Skip Headers
Oracle® Data Provider for .NET Developer's Guide
11g Release 1 (11.1.0.7.20)
E15167-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleTimeStampLTZ Structure
The OracleTimeStampLTZ structure represents the Oracle TIMESTAMP WITH LOCAL TIME ZONE data type to be stored in or retrieved from a database. Each OracleTimeStampLTZ stores the following information: year, month, day, hour, minute, second, and nanosecond.
Class Inheritance
System.Object
  System.ValueType
    Oracle.DataAccess.Types.OracleTimeStampLTZ
Declaration
// ADO.NET 2.0: C#
public struct OracleTimeStampLTZ : IComparable, INullable, IXmlSerializable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using Oracle.DataAccess.Types;
using Oracle.DataAccess.Client;
class OracleTimeStampLTZSample
  static void Main()
    // Illustrates usage of OracleTimeStampLTZ
    // Display Local Time Zone Name
    Console.WriteLine("Local Time Zone Name = " +
      OracleTimeStampLTZ.GetLocalTimeZoneName());
    OracleTimeStampLTZ tsLocal1 = OracleTimeStampLTZ.GetSysDate();
    OracleTimeStampLTZ tsLocal2 = DateTime.Now;
    // Calculate the difference between tsLocal1 and tsLocal2
    OracleIntervalDS idsDiff = tsLocal2.GetDaysBetween(tsLocal1);
    // Calculate the difference using AddNanoseconds()
    int nanoDiff = 0;
    while (tsLocal2 > tsLocal1)
      nanoDiff += 10;
      tsLocal1 = tsLocal1.AddNanoseconds(10);
    Console.WriteLine("idsDiff.Nanoseconds = " + idsDiff.Nanoseconds);
    Console.WriteLine("nanoDiff = " + nanoDiff);
Requirements
Namespace: Oracle.DataAccess.Types
Assembly: Oracle.DataAccess.dll
Microsoft .NET Framework Version: 2.0 or later
OracleTimeStampLTZ Members
OracleTimeStampLTZ members are listed in the following tables:
OracleTimeStampLTZ Constructors
OracleTimeStampLTZ constructors are listed in Table 14-100
Table 14-100 OracleTimeStampLTZConstructors
Constructor Description
Instantiates a new instance of OracleTimeStampLTZ structure (Overloaded)
OracleTimeStampLTZ Static Fields
The OracleTimeStampLTZ static fields are listed in Table 14-101.
Table 14-101 OracleTimeStampLTZ Static Fields
Field Description
MaxValue
Represents the maximum valid date for an OracleTimeStampLTZ structure, which is December 31, 9999 23:59:59.999999999
MinValue
Represents the minimum valid date for an OracleTimeStampLTZ structure, which is January 1, -4712 0:0:0
Null
Represents a null value that can be assigned to an instance of the OracleTimeStampLTZ structure
OracleTimeStampLTZ Static Methods
The OracleTimeStampLTZ static methods are listed in Table 14-102.
Table 14-102 OracleTimeStampLTZ Static Methods
Methods Description
Equals
Determines if two OracleTimeStampLTZ values are equal (Overloaded)
Gets the client's local time zone name
GetLocalTimeZoneOffset
Gets the client's local time zone offset relative to UTC
GetSysDate
Gets an OracleTimeStampLTZ structure that represents the current date and time
GreaterThan
Determines if the first of two OracleTimeStampLTZ values is greater than the second
GreaterThanOrEqual
Determines if the first of two OracleTimeStampLTZ values is greater than or equal to the second
LessThan
Determines if the first of two OracleTimeStampLTZ values is less than the second
LessThanOrEqual
Determines if the first of two OracleTimeStampLTZ values is less than or equal to the second
NotEquals
Determines if two OracleTimeStampLTZ values are not equal
Parse
Gets an OracleTimeStampLTZ structure and sets its value for date and time using the supplied string
SetPrecision
Returns a new instance of an OracleTimeStampLTZ with the specified fractional second precision
OracleTimeStampLTZ Static Operators
The OracleTimeStampLTZ static operators are listed in Table 14-103.
Table 14-103 OracleTimeStampLTZ Static Operators
Operator Description
operator+
Adds the supplied instance value to the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure (Overloaded)
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator -
Subtracts the supplied instance value from the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure (Overloaded)
OracleTimeStampLTZ Static Type Conversions
The OracleTimeStampLTZ static type conversions are listed in Table 14-104.
Table 14-104 OracleTimeStampLTZ Static Type Conversions
explicit operator OracleTimeStampLTZ
Converts an instance value to an OracleTimeStampLTZ structure (Overloaded)
implicit operator OracleTimeStampLTZ
explicit operator DateTime
Converts an OracleTimeStampLTZ value to a DateTime structure
OracleTimeStampLTZ Properties
The OracleTimeStampLTZ properties are listed in Table 14-105.
Table 14-105 OracleTimeStampLTZ Properties
Properties Description
BinData
Returns an array of bytes that represents an Oracle TIMESTAMP WITH LOCAL TIME ZONE in Oracle internal format
Day
Specifies the day component of an OracleTimeStampLTZ
IsNull
Indicates whether or not the OracleTimeStampLTZ instance has a null value
Hour
Specifies the hour component of an OracleTimeStampLTZ
Millisecond
Specifies the millisecond component of an OracleTimeStampLTZ
Minute
Specifies the minute component of an OracleTimeStampLTZ
Month
Specifies the month component of an OracleTimeStampLTZ
Nanosecond
Specifies the nanosecond component of an OracleTimeStampLTZ
Second
Specifies the second component of an OracleTimeStampLTZ
Value
Specifies the date and time that is stored in the OracleTimeStampLTZ structure
Year
Specifies the year component of an OracleTimeStampLTZ
OracleTimeStampLTZ Methods
The OracleTimeStampLTZ methods are listed in Table 14-106.
Table 14-106 OracleTimeStampLTZ Methods
Methods Description
AddDays
Adds the supplied number of days to the current instance
AddHours
Adds the supplied number of hours to the current instance
AddMilliseconds
Adds the supplied number of milliseconds to the current instance
AddMinutes
Adds the supplied number of minutes to the current instance
AddMonths
Adds the supplied number of months to the current instance
AddNanoseconds
Adds the supplied number of nanoseconds to the current instance
AddSeconds
Adds the supplied number of seconds to the current instance
AddYears
Adds the supplied number of years to the current instance
CompareTo
Compares the current OracleTimeStampLTZ instance to an object and returns an integer that represents their relative values
Equals
Determines whether or not an object has the same date and time as the current OracleTimeStampLTZ instance (Overloaded)
GetHashCode
Returns a hash code for the OracleTimeStampLTZ instance
GetDaysBetween
Subtracts an OracleTimeStampLTZ from the current instance and returns an OracleIntervalDS that represents the difference
GetYearsBetween
Subtracts an OracleTimeStampLTZ from the current instance and returns an OracleIntervalYM that represents the difference
GetType
Inherited from System.Object
ToOracleDate
Converts the current OracleTimeStampLTZ structure to an OracleDate structure
ToOracleTimeStamp
Converts the current OracleTimeStampLTZ structure to an OracleTimeStamp structure
ToOracleTimeStampTZ
Converts the current OracleTimeStampLTZ structure to an OracleTimeStampTZ structure
ToString
Converts the current OracleTimeStampLTZ structure to a string
ToUniversalTime
Converts the current local time to Coordinated Universal Time (UTC)
The OracleTimeStampLTZ constructors create new instances of the OracleTimeStampLTZ structure.
Overload List:
OracleTimeStampLTZ(DateTime)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date and time using the supplied DateTime value.
Declaration
// C#
public OracleTimeStampLTZ (DateTime dt);
Parameters
Exceptions
ArgumentException - The dt parameter cannot be used to construct a valid OracleTimeStampLTZ.
OracleTimeStampLTZ(string)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date and time using the supplied string.
Declaration
// C#
public OracleTimeStampLTZ(string tsStr);
Parameters
Exceptions
ArgumentException - The tsStr is an invalid string representation of an Oracle TIMESTAMP WITH LOCAL TIME ZONE or the supplied tsStr is not in the timestamp format specified by the OracleGlobalization.TimeStampFormat property of the thread, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
ArgumentNullException - The tsStr value is null.
Remarks
The names and abbreviations used for months and days are in the language specified by the DateLanguage and Calendar properties of the thread's OracleGlobalization object. If any of the thread's globalization properties are set to null or an empty string, the client computer's settings are used.
Example
// C#
using System;
  static void Main()
    // Set the nls_timestamp_format for the OracleTimeStampLTZ(string)
    // constructor
    OracleGlobalization info = OracleGlobalization.GetClientInfo();
    info.TimeStampFormat = "DD-MON-YYYY HH:MI:SS.FF AM";
    OracleGlobalization.SetThreadInfo(info);
    // construct OracleTimeStampLTZ from a string using the format
    // specified.
    OracleTimeStampLTZ ts =
      new OracleTimeStampLTZ("11-NOV-1999 11:02:33.444 AM");
    // Set the nls_timestamp_format for the ToString() method
    info.TimeStampFormat = "YYYY-MON-DD HH:MI:SS.FF AM";
    // Prints "1999-NOV-11 11:02:33.444000000 AM"
    Console.WriteLine(ts.ToString());
OracleTimeStampLTZ(int, int, int)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date using year, month, and day.
Declaration
// C#
public OracleTimeStampLTZ(int year, int month, int day);
Parameters
Exceptions
ArgumentOutOfRangeException - The argument value for one or more of the parameters is out of the specified range.
ArgumentException - The argument values of the parameters cannot be used to construct a valid OracleTimeStampLTZ (that is, the day is out of range for the month).
OracleTimeStampLTZ(int, int, int, int, int, int)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date and time using year, month, day, hour, minute, and second.
Declaration
// C#
public OracleTimeStampLTZ (int year, int month, int day, int hour,
  int minute, int second);
Parameters
Exceptions
OracleTimeStampLTZ(int, int, int, int, int, int, double)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date and time using year, month, day, hour, minute, second, and millisecond.
Declaration
// C#
public OracleTimeStampLTZ(int year, int month, int day, int hour, int minute, int second, double millisecond);
Parameters
Exceptions
OracleTimeStampLTZ(int, int, int, int, int, int, int)
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value for date and time using year, month, day, hour, minute, second, and nanosecond.
Declaration
// C#
  int minute, int second, int nanosecond);
Parameters
Exceptions
OracleTimeStampLTZ(byte [ ])
This constructor creates a new instance of the OracleTimeStampLTZ structure and sets its value to the provided byte array, which is in the internal Oracle TIMESTAMP WITH LOCAL TIME ZONE format.
Declaration
// C#
public OracleTimeStampLTZ (byte[] bytes);
Parameters
Exceptions
ArgumentException - bytes is not in an internal Oracle TIMESTAMP WITH LOCAL TIME ZONE format or bytes is not a valid Oracle TIMESTAMP WITH LOCAL TIME ZONE.
ArgumentNullException - bytes is null.
The OracleTimeStampLTZ static fields are listed in Table 14-107.
Table 14-107 OracleTimeStampLTZ Static Fields
Field Description
MaxValue
MinValue
Null
MaxValue
This static field represents the maximum valid date for an OracleTimeStampLTZ structure, which is December 31, 9999 23:59:59.999999999.
Declaration
// C#
public static readonly OracleTimeStampLTZ MaxValue;
Remarks
This value is the maximum date and time in the client time zone.
MinValue
This static field represents the minimum valid date for an OracleTimeStampLTZ structure, which is January 1, -4712 0:0:0.
Declaration
// C#
public static readonly OracleTimeStampLTZ MinValue;
Remarks
This value is the minimum date and time in the client time zone.
Null
This static field represents a null value that can be assigned to an instance of the OracleTimeStampLTZ structure.
Declaration
// C#
public static readonly OracleTimeStampLTZ Null;
The OracleTimeStampLTZ static methods are listed in Table 14-108.
Table 14-108 OracleTimeStampLTZ Static Methods
Methods Description
Equals
GetSysDate
GreaterThan
GreaterThanOrEqual
LessThan
LessThanOrEqual
NotEquals
Parse
SetPrecision
Equals
This static method determines if two OracleTimeStampLTZ values are equal.
Declaration
// C#
public static bool Equals(OracleTimeStampLTZ value1,
  OracleTimeStampLTZ value2);
Parameters
Return Value
Returns true if two OracleTimeStampLTZ values are equal. Returns false otherwise.
Remarks
The following rules apply to the behavior of this method.
This static method gets the client's local time zone name.
Declaration
// C#
public static string GetLocalTimeZoneName();
Return Value
A string containing the local time zone.
This static method gets the client's local time zone offset relative to Coordinated Universal Time (UTC).
Declaration
// C#
public static TimeSpan GetLocalTimeZoneOffset( );
Return Value
A TimeSpan structure containing the local time zone hours and time zone minutes.
GetSysDate
This static method gets an OracleTimeStampLTZ structure that represents the current date and time.
Declaration
// C#
public static OracleTimeStampLTZ GetSysDate();
Return Value
An OracleTimeStampLTZ structure that represents the current date and time.
GreaterThan
This static method determines if the first of two OracleTimeStampLTZ values is greater than the second.
Declaration
// C#
public static bool GreaterThan(OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStampLTZ values is greater than the second; otherwise, returns false.
Remarks
GreaterThanOrEqual
This static method determines if the first of two OracleTimeStampLTZ values is greater than or equal to the second.
Declaration
// C#
public static bool GreaterThanOrEqual(OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStampLTZ values is greater than or equal to the second; otherwise, returns false.
Remarks
LessThan
This static method determines if the first of two OracleTimeStampLTZ values is less than the second.
Declaration
// C#
public static bool LessThan(OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStampLTZ values is less than the second. Returns false otherwise.
Remarks
LessThanOrEqual
This static method determines if the first of two OracleTimeStampLTZ values is less than or equal to the second.
Declaration
// C#
public static bool LessThanOrEqual(OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first of two OracleTimeStampLTZ values is less than or equal to the second. Returns false otherwise.
Remarks
NotEquals
This static method determines if two OracleTimeStampLTZ values are not equal.
Declaration
// C#
public static bool NotEquals(OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if two OracleTimeStampLTZ values are not equal. Returns false otherwise.
Remarks
Parse
This static method creates an OracleTimeStampLTZ structure and sets its value using the supplied string.
Declaration
// C#
public static OracleTimeStampLTZ Parse(string tsStr);
Parameters
Return Value
An OracleTimeStampLTZ structure.
Exceptions
ArgumentException - The tsStr parameter is an invalid string representation of an Oracle TIMESTAMP WITH LOCAL TIME ZONE or the tsStr is not in the timestamp format specified by the OracleGlobalization.TimeStampFormat property of the thread, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
Remarks
Example
// C#
using System;
class ParseSample
  static void Main()
    // Set the nls_timestamp_format for the Parse() method
    // construct OracleTimeStampLTZ from a string using the format specified.
      OracleTimeStampLTZ.Parse("11-NOV-1999 11:02:33.444 AM");
SetPrecision
This static method returns a new instance of an OracleTimeStampLTZ with the specified fractional second precision.
Declaration
// C#
public static OracleTimeStampLTZ SetPrecision(OracleTimeStampLTZ value1,
     int fracSecPrecision);
Parameters
Return Value
An OracleTimeStampLTZ structure with the specified fractional second precision
Exceptions
ArgumentOutOfRangeException - fracSecPrecision is out of the specified range.
Remarks
The value specified in the supplied fracSecPrecision parameter is used to perform a rounding off operation on the supplied OracleTimeStampLTZ value. Depending on this value, 0 or more trailing zeros are displayed in the string returned by ToString().
Example
The OracleTimeStampLTZ with a value of "December 31, 9999 23:59:59.99" results in the string "December 31, 9999 23:59:59.99000" when SetPrecision() is called with the fractional second precision set to 5.
The OracleTimeStampLTZ static operators are listed in Table 14-109.
Table 14-109 OracleTimeStampLTZ Static Operators
operator+
operator ==
operator >
operator >=
operator !=
operator <
operator <=
operator -
operator+
operator+ adds the supplied value to the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure.
Overload List:
operator + (OracleTimeStampLTZ, OracleIntervalDS)
This static operator adds the supplied OracleIntervalDS to the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure.
Declaration
// C#
public static operator +(OracleTimeStampLTZ value1,
  OracleIntervalDS value2);
Parameters
Return Value
An OracleTimeStampLTZ.
Remarks
If either parameter has a null value, the returned OracleTimeStampLTZ has a null value.
operator + (OracleTimeStampLTZ, OracleIntervalYM)
This static operator adds the supplied OracleIntervalYM to the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure.
Declaration
// C#
  OracleIntervalYM value2);
Parameters
Return Value
Remarks
operator + (OracleTimeStampLTZ, TimeSpan)
This static operator adds the supplied TimeSpan to the supplied OracleTimeStampLTZ and returns a new OracleTimeStampLTZ structure.
Declaration
// C#
public static operator +(OracleTimeStampLTZ value1, TimeSpan value2);
Parameters
Return Value
Remarks
If the OracleTimeStampLTZ instance has a null value, the returned OracleTimeStampLTZ has a null value.
operator ==
This static operator determines if two OracleTimeStampLTZ values are equal.
Declaration
// C#
public static bool operator == (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if they are the same; otherwise, returns false.
Remarks
operator >
This static operator determines if the first of two OracleTimeStampLTZ values is greater than the second.
Declaration
// C#
public static bool operator > (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first OracleTimeStampLTZ value is greater than the second; otherwise, returns false.
Remarks
operator >=
This static operator determines if the first of two OracleTimeStampLTZ values is greater than or equal to the second.
Declaration
// C#
public static bool operator >= (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first OracleTimeStampLTZ is greater than or equal to the second; otherwise, returns false.
Remarks
operator !=
This static operator determines if two OracleTimeStampLTZ values are not equal.
Declaration
// C#
public static bool operator != (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if two OracleTimeStampLTZ values are not equal; otherwise returns false.
Remarks
operator <
This static operator determines if the first of two OracleTimeStampLTZ values is less than the second.
Declaration
// C#
public static bool operator < (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first OracleTimeStampLTZ is less than the second; otherwise, returns false.
Remarks
operator <=
This static operator determines if the first of two OracleTimeStampLTZ values is less than or equal to the second.
Declaration
// C#
public static bool operator <= (OracleTimeStampLTZ value1,
Parameters
Return Value
Returns true if the first OracleTimeStampLTZ is less than or equal to the second; otherwise, returns false.
Remarks
operator -
operator- subtracts the supplied value, from the supplied OracleTimeStampLTZ value, and returns a new OracleTimeStampLTZ structure.
Overload List:
operator - (OracleTimeStampLTZ, OracleIntervalDS)
This static operator subtracts the supplied OracleIntervalDS value, from the supplied OracleTimeStampLTZ value, and return a new OracleTimeStampLTZ structure.
Declaration
// C#
public static operator - (OracleTimeStampLTZ value1,
Parameters
Return Value
Remarks
operator - (OracleTimeStampLTZ, OracleIntervalYM)
This static operator subtracts the supplied OracleIntervalYM value, from the supplied OracleTimeStampLTZ value, and returns a new OracleTimeStampLTZ structure.
Declaration
// C#
Parameters
Return Value
Remarks
operator - (OracleTimeStampLTZ, TimeSpan)
This static operator subtracts the supplied TimeSpan value, from the supplied OracleTimeStampLTZ value, and returns a new OracleTimeStampLTZ structure.
Declaration
// C#
public static operator -(OracleTimeStampLTZ value1, TimeSpan value2);
Parameters
Return Value
Remarks
If the OracleTimeStampLTZ instance has a null value, the returned OracleTimeStampLTZ structure has a null value.
The OracleTimeStampLTZ static type conversions are listed in Table 14-110.
Table 14-110 OracleTimeStampLTZ Static Type Conversions
explicit operator OracleTimeStampLTZ converts the supplied value to an OracleTimeStampLTZ structure.
Overload List:
explicit operator OracleTimeStampLTZ(OracleTimeStamp)
This static type conversion operator converts an OracleTimeStamp value to an OracleTimeStampLTZ structure.
Declaration
// C#
public static explicit operator OracleTimeStampLTZ (OracleTimeStamp value1);
Parameters
Return Value
The OracleTimeStampLTZ structure contains the date and time of the OracleTimeStampTZ structure.
Remarks
If the OracleTimeStamp structure has a null value, the returned OracleTimeStampLTZ structure also has a null value.
explicit operator OracleTimeStampLTZ(OracleTimeStampTZ)
This static type conversion operator converts an OracleTimeStampTZ value to an OracleTimeStampLTZ structure.
Declaration
// C#
  (OracleTimeStampTZ value1);
Parameters
Return Value
The OracleTimeStampLTZ structure contains the date and time in the OracleTimeStampTZ structure (which is normalized to the client local time zone).
Remarks
If the OracleTimeStampTZ structure has a null value, the returned OracleTimeStampLTZ structure also has a null value.
explicit operator OracleTimeStampLTZ(string)
This static type conversion operator converts the supplied string to an OracleTimeStampLTZ structure.
Declaration
// C#
public static explicit operator OracleTimeStampLTZ (string tsStr);
Parameters
Return Value
A OracleTimeStampLTZ.
Exceptions
ArgumentException - ThetsStr parameter is an invalid string representation of an Oracle TIMESTAMP WITH LOCAL TIME ZONE or the tsStr is not in the timestamp format specified by the thread's OracleGlobalization.TimeStampFormat property, which represents the Oracle NLS_TIMESTAMP_FORMAT parameter.
Remarks
Example
// C#
using System;
  static void Main()
    // constructor
implicit operator OracleTimeStampLTZ converts the supplied structure to an OracleTimeStampLTZ structure.
Overload List:
implicit operator OracleTimeStampLTZ(OracleDate)
This static type conversion operator converts an OracleDate value to an OracleTimeStampLTZ structure.
Declaration
// C#
public static implicit operator OracleTimeStampLTZ(OracleDate value1);
Parameters
Return Value
The returned OracleTimeStampLTZ structure contains the date and time in the OracleDate structure.
Remarks
If the OracleDate structure has a null value, the returned OracleTimeStampLTZ structure also has a null value.
implicit operator OracleTimeStampLTZ(DateTime)
This static type conversion operator converts a DateTime structure to an OracleTimeStampLTZ structure.
Declaration
// C#
public static implicit operator OracleTimeStampLTZ(DateTime value1);
Parameters
Return Value
This static type conversion operator converts an OracleTimeStampLTZ value to a DateTime structure.
Declaration
// C#
public static explicit operator DateTime(OracleTimeStampLTZ value1);
Parameters
Return Value
A DateTime that contains the date and time in the current instance.
Exceptions
OracleNullValueException - The OracleTimeStampLTZ structure has a null value.
Remarks
The precision of the OracleTimeStampLTZ value can be lost during the conversion.
The OracleTimeStampLTZ properties are listed in Table 14-111.
Table 14-111 OracleTimeStampLTZ Properties
BinData
Day
IsNull
Hour
Millisecond
Minute
Month
Nanosecond
Second
Value
Year
BinData
This property returns an array of bytes that represents an Oracle TIMESTAMP WITH LOCAL TIME ZONE in Oracle internal format.
Declaration
// C#
public byte[] BinData {get;}
Property Value
A byte array that represents an Oracle TIMESTAMP WITH LOCAL TIME ZONE internal format.
Exceptions
OracleNullValueException - The current instance has a null value.
Day
This property specifies the day component of an OracleTimeStampLTZ.
Declaration
// C#
public int Day{get;}
Property Value
A number that represents the day. Range of Day is (1 to 31).
Exceptions
IsNull
This property indicates whether or not the current instance has a null value.
Declaration
// C#
public bool IsNull{get;}
Property Value
Returns true if the current instance contains a null value; otherwise, returns false.
Hour
This property specifies the hour component of an OracleTimeStampLTZ.
Declaration
// C#
public int Hour{get;}
Property Value
A number that represents the hour. Range of Hour is (0 to 23).
Exceptions
Millisecond
This property gets the millisecond component of an OracleTimeStampLTZ.
Declaration
// C#
public double Millisecond{get;}
Property Value
A number that represents a millisecond. Range of Millisecond is (0 to 999.999999)
Exceptions
Minute
This property gets the minute component of an OracleTimeStampLTZ.
Declaration
// C#
public int Minute{get;}
Property Value
A number that represent a minute. Range of Minute is (0 to 59).
Exceptions
Month
This property gets the month component of an OracleTimeStampLTZ.
Declaration
// C#
public int Month{get;}
Property Value
A number that represents a month. Range of Month is (1 to 12).
Exceptions
Nanosecond
This property gets the nanosecond component of an OracleTimeStampLTZ.
Declaration
// C#
public int Nanosecond{get;}
Property Value
A number that represents a nanosecond. Range of Nanosecond is (0 to 999999999).
Exceptions
Second
This property gets the second component of an OracleTimeStampLTZ.
Declaration
// C#
public int Second{get;}
Property Value
A number that represents a second. Range of Second is (0 to 59).
Exceptions
Value
This property specifies the date and time that is stored in the OracleTimeStampLTZ structure.
Declaration
// C#
public DateTime Value{get;}
Property Value
A DateTime.
Exceptions
Year
This property gets the year component of an OracleTimeStampLTZ.
Declaration
// C#
public int Year{get;}
Property Value
A number that represents a year. The range of Year is (-4712 to 9999).
Exceptions
The OracleTimeStampLTZ methods are listed in Table 14-112.
Table 14-112 OracleTimeStampLTZ Methods
Methods Description
AddDays
AddHours
AddMilliseconds
AddMinutes
AddMonths
AddNanoseconds
AddSeconds
AddYears
CompareTo
Equals
GetHashCode
GetDaysBetween
GetYearsBetween
GetType
ToOracleDate
ToOracleTimeStamp
ToOracleTimeStampTZ
ToString
ToUniversalTime
AddDays
This method adds the supplied number of days to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddDays(double days);
Parameters
Return Value
Exceptions
ArgumentOutofRangeException - The argument value is out of the specified range.
AddHours
This method adds the supplied number of hours to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddHours(double hours);
Parameters
Return Value
Exceptions
AddMilliseconds
This method adds the supplied number of milliseconds to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddMilliseconds(double milliseconds);
Parameters
Return Value
Exceptions
AddMinutes
This method adds the supplied number of minutes to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddMinutes(double minutes);
Parameters
Return Value
Exceptions
AddMonths
This method adds the supplied number of months to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddMonths(long months);
Parameters
Return Value
Exceptions
AddNanoseconds
This method adds the supplied number of nanoseconds to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddNanoseconds(long nanoseconds);
Parameters
Return Value
Exceptions
AddSeconds
This method adds the supplied number of seconds to the current instance.
Declaration
// C#
public OracleTimeStampLTZ AddSeconds(double seconds);
Parameters
Return Value
Exceptions
AddYears
This method adds the supplied number of years to the current instance
Declaration
// C#
public OracleTimeStampLTZ AddYears(int years);
Parameters
Return Value
Exceptions
CompareTo
This method compares the current OracleTimeStampLTZ instance to an object, and returns an integer that represents their relative values.
Declaration
// C#
public int CompareTo(object obj);
Parameters
Return Value
The method returns a number that is:
Implements
IComparable
Exceptions
ArgumentException - The obj parameter is not of type OracleTimeStampLTZ.
Remarks
Equals
Overrides Object
This method determines whether or not an object has the same date and time as the current OracleTimeStampLTZ instance.
Declaration
// C#
public override bool Equals(object obj);
Parameters
Return Value
Returns true if the obj is of type OracleTimeStampLTZ and represents the same date and time; otherwise, returns false.
Remarks
GetHashCode
Overrides Object
This method returns a hash code for the OracleTimeStampLTZ instance.
Declaration
// C#
public override int GetHashCode();
Return Value
A number that represents the hash code.
GetDaysBetween
This method subtracts an OracleTimeStampLTZ value from the current instance and returns an OracleIntervalDS that represents the difference.
Declaration
// C#
public OracleIntervalDS GetDaysBetween(OracleTimeStampLTZ value1);
Parameters
Return Value
An OracleIntervalDS that represents the interval between two OracleTimeStampLTZ values.
Remarks
If either the current instance or the parameter has a null value, the returned OracleIntervalDS has a null value.
GetYearsBetween
This method subtracts an OracleTimeStampLTZ value from the current instance and returns an OracleIntervalYM that represents the time interval.
Declaration
// C#
public OracleIntervalYM GetYearsBetween(OracleTimeStampLTZ value1);
Parameters
Return Value
An OracleIntervalYM that represents the interval between two OracleTimeStampLTZ values.
Remarks
If either the current instance or the parameter has a null value, the returned OracleIntervalYM has a null value.
ToOracleDate
This method converts the current OracleTimeStampLTZ structure to an OracleDate structure.
Declaration
// C#
public OracleDate ToOracleDate();
Return Value
The returned OracleDate structure contains the date and time in the current instance.
Remarks
If the current instance has a null value, the value of the returned OracleDate structure has a null value.
ToOracleTimeStamp
This method converts the current OracleTimeStampLTZ structure to an OracleTimeStamp structure.
Declaration
// C#
public OracleTimeStamp ToOracleTimeStamp();
Return Value
The returned OracleTimeStamp contains the date and time in the current instance.
Remarks
If the current instance has a null value, the value of the returned OracleTimeStamp structure has a null value.
ToOracleTimeStampTZ
This method converts the current OracleTimeStampLTZ structure to an OracleTimeStampTZ structure.
Declaration
// C#
public OracleTimeStampTZ ToOracleTimeStampTZ();
Return Value
The returned OracleTimeStampTZ contains the date and time of the current instance, with the time zone set to the OracleGlobalization.TimeZone from the thread.
Remarks
If the current instance has a null value, the value of the returned OracleTimeStampTZ structure has a null value.
ToString
Overrides Object
This method converts the current OracleTimeStampLTZ structure to a string.
Declaration
// C#
public override string ToString();
Return Value
A string that represents the same date and time as the current OracleTimeStampLTZ structure.
Remarks
The returned value is a string representation of the OracleTimeStampLTZ in the format specified by the OracleGlobalization.TimeStampFormat property of the thread.
Example
// C#
using System;
class ToStringSample
  static void Main()
    // constructor
    // specified.
ToUniversalTime
This method converts the current local time to Coordinated Universal Time (UTC).
Declaration
// C#
public OracleTimeStampTZ ToUniversalTime();
Return Value
An OracleTimeStampTZ structure.
Remarks
