Skip Headers
Oracle® Enterprise Manager Cloud Control Basic Installation Guide
12c Release 2 (12.1.0.2)
E22624-20
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
A Overview of EM Prerequisite Kit Utility
This appendix describes the Enterprise Manager Prerequisite Kit utility (EM Prerequisite Kit) that the installation wizard runs every time it installs or upgrades your Enterprise Manager. In particular, this appendix covers the following:
About EM Prerequisite Kit
The EM Prerequisite Kit is a command line utility that runs repository-related prerequisite checks in your environment to ensure that you meet all the repository requirements for installing or upgrading an Enterprise Manager system.
The kit not only runs the prerequisite checks but also takes corrective action automatically, to the extent possible, when a prerequisite check fails. The kit also takes postrequisite steps to revert the corrective actions taken and ensure that the system is back to how it was before installing or upgrading the Enterprise Manager system.
The EM Prerequisite Kit is run internally by the Enterprise Manager Installation Wizard while installing or upgrading an Enterprise Manager system.
You can download the latest version of EM Prerequisite Kit from the Self Update framework as follows:
  1. In Cloud Control, from the Setup menu, select Extensibility, and then select Self Update.
  2. On the Self Update page, download the new version of XMLs under the entity EM Deployment Prerequisite Resources Updates, if there are any available.
Once you download and apply these updates, you cannot rollback to the previous version of XMLs.
Running the EM Prerequisite Kit
The EM Prerequisite Kit is run internally by the Enterprise Manager Installation Wizard while installing or upgrading an Enterprise Manager system. However, if any of the repository prerequisite checks fail for some reason, you can manually run them by invoking this kit.
The EM Prerequisite Kit is available in the following location of the software kit (DVD, downloaded software):
install/requisites/bin/emprereqkit
Ensure that the user running the EM Prerequisite Kit has write permission to the central inventory.
To run the EM Prerequisite Kit, do one of the following:
To learn about the other arguments that can be passed with the kit, see Running the EM Prerequisite Kit with Additional Arguments.
Once the Enterprise Manager system is installed or upgraded, the EM Prerequisite Kit and all the other files and directories present in the install/requisites/ directory of the software kit (DVD, downloaded software) are copied to the following location in the OMS home. So, in future, if you decide to install any plug-ins, then before installing them, ensure that you invoke the EM Prerequisite Kit from this location.
$<OMS_HOME>/install/requisites/bin/emprereqkit
The default XML files related to the prerequisite checks, which are stored in the install/requisites/list directory on the software kit (DVD, downloaded software), are current at the time of the release of the product. However, after the release of the product, if a new prerequisite check is introduced or if an existing prerequisite check is updated, then you must do one of the following:
  • Enable the Self Update functionality within Enterprise Manager Cloud Control so that the new or updated prerequisite XML files are automatically downloaded to the $<OMS_HOME>/install/requisites/list directory.
  • Manually download the new or updated prerequisite XML files from Oracle store to the $<OMS_HOME>/install/requisites/list directory.
Table A-1 describes the additional arguments you can pass while invoking the EM Prerequisite Kit:
Table A-1 Arguments Supported by EM Prerequisite Kit
Option Optional or Mandatory Value Required? Example Description
-configurationType
Mandatory
Yes
$<OMS_HOME>/install/requisites/bin/emprereqkit -executionType install -prerequisiteXMLLoc <prereq_xml_location> -connectString <connect_string> -dbUser SYS -dbPassword <db_password> -dbRole sysdba -runPrerequisites -configurationType <configuration type ex: SMALL/MEDIUM/LARGE>
Enables performing prerequisite checks for different repository configurations.
-executionType
Mandatory
Yes
-executionType upgrade
Specify the type of execution, which can be one of the following:
  • install
  • upgrade
  • postrequisite
-prerequisiteXMLLoc or prerequisiteXMLRootDir
Mandatory
Yes
-prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list
Specify the absolute path to the location where the XML files related to the prerequisites are present. If you do not specify a location, the default location is ../list/.
  • -connectString <connectstring>
  • -dbHost <hostname> -dbPort <port> -dbSid <sid>
One of these options is mandatory
Yes
For example (connect string):
-connectString "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=dbview)))"
For example (database details):
-dbHost example.com -dbPort 15044 -dbSid dbview
Specify the database details.
-dbUser
Mandatory
Even if you do not pass this option, you will be prompted to provide a value
Yes
-dbUser SYS
Specify SYS.
-dbPassword
Mandatory
Yes
-dbPassword welcome1
Specify the database password.
-dbRole
Mandatory
Yes
-dbRole sysdba
Specify sysdba.
-prereqResultLoc
Optional
Yes
-prereqResultLoc /scratch/results
Specify the absolute path to a directory where the results (in the form of XML files) of the prerequisite checks can be stored.
If you do not pass this option, the results are stored in a default location which is the current directory.
Note: If you specify details for a different database before completing all the actions, you will need to specify a different -prereqResultLoc.
-showPrereqs
Optional
No
Example using dhHost, dbPort, and dbSid is:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showPrereqs
Example using connectString is:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -connectString  "(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=15044)))(CONNECT_DATA=(SID=sv902)))"  -dbUser SYS -dbPassword example_passwd -dbRole sysdba -showPrereqs
Lists the prerequisite checks to be run.
  • -runPrerequisites
  • -showCorrectiveActions
  • -runCorrectiveActions
  • -showPostCorrectiveActions
  • -runPostCorrectiveActions
One of these options is mandatory.
No
An example for -runPrerequisites:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runPrerequisites
An example for -showCorrectiveActions:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showCorrectiveActions
Example for -runCorrectiveActions:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runCorrectiveActions
Example for -showPostCorrectiveActions:
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -showPostCorrectiveActions
Example for -runPostCorrectiveActions
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade  -dbHost  example.com -dbPort 15044 -dbSid sv902 -dbUser SYS  -dbPassword example_passwd -dbRole sysdba -runPostCorrectiveActions
  • Runs the prerequisite checks and lists the ones that passed and failed.
  • Lists the corrective actions that will be taken for the failed prerequisite checks.
  • Takes corrective actions for the failed prerequisite checks.
  • Lists the post-corrective actions that will be taken for the prerequisite checks for which corrective actions were taken.
  • Takes post-corrective actions for the prerequisite checks for which corrective actions were taken. In other words, reverts to values that existed before corrective actions were taken.
Important: If you passed -prereqResultLoc with -runPrerequisites, then pass -prereqResultLoc with the following options also, and specify the same custom location:
Note: Show actions must be independent, that is, they should not be combined with any other action.
-logLoc
Optional
Yes
-logLoc /scratch/logs
Specify the absolute path to a directory where the logs of the execution of the EM Prerequisite Kit utility can be stored. The default location is <prereqResultloc>/prerequisiteResults/log.
-runOnlyFor
Optional
Yes
-runOnlyFor "repository|11.2.0.43"
Specify the components that must be selected instead of the XML files for checking the prerequisites.
{comp1|<version1>, comp2|<version2>}]
If there are two prerequisite XML files with the same component name, then the <version*> is used to select the correct one. This option is particularly useful when running the prerequisites for installing plug-ins.
-responseFile
Optional
Yes
-responseFile /scratch/response.rsp
Specify the absolute path to a location where the response file is available.
-contextName
Optional
Yes
-contextName 11.2.0.1
Specify a unique name for this run. If you do not specify this, a default name with the format executionType_timestamp is created.
-componentVariables
Optional
Yes
-componentVariables global:EM_REPOS_USER:sysman
Specify the name and value of the component variable in the following format:
component_name:variable_name:variable_value
For example:
You can pass as many component variables as you want, but ensure that you separate them by a comma.
For example:
global:EM_REPOS_USER:sysman,repository:DB_VERSION:10.2.0.5.0
-logInDB
Optional
Yes
-logInDB false
Defaults to true and stores the result XMLs in the database. If you do not want to store them in the database, pass this option and specify false.
-stopExecOnFirstError
Optional
No
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -prerequisiteXMLLoc $ORACLE_HOME/install/requisites/list -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -runPrerequisites -stopExecOnFirstError
Stops the utility the first time it encounters an error, and does not run the remaining prerequisites.
Note: This action must be executed in combination with runPrerequisites.
-list
Optional
Must be passed independently while invoking the utility
No
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -list
Organizes and lists the prerequisite check results (stored in the database) based on when it was run and the context.
-export
Optional
No
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -export
Copies the prerequisite check results (XML files) from the database to an external file system.
-purge
Optional
No
$ORACLE_HOME/install/requisites/bin/emprereqkit -executionType upgrade -dbHost example.com -dbPort 15044 -dbSid sv902 -dbUser SYS -dbPassword example_passwd -dbRole sysdba -purge
Defaults to false and retains the result XMLs in the database. If you want to delete them from the database, pass this option.
-help
Optional
No
emprereqkit -help
This option gives details of various parameters which can be passed to EM Prerequisite Kit.
Viewing Prerequisite Check Results
Every time the EM Prerequisite Kit is run, the results of the prerequisite checks run for a particular component are stored in an instance XML file. The instance XML file has the file name <component>.xml. The results are in the same format as the information stored in the prerequisite XML files. The only difference is the new column that indicates the actual result of the prerequisite check.
Table A-2 lists the instance file locations depending on how the EM Prerequisite Kit was invoked.
Table A-2 EM Prerequisite Kit Result File Location (Instance XML File)
invocation Type Instance File LocationFoot 1  Latest Instance File LocationFoot 2
Manually Invoked
<prereqResultLoc>/resultXMLs/<time-stamp>
Note: When you provide prereqResultLoc value, the result xml location is as mentioned above. Else, the result xml location is <Current Directory>/ prerequisiteResults/resultXMLs/<time-stamp>
<prereqResultLoc>/resultXMLs/LATEST/
Note: When you provide prereqResultLoc value, the result xml location is as mentioned above. Else, the result xml location is <Current Directory>/ prerequisiteResults/resultXMLs/LATEST
Automatically Invoked by the Enterprise Manager Cloud Control Installation Wizard
<MW_HOME>/.gcinstall_temp/resultXMLs/<time-stamp>
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit result XMLs are created in /tmp/OraInstall<timestamp>/emprereqkit/resultXMLs/<time-stamp>.
When install begins, the /tmp/OraInstall<timestamp>/emprereqkit/resultXMLs/<time-stamp> result xmls are copied to <MWHOME>/.gcinstall_temp/resultXMLs/<time-stamp>.
<MW_HOME>/.gcinstall_temp/resultXMLs/LATEST
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit result xmls are created in /tmp/OraInstall<timestamp>/ emprereqkit/p; resultXMLs/LATEST.
When install begins, the /tmp/OraInstall<timestamp>/ emprereqkit/ resultXMLs/LATEST result xmls are copied to <MW_HOME>/.gcinstall_temp/resultXMLs/LATEST
Footnote 1 Instance File Location refers to the <time-stamp> directory that is created dynamically by the utility every time the EM Prerequisite Kit is run. The instance file created here is retained until you decide to delete it.
Footnote 2 Latest Instance File Location refers to a single, standard location maintained for the latest instance file created when the EM Prerequisite Kit was last run. The instance file created here is overwritten every time the utility is run.
The <prereqResultLoc> location refers to the location you enter for the -prereqResultLoc option while invoking the utility. If this option is not passed, then by default, the directory from where you invoke the utility is considered as the base directory, and a directory titled prerequisiteResults is dynamically created in it, and then the instance file is stored in it.
Viewing Log Files
Table A-3 lists all the log files that are created every time the EM Prerequisite Kit is run.
Table A-3 EM Prerequisite Kit Log Files
Log File Name Description
emprereqkit.log
Contains information about every step taken or action performed by the kit
emprereqkit.err.log
Contains only the error and stacktrace of the exceptions occurred
emprereqkit.output
Contains information about the status (pass or fail) of all the prerequisite checks that are run. It also contains detailed information regarding each prerequisite check.For example, prerequisite name, execution status, detailed recommendation (what queries are to be executed to correct the failed prerequisite), and so on.s
<functional_area>.log
Contains information about the function area-specific prerequisite checks that are run. For example, repository.log that contains repository-specific performance-related prerequisite checks that are run.
Table A-4 lists the log file locations depending on how the EM Prerequisite Kit was invoked. This table lists the locations for all the log files except for the emprereqkit.output file. For emprereqkit.output file, see the note after the table.
Table A-4 EM Prerequisite Kit Log File Locations
invocation Type Latest Log File LocationFoot 1  Log File LocationFoot 2
Manually Invoked
<logLoc>/LATEST
Note: When you provide logLoc as the value, the log location is as mentioned above. Else, it is <Current Directory>/prerequisiteResults/log/LATEST
<logLoc>/<time-stamp>
Note: When you provide logLoc as the value, the log location is as mentioned above. Else, it is <Current Directory>/ prerequisiteResults/log/<time-stamp>
<MW_HOME>/.gcinstall_temp/LATEST
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit logs are created in either $OraInventory/logs/emdbprereqs/LATEST or /tmp/OraInstall<timestamp>/ emdbprereqs/LATEST
When install begins, the /tmp/OraInstall<timestamp>/emprereqkit logs are copied to <MW_HOME>/.gcinstall_temp/ /emprereq/LATEST
<MW_HOME>/.gcinstall_temp/<time-stamp>
Note: When you proceed through the installation wizard pages, EM Prerequisite Kit logs are created in either $OraInventory/logs/emdbprereqs/<timestamp> or /tmp/OraInstall<timestamp>/ emdbprereqs/<timestamp>
When install begins, the /tmp/OraInstall<timestamp>/ emdbprereqs/<time-stamp> logs are copied to <MW_HOME>/.gcinstall_temp/ /emprereq/<time-stamp>
Footnote 1 Latest Log File location refers to a single, standard location maintained for the latest log files created when the EM Prerequisite Kit was last run. The log files created here are overwritten every time the utility is run.
Footnote 2 Log File Location refers to the <time-stamp> directory that is created dynamically by the utility every time the EM Prerequisite Kit is run. The log file created here are retained until you decide to delete them.
When the EM Prerequisite Kit is run manually, the log file emprereqkit.output is stored in <prereqResultLoc>/log/<time-stamp>. The latest log file is stored in <prereqResultLoc>/log/LATEST/.
When the EM Prerequisite Kit is run internally by the Enterprise Manager Cloud Control Installation Wizard, the log file emprereqkit.output is stored in <MW_HOME>/.gcinstall_temp/log/<time-stamp>. And the latest log file is stored in <MW_HOME>/.gcinstall_temp/log/<LATEST>.
Repository Prerequisites
This section describes all the repository prerequisites that the EM Prerequisites Kit checks. This section also describes how to manually check these prerequisites.
Following are the repository prerequisites for upgrading Enterprise Manager.
Table A-5 Repository Prerequisites for Upgrading Enterprise Manager System
Prerequisite Applies to Install/Upgrade Automatic Description
Basic Policy Requirements
Upgrade
No
Ensure that valid policy exists for MGMT_TARGETS. To verify, run the following query:
select 'EM_TARGET_POLICY' from dual where not exists (select policy_name from dba_policies where object_owner=SYSMAN' and pf_owner='SYSMAN' and object_name='MGMT_TARGETS') )
The query must not return any rows.
Active Jobs Requirements
Upgrade
No
Ensure that there are no background DBMS jobs currently running in the Repository Database. To verify, run the following query:
select count(*) FROM dba_jobs_running run_job,gv$session sess WHERE sess.sid=run_job.sid AND sess.schemaname='SYSMAN'
If the result of the query is 0 then there are no active DBMS jobs, if result is not 0 then wait for the active jobs to complete.
Checks if GVM Performance collection job is running
Upgrade
Yes
Ensure that the GVM Performance Metric Collection job is stopped and deleted. To verify if a job named GVMPERFMETRICCOLL exists, run the following query:
select count(*) from mgmt_job where job_name = 'GVMPERFMETRICCOLL' and job_type = 'UpdateGVMPerfMetric'
If it exists, then stop and delete.
Valid Reference Requirements
Upgrade
No
Ensure that all entries for execution_id in MGMT_JOB_EXECUTION either point to a valid entry in MGMT_JOB_EXEC_SUMMARY, or are NULL.
To verify, run the following query. The query must not return any rows.
SELECT COUNT(1) FROM MGMT_JOB_EXECUTION e WHERE NOT EXISTS (SELECT 1 FROM MGMT_JOB_EXEC_SUMMARY s WHERE s.execution_id = e.execution_id) AND execution_id IS NOT NULL
Job Type Uniqueness Requirements
Upgrade
No
Ensure that there are no duplicate entries in MGMT_JOB_TYPE_INFO for the following set of columns: job_type, job_type_owner, major_version, minor_version1, minor_version2.
SELECT job_type FROM MGMT_JOB_TYPE_INFO GROUP BY job_type, job_type_owner, major_version, minor_version1, minor_version2 HAVING COUNT(1) > 1
SQL Plan Baseline Capture Parameter Requirements
Install, Upgrade
No
Ensure that the parameter optimizer_capture_sql_plan_baselines is set to FALSE (or default).
The SQL plan baseline capture must never be turned on for the Management Repository. Enterprise Manager heavily depends on updated CBO statistics. If stale CBO statistics exist, the SQL plan baseline capture could cause bad execution plans to be used for critical functionality.
Current Availability Index Requirements
Install, Upgrade
No
Ensure that the current availability index is renamed to the following:
  • If you are running the kit before upgrading to 12c release, then rename it to MGMT_CURRENT_AVAILABILITY_PK.
  • If you are running the kit after upgrading to 12c release, then rename it to EM_CURRENT_AVAILABILITY_PK.
My Oracle Support User Name Size Requirements
Upgrade
No
Ensure that the My Oracle Support user name is not longer than 239 characters. If it is, then you cannot upgrade.
ARU User Name Size Requirements
Upgrade
No
Ensure that the ARU user name is not longer than 239 characters. If it is, you cannot upgrade.
DBMS Package Requirements
Install, Upgrade
No
Ensure that you compile the required DBMS packages.
Log in to the database, where the Management Repository is configured, as SYS user, and run the following query to retrieve the list of invalid DBMS packages:
SELECT object_name, object_type FROM all_objects WHERE status = 'INVALID' AND object_name LIKE 'DBMS%'
If the package is invalid, run the following query:
  • For package:
    ALTER PACKAGE <PACKAGE_NAME> COMPILE
  • For package body:
    ALTER PACKAGE <PACKAGE_NAME> COMPILE BODY
If the packages do not compile successfully, contact Oracle Support.
Snapshot Log Requirements
Upgrade
No
Ensure that the snapshot logs are deleted from the tables.
Connector Configuration Table Requirements
Upgrade
No
Ensure that there is no bad data in the connector configuration table. If there is any, then run the following query to clean the table.
delete from mgmt_cntr_config where connector_guid is null or connector_type_guid is null;
commit;
Compatible Instance Parameter Requirements
Install, Upgrade
No
Ensure that the compatible instance parameter is set to the same version value as the database instance of the Management Repository. Any other value might result in unexpected problems, poor performance, or both.
Primary Key and Foreign Key Requirements
Upgrade
No
Ensure that Primary Key and Foreign keys are not disabled. To verify, run the following query:
select count(*) from (select constraint_name, table_name from DBA_CONSTRAINTS where owner = 'SYSMAN' and (constraint_type = 'P' or constraint_type = 'R') and status = 'DISABLED')
If the result is not 0, then use the following query to enable the constraint:
alter table SYSMAN.<TABLE_NAME> modify constraint <CONSTRAINT_NAME> enable
If the constraints cannot be enabled for any reason, contact Oracle Support.
Enable Queue Requirements
Upgrade
No
Ensure that queues are enabled in the Repository Database. To verify, run the following query:
select count(*) from dba_queues where owner = 'SYSMAN' and queue_type like '%NORMAL_QUEUE%' and (enqueue_enabled like '%NO%' OR dequeue_enabled like '%NO%')
If result is not 0, use the following query to retrieve the list of disabled queue names:
select name, queue_table from dba_queues where owner = 'SYSMAN' and upper(queue_type) not like 'EXCEPTION_QUEUE' and (upper(enqueue_enabled) NOT LIKE '%YES%' OR upper(dequeue_enabled) NOT LIKE '%YES%'))
Execute the following SQL statement to enable the queue:
begin
dbms_aqadm.start_queue('<disabled_queue_name>');
end;
If the queue cannot be started, contact Oracle Support.
Trigger Requirements
Upgrade
No
Ensure that all the triggers in the Repository Database are not disabled. To verify, run the following query:
select count(*) from (select trigger_name, trigger_type, table_name from DBA_TRIGGERS where table_owner = 'SYSMAN' and status = 'DISABLED')
If result is not 0, then enable the trigger.
SYSTEM tablespace requirement
Install and Upgrade
No
Ensure that the SYSTEM tablespace has at least one datafile set to autoextensible. To verify, run the following query:
select count(*) from dba_data_files where tablespace_name = 'SYSTEM' and autoextensible = 'YES'
If the result is 0, then add a new datafile with the autoextend attribute to the SYSTEM tablespace so it has at least one listed in the DBA_DATA_FILES view with autoextensible equal to 'YES'. Contact Oracle Support if there are any errors
emkey requirement
Upgrade
No
Ensure that the emkey is copied to the repository. To verify, run the following query:
select COUNT(*) from sysman.mgmt_repos_time_coefficient
If the result of the query is not 1, then copy the emkey.ora file from another OMS or backup machine to the ORACLE_HOME/sysman/config directory.
Configure the emkey.ora file by running emctl config emkey -copy_to_repos -sysman_pwd <sysman_pwd>.
EM_USER_CONTEXT requirements
Upgrade
No
Ensure that EM_USER_CONTEXT is present in the repository. To verify, run the following query:
select count(*) from dba_context where schema='SYSMAN' and upper(namespace)='EM_USER_CONTEXT'
If the query result is 0, check that the procedure SETEMUSERCONTEXT is valid by executing the following query:
select status from all_objects
where object_name='SETEMUSERCONTEXT' and owner='SYSMAN'
The above query must return 'VALID'. Then run:
alter session set current_schema='SYSMAN';
Create or replace context EM_USER_CONTEXT using SETEMUSERCONTEXT;
If the context cannot be created for any reason, contact Oracle Support.
Audit Master table requirement
Upgrade
No
Ensure that there are no abnormal conditions stored in the Audit Master Table. To verify, run the following query:
select count(*) from sysman.mgmt_audit_master
If the query result is not 1 then, contact Oracle Support to analyze the Enterprise Manager repository before attempting to perform the patch/upgrade.
Exempt Access Policy requirement
Upgrade
No
Ensure that EXEMPT ACCESS POLICY is not granted directly to SYSMAN or indirectly grants to a role that is granted to SYSMAN. To verify, run the following query:
select count(*) from dba_sys_privs where upper(privilege)='EXEMPT ACCESS POLICY' and (grantee = 'sysman' or grantee in (select distinct granted_role from dba_role_privs start with grantee='SYSMAN' connect by prior granted_role=grantee) or grantee = 'sysman')
If the result of the query is not 0, then revoke EXEMPT ACCESS POLICY from SYSMAN and the roles.
For example:
revoke exempt access policy from SYSMAN
max_enabled_roles init parameter requirement
Install and Upgrade
No
Ensure that the max_enabled_roles parameter value is set such that it contains at least 3 more than the flattened roles granted to SYS. To verify, run the following query:
select 1 from DUAL where (select count(*) from v$instance where version like '9.%') = 0 or (select value from v$parameter where name like 'max_enabled_roles') > (select count(*) from dba_role_privs start with grantee='SYS' connect by prior granted_role=grantee)+2;
If the result of the query is not 1 then, increase the max_enabled_roles parameter to ensure it contains at least 3 more than the flattened roles granted to SYS.
To modify max_enabled_roles, perform the following steps:
  1. Bring down all the OMS instances.
  2. Bring down the database cleanly.
  3. Modify the max_enabled_roles parameter in the init.ora or whichever is used by the database's initialization process.
  4. Bring up the database cleanly.
  5. Verify with v$parameter to ensure the parameter value is indeed increased.
PAF execution requirements
Upgrade
No
Ensure that no PAF executions are scheduled or running. To verify, run the following query:
SELECT count(1) FROM SYSMAN.MGMT_PAF_STATES s, SYSMAN.MGMT_PAF_INSTANCES i, SYSMAN.MGMT_PAF_PROCEDURES p WHERE p.procedure_guid = i.procedure_guid AND s.instance_guid = i.instance_guid AND s.state_type = 0 AND s.status in (0,1)
If the query result is not 0, then abort or wait for PAF executions to complete.
Secured Agent requirements
Upgrade
No
Ensure that all the agents are secured with latest CA. To know the list of agents to be secured, run the following command:
emcli get_ca_info -details
Pre-upgrade console patch requirements
Upgrade
No
Ensure that pre-upgrade patch is applied. To verify, run the following query:
select count(*) from all_objects where object_name ='PRE_UPGC_MASTER_INFO' and object_type='TABLE' and owner='SYSMAN'
If the result of the query is not 1, then apply pre-upgrade Console patch before upgrading.
Global Stale percentage requirements
Install and Upgrade
No
Ensure that global stale percentage is in between 5 and 25. To verify, run the following query:
select count(*) from dual where dbms_stats.get_prefs('STALE_PERCENT') between 5 and 25
The query result must be 1.
Account status requirements
Upgrade
No
Ensure that SYSMAN, MGMT_VIEW and ORACLE_OCM accounts are not locked or expired. To verify, run the following queries:
select account_status from dba_users where username='SYSMAN';
select account_status from dba_users where username='MGMT_VIEW';
select account_status from dba_users where username='ORACLE_OCM';
The query result must be OPEN.
SYSMAN schema requirements
Upgrade
No
Ensure that SYSMAN schema is present for upgrade. To verify, run the following query:
SELECT COUNT(*) FROM ALL_USERS WHERE USERNAME='SYSMAN'
Redo Log size requirement
Install and Upgrade
No
Ensure that size of the log file is 300 megabytes or greater. To verify, run the following query:
select min(bytes) from v$log
The query result must be greater or equal to 300000000 (bytes).
Existing Database Not to Be in QUIESCE Mode
Install and Upgrade
No
Ensure that existing, certified Oracle Database is not in QUIESCE mode. To verify this, run the following SQL in the database in the SYS role:
select active_state from v$instance;
The result returned must be NORMAL.
Existing Database Not to Have Database Control (only for fresh install)
Fresh Install
No
(If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5) or higher, which uses an Oracle Database where the Management Repository is already created, that is, where the Grid Control SYSMAN schema is already created, then ignore this prerequisite. This prerequisite applies only when you install Enterprise Manager 12c Cloud Control using an existing, certified Oracle Database that has Database Control SYSMAN schema created, which you want to replace now with Grid Control SYSMAN schema.)
Ensure that your existing, certified Oracle Database does NOT have Database Control SYSMAN schema. If it has, that is, if your existing database is configured with Database Control, then deconfigure it.
  1. Verify whether your database has Database Control SYSMAN schema.
    To do so, log in to the database as SYS user and run the following query:
    If the result of this query is 1, then the database has this schema, so deconfigure it.
  2. Before deconfiguring the Database Control, set the environment variable ORACLE_HOME to the Oracle home of the database, and ORACLE_SID to the SID of the database.
    For example, in bash shell, you can set them in the following way:
    export ORACLE_HOME=/u01/app/oracle/product/11.2.0/dbhome_1
    export ORACLE_SID=orcl
  3. Deconfigure the Database Control.
    To deconfigure Database Control for a standalone database, run the following command from the Oracle home of the database as the user who installed the database. If the command hangs, then restart the database and rerun the command.
    $<ORACLE_HOME>/bin/emca -deconfig dbcontrol db -repos drop -SYS_PWD <sys pasword> -SYSMAN_PWD <sysman password>
    To deconfigure Database Control for a Real Application Cluster (Oracle RAC) database, run the following command from the Oracle home of the database as the user who installed the database. If the command hangs, then restart the database and rerun the command.
    $<ORACLE_HOME>/bin/emca -deconfig dbcontrol db -repos drop -cluster -SYS_PWD <sys pasword> -SYSMAN_PWD <sysman password>
Note: If the deconfigure operation hangs, then refer to My Oracle Support note 375946.1
Existing Database Not to Have SYSMAN and SYSMAN_MDS Schema
Fresh Install
No
Ensure that your existing, certified Oracle Database does NOT have Enterprise Manager Grid Control SYSMAN schema and Metadata (MDS) schema.
  1. Verify whether your database has Enterprise Manager Grid Control SYSMAN schema and MDS schema.
    SELECT COUNT(*) FROM ALL_USERS WHERE USERNAME IN ('SYSMAN','SYSMAN_MDS');
    If the result of this query is 1, then the database has these schemas, so drop them.
  2. Before dropping the schema, set the environment variable LD_LIBRARY_PATH to the ORACLE_HOME/lib directory of the OMS. Also set the ORACLE_HOME to the Oracle home of the OMS.
  3. Drop the schema by running the following command from the Oracle home of the OMS.
    $<ORACLE_HOME>/sysman/admin/emdrep/bin/RepManager <repository_database_host> <repository_database_port> <repository_database_sid> -action dropall -dbUser <repository_database_user> -dbPassword <repository_database_password> -dbRole <repository_database_user_role> -mwHome <middleware_home> -mwOraHome <oms_oracle_home> -oracleHome <oms_oracle_home>
    If you are dropping the schemas that belong to a 10g Release 2 (10.2.x.x) Management Repository, then run previous command without these arguments: -mwHome <middleware_home> -mwOraHome <middleware_ora_home> -oracleHome <oracle_home>
    Note: For Microsoft Windows, invoke RepManager.bat. RepManager 11.1 supports -action dropall (drops SYSMAN as well as SYSMAN_MDS) and -action drop (drops only SYSMAN). RepManager 10.2.0.5 supports -action drop (drops only SYSMAN). Also, the action dropall might not drop all the repository objects. For learn more about this issue and the workaround to be used, see My Oracle Support note 1365820.1.
  4. After dropping the schema, manually delete the database files mgmt.dbf and mgmt_ecm_depot1.dbf.
    You can find these files by running the following command as SYS:
    SELECT FILE_NAME FROM DBA_DATA_FILES WHERE UPPER (TABLESPACE_NAME) LIKE 'MGMT%';
Database Initialization Parameters Requirements
Install and Upgrade except db_block_size which applies only to install.
No
Ensure that you have correctly set the database initialization parameters.
For information about the database initialization parameters to be set, refer to Setting Database Initialization Parameters.
Fine-Grained Access Control Requirements
Upgrade
No
Ensure that the fine-grained access control option is set to TRUE in the existing, certified Oracle Database so that the Management Repository can be created. To verify this, run the following command:
select value from v$option where parameter = 'Fine-grained access control';
UNDO Tablespace Size Requirements
Install and Upgrade
No
Ensure that the UNDO tablespace has a minimum space of 200 MB. To verify this, run the following query:
SELECT SUM(DECODE(autoextensible,'YES',200*1024*1024+1,bytes)) total
FROM dba_data_files f, dba_tablespaces s
WHERE s.contents = 'UNDO'
AND s.tablespace_name = f.tablespace_name;
Note: The result of this query is in bytes.
If the minimum space is less than 200 MB, then set it to 200 MB by running the following command:
alter database datafile <location datafile> resize 200M;
UNDO Tablespace and Temporary Tablespace Settings Requirements
Install and Upgrade
No
Ensure that the UNDO tablespace and the TEMP tablespace are autoextensible in the existing, certified Oracle Database. To verify this, run the following command:
select count(*) from  dba_temp_files where tablespace_name='TEMP' and AUTOEXTENSIBLE  <> 'YES';
select count(*) from dba_data_files where tablespace_name='UNDOTBS' and AUTOEXTENSIBLE <> 'YES';
If the result of the query is 0, then the tablespace is autoextensible. If the result it not 0, then refer to Oracle Database Administrator's Guide available at the following location to make the tablespace autoextensible.
http://www.oracle.com/technology/documentation/database.html
Archive Logging Settings Requirements
Install and Upgrade
No
(Recommended) Ensure that you turn on archive logging in the existing, certified Oracle Database for any environment where continuity of data is important. To verify this, run the following command in the SYS role:
select log_mode from v$database;
The result returned must be ARCHIVELOG.
Tablespace-Related Hard Disk Space Requirements
Install
No
Ensure that you allocate a minimum of 200 MB hard disk space for the following tablespaces:
- Management Tablespace (mgmt.dbf)
- Configuration Data Tablespace (mgmt_ecm_depot1.dbf)
- JVM Diagnostics Data Tablespace (mgmt_ad4j.dbf)
Oracle also recommends that you keep the auto-extend feature enabled for the tablespace data files.
Note that the space requirement increases as the number of monitored targets increase, along with the input/output performance demands on the storage devices.
Existing Management Repository
Upgrade
No
Ensure that the existing, certified Oracle Database, which houses the Management Repository, already has a Management Repository configured, and that the Management Repository is compatible with Oracle Management Service 11g Release 1 (11.1).
Database Partitioning Requirements
Install and Upgrade
No
Ensure that the existing, certified Oracle Database has the Partitioning Option enabled (therefore, ensure that you install it into Oracle Database Enterprise Edition.) Installing and using the partitioning option in the Enterprise Manager repository does not add costs to customers when used solely by Enterprise Manager.
To verify this, connect to the database as SYSDBA and run the following query:
select value from v$option where parameter = 'Partitioning';
The result of this query should be VALUE=TRUE. No additional partitioning license is required for the database that houses the Management Repository.
Database Partition Maintenance Requirements
Upgrade
No
If the Enterprise Manager system that you are about to upgrade was shut down for a long period of time, then you will not have partitions created in the existing, certified Oracle Database, which houses the Management Repository, to load new data. Therefore, under such circumstances, do the following:
  1. Log in to the database as SYSMAN and run the following command:
    execute emd_maintenance.analyze_emd_schema('SYSMAN');
    commit;
  2. Restart the OMS from its Oracle home:
    $<ORACLE_HOME>/bin/emctl start oms
Database and Listener Status Requirements
Install
No
Ensure that the existing, certified Oracle Database and its listener are running.
Valid Objects Requirements
Install, Upgrade, and Post requisite
No
Ensure that you do have only valid SYSMAN and SYS objects in the existing, certified Oracle Database.
  • To verify whether there are only valid SYSMAN objects, log in to the database as SYS and run the following command:
    select object_name, object_type from all_objects where owner='SYSMAN' and status <> 'VALID';
    The command must return 0 rows. However, if it returns one or more rows, then you have some invalid objects, and to turn them valid, run the following command as SYSMAN:
    @admin_recompile_invalid.sql SYSMAN
    Run this command again to ensure that all SYSMAN objects are valid. If you still have invalid SYSMAN objects, then contact Oracle Support.
    Note: The admin_recompile_invalid.sql script is in the following location of the Oracle home of the OMS:
    <ORACLE_HOME>/sysman/admin/emdrep/sql/core/latest/admin
  • To verify whether there are only valid SYS objects, log in to the database as SYS and run the following command:
    select object_name, object_type from all_objects where status<>'VALID' and object_name like 'DBMS%';
    The command must return 0 rows. However, if it returns one or more rows, then you have some invalid objects, and to turn them valid, recompile them by running the following command:
    alter <object type> <object name> compile;
    For example, if the object_type is mypackage and the object_name is foo, then run the following command:
    alter mypackage foo compile;
    Run this command again to ensure that all the packages are valid. If you still have invalid packages, then contact Oracle Support.
DBMS Jobs and DBMS Scheduler Status Requirements
Install and Upgrade
Yes
Ensure that you stop the DBMS Jobs and the DBMS Scheduler in the existing, certified Oracle Database. To do so, log in to the database as SYS:
  1. Write down the value of job_queue_processes by running the following command:
    select a.instance_name as sid, b.value as jobqueue from gv$instance a, gv$parameter b where a.inst_id = b.inst_id and b.name='job_queue_processes';
  2. Stop the DBMS JOBS and DBMS scheduler by running the following command:
    execute emd_maintenance.remove_em_dbms_jobs;
    alter system set job_queue_processes=0 SID='*';
    commit;
    Note: This will allow the currently running jobs to finish, but will not allow any new jobs to be started.
  3. Ensure that there are no active jobs by running the following:
    select l.id2 job, l.sid, to_char(last_date, 'DD-MON-YYYY:HH24.MI.SS') last_date, to_char(this_date, 'DD-MON-YYYY:HH24.MI.SS') this_date, l.inst_id instance from sys.job$ j, gv$lock l where l.type = 'JQ' and j.job (+) = l.id2 order by 5, 4;
Gather Statistics Job Status Requirements
Install and Upgrade
Yes
Ensure that you stop the Gather Statistics job that is running in the existing, certified Oracle Database. To do so, log in to the database as SYS and run the following commands:
For Oracle Database 10g (10.2.0.4) or higher:
execute dbms_scheduler.disable('GATHER_STATS_JOB',TRUE);
execute dbms_scheduler.stop_job('GATHER_STATS_JOB',TRUE);
For Oracle Database 11g (11.1.0.7) or higher:
execute dbms_auto_task_admin.disable('auto optimizer stats collection',null,null);
User Privilege Requirements
Upgrade
No
Ensure that SYSMAN and DBSNMP users have EXECUTE privileges to access the DBMS_RANDOM package in the existing, certified Oracle Database. To verify whether the users have EXECUTE privileges, run the following query. When you run this query for the SYSMAN user, the <user_account_name> must be SYSMAN, and when you run it for the DBSNMP user, the <user_account_name> must be DBSNMP.
SQL> CONNECT AS SYS;
SQL> SELECT grantee, grantor, owner, table_name
FROM DBA_TAB_PRIVS
WHERE table_name = 'DBMS_RANDOM'
AND privilege = 'EXECUTE'
AND grantee IN
SELECT DISTINCT granted_role
FROM DBA_ROLE_PRIVS
START WITH grantee = '<user_account_name>'
CONNECT BY PRIOR granted_role=grantee
UNION ALL
SELECT '<user_account_name>'
FROM dual
WHERE ROWNUM = 1
UNION ALL
SELECT 'PUBLIC'
FROM dual
WHERE ROWNUM = 1
If these users do not have EXECUTE privileges, then grant them the privileges by running the following command. When you run this command for granting the privileges for the SYSMAN user, the <user_account_name> must be SYSMAN, and when you run it for the DBSNMP user, the <user_account_name> must be DBSNMP.
SQL> GRANT EXECUTE ON DBMS_RANDOM TO <user_account_name>;
Environment Variable Setting Requirements
Install
No
Ensure that the environment variable ORACLE_HOME is set to the Oracle home of the OMS.
For example, in Cshell, set it in the following way:
setenv ORACLE_HOME /home/OraHomes/oms10g
For example, in bash shell, set it in the following way:
export ORACLE_HOME= /home/OraHomes/oms10g
SUDO Configuration Requirements
Install
No
Ensure that you configure SUDO in your environment. If you are unable to do so or if you have already upgraded any of the core components (OMS or Management Agent) without configuring SUDO, then follow the workaround described in My Oracle Support note 789363.1.
User-Defined Metric Script Definition Requirement
Upgrade
No
If you have any user-defined metric scripts in the Oracle home of a Management Agent that you are upgrading, then ensure that you manually copy all those scripts to another directory outside any Oracle home, and then update the user-defined metric definitions to reflect the new script location.
This is because, after the Management Agent is upgraded, the user-defined metric scripts are not automatically copied to the new Oracle home.
TEMP Tablespace Group requirement
Upgrade/Install
No
Ensure that there is no tablespace group name called TEMP already existing. If it does, then ensure that you rename it to a different name before installing or upgrade Enterprise Manager. You can always revert to the original name after you finish installing or upgrading.
To verify this, log in to the database as SYS user, and run the following query:
select count(*) group_name from DBA_TABLESPACE_GROUPS where UPPER(group_name)='TEMP'
The result of the above query should not be 0.
SYSMAN_OPSS account status requirement
Upgrade
No
Ensure that SYSMAN_OPSS account is not locked.
To verify this, log in to the database as SYS user and run the following query:
select account_status from dba_users where username='SYSMAN_OPSS'
SYSMAN_OPSS account status should be unlocked and unexpired
Global Name requirement
Upgrade(2-system upgrade only)
No
Ensure that Global names of old and new database are not same.
select count(1) from global_name where global_name=(select property_value from SYSMAN.pre_upgc_master_info where upper(property_name)=upper('oldReposGlobalName') and rownum=1) and exists (select 1 from ${EM_REPOS_USER}.pre_upgc_master_info where upper(property_name)=upper('upgrade_type') and upper(property_value) =upper('TWO_SYSTEM')) and exists (select 1 from SYSMAN.pre_upgc_master_info where upper(property_name)=upper('oldReposGlobalNames') and rownum=1 and upper(property_value)='TRUE')
The result of the above query should be 0, if not then change global-names in old repository to a temporary name as this repository/Enterprise Manager would cease to exist after upgrade; or change GLOBAL_NAME of new repository.
Database Edition Requirements
Install
No
Ensure that you are using Oracle Enterprise Database edition to install Enterprise Manager.
select count(1) from PRODUCT_COMPONENT_VERSION where PRODUCT like '%Oracle Database%' and instr(PRODUCT,'Enterprise Edition')>0
Existing database not to have previous Enterprise Manager's details in schema_version_registry table
Install
No
Ensure that existing database does not have previous Enterprise Manager's details in schema_version_registry table.
select count(1) from SCHEMA_VERSION_REGISTRY where comp_name in ('Authorization Policy Manager','Metadata Services','Oracle Platform Security Services')
If the result of the above query is not 0 then delete the entries from SCHEMA_VERSION_REGISTRY using the following query:
Delete from SCHEMA_VERSION_REGISTRY where comp_name in ('Authorization Policy Manager','Metadata Services','Oracle Platform Security Services');
commit;
Existing Database Not to Have any Enterprise Manager Repository schemas
Install
No
Ensure that your existing, certified Oracle Database does not have Enterprise Manager Repository schemas:
  1. Verify whether your database has Enterprise Manager Repository schemas.
    SELECT COUNT(*) FROM ALL_USERS WHERE USERNAME IN ('SYSMAN', 'SYSMAN_MDS', 'MGMT_VIEW', 'SYSMAN_BIP','SYSMAN_APM','BIP', 'SYSMAN_OPSS', 'SYSMAN_RO');
    If the result of this query is not 0, then the database has these schemas, so drop them.
    Note: For Microsoft Windows, invoke RepManager.bat. RepManager 11.1 supports -action dropall.
Existing database Not to have tablespaces of previous Enterprise Manager
Install
No
Ensure that your existing, certified Oracle Database does not have tablespaces of previous Enterprise Manager.
Following query can be used to verify if the database contains such table spaces:
select count(1) from dba_tablespaces where TABLESPACE_NAME in ('MGMT_ECM_DEPOT_TS','MGMT_TABLESPACE','MGMT_AD4J_TS')
If the result of the above query is not 0, then you can drop these table spaces otherwise new Enterprise Manager will re-use it.
Existing database not to have public synonym on the tables owned by any of the following Enterprise Manager Repository schemas: SYSMAN', SYSMAN_MDS,MGMT_VIEW,'SYSMAN_BIP,'SYSMAN_APM,BIP,SYSMAN_OPSS and SYSMAN_RO
Install
No
Ensure that your existing, certified Oracle Database does NOT have any public synonyms on the tables owned by any of the following schemas:
  1. Verify whether your database has the public synonyms owned by Enterprise Manager database schemas. To do so, log in to the database as SYS user and run the following query:
    select count(1) from dba_synonyms where table_owner in ('SYSMAN','SYSMAN_MDS','MGMT_VIEW','SYSMAN_BIP','SYSMAN_APM','BIP','SYSMAN_OPSS','SYSMAN_RO')
    If the result of this query is not 0, then the database has these public synonyms, so drop them.
  3. Drop the schema by running the following command from the Oracle home f the OMS
This section describes the following:
Setting Database Initialization Parameters for Advanced Installation
For an advanced installation, the database initialization parameters to be set for different deployment sizes (small, medium, large) are described in Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
Setting Database Initialization Parameters for Simple Installation
For a simple installation, the following are the database initialization parameters to be set:
Table A-6 Database Initialization Parameters Set for Simple Installation
Parameter Value
DB_BLOCK_SIZE_VALUE
8192
PROCESSES_PARAMETER_VALUE
300
PGA_AGGREGATE_TARGET_PARAMETER_VALUE
200000000
SESSION_CACHED_CURSORS_PARAM_MIN_VALUE
200
SESSION_CACHED_CURSORS_PARAM_MAX_VALUE
500
JOB_QUEUE_PROCESSES_PARAM_INS_VALUE
20
JOB_QUEUE_PROCESSES_PARAM_UPG_VALUE
0
OPEN_CURSORS_PARAM_MIN_VALUE
300
OPEN_CURSORS_PARAM_MAX_VALUE
400
SGA_TARGET_PARAM_VALUE
800000000
LOG_BUFFER_PARAM_VALUE
1000000
SHARED_POOL_SIZE_PARAM_VALUE
300000000
DB_CACHE_SIZE_PARAM_DEFAULT_VALUE
TRUE
LARGE_POOL_SIZE_PARAM_DEFAULT_VALUE
TRUE
JAVA_POOL_SIZE_PARAM_DEFAULT_VALUE
TRUE
STREAMS_POOL_SIZE_PARAM_DEFAULT_VALUE
TRUE
TIMED_STATISTICS_PARAM_DEFAULT_VALUE
TRUE
TIMED_STATISTICS_PARAM_VALUE
TRUE
STATISTICS_LEVEL_PARAM_DEFAULT_VALUE
TRUE
