| Oracle® Enterprise Manager Cloud Control Basic Installation Guide 12c Release 1 (12.1.0.1) E22624-12 |
![]() Previous |
![]() Next |
This chapter describes how you can install a new Enterprise Manager system while utilizing an existing, certified Oracle Database to store Oracle Management Repository (Management Repository). In particular, this chapter covers the following:
You can install Enterprise Manager Cloud Control with either simple or advanced configuration.
As part of a new Enterprise Manager system, the installation wizard does the following:
Installs the following components in the middleware home you enter in the installation wizard:
Oracle Management Service 12c Release 1 (12.1.0.1)
Oracle Management Agent 12c Release 1 (12.1.0.1)
Oracle JRF 11g Release (11.1.1.4.0), which includes oracle_common directory
Oracle Web Tier 11g Release (11.1.1.4.0), which includes Oracle_WT directory
Oracle Database Management Plug-In
Oracle Fusion Middleware Management Plug-In
Oracle My Oracle Support Management Plug-In
Oracle Exadata Management Plug-In
Creates an Oracle WebLogic domain called GCDomain. For this WebLogic Domain, a default user account, weblogic, is used as the administrative user. You can choose to change this, if you want, in the installer.
Creates a Node Manager user account called nodemanager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
Configures an Oracle Management Service Instance Base location (gc_inst) in the Oracle Middleware Home (middleware home), for storing all configuration details related to Oracle Management Service 12c. You can choose to change this, if you want, in the installer.
For example, if the middleware home is /u01/app/Oracle/Middleware/, then the instance base location is /u01/app/Oracle/Middleware/gc_inst. You can choose to change this, if you want, in the installer. However, you can change it for only advanced installation and not for simple installation.
Configures Oracle Management Repository in the existing, certified Oracle Database.
Runs the following configuration assistants to configure the installed or upgraded components:
Plugins Prerequisites Check
Repository Configuration Assistant
MDS Schema Configuration Assistant
OMS Configuration Assistant
Plugins Deployment and Configuration Assistant
Start Oracle Management Service Configuration Assistant
Plugins Inventory Migration Configuration Assistant
Oracle Configuration Manager Repeater Configuration Assistant
Oracle Configuration Manager for OMS Configuration Assistant
Agent Configuration Assistant
By default, the following are the contents of the middleware home for this type of installation:
<middleware_home>
|_____wlserver_10.3
|_____jdk16
|_____oms
|_____plugins
|_____oracle.sysman.db.oms.plugin_12.1.0.1.0
|_____oracle.sysman.emas.oms.plugin_12.1.0.1.0
|_____oracle.sysman.mos.oms.plugin_12.1.0.1.0
|_____agent
|_____plugins
|_____oracle.sysman.db.agent.plugin_12.1.0.1.0
|_____oracle.sysman.db.discovery.plugin_12.1.0.1.0
|_____oracle.sysman.emas.agent.plugin_12.1.0.1.0
|_____oracle.sysman.emas.discovery.plugin_12.1.0.1.0
|_____core
|_____12.1.0.1.0
|_____agent_inst
|_____sbin
|_____agentimage.properties
|_____gc_inst
|_____Oracle_WT
|_____oracle_common
|_____utils
|_____logs
|_____modules
|_____user_project
|_____ocm.rsp
|_____registry.dat
|_____domain-registry.xml
|_____registry.xml
Before you begin, keep these points in mind:
You must ensure that you have the latest Enterprise Manager Cloud Control software:
Ensure that you have the Enterprise Manager Cloud Control software for Linux x86 and Linux x86-64 released in February 2012 - Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1) (With Bundle Patch 1). You can download it from the following URL:
http://www.oracle.com/technetwork/oem/enterprise-manager/downloads/index.html
Refer to the BP1 Workbook from My Oracle Support Note 1393173.1 on BP1 patch application instructions for different platforms and use cases.
Get the software by following the section "Procuring Software" from the Enterprise Manager Cloud Control Advanced Installation and Configuration Guide:
http://docs.oracle.com/cd/E24628_01/install.121/e24089/getstrtd_proc_sw.htm#BACFDBCA
Ensure that there are no white spaces in the name of the directory where you download and run the Enterprise Manager Cloud Control software from. For example, do not download and run the software from a directory titled Program Files because there is a white space between the two words of the directory name.
You can install Enterprise Manager Cloud Control using the installation wizard only on a single host, that is, locally on the server where the wizard is invoked. You cannot install on multiple or remote hosts.
To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
Enterprise Manager Cloud Control can communicate only with Oracle Management Agent 12c and not with any earlier release of the Management Agent.
Do not install on a symlink. If you do, then you will not be able to clone this OMS later.
While installing on hosts that have multiple host names (for example, virtual hosts), you can pass the fully qualified host name using the ORACLE_HOSTNAME argument. Ensure that the host name you enter does not have underscores.
For example:
./runInstaller ORACLE_HOSTNAME=example.com
You must not set the ORACLE_HOME and ORACLE_SID environment variables. You must ensure that the Oracle directories do NOT appear in the PATH.
You must set the DISPLAY environment variable.
In bash terminal, run the following command:
export DISPLAY=<hostname>:<vnc port>.0
For example, export DISPLAY=example.com:1.0
In other terminals, run the following command:
setenv DISPLAY <hostname>:1.0
For example, setenv DISPLAY example.com:1.0
The Enterprise Manager Cloud Control Installation Wizard installs Java Development Kit (JDK) 1.6 v24 and Oracle WebLogic Server 11g Release 1 (10.3.5) only if they do not exist in your environment.
If Oracle WebLogic Server 11g Release 1 (10.3.5) does not exist and if you want to manually install it, then ensure that you install it using JDK 1.6 v24+ (64-bit version for 64-bit platforms and 32-bit version for 32-bit platforms).
Download JDK 1.6 v24+ for your platform from the platform vendor's Web site. For example, download SUN JDK 1.6 v24+ for Linux platforms from Oracle Web site. Similarly, download the JDK for other platforms from other vendors' trusted Web sites.
If you already have JDK, then verify its version by navigating to the <JDK_Location>/bin directory and running the following command:
"./java -fullversion"
To verify whether it is a 32-bit or a 64-bit JDK, run the following command:
"file *"
If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.5) on Linux 64-bit platforms, first install the 64-bit JDK for that platform, and then download and use the wls1035_generic.jar file to install Oracle WebLogic Server.
For example,
<JDK home>/bin/java -d64 -jar <absolute_path _to_wls1035_generic.jar>
If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.5) on Linux 32-bit platforms, then download and use either the wls1035_linux32.bin file or the wls1035_generic.jar file.
For example,
<JDK home>/bin/java -jar <absolute_path _to_wls1035_generic.jar>
You must download the Oracle WebLogic Server software from Oracle Web site, and follow the instructions outlined in the Oracle® Fusion Middleware Installation Guide for Oracle WebLogic Server to install it. The guide is available in the Fusion Middleware documentation library available at:
http://www.oracle.com/technetwork/middleware/weblogic/documentation/index.html
You must ensure that the Oracle WebLogic Server installation is a typical installation, and even if you choose to perform a custom installation, ensure that components chosen for custom installation are the same as the ones associated with a typical installation.
You must ensure that the user installing the WebLogic Server is the same as the one installing Enterprise Manager Cloud Control.
If you are installing Enterprise Manager Cloud Control in a middleware home that is on an NFS-mounted drive, then ensure that you maintain the lock file in a local file system and not in that NFS-mounted location. To do so, modify the lock file location in the httpd.conf file to map to a location on a local file system.
Stop the OMS:
<OMS_HOME>/bin/emctl stop oms -all
Open the following file:
Note: Oracle recommends you to take a backup of this file before editing it. |
<WEBTIER_INSTANCE_HOME>/config/OHS/ohs1/httpd.conf
Search for sections related to the modules mpm_prefork_module and mpm_worker_module. In both these sections, modify the value for the LockFile parameter so that the path leads to a location on the local file system.
<IfModule mpm_prefork_module> StartServers 5 MinSpareServers 5 MaxSpareServers 10 MaxClients 150 MaxRequestsPerChild 0 AcceptMutex fcntl LockFile "${ORACLE_INSTANCE}/diagnostics/logs/${COMPONENT_TYPE}/${COMPONENT_NAME}/http_lock" </IfModule> .... <IfModule mpm_worker_module> StartServers 2 MaxClients 150 MinSpareThreads 25 MaxSpareThreads 75 ThreadsPerChild 25 MaxRequestsPerChild 0 AcceptMutex fcntl LockFile "${ORACLE_INSTANCE}/diagnostics/logs/${COMPONENT_TYPE}/${COMPONENT_NAME}/http_lock" </IfModule>
Save the changes.
Restart the OMS:
<OMS_HOME>/bin/emctl start oms
You must ensure that the Oracle WebLogic Server 11g Release 1 (10.3.5) installed by the Enterprise Manager Cloud Control Installation Wizard or by you is dedicated for Enterprise Manager Cloud Control. You must not have any other Oracle Fusion Middleware product installed in that middleware home.
Enterprise Manager Cloud Control cannot coexist with any Oracle Fusion Middleware product in the same middleware home because the ORACLE_COMMON property is used by both the products.
Oracle offers bug fixes for a product based on the Oracle Lifetime Support Policy. When the license period expires for a particular product, the support for bug fixes offered by Oracle also ends. For more information, see the Oracle Lifetime Support Policy available at:
http://www.oracle.com/support/library/brochure/lifetime-support-technology.pdf
When determining supportability and certification combinations for an Enterprise Manager Cloud Control installation, you must consider Enterprise Manager Cloud Control's framework components as well as the targets monitored by Enterprise Manager Cloud Control. Oracle recommends keeping your Cloud Control components and targets updated to the latest certified versions in order to receive code fixes without having to purchase an Extended Support license.
You must upgrade all existing EMCLI clients of the earlier release to 12c Release 1 so that they can work with Enterprise Manager Cloud Control. This means, you must discard the old one and set up a new one.
For information about setting up a new EMCLI client, see the Enterprise Manager Command Line Interface Download page within the Cloud Control console. To access that page, in Cloud Control, from the Setup menu, select My Preferences, and then, click Command Line Interface.
In addition to the mandatory plug-ins listed above, you can optionally install other plug-ins available in the software kit (DVD, downloaded software). The installer offers a screen where you can select the optional plug-ins and install them. However, if you want to install some plug-ins that are not available in the software kit (DVD, downloaded software), then refer to Advanced Installer Options.
You can find the OMS and Management Agent entries in the /etc/oragchomelist file for all UNIX platforms except HPUNIX, HPia64, Solaris Sparc.
On HPUNIX, HPia64, Solaris Sparc platforms, the entries are present in /var/opt/oracle/oragchomelist.
As a prerequisite, you must have an existing Oracle Database to configure the Management Repository. This database can also have the Automatic Memory Management (AMM) feature enabled.
Table 6-1 lists the prerequisites you must meet before installing Enterprise Manager Cloud Control.
Table 6-1 Prerequisites for Installing Enterprise Manager Cloud Control
| Requirement | Description |
Hardware Requirements |
Ensure that you meet the hard disk space and physical memory requirements as described in Chapter 2. |
Operating System Requirements |
Ensure that you install Enterprise Manager Cloud Control only on certified operating systems as mentioned in the Enterprise Manager Certification Matrix available on My Oracle Support. To access this matrix, follow these steps:
Note: If you use Oracle Solaris 10, then ensure that you have update 9 or higher installed. To verify whether it is installed, run the following command:
You should see the output similar to the following. Here,
Package Requirements |
Ensure that you install all the operating system-specific packages as described in Chapter 2. |
Operating System Groups and Users Requirements |
Ensure that you create the required operating system groups and users as described in Chapter 4. |
Unique Host Name and Static IP Address Requirements |
Ensure that you check the network configuration to verify that the host on which you are installing resolves to a unique host name and a static IP address that are visible to other hosts in the network. Note: You must use only a static IP address. If you use a dynamic IP address, the installation will fail. |
Ensure that you allocate 400 MB of space for a temporary directory where the executables can be copied. By default, the temporary directory location set to the environment variable |
Ensure that you allocate 100 MB of space for the central inventory directory. Also ensure that the central inventory directory is not on a shared file system. If it is already on a shared file system, then switch over to a non-shared file system by following the instructions outlined in My Oracle Support note 1092645.1. |
Ensure that you set the default file mode creation mask (umask) to 022 in the shell startup file. For example:
Unset the |
File Descriptor Requirements |
Ensure that you set the file descriptor to a minimum of 4096. To verify the current value set to the file descriptors, run the following command:
If the current value is not 4096 or greater, then as a root user, update the
Ensure that the existing database is a certified database as mentioned in the Enterprise Manager Certification Matrix available on My Oracle Support. Ensure that this database is dedicated to Enterprise Manager. To access this matrix, follow these steps:
Important:
Ensure that the host name specified in the The following is the recommended format of the
For example,
According to RFC 952, the following are the assumptions: A name (Net, Host, Gateway, or Domain name) is a text string up to 24 characters drawn from the alphabet (A-Z), digits (0-9), minus sign (-), and period (.). Note that periods are only allowed when they serve to delimit components of domain style names. No blank or space characters are permitted as part of a name. No distinction is made between upper and lower case. The first character must be an alpha character. Also, if DNS server is configured in your environment, then you should be able to use DNS to resolve the name of the host on which you want to install the OMS. For example, all these commands must return the same output:
Ensure that you meet the following requirements:
Ensure that the Central Inventory ( |
Proximity Requirements |
Ensure that the host on which the OMS is being installed and the host on which the Management Repository is being configured are located in close proximity to each other. Ideally, the round trip network latency between the two should be less than 1 millisecond. |
Ensure that the ports you assign (within the given range) to the following components are free and available:
To verify if a port is free, run the following command:
Internet Connection Requirements |
Oracle recommends that the host from where you are running the installer have a connection to the Internet so that the configuration information can be automatically collected and uploaded to My Oracle Support. |
This section describes the following:
To install Enterprise Manager Cloud Control with simple configuration, follow these steps:
Note: Oracle recommends you to run the EM Prerequisite Kit before invoking the installer to ensure that you meet all the repository requirements beforehand. This helps you set up your Management Repository beforehand without starting the installation or upgrade process. For information on the kit, to understand how to run it, and to know about the prerequisite checks it runs, see Appendix A. |
Invoke the Enterprise Manager Cloud Control Installation Wizard
Invoke the installation wizard as a user who belongs to the oinstall group you created following the instructions in Chapter 4.
<Software_Location>/runInstaller
In this command, <Software_Location> is either the DVD location or the location where you have downloaded the software kit.
Note: To invoke the installation wizard on UNIX platforms, runrunInstaller. To invoke on Microsoft Windows platforms, run setup.exe. |
Note: Ensure that there are no white spaces in the name of the directory where you download and run the Enterprise Manager Cloud Control software from. For example, do not download and run the software from a directory titledProgram Files because there is a white space between the two words of the directory name. |
Note: When you invokerunInstaller or setup.exe, if the Enterprise Manager Cloud Control Installation Wizard does not appear, then it is possible that you do not access to the /stage directory.
There is a classpath variable that the installation wizard computes for OPatch as |
Enter My Oracle Support Details
(Optional) On the My Oracle Support Details screen, enter your My Oracle Support credentials to enable Oracle Configuration Manager. If you do not want to enable Oracle Configuration Manager now, go to Step (3).
If the host from where you are running the installation wizard does not have a connection to the Internet, then enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support.
Click Next.
Install Software Updates
On the Software Updates screen, select one of the following sources from where the software updates can be installed while the installation of the Enterprise Manager system is in progress. If you do not want to apply them now, then select Skip.
(Recommended) Select Search for Updates, and then, select Local Directory if you have already manually downloaded the software updates to an accessible local or remote location. Enter the location where the updates are available, and click Search for Updates. To search the computer and select the location, click Browse. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch.
If the updates have been downloaded to the default location, then select or enter the full path to the scratch path location. For example, if the scratch path location is /scratch/OracleHomes and if the software updates are available in /scratch/OracleHomes/Updates, then enter /scratch/OracleHomes/Updates.
If the software updates have been downloaded to a custom location, then select or enter the full path to the custom location. For example, if the custom location is /home/john and if the software updates are available in /home/john/Updates, then enter /home/john/Updates.
Select Search for Updates, and then, select My Oracle Support if you want the installer to connect to My Oracle Support and automatically download the updates from there.
Enter the My Oracle Support account user name and password, and click Search for Updates. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch
Note: If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, log in to Enterprise Manager Cloud Control, and from the Setup menu, select My Oracle Support, and then, click Set Credentials. On the My Oracle Support Preferred Credentials page, enter the credentials and click Apply. |
Note: Despite providing the My Oracle Support credentials, if you are unable to download the software updates, then exit the installer, and invoke the installer again passing the-showProxy parameter in the following way:
Click Next.
If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on UNIX operating system, then the Oracle Inventory screen appears. For details, see step (6). Otherwise, the Check Prerequisites screen appears. For details, see step (8).
If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on Microsoft Windows operating system, then the Oracle Inventory screen does not appear. On Microsoft Windows, the following is the default inventory directory:
<system drive>\Program Files\Oracle\Inventory
Enter Oracle Inventory Details
On the Oracle Inventory screen, do the following. You will see this screen only if this turns out to be your first ever installation of an Oracle product on the host.
Enter the full path to a directory where the inventory files and directories can be placed.
Select the appropriate operating system group name that will own the Oracle inventory directories. The group that you select must have write permissions on the Oracle Inventory directories.
Click Next.
Check Prerequisites
On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful installation.
The installation wizard runs the prerequisite checks automatically when you come to this screen. It checks for the required operating system patches, operating system packages, and so on.
The status of the prerequisite check can be either Warning, Failed, or Succeeded.
If some checks result in Warning or Failed status, then investigate and correct the problems before you proceed with the installation. The screen provides details on why the prerequisites failed and how you can resolve them. After you correct the problems, return to this screen and click Rerun to check the prerequisites again.
Although Oracle recommends you to investigate and correct the problems, if you are compelled to proceed without resolving them, then select Ignore to ignore the warnings and failures.
However, all package requirements must be met or fixed before proceeding any further. Otherwise, the installation might fail.
Click Next.
Select Installation Type
On the Install Types screen, do the following:
Select Create a New Enterprise Manager System, and then, select Simple.
Validate or enter the middleware home where you want to install the OMS and other core components.
Click Next.
Enter Configuration Details
On the Configuration Details screen, do the following:
Enter an administrator password, which can be used as a common password for configuring the Enterprise Manager Cloud Control.
Note: Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value. |
The administrator password is used as a common password for SYSMAN user account, WebLogic user account, node manager user account, and also for authenticating new Oracle Management Agents that join the Enterprise Manager system.
Enter the fully qualified name of the host where the existing database resides, the database's listener port and its service name or system ID (SID), and the SYS user account's password.
Note: Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. Theservice_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide. |
The installer uses this information to connect to the existing, certified Oracle Database for creating the SYSMAN schema. SYSMAN schema holds most of the relational data used in managing Enterprise Manager Cloud Control.
Note: If any repository-related prerequisite check fails, see Appendix A to manually run the prerequisite check. |
Click Next.
Review and Install
On the Review screen, review the details you provided for the selected installation type.
If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
After you verify the details, if you are satisfied, click Install to begin the installation process.
On the Install Progress screen, view the overall progress (in percentage) of the installation and the status of each of the configuration assistants. Configuration assistants are run for configuring the installed components of Enterprise Manager Cloud Control.
Once the software binaries are copied and configured, you are prompted to run the allroot.sh script, and the oraInstRoot.sh script if this is the first Oracle product installation on the host. Open another window, log in as root, and manually run the scripts.
If you are installing on Microsoft Windows operating system, then you will NOT be prompted to run this script.
On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
For more information about this installation, refer to the following file in the OMS home:
$<OMS_HOME>/install/setupinfo.txt
Note: If the installation fails for some reason, review the log files available in the following locations of the OMS home:
To install Enterprise Manager Cloud Control with advanced configuration, follow these steps:
Note: For information about the additional, advanced options you can pass while invoking the installer, refer to Advanced Installer Options. To make yourself aware of some installation-related known issues, see Limitations. |
Click Next.
Note: If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, click Set MOS Credentials and register the credentials. |
Click Next.
Click Next.
Check Prerequisites
Note: You can choose to ignore the checks with Warning status by clicking Ignore. However, all package requirements must be met or fixed before proceeding any further. |
Click Next.
Select Create a New Enterprise Manager System, and then, select Advanced.
Click Next.
Select Plug-Ins
On the Select Plug-Ins screen, select the optional plug-ins you want to install from the software kit (DVD, downloaded software) while installing the Enterprise Manager system. The screen lists the mandatory plug-ins as well as the optional plug-ins. The grayed rows indicate the mandatory plug-ins that will be installed.
Note: During installation, if you want to install a plug-in that is not available in the software kit, then refer to Advanced Installer Options for the point that describes how you can install additional plug-ins. |
Click Next.
Enter WebLogic Server Configuration Details
On the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the Oracle Management Service instance base location.
By default, the WebLogic Domain name is GCDomain, and the Node Manager name is nodemanager. These are non-editable fields. The installer uses this information for creating Oracle WebLogic Domain and other associated components such as the admin server, the managed server, and the node manager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
Click Next.
Enter Database Connection Details
On the Database Connection Details screen, enter the fully qualified name of the host where your existing, certified Oracle Database resides, its listener port and its service name or system ID (SID), and the SYS user account's password.
Click Next.
Enter Repository Configuration Details
On the Repository Configuration Details screen, do the following:
For SYSMAN Password, enter a password for creating the SYSMAN user account. The SYSMAN user account is used for creating the SYSMAN schema, which holds most of the relational data used in managing Enterprise Manager Cloud Control. SYSMAN is also the super administrator for Enterprise Manager Cloud Control.
For Registration Password, enter a password for registering the new Management Agents that join the Enterprise Manager system.
For Management Tablespace, enter the full path to the location where the data file for management tablespace (mgmt.dbf) can be stored. The installer uses this information for storing data about the monitored targets, their metrics, and so on. Ensure that the specified path leads up to the file name.
For example, /u01/oracle/prod/oradata/mgmt.dbf
For Configuration Data Tablespace, enter the full path to the location where the data file for configuration data tablespace (mgmt_ecm_depot1.dbf) can be stored. This is required for storing configuration information collected from the monitored targets. Ensure that the specified path leads up to the file name.
For example, /u01/oracle/prod/oradata/mgmt_ecm_depot1.dbf
For JVM Diagnostics Data Tablespace, enter the full path to a location where the data file for JVM Diagnostics data tablespace (mgmt_ad4j.dbf) can be stored. Ensure that the specified path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
For example, /u01/oracle/prod/oradata/mgmt_ad4j.dbf
Note: If you are configuring the Management Repository on a database that uses Oracle Automatic Storage Management (Oracle ASM) for storage, then when you enter the data file location, only the disk group is used for creating the tablespaces. For example, if you specify+DATA/a.dbf, then only +DATA is used for creating the tablespaces on Oracle ASM, and the exact location of the data file on the disk group is decided by Oracle Managed Files. |
Click Next.
Customize Ports
On the Port Configuration Details screen, customize the ports to be used for various components.
Note: If all the ports on this screen appear as -1, then it indicates that the installer is unable to bind the ports on the host. To resolve this issue, exit the installer, verify the host name and the IP configuration of this host (ensure that the IP address of the host is not being used by another host), restart the installer, and try again. |
You can enter a free custom port that is either within or outside the port range recommended by Oracle.
On Unix:
netstat -anp | grep <port no>
On Microsoft Windows:
netstat -an|findstr <port_no>
However, the custom port must be greater than 1024 and lesser than 65535. Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
Note: If thestaticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed. |
Click Next.
Review and Install
On the Install Progress screen, view the overall progress (in percentage) of the installation and the status of each of the Configuration Assistants. Configuration Assistants are run for configuring the installed components of Enterprise Manager Cloud Control.
If you are installing on Microsoft Windows operating system, then you will NOT be prompted to run this script. You will directly reach the Finish screen as described in Step (25).
For more information about this installation, refer to the following file available in the OMS home:
The following are some additional, advanced options you can pass while invoking the installer:
By default, GCDomain is the default name used for creating the WebLogic Domain. To override this and use a custom WebLogic Domain name, invoke the installer with the WLS_DOMAIN_NAME option, and enter a unique custom name.
For example, if you want to use the custom name EMDomain, then run the following command:
./runInstaller WLS_DOMAIN_NAME=EMDomain
By default, a Provisioning Advisor Framework (PAF) staging directory is created for copying the Software Library entities related to the deployment procedures. By default, this location is the scratch path location (/tmp). The location is used only for provisioning activities—entities are copied for a deployment procedure, and then, deleted once the deployment procedure ends.
If you want to override this location with a custom location, then invoke the installer with the EM_STAGE_DIR option, and enter a unique custom location.
For example,
./runInstaller EM_STAGE_DIR=/home/john/software/oracle/pafdir
During installation, if you want to install some plug-ins that are not in the software kit (DVD, downloaded software), then follow these steps:
Manually download the plug-ins from the Enterprise Manager download page on OTN, and store them in an accessible location:
http://www.oracle.com/technetwork/oem/grid-control/downloads/oem-upgrade-console-502238.html
Invoke the installer with the following option, and pass the location where the plug-ins you want to install are available:
./runInstaller -pluginLocation <absolute_path_to_plugin_software_location>
This displays a list of plug-ins available in the software kit (DVD, downloaded software) as well as the plug-ins available in this custom location. You can choose the ones you want to install.
After the installation ends successfully, the OMS and the Management Agent start automatically. If you do not want them to start automatically, then invoke the installer with START_OMS and b_startAgent options, and set them to TRUE or FALSE depending on what you want to control.
For example, if you do not want the Management Agent to start automatically, then run the following command:
./runInstaller START_OMS=TRUE b_startAgent=FALSE
To understand the limitations involved with this advanced option, see Limitations.
While installing on hosts having multiple IP addresses, the host name is derived from the ORACLE_HOSTNAME variable that is passed while invoking the installer. Ensure that the host name you enter does not have underscores.
For example:
When you use START_OMS and b_startAgent as advanced options to control the way the OMS and the Management Agent start up automatically, sometimes the Management Agent and the host on which it was installed do not appear as targets in the Cloud Control console.
Table 6-2 lists the different combinations of these advanced options, and describes the workaround to be followed for each combination:
Table 6-2 Advanced Options and Workarounds
| Advanced Option | Workaround |
After you install, do the following:
(Only for UNIX Operating Systems) If you did not run the allroot.sh script when the installer prompted you to do so, then run them manually now:
If this is the first Oracle product you just installed on the host, then run the oraInstroot.sh script from the inventory location specified in the oraInst.loc file that is available in the Management Agent home.
For example, if the inventory location specified in the oraInst.loc file is $HOME/oraInventory, then run the following command:
$HOME/oraInventory/oraInstRoot.sh
Note: If you are not a root user, then use SUDO to change to a root user. For example, run the following command:
Run the allroot.sh script from the OMS home:
$<OMS_HOME>/allroot.sh
If the name of the host (including the domain name) where you installed the OMS is longer than 30 characters, then apply patch 13788861 on the <MIDDLEWARE_HOME>/oracle_common directory. To apply the patch, follow the instructions outlined in the patch ReadMe.
If you do not apply this patch, then all the Enterprise Manager jobs fail, and you will see an Java Object Cache (JOC) error similar to the following in the EMGC_OMS1-diagnostic.log file.
[2012-02-23T11:16:02.391-08:00] [EMGC_OMS1] [ERROR] [WSM-02311] [oracle.wsm.resources.policymanager] [tid: [ACTIVE].ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'] [userId: <anonymous>] [ecid: 19f969fe781e0dcb:-4eacfe4a:135ab778dad:-8000-0000000000000d12,0] [APP: emgc] Failed to retrieve requested documents due to underlying error "java.rmi.RemoteException: EJB Exception: ; nested exception is: [[ oracle.mds.exception.MDSRuntimeException: MDS-00001: exception in Metadata Services layer J2EE JOC-044 An exception is occurring in the method. CacheAccess.put J2EE JOC-039 cannot find region: "ADFApplication1/main_region"". ]] [2012-02-23T11:16:07.022-08:00] [EMGC_OMS1] [ERROR] [] [oracle.mds] [tid: [ACTIVE].ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'] [userId: OracleSystemUser] [ecid: 19f969fe781e0dcb:-4eacfe4a:135ab778dad:-8000-0000000000000d15,0] [APP: wsm-pm] [[ oracle.mds.exception.MDSRuntimeException: J2EE JOC-044 An exception is occurring in the method. CacheAccess.put J2EE JOC-039 cannot find region: "ADFApplication1/main_region" at oracle.mds.internal.cache.JOCCache.put(JOCCache.java:273) at oracle.mds.internal.cache.JOCCache.put(JOCCache.java:228) at oracle.mds.internal.cache.LayeredCache.getCacheAccess(LayeredCache.java:460) ...
This error occurs when web services are being called by the Enterprise Manager job subsystem, and when Oracle Web Service Manager (OWSM) is unable to access the web service security policy that is stored in the Metadata Services (MDS) repository. When the jobs fail, you will see that they are constantly in a scheduled or running state. Once the patch is applied, a simple test can be conducted by submitting a basic OS command job and ensuring that it completes successfully.
Navigate to the OMS home and run the following command to see a message that confirms that OMS is up and running.
$<OMS_HOME>/bin/emctl status oms
For example,
/u01/middleware/oms/bin/emctl status oms
Navigate to the Management Agent home and run the following command to see a message that confirms that the Management Agent is up and running.
$<AGENT_HOME>/bin/emctl status agent
Navigate to the Management Agent home and run the following command to see a message that confirms that EMD upload completed successfully.
$<AGENT_HOME>/bin/emctl upload agent
Note: By default, you can access Enterprise Manager Cloud Control only using the HTTPS protocol. If you want to use the HTTP protocol, then unlock it by running the following command from the OMS home:
Verify if all the plug-ins were installed successfully. To do so, access the following log file from the Management Agent home, and search for the sentence WARN:Plugin configuration has failed.
$<AGENT_HOME>/cfgtoollogs/cfgfw/CfmLogger-<timestamp>.log
For example,
$<MIDDLEWARE_HOME>/agent/core/12.1.0.1.0/cfgtoollogs/cfgfw/CfmLogger-<timestamp>.log
If you find the sentence, resolve the issue by running the AgentPluginDeploy.pl script from the Management Agent home.
$<MIDDLEWARE_HOME>/agent/core/12.1.0.1.0/perl/bin/perl <MIDDLEWARE_HOME>/agent/core/12.1.0.1.0/bin/AgentPluginDeploy.pl -oracleHome <MIDDLEWARE_HOME>/agent/core/12.1.0.1.0 -agentDir <AGENT_BASE_DIR> -pluginIdsInfoFile <AGENT_BASE_DIR>/plugins.txt -action configure -emStateDir <AGENT_INSTANCE_HOME>
For example,
/u01/app/Oracle/Middleware/agent/core/12.1.0.1.0/perl/bin/perl /u01/app/Oracle/Middleware/agent/core/12.1.0.1.0/bin/AgentPluginDeploy.pl -oracleHome /u01/app/Oracle/Middleware/agent/core/12.1.0.1.0/ -agentDir /u01/app/Oracle/Middleware/agent -pluginIdsInfoFile /u01/app/Oracle/Middleware/agent/core/12.1.0.1.0/sysman/install/plugins.txt -action configure -emStateDir /u01/app/Oracle/Middleware/agent/agent_inst
(Optional) If the repository prerequisites had failed, and if you had manually run the EM Prerequisite Kit and taken corrective actions to meet the repository requirements, then run the utility again to reset the repository settings to what it had originally:
/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -reposUser sysman -reposPassword <repo_user_password> -dbRole sysdba -runPrerequisites -runPostCorrectiveActions -useHistory
Note: If you had run the installation wizard and let the installation wizard take corrective actions to correct the repository settings, and if you had exited the wizard without completing the installation process, then remember that the repository settings might not reset to their original values because you abruptly ended the installation. In this case, before invoking the installation wizard again, run this command to manually reset the values. |
By default, the following targets get automatically discovered and monitored in the Enterprise Manager Cloud Control console:
Oracle WebLogic Domain (for example, GCDomain)
Oracle WebLogic AdminServer
Oracle Web Tier
Application deployments, one for the Enterprise Manager Cloud Control console and one for the platform background services.
The host on which you installed Enterprise Manager Cloud Control
However, the other targets running on that host and other hosts do not get automatically discovered and monitored. To monitor the other targets, you need to add them to Enterprise Manager Cloud Control either using the Auto Discovery Results page, the Add Targets Manually page, or the discovery wizards offered for the targets you want to monitor.
For information about discovering targets in Enterprise Manager Cloud Control, refer to the chapter on adding targets in the Oracle Enterprise Manager Cloud Control Administrator's Guide.
Configure your proxy server as described in .
(Optional) If you want to modify the connection descriptor for the Management Repository, then shut down the OMS, run the following command, and then restart the OMS.
emctl config oms -store_repos_details (-repos_host <host> -repos_port <port> -repos_sid <sid> | -repos_conndesc <connect descriptor>) -repos_user <username> [-repos_pwd <pwd>] [-no_check_db]
Note: On Linux, you need to double escape the connect descriptor using single and double quotes. However, on Microsoft Windows, you need not.For example, on Linux:
For example, on Microsoft Windows:
(Optional) If you want to change the SYSMAN and SYSMAN_MDS passwords, then shut down the OMS, run the following command, and then restart the OMS.
emctl config oms -change_repos_pwd
If you have installed Enterprise Manager Cloud Control in a middleware home that is on an NFS-mounted drive, then ensure that you maintain the lock file in a local file system and not in that NFS-mounted location. To do so, modify the lock file location in the httpd.conf file to map to a location on a local file system.
Stop the OMS:
Save the changes.
Restart the OMS:
An encryption key is generated to encrypt sensitive data in the Management Repository. If this key is lost, all encrypted data in the Management Repository becomes unusable. Therefore, back up the Management Service configuration including the emkey, and maintain the backup on another host.
To back up the Management Service configuration including the emkey, run the following command:
<OMS_HOME>/bin/emctl exportconfig oms -dir <path_to_backup_location>
