Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleDataSourceEnumerator Class
An OracleDataSourceEnumerator object allows applications to generically obtain a collection of data sources to connect to.
Supported Only in ADO.NET 2.0-Compliant ODP.NET
Class Inheritance
System.Object
  System.DbDataSourceEnumerator
    Oracle.DataAccess.Client.OracleDataSourceEnumerator
Declaration
// C#
public sealed class OracleDataSourceEnumerator : DbDataSourceEnumerator
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using System.Data.Common;
using Oracle.DataAccess.Client;
class DataSourceEnumSample
  static void Main()
    string ProviderName = "Oracle.DataAccess.Client";
    DbProviderFactory factory = DbProviderFactories.GetFactory(ProviderName);
    if (factory.CanCreateDataSourceEnumerator)
      DbDataSourceEnumerator dsenum = factory.CreateDataSourceEnumerator();
      DataTable dt = dsenum.GetDataSources();
      // Print the first column/row entry in the DataTable
      Console.WriteLine(dt.Columns[0] + " : " + dt.Rows[0][0]);
      Console.WriteLine(dt.Columns[1] + " : " + dt.Rows[0][1]);
      Console.WriteLine(dt.Columns[2] + " : " + dt.Rows[0][2]);
      Console.WriteLine(dt.Columns[3] + " : " + dt.Rows[0][3]);
      Console.WriteLine(dt.Columns[4] + " : " + dt.Rows[0][4]);
    else
      Console.Write("Data source enumeration is not supported by provider");
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleDataSourceEnumerator Members
OracleDataSourceEnumerator members are listed in the following tables.
OracleDataSourceEnumerator Public Methods
OracleDataSourceEnumerator Public Methods are listed in Table 7-10.
Table 7-10 OracleDataSourceEnumerator Method
Method Description
GetDataSources
Returns a DataTable object with information on all the TNS alias entries in the tnsnames.ora file
The OracleDataSourceEnumerator static method is listed in Table 7-11.
Table 7-11 OracleDataSourceEnumerator Method
Method Description
GetDataSources
GetDataSources
This method returns a DataTable object with information on all the TNS alias entries in the tnsnames.ora file.
Declaration
// C#
public override DataTable GetDataSources();
Return Value
A DataTable object.
Remarks
This method returns a DataTable object for each TNS Alias entry that exists in the tnsnames.ora file.
If the tnsnames.ora file is not found, then the returned DataTable object is empty.
The following columns are returned for each row, but only the InstanceName column is populated.
