| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
An OracleErrorCollection class represents a collection of all errors that are thrown by the Oracle Data Provider for .NET.
Class Inheritance
System.Object
System.ArrayList
Oracle.DataAccess.Client.OracleErrorCollection
Declaration
// C# public sealed class OracleErrorCollection : ArrayList
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
A simple ArrayList that holds a list of OracleErrors.
If there are multiple errors, ODP.NET only returns the first error message on the stack.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleErrorCollectionSample
static void Main()
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
// Create an OracleCommand object using the connection object
OracleCommand cmd = con.CreateCommand();
try
cmd.CommandText = "insert into notable values (99, 'MyText')";
cmd.ExecuteNonQuery();
catch (OracleException ex)
Console.WriteLine("Record is not inserted into the database table.");
foreach (OracleError error in ex.Errors)
Console.WriteLine("Error Message: " + error.Message);
Console.WriteLine("Error Source: " + error.Source);
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleErrorCollection members are listed in the following tables.
OracleErrorCollection Static Methods
OracleErrorCollection static methods are listed in Table 5-56.
Table 5-56 OracleErrorCollection Static Methods
| Method | Description |
Inherited from |
OracleErrorCollection Properties
OracleErrorCollection properties are listed in Table 5-57.
Table 5-57 OracleErrorCollection Properties
| Property | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleErrorCollection Public Methods
OracleErrorCollection public methods are listed in Table 5-58.
Table 5-58 OracleErrorCollection Public Methods
| Public Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
The OracleErrorCollection static method is listed in Table 5-59.
Table 5-59 OracleErrorCollection Static Method
Inherited from |
OracleErrorCollection properties are listed in Table 5-60.
Table 5-60 OracleErrorCollection Properties
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OracleErrorCollection public methods are listed in Table 5-61.
