Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleRowUpdatingEventArgs Class
The OracleRowUpdatingEventArgs class provides event data for the OracleDataAdapter.RowUpdating event.
Class Inheritance
System.Object
  System.EventArgs
    System.RowUpdatingEventArgs
      System.OracleRowUpdatingEventArgs
Declaration
// C#
public sealed class OracleRowUpdatingEventArgs : RowUpdatingEventArgs
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The example for the RowUpdated event shows how to use OracleRowUpdatingEventArgs. See RowUpdated event "Example".
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleRowUpdatingEventArgs Members
OracleRowUpdatingEventArgs members are listed in the following tables.
OracleRowUpdatingEventArgs Constructors
OracleRowUpdatingEventArgs constructors are listed in Table 5-108.
Table 5-108 OracleRowUpdatingEventArgs Constructors
Constructor Description
Instantiates a new instance of OracleRowUpdatingEventArgs class (Overloaded)
OracleRowUpdatingEventArgs Static Methods
The OracleRowUpdatingEventArgs static methods are listed in Table 5-109.
Table 5-109 OracleRowUpdatingEventArgs Static Methods
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleRowUpdatingEventArgs Properties
The OracleRowUpdatingEventArgs properties are listed in Table 5-110.
Table 5-110 OracleRowUpdatingEventArgs Properties
Property Description
Command
Specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called
Errors
Inherited from System.Data.Common.RowUpdatingEventArgs
Row
StatementType
Status
TableMapping
OracleRowUpdatingEventArgs Public Methods
The OracleRowUpdatingEventArgs public methods are listed in Table 5-111.
Table 5-111 OracleRowUpdatingEventArgs Public Methods
Public Method Description
Equals
GetHashCode
GetType
ToString
The OracleRowUpdatingEventArgs constructor creates a new instance of the OracleRowUpdatingEventArgs class using the supplied data row, IDbCommand, type of SQL statement, and table mapping.
Declaration
// C#
public OracleRowUpdatingEventArgs(DataRow row, IDbCommand command,
    StatementType statementType, DataTableMapping tableMapping);
Parameters
The OracleRowUpdatingEventArgs static method is listed in Table 5-112.
Table 5-112 OracleRowUpdatingEventArgs Static Method
Method Description
Equals
The OracleRowUpdatingEventArgs properties are listed in Table 5-113.
Table 5-113 OracleRowUpdatingEventArgs Properties
Command
Errors
Row
StatementType
Status
TableMapping
Command
This property specifies the OracleCommand that is used when the OracleDataAdapter.Update() is called.
Declaration
// C#
public new OracleCommand Command {get; set;}
Property Value
The OracleCommand executed when Update is called.
The OracleRowUpdatingEventArgs public methods are listed in Table 5-114.
Table 5-114 OracleRowUpdatingEventArgs Public Methods
Equals
GetHashCode
GetType
ToString
