Skip Headers
Oracle® Enterprise Manager Cloud Control Basic Installation Guide
12c Release 1 (12.1.0.1)
E22624-12
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
3 Meeting Package, Kernel Parameter, and Library Requirements
This chapter describes the packages, kernel parameters settings, and libraries required on different platforms (32-bit and 64-bit) for installing a new Enterprise Manager system, an additional Oracle Management Service (OMS), and a standalone Oracle Management Agent (Management Agent).
In particular, this chapter covers the following:
  • The packages and libraries are required for installation and operation, so do NOT remove them after installation.
  • The packages and libraries are NOT required for Microsoft Windows platforms.
Package Requirements
This section lists the packages required on different platforms (32-bit and 64-bit) for installing an OMS or a Management Agent. In particular, this section covers the following:
Identifying Installed Packages
To identify the packages already installed on your system, run the following command. If the command does not list the packages listed in Package Requirements for Oracle Management Service or Package Requirements for Oracle Management Agent, then install them manually.
rpm -qa --queryformat "%{NAME}-%{VERSION}-%{RELEASE}(%{ARCH})\n" | grep glibc
The command lists all the packages installed on the system. The 32-bit ones are appended with (i386) and the 64-bit ones are appended with (x86_64).
For example, if you run the command on a 32-bit system, you should see something similar to the following:
glibc-devel-2.3.4-2.43(i386)
glibc-headers-2.3.4-2.43(i386)
glibc-2.3.4-2.43(i686)
compat-glibc-headers-2.3.2-95.30(i386)
glibc-profile-2.3.4-2.43(i386)
glibc-utils-2.3.4-2.43(i386)
glibc-kernheaders-2.4-9.1.103.EL(i386)
glibc-common-2.3.4-2.43(i386)
compat-glibc-2.3.2-95.30(i386)
For example, if you run the command on a 64-bit system, you should see something similar to the following:
glibc-common-2.3.4-2.43(x86_64)
glibc-devel-2.3.4-2.43(x86_64)
glibc-profile-2.3.4-2.43(x86_64)
glibc-headers-2.3.4-2.43(x86_64)
glibc-utils-2.3.4-2.43(x86_64)
glibc-2.3.4-2.43(x86_64)
Table 3-1 lists the packages required on different platforms (32-bit and 64-bit) for installing a new Enterprise Manager system or an additional OMS.
Table 3-1 Package Requirements for Oracle Management Service
Platform 32-Bit Packages for 32-Bit Platform 64-Bit Packages for 64-Bit Platform
Oracle Linux 6.x
(Red Hat 6 Kernel and Unbreakable Enterprise Kernel (UEK))
  • make-3.81
  • binutils-2.17.50.0.6
  • gcc-4.1.1
  • libaio-0.3.106
  • glibc-common-2.3.4
  • compat-libstdc++296-2.96
  • libstdc++ 4.1.1
  • libstdc++devel-4.1.0
  • setarch-1.6
  • sysstat-5.0.5
  • compat-db 4.1.25
  • xorg-x11-utils (This package is required only for GUI-based interactive installation, and not for silent installation)
  • make-3.81
  • gcc-4.1.1
  • libaio-0.3.106
  • libstdc++-4.1.1
  • sysstat-5.0.5
  • glibc-devel-2.5-49-i686 (This is a 32-bit package)
  • glibc-devel-2.5-49-x86_64 (This is a 64-bit package)
Oracle Linux 5.x
Red Hat Enterprise Linux 5.x
  • make-3.81
  • gcc-4.1.1
  • libaio-0.3.106
  • libstdc++ 4.1.1
  • setarch-1.6
  • sysstat-5.0.5
  • compat-db 4.1.25
  • rng_utils-2.0
  • libXtst-1.0.1-3.1(i386)
  • make-3.81
  • gcc -4.1.1
  • libaio-0.3.106
  • libstdc++ -4.1.1
  • setarch-1.6
  • sysstat-5.0.5
  • rng-utils-2.0
  • libXtst-1.0.1-3.1(x86_64)
In addition, install the 32-bit version as well as the 64-bit version of glibc-devel-2.5-49 to avoid any linking errors while installing the OMS. The installer checks for this package, so if this package is not installed, the installer displays an error.
Oracle Linux 4.x
Red Hat Enterprise Linux 4.x
  • make-3.80
  • binutils-2.15.92.0.2
  • gcc-3.4.5
  • libaio-0.3.105
  • libstdc++-3.4.5
  • libstdc++-devel-3.4.3
  • pdksh-5.2.14
  • setarch-1.6
  • sysstat-5.0.5
  • compat-db-4.1.25
  • kernel-utils-2.4
Not Supported
SUSE Linux Enterprise 10
  • make-3.80
  • binutils-2.16.91.0.5
  • gcc-4.1.0
  • libstdc++ 4.1.0
Not Supported
SUSE Linux Enterprise 11
  • make-3.81
  • binutils-2.19-9.3
  • gcc-4.3-62.198
  • libstdc++ 43.4.3
  • make-3.80
  • gcc -4.1.0
  • libstdc++ 43.4.3
Asianux Server 3
  • make-3.81-3AXS3-i386
  • binutils-2.17.50.0.6-9AXS3-i386
  • gcc-4.1.2-44.1-i386
  • libaio-0.3.106-3.2-i386
  • glibc-common-2.5-34.1AXS3-i386
  • compat-libstdc++-296-2.96-138.2AX-i386
  • libstdc++-4.1.2-44.1-i386
  • libstdc++-devel-4.1.2-44.1-i386
  • setarch-2.0-1.1-i386
  • sysstat-7.0.4-1AX-i386
  • compat-db-4.2.52-5.1-i386
  • make-3.81
  • gcc -4.1.1
  • libaio-0.3.106
  • libstdc++ -4.1.1
  • setarch-1.6
  • sysstat-5.0.5
Solaris SPARC 5.9
Not Supported
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWsprox
  • SUNWtoo
  • SUNWi1of
  • SUNWxwfnt
Solaris SPARC 5.10
Also supported on Solaris Logical Domains (LDOM)
Not Supported
SUNWbtool
Solaris SPARC 5.11
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWxwplt (This is for setting xwindow)
  • SUNWfont-xorg-core (This package is required only for GUI-based interactive installation, and not for silent installation)
  • SUNWlibC
  • SUNWcsl
Solaris x86-64 5.11
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWlibC
  • SUNWcsl
Solaris x86-64 5.10
Not Supported
  • SUNWbtool
  • SUNWarc
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWi1of
  • SUNWi1cs
  • SUNWi15cs
  • SUNWxwfnt
IBM AIX 5.3.00.04
Note: Maintenance level 4 and higher are supported for AIX 5.3.
Check the maintenance level using the following command:
oslevel -r
Not Supported
  • bos.perf.proctools(0.0)
  • bos.adt.base(0.0)
  • bos.adt.libm(0.0)
IBM AIX 6.1
Note: All maintenance levels are supported.
oslevel -r
Not Supported
  • bos.adt.base(0.0)
  • bos.adt.lib(0.0)
  • bos.adt.libm(0.0)
  • bos.perf.libperfstat(0.0)
  • bos.perf.perfstat(0.0)
  • rsct.basic.rte(0.0)
  • rsct.compat.clients.rte(0.0)
  • xlC.aix61.rte.(9.0.0.0)
  • xlC.rte.(9.0.0.0)
IBM AIX 7.1
oslevel -r
Not Supported
  • bos.adt.base(0.0)
  • bos.adt.lib(0.0)
  • bos.adt.libm(0.0)
  • xlC.rte.(9.0.0.0)
Table 3-2 lists the packages required on different platforms (32-bit and 64-bit) for installing a Management Agent.
Table 3-2 Package Requirements for Oracle Management Agent
Oracle Linux 6.x
  • make-3.81
  • gcc-4.1.1
  • libstdc++ 4.1.1
  • make-3.81
  • gcc-4.1.1
  • libaio-0.3.106
  • libstdc++-4.1.1
  • sysstat-5.0.5
Oracle Linux 5.x
  • make-3.81
  • gcc-4.1.1
  • libstdc++-4.1.1
Oracle Linux 5.x and Red Hat Enterprise Linux 5.x, where x <= 5 [for example, Oracle Linux 5.3]
  • make-3.81
  • gcc -4.1.1
  • libstdc++ -4.1.1
Oracle Linux 5.x and Red Hat Enterprise Linux 5.x, where x > 5 [for example, Oracle Linux 5.6]
  • make-3.81
  • gcc -4.1.1
  • libaio-0.3.106
  • libstdc++ -4.1.1
  • setarch-1.6
  • sysstat-5.0.5
  • rng-utils-2
Oracle Linux 4.x
  • make-3.80
  • gcc-3.4.5
  • libstdc++-3.4.5
  • kernel-utils-2.4
64-bit Management Agent is NOT supported on 64-bit platform, but 32-bit Management Agent is supported, so install all 32-bit packages (listed in the previous column) on your 64-bit platform.
  • make-3.80
  • gcc-4.1.0
  • libstdc++ 4.1.0
  • make-3.81
  • binutils-2.19-9.3
  • gcc-4.3-62.198
  • libstdc++ 43.4.3
  • make-3.80
  • gcc -4.1.0
  • libstdc++ 43.4.3
Asianux Server 3
  • make-3.81
  • gcc -4.1.1
  • libstdc++ -4.1.1
Solaris SPARC 5.9
Not Supported
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWsprox
  • SUNWtoo
  • SUNWi1of
  • SUNWxwfnt
Solaris SPARC 5.10
Not Supported
SUNWbtool
Solaris SPARC 5.11
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWlibC
  • SUNWcsl
Solaris x86-64 5.11
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWlibC
  • SUNWcsl
Solaris x86-64 5.10
Not Supported
  • SUNWbtool
  • SUNWarc
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWi1of
  • SUNWi1cs
  • SUNWi15cs
  • SUNWxwfnt
Solaris Express 5.11 x86-64
Note: The supported Kerne lID is 175.0.0.0.2.0,151.0.1.12.
To check the kernel ID, run the following command:
uname -X |grep KernelID
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWlibC
  • SUNWcsl
Solaris SPARC Express 5.11
Note: The supported Kernel ID is 175.0.0.0.2.0,151.0.1.12.
To check kernel ID, run the following command:
Not Supported
  • SUNWbtool
  • SUNWhea
  • SUNWlibm
  • SUNWlibms
  • SUNWsprot
  • SUNWtoo
  • SUNWlibC
  • SUNWcsl
IBM AIX 5.3.00.04
Maintenance level can be checked using the following command:
oslevel -r
Not Supported
  • bos.perf.proctools(5.3.0.50)
  • bos.adt.base(0.0)
  • bos.adt.libm(0.0)
IBM AIX 6.1
oslevel -r
Not Supported
  • bos.adt.base(0.0)
  • bos.adt.lib(0.0)
  • bos.adt.libm(0.0)
  • xlC.rte.(9.0.0.0)
IBM AIX 7.1
oslevel -r
Not Supported
  • bos.adt.base(0.0)
  • bos.adt.lib(0.0)
  • bos.adt.libm(0.0)
  • xlC.rte.(9.0.0.0)
HP PA-RISC 11.23
Not Supported
BUNDLE11i(B.11.23.0409.3)
HP PA-RISC 11.31
Not Supported
  • OnlineDiag(B.11.31.01.03)
  • Base-VXFS(B.11.31)
HP-UX Itanium 11.23
Not Supported
HP-UX Itanium 11.31
Not Supported
OS-Core(B.11.31)
Kernel Parameter Requirements
For installing an OMS or a Management Agent on Unix operating systems (32-bit or 64-bit), set the kernel.shmmax parameter to a value 1 byte less than 4 GB or 4294967295.
Oracle recommends this value to avoid lack of memory issues for other applications and to enable a complete and successful core file generation under any and all circumstances.
To verify the value assigned to kernel.shmmax parameter, run the following command:
cat /proc/sys/kernel/shmmax
To set the value for kernel.shmmax parameter, run the following command:
sysctl -w kernel.shmmax=<new value>
This section lists the libraries required on different platforms (32-bit and 64-bit) for installing an OMS or a Management Agent. In particular, this section covers the following:
Library Requirements for Oracle Management Service
Table 3-3 lists the libraries required on different platforms (32-bit and 64-bit) for installing a new Enterprise Manager system or an additional OMS.
Table 3-3 Library Requirements for Oracle Management Service
Platform 32-Bit Libraries for 32-Bit Platform 64-Bit Libraries for 64-Bit Platform
Oracle Linux 6.x
Red Hat Enterprise Linux 6.x
glibc-2.5.12
glibc-2.5.12
Oracle Linux 5.x
glibc-2.5-12
glibc-2.5.12
Oracle Linux 4.x
glibc-2.3.4-2.43.i386
glibc-2.2.4-31.7
glibc-2.2.4-31.7
glibc-2.9
Asianux Server 3
glibc-2.3.4-2.9
glibc-2.3.4-2.9
Library Requirements for Oracle Management Agent
There are no library requirements for Management Agent.
