| Oracle® Data Provider for .NET Developer's Guide 11g Release 1 (11.1.0.7.20) E15167-01 |
![]() Previous |
![]() Next |
The OracleXmlCommandType enumeration specifies the values that are allowed for the XmlCommandType property of the OracleCommand class. It is used to specify the type of XML operation.
Table 6-1 lists all the OracleXmlCommandType enumeration values with a description of each enumerated value.
Table 6-1 OracleXmlCommandType Members
| Member Name | Description |
No XML operation is desired |
The command text is a SQL query and the result of the query is an XML document. The SQL query needs to be a select statement |
The command text is an XML document containing rows to insert. |
The command text is an XML document containing rows to update. |
The command text is an XML document containing rows to delete. |
