| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
An OraclePermission object enables ODP.NET to enforce imperative security and helps ensure that a user has a security level adequate for accessing data.
Class Inheritance
System.Object
System.Security.CodeAccessPermission
System.Data.Common.DBDataPermission
Oracle.DataAccess.Client.OraclePermission
Declaration
// ADO.NET 2.0: C# public class OraclePermission: DBDataPermission
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess
Microsoft .NET Framework Version: 2.0 or later
OraclePermission members are listed in the following tables.
OraclePermission Constructors
The OraclePermission constructor is listed in Table 5-87.
Table 5-87 OraclePermission Constructor
| Constructor | Description |
Instantiates a new instance of the |
OraclePermission Static Methods
The OraclePermission static methods are listed in Table 5-88.
Table 5-88 OraclePermission Static Methods
| Static Method | Description |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
OraclePermission Public Properties
The OraclePermission public methods are listed in Table 5-92.
Table 5-89 OraclePermission Public Properties
| Public Properties | Description |
Inherited from
OraclePermission Public Methods
The OraclePermission public methods are listed in Table 5-90.
Table 5-90 OraclePermission Public Methods
| Public Method | Description |
Adds a new connection string fragment and a list of restricted keywords to the |
Inherited from |
Returns a copy of the current permission object |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Returns a boolean value that indicates whether or not the current permission is a subset of the target permission |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
The OraclePermission constructor instantiates a new instance of the OraclePermission class.
Declaration
// C#
public OraclePermission (PermissionState state);
Parameters
state
The state parameter takes one of the following two values: PermissionState.None or PermissionState.Unrestricted.
Exceptions
ArgumentException - The PermissionState value is invalid.
The OraclePermission static methods are listed in Table 5-91.
Table 5-91 OraclePermission Static Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Table 5-92 OraclePermission Public Properties
Inherited from
The OraclePermission public methods are listed in Table 5-93.
Table 5-93 OraclePermission Public Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
This method adds a new connection string fragment and a list of restricted keywords to the OraclePermission object.
Declaration
// C# public void Add(string connStr, string keyRestrict, KeyRestrictionBehavior behavior);
Parameters
connStr
The connection string fragment.
keyRestrict
The key restrictions.
behavior
One of the following KeyRestrictionBehavior enumerations:
AllowOnly
PreventUsage
Exceptions
ArgumentException - The KeyRestrictionBehavior value or the format of the connStr or keyRestict string is invalid.
Remarks
The Add method configures the connection strings allowed or disallowed by the permission object.
Opening an OracleConnection is allowed or denied based upon the connection string fragment, key restrictions combination, and the key restriction behavior.
In the following example, KeyRestrictionBehavior.AllowOnly allows connection strings that use orcl as the Data Source with any User Id and Password combination but no other connection string keywords. Connection string keywords other than User Id and Password cause security exceptions.
orclPermission.Add("Data Source=orcl;","User Id=;Password=;",
KeyRestrictionBehavior.AllowOnly);
In the next example, KeyRestrictionBehavior.PreventUsage restricts connection strings that use the keyword Pooling. Use of the Pooling keyword causes an exception.
orclPermission.Add("Data Source=orcl;","Pooling=;",
KeyRestrictionBehavior.PreventUsage)
As a general rule, in an unrestricted environment, any connection string that is not allowed is restricted and throws a security exception.
If a connection string fragment contains key-value pairs for the password and proxy password attributes, then values for these attributes are ignored. However, the presence of the attributes themselves is still checked. This means that the connection is allowed only if the password and proxy attributes keywords are allowed in the connection string.
This method returns a copy of the current permission object.
Declaration
// C# public override IPermission Copy();
Return Value
A copy of the OraclePermission object.
This method returns a boolean value that indicates whether or not the current permission is a subset of the target permission.
Declaration
// C#
public override bool IsSubsetOf(IPermission target);
Parameters
target
A permission that must be of type OraclePermission.
Return Value
A bool value that indicates whether or not the current permission is a subset of the target permission.
Exceptions
ArgumentException - The permission is not of the OraclePermission type.
Remarks
The AllowBlankPassword property is ignored when evaluating whether or not the current permission is a subset of the target permission.
