object
Returns a DbDataSourceEnumerator object that represents an OracleDataSourceEnumerator object
CreateParameter
Returns a DbParameter object that represents an OracleParameter object
CreatePermission
Returns a CodeAccessPermission object that represents an OraclePermission object
The OracleClientFactory public properties are listed in Table 7-3.
Table 7-3 OracleClientFactory Public Properties
This property indicates whether or not the CreateDataSourceEnumerator method is supported.
Declaration
// C#
public override bool CanCreateDataSourceEnumerator { get; }
Property Value
Returns true.
Remarks
ODP.NET supports the OracleDataSourceEnumerator object.
The OracleClientFactory public method is listed in Table 7-4.
Table 7-4 OracleClientFactory Public Method
Method Description
CreateCommand
CreateConnection
CreateDataAdapter
CreateParameter
CreatePermission
CreateCommand
This method returns a DbCommand object that represents an OracleCommand object.
Declaration
// C#
public override DbCommand CreateCommand();
Return Value
A DbCommand object that represents an OracleCommand object.
This method returns a DbCommandBuilder object that represents an OracleCommandBuilder object.
Declaration
// C#
public override DbCommandBuilder CreateCommandBuilder();
Return Value
A DbCommandBuilder object that represents an OracleCommandBuilder object.
CreateConnection
This method returns a DbConnection object that represents an OracleConnection object.
Declaration
// C#
public override DbConnection CreateConnection();
Return Value
A DbConnection object that represents an OracleConnection object.
This method returns a DbConnectionStringBuilder object that represents an OracleConnectionStringBuilder object.
Declaration
// C#
public override DbConnectionStringBuilder CreateConnectionStringBuilder();
Return Value
A DbConnectionStringBuilder object that represents an OracleConnectionStringBuilder object.
CreateDataAdapter
This method returns a DbDataAdapter object that represents an OracleDataAdapter object.
Declaration
// C#
public override DbDataAdapter CreateDataAdapter();
Return Value
A DbDataAdapter object that represents an OracleDataAdapter object.
This method returns a DbDataSourceEnumerator object that represents an OracleDataSourceEnumerator object.
Declaration
// C#
public override DbDataSourceEnumerator CreateDataSourceEnumerator();
Return Value
A DbDataSourceEnumerator object that represents an OracleDataSourceEnumerator object.
CreateParameter
This method returns a DbParameter object that represents an OracleParameter object.
Declaration
// C#
public override DbParameter CreateParameter();
Return Value
A DbParameter object that represents an OracleParameter object.
CreatePermission
This method returns a CodeAccessPermission object that represents an OraclePermission object.
Declaration
// C#
public override System.Security.CodeAccessPermission CreatePermission(
  System.Security.Permissions.PermissionState state);
Parameter
Return Value
A CodeAccessPermission object that represents an OraclePermission object.
Remarks
This method enables users, writing provider-independent code, to get a CodeAccessPermission instance that represents an OraclePermission object.
