Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleRowUpdatedEventArgs Class
The OracleRowUpdatedEventArgs class provides event data for the OracleDataAdapter.RowUpdated event.
Class Inheritance
System.Object
  System.EventArgs
    System.RowUpdatedEventArgs
      System.OracleRowUpdatedEventArgs
Declaration
// C#
public sealed class OracleRowUpdatedEventArgs : RowUpdatedEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatedEventArgs. See RowUpdated event "Example".
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleRowUpdatedEventArgs Members
OracleRowUpdatedEventArgs members are listed in the following tables.
OracleRowUpdatedEventArgs Constructors
OracleRowUpdatedEventArgs constructors are listed in Table 5-101.
Table 5-101 OracleRowUpdatedEventArgs Constructors
Constructor Description
Instantiates a new instance of OracleRowUpdatedEventArgs class
OracleRowUpdatedEventArgs Static Methods
The OracleRowUpdatedEventArgs static method is listed in Table 5-102.
Table 5-102 OracleRowUpdatedEventArgs Static Method
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleRowUpdatedEventArgs Properties
The OracleRowUpdatedEventArgs properties are listed in Table 5-103.
Table 5-103 OracleRowUpdatedEventArgs Properties
Property Description
Command
Specifies the OracleCommand that is used when OracleDataAdapter.Update() is called
Errors
Inherited from System.Data.Common.RowUpdatedEventArgs
RecordsAffected
Row
StatementType
Status
TableMapping
OracleRowUpdatedEventArgs Public Methods
The OracleRowUpdatedEventArgs properties are listed in Table 5-104.
Table 5-104 OracleRowUpdatedEventArgs Public Methods
Public Method Description
Equals
GetHashCode
GetType
ToString
The OracleRowUpdatedEventArgs constructor creates a new OracleRowUpdatedEventArgs instance.
Declaration
// C#
public OracleRowUpdatedEventArgs(DataRow row,IDbCommand command,
    StatementType statementType, DataTableMapping tableMapping);
Parameters
The OracleRowUpdatedEventArgs static method is listed in Table 5-105.
Table 5-105 OracleRowUpdatedEventArgs Static Method
Method Description
Equals
The OracleRowUpdatedEventArgs properties are listed in Table 5-106.
Table 5-106 OracleRowUpdatedEventArgs Properties
Command
Errors
RecordsAffected
Row
StatementType
Status
TableMapping
Command
This property specifies the OracleCommand that is used when OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatedEventArgs properties are listed in Table 5-107.
Table 5-107 OracleRowUpdatedEventArgs Public Methods
Equals
GetHashCode
GetType
ToString
