Skip Headers
Oracle® Enterprise Manager Cloud Control Basic Installation Guide
12c Release 2 (12.1.0.2)
E22624-20
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
C Setting Up Proxy Configuration for Oracle Management Service
For the following reasons, set up the proxy server settings in Enterprise Manager Cloud Control so that it can use those details to access My Oracle Support:
To set up the proxy server settings, do the following:
  1. In Cloud Control, from the Setup menu, click Proxy Settings.
  2. On the Setup page, in the My Oracle Support and Proxy Connection tab, in the My Oracle Support Connection Setting section, select Manual proxy configuration and specify the proxy server host, port, realm, user name, and password.
    Note: Only HTTP and HTTPS protocols are supported. Also note that NTLM proxy is not currently supported.
  3. If you want to use the same proxy settings for communicating with the Management Agents, then go to Step (5). Otherwise, go to Step (4).
  4. In the Agent Connection Setting section, do one of the following:
    1. If you want to use the proxy settings given in My Oracle Support Connection Setting section, then retain the default section, that is, Use My Oracle Support connection settings.
    2. If you want to use proxy settings different from the ones specified in My Oracle Support Connection Setting section, then select Manual proxy configuration and specify the proxy server details.
      Note: Only HTTP and HTTPS protocols are supported. NTLM proxy is not currently supported.
  5. Click Apply.
The proxy server settings you specify are registered in the Management Repository. However, in case of multiple OMS environment, after you set up the proxy server settings for one OMS, restart other OMS instances to ensure that the proxy server settings registered for communicating with the Management Agents are propogated across all OMS instances.
