| Oracle® Enterprise Manager Cloud Control Basic Installation Guide 12c Release 1 (12.1.0.1) E22624-12 |
![]() Previous |
![]() Next |
This chapter describes what property files and the command locations within them you need to validate before installing a standalone Oracle Management Agent (Management Agent). In particular, this chapter covers the following:
Every time you install a Management Agent, the property files mentioned in the platformInfo.properties file are loaded with default locations to commands that are required for successfully running certain Application Programming Interfaces (APIs). For example, the ping executable. This section describes such property files. In particular, this section covers the following:
Table B-1 describes the property files loaded from the platformInfo.properties file.
Table B-1 Property Files Loaded from platformInfo.properties File
| Loading Order | Property File Name | Type | Description |
1 |
Generic |
Contains arguments that need to be passed every time the commands listed in this file are run. |
2 |
Generic |
Contains paths for all the commands that need to be run, regardless of the operating system. |
3 |
Operating System-Specific |
Contains commands that need to be run for a particular operating system. For example, On Microsoft Windows, the path to the Cygwin binaries is hardcoded in the ssPaths_msplats.properties file. If you install Cygwin in a location other than c:\cygwin (default location), it can cause the Management Agent installation to fail. To resolve this issue, you must either install Cygwin in the default directory (c:\cygwin), or update this properties file with the correct path to the Cygwin binaries. |
4 |
Generic |
Contains variables that are used to specify the command paths. You must uncomment the variables that you want to use and specify appropriate values. |
Keep in mind the following points:
The property files mentioned in the platformInfo.properties file are loaded one-by-one in ascending order. This means that command locations you specify in the last file that is loaded will override the values you specified for the same key in the previously loaded property file.
For example, spaths.properties is loaded before ssPaths.properties. So if the default location for the ping executable in sPaths.properties file is usr/bin/ping, and if location for the same executable in the ssPaths.properties file is usr/sbin/ping, then the value in the latter file takes precedence over the former file.
If you want to include other command variables, then you can do one of the following:
Specify the additional command variables in sPaths.properties, ssPaths_<platform>.properties, or userPaths.properties.
Create a new property file with additional command variables. Then, mention the name of this new property file in platforminfo.properties.
Table B-2 describes the other property files that are loaded.
Table B-2 Other Property Files Loaded
Generic |
Contains properties that help you control the activity and performance of the application. For example, these:
Generic |
If there are error messages displayed in the error stream that you know can be ignored in the setup, then you can update these messages in the Generally, if the error stream contains data when you run any command, then it is assumed that the command failed. However, the data in the error stream may not always correspond to the error. So, to ignore such error messages, you must add the messages (including the banner) to the For example, when you run Administrator. It usually boils down to these two things:#1) Respect the privacy of others.#2) Think before you type.Password: This essentially is just a warning and does not constitute the failure of the executed command. |
Note: The data format for these files mandates only one property per line. You must specify the property values in the format:variable=value. |
The default command locations specified in the property files can vary between hosts and operating systems. Therefore, it is important to verify the command locations before you install a Management Agent.
To validate the command locations, follow these steps:
Access the platformInfo.properties file from the following location of the OMS home, and make note of the property files you need to validate for your platform:
$<OMS_HOME>/oui/prov/resources
Access each of the property files you noted in Step (1), and verify that the command locations mentioned for the following variables map to valid locations on the OMS host:
SSH_PATH
SCP_PATH
SH_PATH
PING_PATH
Access each of the property files you noted in Step (1), and verify that the command locations mentioned for the following variables also map to valid locations on the destination host:
SCP_PATH
SH_PATH
SSH_PATH
CHMOD_PATH
MKDIR_PATH
RM_PATH
