| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
An OracleDataAdapter object represents a data provider object that populates the DataSet and updates changes in the DataSet to the Oracle database.
Class Inheritance
System.Object
System.MarshalByRefObject
System.ComponentModel.Component
System.Data.Common.DataAdapter
System.Data.Common.DbDataAdapter (ADO.NET 2.0 only)
Oracle.DataAccess.Client.OracleDataAdapter
Declaration
// C# public sealed class OracleDataAdapter : DbDataAdapter, IDbDataAdapter
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The following example uses the OracleDataAdapter and the dataset to update the EMP table:
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleDataAdapterSample
static void Main()
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
string cmdstr = "SELECT empno, sal from emp";
// Create the adapter with the selectCommand txt and the
// connection string
OracleDataAdapter adapter = new OracleDataAdapter(cmdstr, constr);
// Create the builder for the adapter to automatically generate
// the Command when needed
OracleCommandBuilder builder = new OracleCommandBuilder(adapter);
// Create and fill the DataSet using the EMP
DataSet dataset = new DataSet();
adapter.Fill(dataset, "EMP");
// Get the EMP table from the dataset
DataTable table = dataset.Tables["EMP"];
// Indicate DataColumn EMPNO is unique
// This is required by the OracleCommandBuilder to update the EMP table
table.Columns["EMPNO"].Unique = true;
// Get the first row from the EMP table
DataRow row = table.Rows[0];
// Update the salary
double sal = double.Parse(row["SAL"].ToString());
row["SAL"] = sal + .01;
// Now update the EMP using the adapter
// The OracleCommandBuilder will create the UpdateCommand for the
// adapter to update the EMP table
adapter.Update(dataset, "EMP");
Console.WriteLine("Row updated successfully");
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleDataAdapter members are listed in the following tables.
OracleDataAdapter Constructors
OracleDataAdapter constructors are listed in Table 5-29.
Table 5-29 OracleDataAdapter Constructors
| Constructor | Description |
Instantiates a new instance of |
OracleDataAdapter Static Methods
The OracleDataAdapter static method is listed in Table 5-30.
Table 5-30 OracleDataAdapter Static Method
| Method | Description |
Inherited from |
OracleDataAdapter Properties
OracleDataAdapter properties are listed in Table 5-31.
Table 5-31 OracleDataAdapter Properties
| Property | Description |
Inherited from |
Inherited from |
Inherited from |
A SQL statement or stored procedure to delete rows from an Oracle database |
A SQL statement or stored procedure to insert new rows into an Oracle database |
Inherited from |
Inherited from |
Determines whether or not the |
Determines if the |
Creates a mapping between column names in the result set to .NET types, to preserve the data |
A SQL statement or stored procedure that returns a single or multiple result set |
Inherited from |
Inherited from |
Specifies a value that enables or disables batch processing support, and specifies the number of SQL statements that can be executed in a single round-trip to the database Supported Only in ADO.NET 2.0-Compliant ODP.NET |
A SQL statement or stored procedure to update rows from the |
OracleDataAdapter Public Methods
OracleDataAdapter public methods are listed in Table 5-32.
Table 5-32 OracleDataAdapter Public Methods
| Public Method | Description |
Inherited from |
Inherited from |
Inherited from |
Adds or refreshes rows in the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleDataAdapter Events
OracleDataAdapter events are listed in Table 5-33.
Table 5-33 OracleDataAdapter Events
| Event Name | Description |
Inherited from |
Inherited from |
This event is raised when row(s) have been updated by the |
This event is raised when row data are about to be updated to the database |
OracleDataAdapter constructors create new instances of an OracleDataAdapter class.
Overload List:
This constructor creates an instance of an OracleDataAdapter class.
OracleDataAdapter(OracleCommand)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleCommand as the SelectCommand.
OracleDataAdapter(string, OracleConnection)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleConnection object and the command text for the SelectCommand.
OracleDataAdapter(string, string)
This constructor creates an instance of an OracleDataAdapter class with the provided connection string and the command text for the SelectCommand.
This constructor creates an instance of an OracleDataAdapter class with no arguments.
Declaration
// C# public OracleDataAdapter();
Remarks
Initial values are set for the following OracleDataAdapter properties as indicated:
MissingMappingAction = MissingMappingAction.Passthrough
MissingSchemaAction = MissingSchemaAction.Add
Declaration
// C#
public OracleDataAdapter(OracleCommand selectCommand);
Parameters
selectCommand
The OracleCommand that is to be set as the SelectCommand property.
Remarks
Declaration
// C# public OracleDataAdapter(string selectCommandText, OracleConnection selectConnection);
Parameters
selectCommandText
The string that is set as the CommandText of the SelectCommand property of the OracleDataAdapter.
selectConnection
The OracleConnection to connect to the Oracle database.
Remarks
The OracleDataAdapter opens and closes the connection, if it is not already open. If the connection is open, it must be explicitly closed.
Declaration
// C# public OracleDataAdapter(string selectCommandText, string selectConnectionString);
Parameters
selectCommandText
The connection string.
Remarks
The OracleDataAdapter static method is listed in Table 5-34.
Table 5-34 OracleDataAdapter Static Method
Inherited from |
OracleDataAdapter properties are listed in Table 5-35.
Table 5-35 OracleDataAdapter Properties
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Determines if the |
Inherited from |
Inherited from |
This property is a SQL statement or stored procedure to delete rows from an Oracle database.
Declaration
// C#
public OracleCommand DeleteCommand {get; set;}
Property Value
An OracleCommand used during the Update call to delete rows from tables in the Oracle database, corresponding to the deleted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the DeleteCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this.
This property is a SQL statement or stored procedure to insert new rows into an Oracle database.
Declaration
// C#
public OracleCommand InsertCommand {get; set;}
Property Value
An OracleCommand used during the Update call to insert rows into a table, corresponding to the inserted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the InsertCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
This property determines whether or not the SelectCommand is reexecuted on the next call to Fill.
Declaration
// C#
public Boolean Requery {get; set;}
Property Value
Returns true if the SelectCommand is reexecuted on the next call to Fill; otherwise, returns false.
This property determines if the Fill method returns ODP.NET-specific values or .NET common language specification compliant values.
Declaration
// C#
public Boolean ReturnProviderSpecificTypes {get; set;}
Property Value
A value that indicates whether or not the Fill method returns ODP.NET-specific values. A value of false indicates that the Fill method returns .NET common language specification compliant values. The default is false.
This property creates a mapping between column names in the result set to .NET types that represent column values in the DataSet, to preserve the data.
Declaration
// C#
public Hashtable SafeMapping {get; set;}
Property Value
A hash table.
Remarks
Default = null
The SafeMapping property is used, when necessary, to preserve data in the following types:
DATE
TimeStamp (refers to all TimeStamp objects)
INTERVAL DAY TO SECOND
NUMBER
Example
See the example in "OracleDataAdapter Safe Type Mapping".
This property is a SQL statement or stored procedure that returns single or multiple result sets.
Declaration
// C#
public OracleCommand SelectCommand {get; set;}
Property Value
An OracleCommand used during the Fill call to populate the selected rows to the DataSet.
Remarks
Default = null
If the SelectCommand does not return any rows, no tables are added to the dataset and no exception is raised.
If the SELECT statement selects from a VIEW, no key information is retrieved when a FillSchema() or a Fill() with MissingSchemaAction.AddWithKey is invoked.
This property specifies a value that enables or disables batch processing support, and specifies the number of SQL statements that can be executed in a single round-trip to the database.
Declaration
// C#
public virtual int UpdateBatchSize {get; set;}
Property Value
An integer that returns the batch size.
Exceptions
ArgumentOutOfRangeException - The value is set to a number < 0.
Remarks
Update batches executed with large amounts of data may encounter an "PLS-00123: Program too large" error. To avoid this error, reduce the size of UpdateBatchSize to a smaller value.
For each row in the DataSet that has been modified, added, or deleted, one SQL statement will be executed on the database.
Values are as follows:
Value = 0
The data adapter executes all the SQL statements in a single database round-trip
Value = 1 - Default value
This value disables batch updating and SQL statements are executed one at a time.
Value = n where n > 1
The data adapter updates n rows of data per database round-trip.
This property is a SQL statement or stored procedure to update rows from the DataSet to an Oracle database.
Declaration
// C#
public OracleCommand UpdateCommand {get; set;}
Property Value
An OracleCommand used during the Update call to update rows in the Oracle database, corresponding to the updated rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the UpdateCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
OracleDataAdapter public methods are listed in Table 5-36.
Table 5-36 OracleDataAdapter Public Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from System. |
Inherited from |
Inherited from |
Fill populates or refreshes the specified DataTable or DataSet.
Overload List:
Fill(DataTable, OracleRefCursor)
This method adds or refreshes rows in the specified DataTable to match those in the provided OracleRefCursor object.
Fill(DataSet, OracleRefCursor)
This method adds or refreshes rows in the DataSet to match those in the provided OracleRefCursor object.
Fill(DataSet, string, OracleRefCursor)
This method adds or refreshes rows in the specified source table of the DataSet to match those in the provided OracleRefCursor object.
Fill(DataSet, int, int, string, OracleRefCursor)
This method adds or refreshes rows in a specified range in the DataSet to match rows in the provided OracleRefCursor object.
Declaration
// C# public int Fill(DataTable dataTable, OracleRefCursor refCursor);
Parameters
dataTable
The DataTable object being populated.
refCursor
The OracleRefCursor that rows are being retrieved from.
Return Value
The number of rows added to or refreshed in the DataTable.
Exceptions
ArgumentNullException - The dataTable or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is already being used to fetch data.
NotSupportedException - The SafeMapping type is not supported.
Remarks
No schema or key information is provided, even if the Fill method is called with MissingSchemaAction set to MissingSchemaAction.AddWithKey.
Declaration
// C# public int Fill(DataSet dataSet, OracleRefCursor refCursor);
Parameters
dataSet
The DataSet object being populated.
refCursor
Return Value
Returns the number of rows added or refreshed in the DataSet.
Exceptions
ArgumentNullException - The dataSet or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is ready to fetch data.
Remarks
If there is no DataTable to refresh, a new DataTable named Table is created and populated using the provided OracleRefCursor object.
Declaration
// C# public int Fill(DataSet dataSet, string srcTable, OracleRefCursor refCursor);
Parameters
dataSet
srcTable
The name of the source table used in the table mapping.
refCursor
Return Value
Returns the number of rows added or refreshed into the DataSet.
Exceptions
InvalidOperationException - The OracleRefCursor is already being used to fetch data or the source table name is invalid.
Remarks
Declaration
// C# public int Fill(DataSet dataSet, int startRecord, int maxRecords, string srcTable, OracleRefCursor refCursor);
Parameters
dataSet
startRecord
The record number to start with.
maxRecords
The maximum number of records to obtain.
srcTable
refCursor
Return Value
This method returns the number of rows added or refreshed in the DataSet. This does not include rows affected by statements that do not return rows.
Exceptions
Remarks
OracleDataAdapter events are listed in Table 5-37.
Table 5-37 OracleDataAdapter Events
Inherited from |
Inherited from |
This event is raised when row(s) have been updated by the Update() method.
Declaration
// C# public event OracleRowUpdatedEventHandler RowUpdated;
Event Data
The event handler receives an OracleRowUpdatedEventArgs object which exposes the following properties containing information about the event.
Command
The OracleCommand executed during the Update.
Errors (inherited from RowUpdatedEventArgs)
The exception, if any, is generated during the Update.
RecordsAffected (inherited from RowUpdatedEventArgs)
The number of rows modified, inserted, or deleted by the execution of the Command.
Row (inherited from RowUpdatedEventArgs)
The DataRow sent for Update.
StatementType (inherited from RowUpdatedEventArgs)
The type of SQL statement executed.
Status (inherited from RowUpdatedEventArgs)
The UpdateStatus of the Command.
TableMapping (inherited from RowUpdatedEventArgs)
The DataTableMapping used during the Update.
Example
The following example shows how to use the RowUpdating and RowUpdated events.
// C#
using System;
using System.Data;
class RowUpdatedSample
// Event handler for RowUpdating event
protected static void OnRowUpdating(object sender,
OracleRowUpdatingEventArgs e)
Console.WriteLine("Row updating.....");
Console.WriteLine("Event arguments:");
Console.WriteLine("Command Text: " + e.Command.CommandText);
Console.WriteLine("Command Type: " + e.StatementType);
Console.WriteLine("Status: " + e.Status);
// Event handler for RowUpdated event
protected static void OnRowUpdated(object sender,
OracleRowUpdatedEventArgs e)
Console.WriteLine("Row updated.....");
static void Main()
string cmdstr = "SELECT EMPNO, ENAME, SAL FROM EMP";
// Set the event handlers for the RowUpdated and the RowUpdating event
// the OnRowUpdating() method will be triggered before the update, and
// the OnRowUpdated() method will be triggered after the update
adapter.RowUpdating += new OracleRowUpdatingEventHandler(OnRowUpdating);
adapter.RowUpdated += new OracleRowUpdatedEventHandler(OnRowUpdated);
// The OnRowUpdating() and the OnRowUpdated() methods will be triggered
This event is raised when row data are about to be updated to the database.
Declaration
// C# public event OracleRowUpdatingEventHandler RowUpdating;
Event Data
The event handler receives an OracleRowUpdatingEventArgs object which exposes the following properties containing information about the event.
Command
Errors (inherited from RowUpdatingEventArgs)
Row (inherited from RowUpdatingEventArgs)
StatementType (inherited from RowUpdatingEventArgs)
Status (inherited from RowUpdatingEventArgs)
TableMapping (inherited from RowUpdatingEventArgs)
Example
The example for the RowUpdated event also shows how to use the RowUpdating event. See RowUpdated event "Example".
