Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleConnection Class
An OracleConnection object represents a connection to an Oracle database.
Class Inheritance
System.Object
  System.MarshalByRefObject
    System.ComponentModel.Component
      System.Data.Common.DbConnection (ADO.NET 2.0 only)
        Oracle.DataAccess.Client.OracleConnection
Declaration
// ADO.NET 2.0: C#
public sealed class OracleConnection : DbConnection, IDbConnection, ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleConnectionSample
  static void Main()
    // Connect
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Execute a SQL SELECT
    OracleCommand cmd = con.CreateCommand();
    cmd.CommandText = "select * from emp";
    OracleDataReader reader = cmd.ExecuteReader();
    // Print all employee numbers
    while (reader.Read())
      Console.WriteLine(reader.GetInt32(0));
    // Clean up
    reader.Dispose();
    cmd.Dispose();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleConnection Members
OracleConnection members are listed in the following tables.
OracleConnection Constructors
OracleConnection constructors are listed in Table 5-17.
Table 5-17 OracleConnection Constructors
Constructor Description
Instantiates a new instance of the OracleConnection class (Overloaded)
OracleConnection Static Properties
The OracleConnection static property is listed in Table 5-19.
Table 5-18 OracleConnection Static Property
Property Description
IsAvailable
Indicates whether or not the implicit database connection is available for use
OracleConnection Static Methods
The OracleConnection static methods are listed in Table 5-19.
Table 5-19 OracleConnection Static Methods
Method Description
Equals
Inherited from System.Object (Overloaded)
ClearPool
Clears the connection pool that is associated with the provided OracleConnection object.
Not supported in a .NET stored procedure
ClearAllPools
Clears all connections from all the connection pools
OracleConnection Properties
OracleConnection properties are listed in Table 5-20.
Table 5-20 OracleConnection Properties
ActionName
Specifies the action name for the connection
ClientId
Specifies the client identifier for the connection
ConnectionString
Specifies connection information used to connect to an Oracle database
ConnectionTimeout
Indicates the maximum amount of time that the Open method can take to obtain a pooled connection before the request is terminated
Container
Inherited from System.ComponentModel.Component
Database
Not Supported
DatabaseDomainName
Specifies the name of the database domain to which the connection is set
DatabaseName
Specifies the name of the database to which the connection is set
DataSource
Specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect
HostName
Specifies the name of the host to which the connection is set
InstanceName
Specifies the name of the instance to which the connection is set
ModuleName
Specifies the module name for the connection
ServerVersion
Specifies the version number of the Oracle database to which the OracleConnection has established a connection
ServiceName
Specifies the name of the service to which the connection is set
Site
State
Specifies the current state of the connection
StatementCacheSize
Specifies the current size of the statement cache associated with this connection
OracleConnection Public Methods
OracleConnection public methods are listed in Table 5-21.
Table 5-21 OracleConnection Public Methods
Public Method Description
BeginTransaction
Begins a local transaction (Overloaded)
ChangeDatabase
Not Supported
Clone
Creates a copy of an OracleConnection object
Close
Closes the database connection
CreateCommand
Creates and returns an OracleCommand object associated with the OracleConnection object
CreateObjRef
Inherited from System.MarshalByRefObject
Dispose
EnlistDistributedTransaction
Enables applications to explicitly enlist in a specified distributed transaction
EnlistTransaction
Enables applications to enlist in a specified distributed transaction
Supported Only in ADO.NET 2.0-Compliant ODP.NET
Equals
FlushCache
Flushes all updates and deletes made through REF objects retrieved using this connection
GetHashCode
GetLifetimeService
GetSchema
Returns schema information for the data source of the OracleConnection
GetSessionInfo
Returns or refreshes the property values of the OracleGlobalization object that represents the globalization settings of the session (Overloaded)
GetType
InitializeLifetimeService
Open
Opens a database connection with the property settings specified by the ConnectionString
OpenWithNewPassword
Opens a new connection with the new password
PurgeStatementCache
Flushes the Statement Cache by closing all open cursors on the database, when statement caching is enabled
SetSessionInfo
Alters the session's globalization settings with the property values provided by the OracleGlobalization object
ToString
OracleConnection Events
OracleConnection events are listed in Table 5-22.
Table 5-22 OracleConnection Events
Event Name Description
Disposed
Failover
An event that is triggered when an Oracle failover occurs
HAEvent
An event that is triggered when an HA event occurs.
InfoMessage
An event that is triggered for any message or warning sent by the database
StateChange
An event that is triggered when the connection state changes
OracleConnection constructors instantiate new instances of the OracleConnection class.
Overload List:
OracleConnection()
This constructor instantiates a new instance of the OracleConnection class using default property values.
Declaration
// C#
public OracleConnection();
Remarks
The properties for OracleConnection are set to the following default values:
OracleConnection(String)
This constructor instantiates a new instance of the OracleConnection class with the provided connection string.
Declaration
// C#
public OracleConnection(String connectionString);
Parameters
Remarks
The ConnectionString property is set to the supplied connectionString. The ConnectionString property is parsed and an exception is thrown if it contains invalid connection string attributes or attribute values.
The properties of the OracleConnection object default to the following values unless they are set by the connection string:
The OracleConnection static property is listed in Table 5-23.
Table 5-23 OracleConnection Static Property
IsAvailable
IsAvailable
This property indicates whether or the implicit database connection is available for use.
Declaration
// C#
public static bool IsAvailable {get;}
Property Value
Returns true if the implicit database connection is available for use.
Remarks
The availability of the implicit database connection can be checked at run time through this static property. When Oracle Data Provider for .NET is used within a .NET stored procedure, this property always returns true. Otherwise, false is returned.
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method.
Note that not all features that are available for an explicit user connection are available for an implicit database connection. See "Implicit Database Connection" for details.
Example
// C# (Library/DLL)
using System;
public class IsAvailableSample
  static void MyStoredProcedure()
    OracleConnection con = new OracleConnection();
    if (OracleConnection.IsAvailable)
      // This function is invoked as a stored procedure
      // Obtain the implicit database connection by setting
      //   "context connection=true" in the connection string
      con.ConnectionString = "context connection=true";
    else
      // This function is not invoked as a stored procedure
      // Set the connection string for a normal client connection
      con.ConnectionString = "user id=scott;password=tiger;data source=oracle";
    con.Open();
    Console.WriteLine("connected!");
The OracleConnection static methods are listed in Table 5-24.
Table 5-24 OracleConnection Static Methods
Method Description
Equals
ClearPool
ClearAllPools
ClearPool
This method clears the connection pool that is associated with the provided OracleConnection object.
Declaration
// C#
public static void ClearPool(OracleConnection connection);
Remarks
When this method is invoked, all idle connections are closed and freed from the pool. Currently used connections are not discarded until they are returned to the pool.
The ClearPool method should be invoked only when valid connections can be created (that is, the database is up and can be connected to). Otherwise, the ClearPool method may just create invalid connections to a downed database instance. Assuming valid database connections, a ClearPool invocation creates a connection pool with usable connections. Therefore, connection requests succeed even after the invocation of this method. Connections created after this method invocation are not cleared unless another invocation is made.
This method can be invoked with an OracleConnection object before opening the connection as well as after, provided the ConnectionString is properly set.
Exceptions
InvalidOperationException – Either the connection pool cannot be found or the provided connection string is invalid.
Example
// C#
// Sample demonstrating the use of ClearPool API in OracleConnection class
using System;
class ClearPoolSample
  static void Main()
    Console.WriteLine("Running ClearPool sample..." );
    string strConn = "User Id=scott;Password=tiger;Data Source=oracle;" +
                     "Min pool size=5;";
    OracleConnection conn = new OracleConnection(strConn);
    // Open the connection
    conn.Open();
    // Clears the connection pool associated with connection 'conn'
    OracleConnection.ClearPool (conn);
    // This connection will be placed back into the pool
    conn.Close ();
    // Open the connection again to create additional connections in the pool
    conn.Open();
    // Create a new connection object
    OracleConnection connNew = new OracleConnection(strConn);
    // Clears the pool associated with Connection 'connNew'
    // Since the same connection string is set for both the connections,
    // connNew and conn, they will be part of the same connection pool.
    // We need not do an Open() on the connection object before calling
    // ClearPool
    OracleConnection.ClearPool (connNew);
    // cleanup
    conn.Close();
    Console.WriteLine("Done!");
ClearAllPools
This method clears all connections from all the connection pools.
Declaration
// C#
public static void ClearAllPools();
Remarks
This call is analogous to calling ClearPool for all the connection pools that are created for the application.
Exceptions
InvalidOperationException – No connection pool could be found for the application.
Example
// C#
// Sample demonstrating the use of ClearAllPools API in OracleConnection class
using System;
class ClearAllPoolsSample
  static void Main()
    Console.WriteLine("Running ClearAllPools sample..." );
           "Min pool size=5;";
    // Create another connection object with a different connection string
    string strConnNew = "User Id=scott;Password=tiger;Data Source=oracle;";
    OracleConnection connNew = new OracleConnection(strConnNew);
    // Open the connections. Separate pools are created for conn and connNew
    conn.Open();
    connNew.Open();
    // Clears the pools associated with conn and connNew
    OracleConnection.ClearAllPools ();
    // cleanup
    conn.Close();
    connNew.Close();
OracleConnection properties are listed in Table 5-25
Table 5-25 OracleConnection Properties
ActionName
ClientId
ConnectionString
ConnectionTimeout
Container
Database
Not Supported
DatabaseDomainName
DatabaseName
DataSource
HostName
InstanceName
ModuleName
ServerVersion
ServiceName
Site
State
StatementCacheSize
ActionName
This property specifies the action name for the connection.
Declaration
// C#
public string ActionName {set;}
Property Value
The string to be used as the action name.
Remarks
The default value is null and the maximum length of the string is 32 bytes.
Using the ActionName property allows the application to set the action name in the application context for a given OracleConnection object.
The ActionName property is reset to null when the Close or Dispose method is called on the OracleConnection object.
ClientId
This property specifies the client identifier for the connection.
Declaration
// C#
public string ClientId {set;}
Property Value
The string to be used as the client identifier.
Remarks
The default value is null and the maximum length is 64 bytes.
Using the ClientId property allows the application to set the client identifier in the application context for every database session using ODP.NET. This enables ODP.NET developers to configure the Oracle Virtual Private Database (VPD) more easily.
Setting ClientId to null resets the client identifier for the connection. Setting ClientId to an empty string sets the client identifier for the connection to an empty string. ClientId is set to null when the Close method is called on the OracleConnection object.
ConnectionString
This property specifies connection information used to connect to an Oracle database.
Declaration
// ADO.NET 2.0: C#
public override string ConnectionString{get; set;}
Property Value
If the connection string is supplied through the constructor, this property is set to that string.
Implements
IDbConnection
Exceptions
ArgumentException - An invalid syntax is specified for the connection string.
InvalidOperationException - ConnectionString is being set while the connection is open.
Remarks
The default value is an empty string.
ConnectionString must be a string of attribute name and value pairings, separated by a semi-colon, for example:
"User Id=scott;password=tiger;data source=oracle"
If the ConnectionString is not in a proper format, an exception is thrown. All spaces are ignored unless they are within double quotes.
When the ConnectionString property is set, the OracleConnection object immediately parses the string for errors. An ArgumentException is thrown if the ConnectionString contains invalid attributes or invalid values. Attribute values for User Id, Password, Proxy User Id, Proxy Password, and Data Source (if provided) are not validated until the Open method is called.
The connection must be closed to set the ConnectionString property. When the ConnectionString property is reset, all previously set values are reinitialized to their default values before the new values are applied.
Starting with ODP.NET 11.1, password and proxy password connection string attribute values are accepted as case-sensitive strings. Thus, they are passed to the database for authentication in the case provided in the connection string. Therefore, if the database is configured to support case-sensitive passwords, passwords must be passed in the correct case.
If a connection string attribute is set more than once, the last setting takes effect and no exceptions are thrown.
Boolean connection string attributes can be set to either true, false, yes, or no.
Remarks (.NET Stored Procedure)
To obtain an OracleConnection object in a .NET stored procedure that represents the implicit database connection, set the ConnectionString property of the OracleConnection object to "context connection=true" and invoke the Open method. Other connection string attributes cannot be used in conjunction with "context connection" when it is set to true.
Supported Connection String Attributes
Table 5-26 lists the supported connection string attributes.
Table 5-26 Supported Connection String Attributes
Connection String Attribute Description Default Value
Connection Lifetime
Maximum life time (in seconds) of the connection.
This attribute specifies the lifetime of the connection in seconds. Before the Connection is placed back into the pool, the lifetime of the connection is checked. If the lifetime of the connection exceeds this property value, the connection is closed and disposed of. If this property value is 0, the connection lifetime is never checked. Connections that have exceeded their lifetimes are not closed and disposed of, if doing so brings the number of connections in the pool below the Min Pool Size.
0
Connection Timeout
Maximum time (in seconds) to wait for a free connection from the pool.
This attribute specifies the maximum amount of time (in seconds) that the Open() method can take to obtain a pooled connection before it terminates the request. This value comes into effect only if no free connection is available from the connection pool and the Max Pool Size is reached. If a free connection is not available within the specified time, an exception is thrown. Connection Timeout does not limit the time required to open new connections.
This attribute value takes effect for pooled connection requests and not for new connection requests.
(The default value is 0 for the implicit database connection in a .NET stored procedure.)
15
Context Connection
Returns an implicit database connection if set to true.
An implicit database connection can only be obtained from within a .NET stored procedure. Other connection string attributes cannot be used in conjunction with "context connection" when it is set to true.
Supported in a .NET stored procedure only
false
Data Source
Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect.
empty string
DBA Privilege
Administrative privileges SYSDBA or SYSOPER.
This connection string attribute only accepts SYSDBA or SYSOPER as the attribute value. It is case-insensitive.
empty string
Decr Pool Size
Number of connections that are closed when an excessive amount of established connections are unused.
This connection string attribute controls the maximum number of unused connections that are closed when the pool regulator makes periodic checks. The regulator thread is spawned every 3 minutes and closes up to Decr Pool Size amount of pooled connections if they are not used. The pool regulator never takes the total number of connections below the Min Pool Size by closing pooled connections.
1
Enlist
Controls the enlistment behavior and capabilities of a connection in context of COM+ transactions or System.Transactions.
If this attribute is set to true, the connection is automatically enlisted in the thread's transaction context. If this attribute is false, no enlistments are made. If this attribute is set to dynamic, applications can dynamically enlist in distributed transactions. This attribute can be set to true, false, yes, no, or dynamic.
true
HA Events
Enables ODP.NET connection pool to proactively remove connections from the pool when an Oracle RAC service, service member, or node goes down.
This feature can only used against an Oracle RAC database and only if "pooling=true".
This attribute can be set to true, false, yes, or no.
false
Load Balancing
Enables ODP.NET connection pool to balance work requests across Oracle RAC instances based on the load balancing advisory and service goal.
false
Incr Pool Size
Number of new connections to be created when all connections in the pool are in use.
This connection string attribute determines the number of new connections that are established when a pooled connection is requested, but no unused connections are available and Max Pool Size is not reached. If new connections have been created for a pool, the regulator thread skips a cycle and does not have an opportunity to close any connections for 6 minutes. Note, however, that some connections can be still be closed during this time if their lifetime has been exceeded.
5
Max Pool Size
Maximum number of connections in a pool.
This attribute specifies the maximum number of connections allowed in the particular pool used by that OracleConnection. Simply changing this attribute in the connection string does not change the Max Pool Size restriction on a currently existing pool. Doing so simply creates a new pool with a different Max Pool Size restriction. This attribute must be set to a value greater than the Min Pool Size. This value is ignored unless Pooling is turned on.
100
Metadata Pooling
Caches metadata information.
This attribute indicates whether or not metadata information for executed queries are cached for improved performance.
True
Min Pool Size
Minimum number of connections in a pool.
This attribute specifies the minimum number of connections to be maintained by the pool during its entire lifetime. Simply changing this attribute in the connection string does not change the Min Pool Size restriction on a currently existing pool. Doing so simply creates a new pool with a different Min Pool Size restriction. This value is ignored unless Pooling is turned on.
1
Password
Password for the user specified by User Id.
This attribute specifies an Oracle user's password. Password is case-sensitive by default for Oracle Database 11g release 1 (11.1) and later.
empty string
Persist Security Info
Retrieval of the password in the connection string.
If this attribute is set to false, the Password value setting is not returned when the application requests the ConnectionString after the connection is successfully opened by the Open() method. This attribute can be set to either true, false, yes, or no.
false
Pooling
Connection pooling.
This attribute specifies whether or not connection pooling is to be used. Pools are created using an attribute value matching algorithm. This means that connection strings which only differ in the number of spaces in the connection string use the same pool. If two connection strings are identical except that one sets an attribute to a default value while the other does not set that attribute, both requests obtain connections from the same pool. This attribute can be set to either true, false, yes, or no.
true
Promotable Transaction
Promotable to distributed transaction or not.
If "promotable" is specified, the first and all subsequent connections opened in the same TransactionScope enlist in the same distributed transaction. If "local" is specified, the first connection opened in the TransactionScope uses a local transaction.
promotable
Proxy User Id
User name of the proxy user.
This connection string attribute specifies the middle-tier user, or the proxy user, who establishes a connection on behalf of a client user specified by the User Id attribute. ODP.NET attempts to establish a proxy connection if either the Proxy User Id or the Proxy Password attribute is set to a non-empty string.
empty string
For the proxy user to connect to an Oracle database using operating system authentication, the Proxy User Id must be set to "/". The Proxy Password is ignored in this case. The User Id cannot be set to "/" when establishing proxy connections. The case of this attribute value is preserved.
Proxy Password
Password of the proxy user.
This connection string attribute specifies the password of the middle-tier user or the proxy user. This user establishes a connection on behalf of a client user specified by the User Id attribute. ODP.NET attempts to establish a proxy connection if either the Proxy User Id or the Proxy Password attribute is set to a non-empty string.
The case of this attribute value is preserved if it is surrounded by double quotes.
empty string
Statement Cache Purge
Statement cache purged when the connection goes back to the pool.
If statement caching is enabled, setting this attribute to true purges the Statement Cache when the connection goes back to the pool.
false
Statement Cache Size
Statement cache enabled and cache size set size, that is, the maximum number of statements that can be cached.
A value greater than zero enables statement caching and sets the cache size to itself. This value should not be greater than the value of the OPEN_CURSORS parameter set in the init.ora database configuration file.
0
Self Tuning
Enables or disables self-tuning for the connection.
If self-tuning is enabled, then the StatementCacheSize settings in the registry, configuration files, and connection string are ignored.
If self-tuning is disabled, then a StatementCacheSize value of 0 is used unless StatementCachSize is specified in the registry, configuration file, or connection string.
true
User Id
Oracle user name.
This attribute specifies the Oracle user name. The case of this attribute value is preserved if it is surrounded by double quotes. For the user to connect to an Oracle database using operating system authentication, set the User Id to "/". Any Password attribute setting is ignored in this case.
empty string
Validate Connection
Validation of connections coming from the pool.
Validation causes a round-trip to the database for each connection. Therefore, it should only be used when necessary.
false
ConnectionTimeout
This property indicates the maximum amount of time that the Open method can take to obtain a pooled connection before the request is terminated.
Declaration
// ADO.NET 2.0: C#
public override int ConnectionTimeout {get;}
Property Value
The maximum time allowed for a pooled connection request, in seconds.
Implements
IDbConnection
Remarks
This property indicates the connection timeout that has been set using the ConnectionString attribute Connection TimeOut.
This property is read-only.
There is no connection string specified by the application and a connection on the implicit database is always available, therefore, this property is set to 0.
Database
This property is not supported.
Declaration
// ADO.NET 2.0: C#
public override string Database {get;}
Property Value
A string.
Implements
IDbConnection.Database
Remarks
This property is not supported. It always returns an empty string.
DatabaseDomainName
This property specifies the name of the database domain that this connection is connected to.
Declaration
// C#
public string DatabaseDomainName {get;}
Property Value
The database domain that this connection is connected to.
DatabaseName
This property specifies the name of the database that this connection is connected to.
Declaration
// C#
public string DatabaseName {get;}
Property Value
The database that this connection is connected to.
DataSource
This property specifies the Oracle Net Services Name, Connect Descriptor, or an easy connect naming that identifies the database to which to connect
Declaration
// ADO.NET 2.0: C#
public override string DataSource {get;}
Property Value
The value of this property is always an empty string for the implicit database connection.
HostName
This property specifies the name of the host that this connection is connected to.
Declaration
// C#
public string HostName {get;}
Property Value
The host that this connection is connected to.
InstanceName
This property specifies the name of the instance that this connection is connected to.
Declaration
// C#
public string InstanceName {get;}
Property Value
The instance that this connection is connected to.
ModuleName
This property specifies the module name for the connection.
Declaration
// C#
public string ModuleName {set;}
Property Value
The string to be used as the module name.
Remarks
The default value is null and the maximum string length is 48 bytes.
Using the ModuleName property allows the application to set the module name in the application context for a given OracleConnection object.
The ModuleName property is reset to null when the Close or Dispose method is called on the OracleConnection object.
ServerVersion
This property specifies the version number of the Oracle database to which the OracleConnection has established a connection.
Declaration
// ADO.NET 2.0: C#
public override string ServerVersion {get;}
Property Value
The version of the Oracle database.
Exceptions
InvalidOperationException - The connection is closed.
Remarks
The default is an empty string.
ServiceName
This property specifies the name of the service that this connection is connected to.
Declaration
// C#
public string ServiceName {get;}
Property Value
The service that this connection is connected to.
State
This property specifies the current state of the connection.
Declaration
// ADO.NET 2.0: C#
public override ConnectionState State {get;}
Property Value
The ConnectionState of the connection.
Implements
IDbConnection
Remarks
ODP.NET supports ConnectionState.Closed and ConnectionState.Open for this property. The default value is ConnectionState.Closed.
StatementCacheSize
This property specifies the current size of the statement cache associated with this connection.
Declaration
// C#
public int StatementCacheSize{get;}
Property Value
An integer value indicating the size of the statement cache.
Remarks
If self tuning is not enabled, then the default value of this property depends upon the statement cache size specified in the connection string, application configuration file, or the registry. If none of these values are specified, then a default value of 0 is used.
If self tuning is enabled, then the property value is adjusted automatically. Any values specified in the connection string, application configuration file, or the registry are ignored.
OracleConnection public methods are listed in Table 5-27.
Table 5-27 OracleConnection Public Methods
BeginTransaction
ChangeDatabase
Not Supported
Clone
Close
CreateCommand
CreateObjRef
Dispose
EnlistTransaction
Equals
FlushCache
GetHashCode
GetLifetimeService
GetSchema
GetSessionInfo
GetType
Open
OpenWithNewPassword
PurgeStatementCache
SetSessionInfo
ToString
BeginTransaction
BeginTransaction methods begin local transactions.
Overload List
BeginTransaction()
This method begins a local transaction.
Declaration
// C#
public OracleTransaction BeginTransaction();
Return Value
An OracleTransaction object representing the new transaction.
Implements
IDbConnection
Exceptions
InvalidOperationException - A transaction has already been started.
Remarks
The transaction is created with its isolation level set to its default value of IsolationLevel.ReadCommitted. All further operations related to the transaction must be performed on the returned OracleTransaction object.
Using this method causes a Not Supported exception.
BeginTransaction(IsolationLevel)
This method begins a local transaction with the specified isolation level.
Declaration
// C#
public OracleTransaction BeginTransaction(IsolationLevel isolationLevel);
Parameters
Return Value
Implements
IDbConnection
Exceptions
ArgumentException - The isolationLevel specified is invalid.
Remarks
The following isolation levels are supported: IsolationLevel.ReadCommitted and IsolationLevel.Serializable.
Requesting other isolation levels causes an exception.
Example
// C#
using System;
using System.Data;
class BeginTransactionSample
  static void Main()
    con.Open();
    // Create an OracleCommand object using the connection object
    // Start a transaction
    OracleTransaction txn = con.BeginTransaction(IsolationLevel.ReadCommitted);
    // Update EMP table
    cmd.CommandText = "update emp set sal = sal + 100";
    cmd.ExecuteNonQuery();
    // Rollback transaction
    txn.Rollback();
    Console.WriteLine("Transaction rolledback");
    // Clean up
    txn.Dispose();
    cmd.Dispose();
    con.Dispose();
ChangeDatabase
This method is not supported.
Declaration
// ADO.NET 2.0: C#
public override void ChangeDatabase(string databaseName);
Parameters
Implements
IDbConnection.ChangeDatabase
Exceptions
NotSupportedException - Method not supported.
Remarks
This method is not supported and throws a NotSupportedException if invoked.
Clone
This method creates a copy of an OracleConnection object.
Declaration
// C#
public object Clone();
Return Value
An OracleConnection object.
Implements
ICloneable
Remarks
The cloned object has the same property values as that of the object being cloned.
This method is not supported for an implicit database connection.
Example
// C#
using System;
class CloneSample
  static void Main()
    con.Open();
    // Need a proper casting for the return value when cloned
    OracleConnection clonedCon = (OracleConnection)con.Clone();
    // Cloned connection is always closed, regardless of its source,
    //   But the connection string should be identical
    clonedCon.Open();
    if (clonedCon.ConnectionString.Equals(con.ConnectionString))
      Console.WriteLine("The connection strings are the same.");
    else
      Console.WriteLine("The connection strings are different.");
    // Close and Dispose OracleConnection object
    clonedCon.Dispose();
Close
This method closes the connection to the database.
Declaration
// ADO.NET 2.0: C#
public override void Close();
Implements
IDbConnection
Remarks
Performs the following:
The connection can be reopened using Open().
CreateCommand
This method creates and returns an OracleCommand object associated with the OracleConnection object.
Declaration
// C#
public OracleCommand CreateCommand();
Return Value
The OracleCommand object.
Implements
IDbConnection
Example
// C#
using System;
using System.Data;
class CreateCommandSample
  static void Main()
    // Connect
    con.Open();
    // Clean up
    reader.Dispose();
    cmd.Dispose();
    con.Dispose();
This method enables applications to explicitly enlist in a specific distributed transaction after a connection has been opened.
Declaration
// C#
public void EnlistDistributedTransaction(ITransaction transaction);
Parameters
Exceptions
InvalidOperationException - The connection is part of a local transaction or the connection is closed.
Remarks
EnlistDistributedTransaction enables objects to enlist in a specific transaction that is passed to the method. The ITransaction interface can be obtained by applying an (ITransaction) cast to the ContexUtil.Transaction property within the component that started the distributed transaction.
The connection must be open before calling this method or an InvalidOperationException is thrown.
If a connection is part of a local transaction that was started implicitly or explicitly while attempting to enlist in a distributed transaction, the local transaction is rolled back and an exception is thrown.
By default, distributed transactions roll back, unless the method-level AutoComplete declaration is set.
Invoking the commit on the ITranasction raises an exception.
Invoking the rollback on the ITransaction method and calling ContextUtil.SetComplete on the same distributed transaction raises an exception.
Example
Application:
// C#
/* This is the class that will utilize the Enterprise Services
   component.  This module needs to be built as an executable.
   The Enterprise Services Component DLL must be built first
   before building this module.
   In addition, the DLL needs to be referenced appropriately
   when building this application.
using System;
using System.EnterpriseServices;
using DistribTxnSample;
class DistribTxnSample_App
  static void Main()
    DistribTxnSample_Comp comp = new DistribTxnSample_Comp();
    comp.DoWork();
Component:
// C#
/* This module needs to be
   1) built as a component DLL/Library
   2) built with a strong name
  This library must be built first before the application is built.
using System;
using System.Data;
namespace DistribTxnSample
  [Transaction(TransactionOption.RequiresNew)]
  public class DistribTxnSample_Comp : ServicedComponent
    public void DoWork()
      string constr =
        "User Id=scott;Password=tiger;Data Source=oracle;enlist=false";
      con.Open();
      // Enlist in a distrubuted transaction
      con.EnlistDistributedTransaction((ITransaction)ContextUtil.Transaction);
      // Update EMP table
      cmd.CommandText = "UPDATE emp set sal = sal + .01";
      // Commit
      ContextUtil.SetComplete();
      // Dispose OracleConnection object
      con.Dispose();
EnlistTransaction
This method enlists the connection to the specified transaction.
Declaration
// C#
public override void EnlistTransaction(Transaction transaction)
Parameters
Exceptions
Remarks
Invocation of this method immediately enlists the connection to a transaction that is specified by the provided transaction parameter.
If OracleConnection is still associated with a distributed transaction that has not completed from a previous EnlistTransaction method invocation, calling this method will cause an exception to be thrown.
In general, for transaction enlistments to succeed, the "enlist" connection string attribute must be set to either "true" or "dynamic" before invoking the Open method. Setting the "enlist" connection string attribute to "true" will implicitly enlist the connection when the Open method is called, if the connection is within a transaction context. Setting it to "dynamic" allows the connection to dynamically enlist in transactions when an EnlistTransaction or EnlistDistributedTransaction method is called. The "enlist" attribute should be set to "false" only if the connection will never enlist in a transaction.
FlushCache
This method flushes all updates and deletes made through REF objects retrieved using this connection.
Declaration
// c#
public void FlushCache();
Exceptions
InvalidOperationException - The specified connection is not open.
Remarks
Before flushing objects, it is required that the application has explicitly started a transaction by executing the BeginTransaction method on the OracleConnection object. This is because if the object being flushed has not already been locked by the application, an exclusive lock is obtained implicitly for the object. The lock is only released when the transaction commits or rollbacks.
GetSchema
GetSchema methods return schema information for the data source of the OracleConnection.
Overload List
GetSchema()
This method returns schema information for the data source of the OracleConnection.
Declaration
// ADO.NET 2.0: C#
public override DataTable GetSchema();
Return Value
A DataTable object.
Exceptions
InvalidOperationException – The connection is closed.
Remarks
This method returns a DataTable object that contains a row for each metadata collection available from the database.
The method is equivalent to specifying the String value "MetaDataCollections" when using the GetSchema(String) method.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
class GetSchemaSample
  static void Main(string[] args)
    string constr = "User Id=scott; Password=tiger; Data Source=oracle;";
    string ProviderName = "Oracle.DataAccess.Client";
    DbProviderFactory factory = DbProviderFactories.GetFactory(ProviderName);
    using (DbConnection conn = factory.CreateConnection())
      try
        conn.ConnectionString = constr;
        conn.Open();
        //Get all the schema collections and write to an XML file.
        //The XML file name is Oracle.DataAccess.Client_Schema.xml
        DataTable dtSchema = conn.GetSchema();
        dtSchema.WriteXml(ProviderName + "_Schema.xml");
      catch (Exception ex)
        Console.WriteLine(ex.Message);
        Console.WriteLine(ex.StackTrace);
GetSchema (string collectionName)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name.
Declaration
// ADO.NET 2.0: C#
public override DataTable GetSchema (string collectionName);
Parameters
collectionName
Name of the collection for which metadata is required.
Return Value
A DataTable object.
Exceptions
ArgumentException – The requested collection is not defined.
InvalidOperationException – The requested collection is not supported by current version of Oracle database.
InvalidOperationException – No population string is specified for requested collection.
Example
// C#
using System;
using System.Data;
      try
        conn.Open();
        //Get MetaDataCollections and write to an XML file.
        //This is equivalent to GetSchema()
        DataTable dtMetadata =
          conn.GetSchema(DbMetaDataCollectionNames.MetaDataCollections);
        dtMetadata.WriteXml(ProviderName + "_MetaDataCollections.xml");
        //Get Restrictions and write to an XML file.
        DataTable dtRestrictions =
          conn.GetSchema(DbMetaDataCollectionNames.Restrictions);
        dtRestrictions.WriteXml(ProviderName + "_Restrictions.xml");
        //Get DataSourceInformation and write to an XML file.
        DataTable dtDataSrcInfo =
          conn.GetSchema(DbMetaDataCollectionNames.DataSourceInformation);
        dtDataSrcInfo.WriteXml(ProviderName + "_DataSourceInformation.xml");
        //data types and write to an XML file.
        DataTable dtDataTypes =
          conn.GetSchema(DbMetaDataCollectionNames.DataTypes);
        dtDataTypes.WriteXml(ProviderName + "_DataTypes.xml");
        //Get ReservedWords and write to an XML file.
        DataTable dtReservedWords =
          conn.GetSchema(DbMetaDataCollectionNames.ReservedWords);
        dtReservedWords.WriteXml(ProviderName + "_ReservedWords.xml");
        //Get all the tables and write to an XML file.
        DataTable dtTables = conn.GetSchema("Tables");
        dtTables.WriteXml(ProviderName + "_Tables.xml");
        //Get all the views and write to an XML file.
        DataTable dtViews = conn.GetSchema("Views");
        dtViews.WriteXml(ProviderName + "_Views.xml");
        //Get all the columns and write to an XML file.
        DataTable dtColumns = conn.GetSchema("Columns");
        dtColumns.WriteXml(ProviderName + "_Columns.xml");
GetSchema (string collectionName, string[] restrictions)
This method returns schema information for the data source of the OracleConnection using the specified string for the collection name and the specified string array for the restriction values.
Declaration
// ADO.NET 2.0: C#
public override DataTable GetSchema (string collectionName,
    string[] restrictions);
Parameters
Return Value
A DataTable object.
Exception
Remarks
This method takes the name of a metadata collection and an array of String values that specify the restrictions for filtering the rows in the returned DataTable. This returns a DataTable that contains only rows from the specified metadata collection that match the specified restrictions.
For example, if the Columns collection has three restrictions (owner, tablename, and columnname), to retrieve all the columns for the EMP table regardless of schema, the GetSchema method must pass in at least these values: null, EMP.
If no restriction value is passed in, default values are used for that restriction, which is the same as passing in null. This differs from passing in an empty string for the parameter value. In this case, the empty string ("") is considered the value for the specified parameter.
collectionName is not case-sensitive, but restrictions (string values) are.
Example
// C#
using System;
using System.Data;
      try
        conn.Open();
        //Get Restrictions
        DataView dv = dtRestrictions.DefaultView;
        dv.RowFilter = "CollectionName = 'Columns'";
        dv.Sort = "RestrictionNumber";
        for (int i = 0; i < dv.Count; i++)
          Console.WriteLine("{0} (default) {1}" ,
                            dtRestrictions.Rows[i]["RestrictionName"],
                            dtRestrictions.Rows[i]["RestrictionDefault"]);
        //Set restriction string array
        string[] restrictions = new string[3];
        //Get all columns from all tables owned by "SCOTT"
        restrictions[0] = "SCOTT";
        DataTable dtAllScottCols = conn.GetSchema("Columns", restrictions);
        // clear collection
        for (int i = 0; i < 3; i++)
          restrictions[i] = null;
        //Get all columns from all tables named "EMP" owned by any
        //owner/schema
        restrictions[1] = "EMP";
        DataTable dtAllEmpCols = conn.GetSchema("Columns", restrictions);
        // clear collection
        //Get columns named "EMPNO" from tables named "EMP",
        //owned by any owner/schema
        restrictions[2] = "EMPNO";
        DataTable dtAllScottEmpCols = conn.GetSchema("Columns", restrictions);
        // clear collection
        //Get columns named "EMPNO" from all
        //tables, owned by any owner/schema
        DataTable dtAllEmpNoCols = conn.GetSchema("Columns", restrictions);
        Console.WriteLine(ex.Source);
GetSessionInfo
GetSessionInfo returns or refreshes an OracleGlobalization object that represents the globalization settings of the session.
Overload List:
GetSessionInfo()
This method returns a new instance of the OracleGlobalization object that represents the globalization settings of the session.
Declaration
// C#
public OracleGlobalization GetSessionInfo();
Return Value
The newly created OracleGlobalization object.
Example
// C#
using System;
class GetSessionInfoSample
  static void Main()
    con.Open();
    // Get session info from connection object
    OracleGlobalization info = con.GetSessionInfo();
    // Update session info
    info.DateFormat = "YYYY-MM-DD";
    con.SetSessionInfo(info);
    // Execute SQL SELECT
    cmd.CommandText = "select TO_CHAR(hiredate) from emp";
    Console.WriteLine("Hire Date ({0}): {1}",
      info.DateFormat, cmd.ExecuteScalar());
    // Clean up
    cmd.Dispose();
    con.Dispose();
GetSessionInfo(OracleGlobalization)
This method refreshes the provided OracleGlobalization object with the globalization settings of the session.
Declaration
// C#
public void GetSessionInfo(OracleGlobalization oraGlob);
Parameters
Open
This method opens a connection to an Oracle database.
Declaration
// ADO.NET 2.0: C#
public overide void Open();
Implements
IDbConnection
Exceptions
ObjectDisposedException - The object is already disposed.
InvalidOperationException - The connection is already opened or the connection string is null or empty.
Remarks
The connection is obtained from the pool if connection pooling is enabled. Otherwise, a new connection is established.
It is possible that the pool does not contain any unused connections when the Open() method is invoked. In this case, a new connection is established.
If no connections are available within the specified connection timeout value, when the Max Pool Size is reached, an OracleException is thrown.
OpenWithNewPassword
This method opens a new connection with the new password.
Declaration
// C#
public void OpenWithNewPassword(string newPassword);
Parameters
Remarks
This method uses the ConnectionString property settings to establish a new connection. The old password must be provided in the connection string as the Password attribute value.
This method can only be called on an OracleConnection in the closed state.
This method is not supported with an implicit database connection.
If connection pooling is enabled, then invoking the OpenWithNewPassword method also clears the connection pool. This closes all idle connections created with the old password.
PurgeStatementCache
This method flushes the statement cache by closing all open cursors on the database, when statement caching is enabled.
Declaration
// C#
public void PurgeStatementCache();
Remarks
Flushing the statement cache repetitively results in decreased performance and may negate the performance benefit gained by enabling the statement cache.
Statement caching remains enabled after the call to PurgeStatementCache.
Invocation of this method purges the cached cursors that are associated with the OracleConnection. It does not purge all the cached cursors in the database.
Example
// C#
using System;
using System.Data;
class PurgeStatementCacheSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle;" +
      "Statement Cache Size=20";
    con.Open();
    OracleCommand cmd = new OracleCommand("select * from emp", con);
    cmd.CommandType = CommandType.Text;
    // Purge Statement Cache
    con.PurgeStatementCache();
    Console.WriteLine("Statement Cache Flushed");
    con.Close();
    con.Dispose();
SetSessionInfo
This method alters the session's globalization settings with all the property values specified in the provided OracleGlobalization object.
Declaration
// C#
public void SetSessionInfo(OracleGlobalization oraGlob);
Parameters
An OracleGlobalization object.
Remarks
Calling this method is equivalent to calling an ALTER SESSION SQL on the session.
Example
// C#
using System;
class SetSessionInfoSample
  static void Main()
    con.Open();
    info.DateFormat = "MM-DD-RR";
    // Execute SQL SELECT again
    // Clean up
    cmd.Dispose();
    con.Dispose();
OracleConnection events are listed in Table 5-28.
Table 5-28 OracleConnection Events
Disposed
Failover
HAEvent
InfoMessage
StateChange
Failover
This event is triggered when an Oracle failover occurs.
Declaration
// C#
public event OracleFailoverEventHandler Failover;
Event Data
The event handler receives an OracleFailoverEventArgs object which exposes the following properties containing information about the event.
Remarks
The Failover event is raised when a connection to an Oracle instance is unexpectedly severed. The client should create an OracleFailoverEventHandler delegate to listen to this event.
HAEvent
This event is triggered when an HA event occurs.
Declaration
// C#
public static event OracleHAEventHandler HAEvent;
Event Data
The event handler receives an OracleHAEventArgs object which exposes the following properties containing information about the event.
Remarks
The HAEvent is static, which means that any HA Events that happen within the application domain can trigger this event. Note that in order to receive HA event notifications, OracleConnection objects that establish connections within the application domain must have "ha events=true" in the application. Otherwise, the application never receives any HA Events.
InfoMessage
This event is triggered for any message or warning sent by the database.
Declaration
// C#
public event OracleInfoMessageEventHandler InfoMessage;
Event Data
The event handler receives an OracleInfoMessageEventArgs object which exposes the following properties containing information about the event.
Remarks
In order to respond to warnings and messages from the database, the client should create an OracleInfoMessageEventHandler delegate to listen to this event.
StateChange
This event is triggered when the connection state changes.
Declaration
// ADO.NET 2.0: C#
public override event StateChangeEventHandler StateChange;
Event Data
The event handler receives a StateChangeEventArgs object which exposes the following properties containing information about the event.
Remarks
The StateChange event is raised after a connection changes state, whenever an explicit call is made to Open, Close or Dispose.
See Also:
