Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OraclePermissionAttribute Class
An OraclePermissionAttribute object enables ODP.NET to enforce declarative security and helps ensure that a user has a security level adequate for accessing data.
Class Inheritance
  System.Object
    System.Attribute
      System.Security.Permissions.SecurityAttribute
        System.Security.Permissions.CodeAccessSecurityAttribute
          System.Data.Common.DBDataPermissionAttribute
            Oracle.DataAccess.Client.OraclePermissionAttribute
Declaration
// ADO.NET 2.0:C#
[Serializable, AttributeUsage(AttributeTargets.Method |
AttributeTargets.Constructor | AttributeTargets.Class | AttributeTargets.Struct |
AttributeTargets.Assembly, AllowMultiple = true, Inherited = false)]
public sealed class OraclePermissionAttribute: DBDataPermissionAttribute
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess
OraclePermissionAttribute Members
OraclePermissionAttribute members are listed in the following tables.
OraclePermissionAttribute Constructor
The OraclePermissionAttribute constructor is listed in Table 5-94.
Table 5-94 OraclePermission Constructor
Constructor Description
Instantiates a new instance of the OraclePermissionAttribute class.
OraclePermissionAttribute Static Methods
The OraclePermissionAttribute static methods are listed in Table 5-95.
Table 5-95 OraclePermissionAttribute Static Methods
Static Methods Description
GetCustomAttribute
Inherited from System.Attribute (Overloaded)
GetCustomAttributes
Inherited from System.Attribute(Overloaded)
IsDefined
ReferenceEquals
Inherited from System.Object
OraclePermissionAttribute Public Properties
The OraclePermissionAttribute public properties are listed in Table 5-96.
Table 5-96 OraclePermissionAttribute Public Properties
Public Properties Description
Action
Inherited from SecurityAttribute
AllowBlankPassword
Inherited from DBDataPermissionAttribute.
OraclePermissionAttribute ignores this property. Any value set for this property, for an OraclePermissionAttribute object, is ignored.
ConnectionString
KeyRestrictionBehavior
KeyRestrictions
TypeId
Unrestricted
OraclePermissionAttribute Public Methods
The OraclePermissionAttribute public methods are listed in Table 5-97.
Table 5-97 OraclePermissionAttribute Public Methods
Public Methods Description
CreatePermission
Returns a new OraclePermissionAttribute object that is configured based on the attributes set
Equals
GetHashCode
GetType
IsDefaultAttribute
Match
ShouldSerializeConnectionString
ShouldSerializeKeyRestrictions
ToString
The OraclePermissionAttribute constructor instantiates new instances of the OraclePermissionAttribute class.
Declaration
// C#
public OraclePermissionAttribute (SecurityAction action);
Parameters
The OraclePermissionAttribute static methods are listed in Table 5-98.
Table 5-98 OraclePermissionAttribute Static Methods
GetCustomAttribute
GetCustomAttributes
IsDefined
ReferenceEquals
The OraclePermissionAttribute public properties are listed in Table 5-99.
Table 5-99 OraclePermissionAttribute Public Properties
Action
AllowBlankPassword
ConnectionString
KeyRestrictions
TypeId
Unrestricted
The OraclePermissionAttribute public methods are listed in Table 5-100.
Table 5-100 OraclePermissionAttribute Public Methods
CreatePermission
Equals
GetHashCode
GetType
IsDefaultAttribute
Match
ToString
CreatePermission
This method returns a new OraclePermissionAttribute object that is configured based on the attributes set.
Declaration
// C#
public override IPermission CreatePermission();
Return Value
An OraclePermission object.
