| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
The OracleRowUpdatingEventHandler delegate represents the signature of the method that handles the OracleDataAdapter.RowUpdating event.
Declaration
// C# public delegate void OracleRowUpdatingEventHandler (object sender, OracleRowUpdatingEventArgs eventArgs);
Parameters
sender
The source of the event.
eventArgs
The OracleRowUpdatingEventArgs object that contains the event data.
Remarks
Event callbacks can be registered through this event delegate for applications that wish to be notified after a row is updated.
In the .NET framework, the convention of an event delegate requires two parameters: the object that raises the event and the event data.
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
