Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleInfoMessageEventArgs Class
The OracleInfoMessageEventArgs class provides event data for the OracleConnection.InfoMessage event. When any warning occurs in the database, the OracleConnection.InfoMessage event is triggered along with the OracleInfoMessageEventArgs object that stores the event data.
Class Inheritance
System.Object
  System.EventArgs
    Oracle.DataAccess.Client.OracleInfoMessageEventArgs
Declaration
// C#
public sealed class OracleInfoMessageEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
using Oracle.DataAccess.Types;
class InfoMessageSample
  public static void WarningHandler(object src,
    OracleInfoMessageEventArgs args)
      Console.WriteLine("Source object is: " + src.GetType().Name);
      Console.WriteLine("InfoMessageArgs.Message is " + args.Message);
      Console.WriteLine("InfoMessageArgs.Source is " + args.Source);
  static void Main()
    OracleConnection con = new OracleConnection("User Id=scott;" +
      "Password=tiger;Data Source=oracle;");
    con.Open();
    OracleCommand cmd = con.CreateCommand();
    //Register to the InfoMessageHandler
    cmd.Connection.InfoMessage +=
      new OracleInfoMessageEventHandler(WarningHandler);
    cmd.CommandText =
      "create or replace procedure SelectWithNoInto( " +
      "  empname in VARCHAR2) AS " +
      "BEGIN " +
      "  select * from emp where ename = empname; " +
      "END SelectWithNoInto;";
    // Execute the statement that produces a warning
    cmd.ExecuteNonQuery();
    // Clean up
    cmd.Dispose();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleInfoMessageEventArgs Members
OracleInfoMessageEventArgs members are listed in the following tables.
OracleInfoMessageEventArgs Static Methods
The OracleInfoMessageEventArgs static methods is listed in Table 5-68.
Table 5-68 OracleInfoMessageEventArgs Static Method
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleInfoMessageEventArgs Properties
The OracleInfoMessageEventArgs properties are listed in Table 5-69.
Table 5-69 OracleInfoMessageEventArgs Properties
Property Description
Errors
Specifies the collection of errors generated by the data source
Message
Specifies the error text generated by the data source
Source
Specifies the name of the object that generated the error
OracleInfoMessageEventArgs Public Methods
The OracleInfoMessageEventArgs methods are listed in Table 5-70.
Table 5-70 OracleInfoMessageEventArgs Public Methods
Method Description
Equals
GetHashCode
GetType
ToString
The OracleInfoMessageEventArgs static method is listed in Table 5-71.
Table 5-71 OracleInfoMessageEventArgs Static Method
Method Description
Equals
The OracleInfoMessageEventArgs properties are listed in Table 5-72.
Table 5-72 OracleInfoMessageEventArgs Properties
Errors
Message
Source
Errors
This property specifies the collection of errors generated by the data source.
Declaration
// C#
public OracleErrorCollection Errors {get;}
Property Value
The collection of errors.
Message
This property specifies the error text generated by the data source.
Declaration
// C#
public string Message {get;}
Property Value
The error text.
Source
This property specifies the name of the object that generated the error.
Declaration
// C#
public string Source {get;}
Property Value
The object that generated the error.
The OracleInfoMessageEventArgs methods are listed in Table 5-73.
Table 5-73 OracleInfoMessageEventArgs Public Methods
Method Description
Equals
GetHashCode
GetType
ToString
